Aging in Place with EcoFlow DELTA Pro 3
As baby boomers continue to age, more adults than ever are wanting to age in place in the comfort and familiarity of their homes. Mobility issues and home support typically receive the most attention. However, one critical but often overlooked risk is the importance of backup power so that essential appliances like fridges, heaters, air conditioners, and devices stay running when the grid goes down. This enables the independence we all desire while ensuring safety, giving both older adults and their families peace of mind. Let’s take a closer look and see how the EcoFlow DELTA Pro 3 can support independent living.
The Hidden Risk: Power Outages for Aging Adults
The majority of aging adults want to stay in their homes as they age. However, some seniors, or their loved ones, worry about staying at home as maintenance and repairs become more difficult, or mobility issues present challenges for stairs or other features that are not senior-friendly. While those are serious considerations, they can be safely addressed.
Another hidden risk we don’t always consider is power outages. If the electricity goes out, it can be difficult to heat or cool the home, keep equipment running, monitor weather alerts, or call for help, and it can significantly increase the risk of injury. However, with an affordable and reliable backup system like the EcoFlow DELTA Pro 3 or EcoFlow DELTA 3 Ultra Plus, essential appliances can keep on running.
Why Backup Power Matters for Aging in Place
An important aspect of aging in place is self-sufficiency, because it means aging adults can be independent. And being self-sufficient, at any age, means having a home backup power system in place. This is essential for heating or cooling the home, keeping essential equipment and refrigerators running, and staying connected. It also significantly reduces the risk of injuries from falling in the dark.
Essential Devices Older Adults May Need During an Outage
While all homes benefit from having backup power, it becomes even more essential for senior citizens because they often require specialized equipment and need lights at night to help prevent injuries. Here are some essential devices that may be needed:
  • Equipment like electric wheelchairs that require recharging.
  • Refrigerator to keep food at food-safe temperatures and to keep medicines like insulin cold.
  • Lights help seniors move safely at night, reducing the risk of injury without using candles and the fire risks they create.
  • Rechargeable flashlights are essential for safely venturing into areas with limited lighting.
  • Radios, routers, computers, and other devices to stay connected and monitor emergency weather alerts.
  • Charged cell phones are essential for staying connected with loved ones and for calling for help.
  • In addition to powered items, everyone should also have a 3-day supply of non-perishable food and water, a first aid kit, and an emergency whistle to call for help.
Why EcoFlow DELTA Pro 3 Works Well for Aging-in-Place Homes
The EcoFlow DELTA Pro 3 is perfect for aging in place with the right balance of power, versatility, and affordability. With 4000W of output, it can run any essential 120/240V appliance. You can use it as a standalone backup, plugging in essential appliances manually when the grid goes down. You can also leave essential equipment plugged into it at all times so it always stays powered.
Alternatively, you can connect it to the household electrical and use the 20ms automatic switchover option so it automatically switches to backup. And if you need more power or experience extended power outages, its expandable capacity (up to 48kWh) means you can last anywhere from about 1 day to 1 week without grid power.
You can also extend your runtime using the EcoFlow app to prioritize essential appliances like refrigerators.
EcoFlow DELTA Pro 3
Preparing an Aging-in-Place Backup Power Plan
Here are some things to consider before buying a power station.
  1. Decide if you want manual or automatic backup.
  2. Decide if you want to run essential appliances or a whole-home generator.
  3. Determine your energy needs. For essential appliances, make a list of the appliances and their watts, then multiply the watts by the number of hours each appliance needs to run each day to get watt-hours. Add up your watt-hours, and that’s your absolute minimum capacity. For whole-home solutions, calculate your average daily kWh of usage from your electrical bill.
  4. Decide if you want to use solar panels to recharge the batteries and supplement the household electrical or if you want to recharge it with grid energy. (Hint: you can last through longer outages with solar).
  5. Purchase a quality indoor-safe, battery-operated backup power system and optional solar panels.
  6. If the system is for automatic backup, hire a licensed electrician to connect it to your electrical panel, ensuring it’s done safely and to code.
  7. Turn off the main power and test your system to ensure everything works as intended.
Is Battery Backup Safer Than a Generator for Seniors?
Battery backups are safer than gas because they produce zero emissions, so there’s no carbon monoxide poisoning or other health risks, and no fire risk from fuels, motors, or extension cords. Also, modern LFP batteries are not prone to thermal runaway like older lithium-ion models, making them even safer.
Reliable Backup Power Improves Independence for Aging Adults
Aging in place allows older adults to maintain independence and comfort in the familiarity of their own home. However, reliable backup power is a critical consideration to maintain safe indoor temperatures and run essential appliances like refrigerators and devices that cannot be without electricity. By planning ahead and using a reliable, indoor-safe backup power system like the EcoFlow DELTA Pro 3, families can reduce the risks associated with power outages for aging adults. This will allow them to continue living at home while enjoying the security and peace of mind that dependable energy provides.
Home Backup
