4kWh to 48kWh: Scaling Your Home Backup with EcoFlow DELTA Pro 3
If you’re feeling nervous about picking the wrong home energy solution, you’re not alone. There’s a lot of numbers, jargon, and brands to sort through. Compared to fixed-capacity systems, EcoFlow’s modular and scalable battery systems are the right choice for many homeowners. They’re affordable, portable, and scalable for anyone’s energy needs. Keep reading to learn how you can scale your home energy system with EcoFlow’s DELTA Pro Series portable power stations, from the entry-level 4kWh essential to whole-home 48kWh resilience.
EcoFlow DELTA Pro 3
Why Scalable Home Backup Matters More Than Ever
It’s no secret that America’s reliable power sources are becoming increasingly unreliable. The outdated grid system, high frequency of severe weather, and federal funding shuffle increases the chances of blackouts for those in the U.S.
In response, many people in the states want to take responsibility for their energy supply, but whole-home backup is an expensive initial investment.
Fortunately, you don’t have to put off building your energy resilience at home with scalable home backup systems. Modern lithium iron phosphate (LFP) battery systems have moved away from static, heavy blocks towards scalable, modular architectures.
You can get your foot in the door with an initial building block to back up the essentials, then expand at your own pace.
The plug-and-play installation option with EcoFlow allows you to chain together battery units to reach a desired energy capacity.
What Does 4kWh to 48kWh Actually Mean?
The kWh metric describes how much power is delivered in an hour. A 4kWh battery delivers 4kW in one hour, 2kW in two hours, or 1kW in four hours. The breakdown is the same for 48kWh battery systems.
With a 4kWh battery, you can power essential circuits. It’s considered a starter battery size for home backup. For whole-home backup, you’re going to need more power. With scalable batteries, you can chain multiple 4kWh batteries together to achieve 48kWh for whole-home power.
Before jumping up to 48kWh capacity, calculate how much power you need for the appliances that will be plugged into the system. You might find you can get by with fewer kWh.
Harness up to 2600W solar input via dual PV ports for flexible setups and faster charging with high conversion efficiency. Enjoy powerful AC output and 99% MPPT efficiency for optimal energy capture. Manage it all seamlessly through the app—monitor usage, set priorities, and stay powered effortlessly.
Starting Small: A 4kWh Entry-Level Backup Setup
While a 4kWh may not sound like much electricity, it’s more capable than you might think. The EcoFlow DELTA Pro 3 is a 4kWh entry-level, self-contained power station with enough juice for your refrigerator, laptop, Wi-Fi router, and cellphone over the course of a short, 12-18-hour power outage. Pair the power station with solar panels to quickly recharge it during the outage.
This single-unit station powers the essentials for apartment owners, tiny houses, or small cabins. That’s a great starting spot for anyone beginning their energy backup journey, even in a larger home.
EcoFlow DELTA Pro 3
Whole-Home Power: Scaling Up to 48kWh
If 4kWh is considered the essential unit for entry-level, then 48kWh is a total preparedness package.
To put this amount of power into perspective, the average American household uses about 10,566kWh annually. Divide that by 365 days for about 30kWh per day. That means a 48kWh backup system can cover more than a full day of typical household energy use.
With this amount of power, you can power refrigerators, lights, washing machines, dryers, and everyday electronics. For extended outages, integrated solar panels quickly recharge the backup power stations for a continued electricity supply over weeks.
Why EcoFlow’s Modular Approach Beats Fixed Backup Systems
Fixed systems have been the go-to in-home energy storage, and the one-and-done approach is easy.
But, EcoFlow’s modular energy storage approach is becoming more popular, and easier, for homeowners. Here’s why:
  • Scalability. Fixed systems come with a fixed capacity, and they’re usually sold in large increments. Meaning if the fixed unit is 20kWh, and you need 24kWh, you’ll need to buy two units for a total of 40kWh. EcoFlow modular batteries are more customizable. You can create a system that more closely aligns with your energy needs through small incremental, stackable batteries.
  • Affordability. Fixed systems are expensive because you have to purchase the entire unit at once. Traditionally, this high initial investment has kept home energy storage as a luxury household essential. The modular approach allows budget users to start small with a single unit, then add more units over time. Instead of saving up for one large purchase, many homeowners can begin building energy resilience far sooner compared to a fixed system approach.
  • Portability. If you go with the fixed system approach, it’s stuck at the house it was installed in. These systems are normally bolted onto the wall and are very difficult to transport to another location. EcoFlow’s modular battery units have a flexible design. They work as stationary units to power your home, but they can also go on road trips, camping weekends, move to a new house, or power a movie projector in the backyard for a party.
EcoFlow DELTA Pro Series
EcoFlow DELTA Pro is a portable home battery built for plug-and-play backup, delivering 3,600–7,200W AC output to run 99% of appliances. Expand capacity from 3.6kWh up to 25kWh with Smart Extra Batteries, recharge fast with up to 6,500W MultiCharge (as little as 2.7 hours via AC), and even top up at thousands of EV charging stations—powered by a long-lasting LFP battery designed to support up to 10 years of use.
How Do You Choose the Right Backup Size for Your Home?
The first step to choosing the right size battery system is to determine which appliances you want to back up during an outage. Calculate the total amount of running wattage required for all of your essentials. Then, determine how long you need to power them. Divide the total wattage by the required time for the size system you need.
Is 48kWh Enough To Power a House During an Outage?
A backup battery system with 48kWh of capacity is enough to power a house during an outage. The average American household uses 30kWh per day, so 48kWh of backup power will provide over one full day of power during an outage. You can make it last longer by only connecting essential appliances to the backup circuits.
Scalable Battery Systems Build Long-Term Home Energy Resilience
If you’ve been considering backup home energy, now is the time as power outages will only become more frequent. The energy grid system in the United States is aging, severe storms occur more frequently, and federal funding for addressing grid issues is unstable.
Scalable battery solutions are an accessible, beginner-friendly option. Start with an entry-level 4kWh power station for the essentials during an outage. Over time, increase your energy resilience by adding additional batteries to power your whole home. The EcoFlow DELTA Pro Series provides reliable, scalable battery units for your customized system.
Home Backup
