200 Amp Wire Size: Copper, Aluminum, and NEC Sizing Guide
- 200 Amp Service Wire Size: Quick Reference Chart
- What Size Wire for 200 Amp Service? Copper vs. Aluminum
- Can Battery Backup Work With a 200 Amp Electrical Service?
- NEC Requirements for 200 Amp Service Wire
- 200 Amp Wire Size for Long Runs and Voltage Drop
- Conduit Sizing and Wire Types for 200 Amp Service Wire
- Conclusion
- FAQs
Choosing the right 200-amp wire size matters. It can mean the difference between passing inspection or getting flagged immediately. A 200-amp service is standard in modern homes. The needed conductor size varies based on the material, installation, load calculation, and NEC rules. Conductors feeding the panel must meet certain requirements. This depends on whether they are copper or aluminum. It also varies based on whether they connect to the main service or a subpanel further along. Get it wrong, and you're looking at a failed inspection, a fire hazard, or both.
In this article, we'll talk about the 200-amp wire size requirements the way an electrician actually thinks about them. We will discuss how to pick the right conductor size. Also, we'll look at longer runs and voltage drops. Finally, we’ll cover the NEC requirements for 200-amp services and feeders.
So, before we go into the reasons behind every figure, here's the one stop answer to the 200-amp service wire size question. Start with this chart, then read below for the specifics on why each size applies.
Conductor Material | Insulation Type | Residential Main Service Drop (NEC 310.12) | Dedicated Feeder / Subpanel Size (NEC 310.16) | Minimum Conduit Size |
Copper | THHN/THWN-2, XHHW-2 | 2/0 AWG | 3/0 AWG | 1.5 in to 2 in PVC/EMT |
Aluminum | XHHW-2, USE-2/URD, SER | 4/0 AWG | 250 kcmil | 2 in to 2.5 in PVC/EMT |
These figures assume standard 75°C terminations and typical installation conditions. Longer runs, higher ambient temperatures, and shared conduit with other circuits can all affect conductor sizing, which is exactly what the sections below walk through.
When you're deciding on wire size for 200 amp service, the choice usually comes down to copper or aluminum. Both metals can be used for a qualifying 200-amp dwelling service, but they get there in different ways, and each comes with its own installation tradeoffs in cost, ease of pull, and ampacity.
2/0 AWG Copper Wire: Compact Conduit and High Conductivity
When panel space and conduit room are tight, copper is the material most electricians turn to. A 2/0 AWG copper conductor generally has a smaller outside diameter than a 4/0 AWG aluminum conductor, which can reduce conduit fill and take up less room in the panel gutter. That's a consideration when you're remodeling an older property where the service entrance conduit was never sized to anything greater.
Copper also terminates more easily and is more conductive, so a smaller copper conductor can provide the required ampacity for a qualifying 200-amp dwelling service without the bulk of a larger aluminum conductor. So lugs, connections, and panel gutters are not as packed, but the expense is the price. Aluminum is considerably cheaper per foot than copper, and this adds up fast on longer service runs or feeder runs.
4/0 AWG Aluminum Wire: A Common Choice for Residential Main Service
Aluminum is a common choice for new residential 200-amp services, mainly because it's lighter and considerably cheaper than copper at the same ampacity. Modern AA-8000 series aluminum alloy conductors are built specifically to resist the cold flow and oxidation issues that gave older aluminum wiring a bad reputation decades ago. That reliability is a big reason aluminum keeps winning the 200 amp wire size debate for new construction.
But working with aluminum requires tight attention to manufacturer specs and code regulations. Anti-oxidant compound should be used only when required or permitted by the conductor, terminal, or equipment manufacturer's instructions.
The terminations must have the appropriate temperature rating for the conductor and equipment, with 75°C ratings generally used for sizing where permitted by the applicable requirements. You will also need to size your conduit up to accommodate the larger 4/0 conductor over 2/0 copper and maintain proper conduit fill. Miss any of these steps, and you're asking for loose connections, heat buildup, and eventually a failed termination.
A 200A service rating sets the ceiling on what your utility can feed into your home. It has nothing to do with what a battery backup system has to put out. Battery output depends on the unit you choose and how you wire it, not your panel's rating. So a battery backup system can cover anywhere from a few key circuits to your whole house, depending on the equipment behind it.
Most homeowners fall into one of two camps. Some just want the essentials covered, things like the fridge, a few lighting circuits, maybe a well pump. Others want the whole house running as if nothing happened. EcoFlow has options built for both.
EcoFlow DELTA Pro for Essential 120V Circuit Backup
The EcoFlow DELTA Pro is a good choice for the first set of people. It has a base storage capacity of 3.6 kWh, but you can add more Smart Extra Batteries to extend it up to 25 kWh. It has a 3600W continuous AC output and can be boosted to 4500W with X-Boost. Depending on the starting and running power of the connected loads, it can support essential circuits such as refrigeration, lighting, selected outlets, and some pumps during an outage.
This kind of setup is built into a backup-load setup sized to what the EcoFlow DELTA Pro can realistically supply. You're not here to replace your 200A service on paper. You're selecting the most important circuits and putting redundancy around them.
EcoFlow DELTA Pro Ultra for Full 240V Whole-Home Backup
If you want to cover more of the house, the EcoFlow DELTA Pro Ultra is built for that. A single inverter puts out 7200 continuous watts, and EcoFlow's X-Fusion technology allows the system to continue supplying power while charging and discharging simultaneously. Add more inverters and that number climbs, up to 21,600 watts across three units.
The EcoFlow DELTA Pro Ultra fits into a backup-load setup that can cover most or all of a home's circuits, including bigger draws like a central air conditioner. The available output can cover a substantial portion of typical household loads, with the actual level of whole-home coverage depending on the home's calculated load and the number of EcoFlow DELTA Pro Ultra inverters installed.
The reason your 200 amp wire size can be smaller at the meter than it is at a subpanel comes down to which NEC table applies. Service entrance conductors and subpanel feeders are governed by different sections of the code, and mixing them up is one of the more common mistakes in a residential job.
NEC Section 310.12: 83% Sizing Allowance for Qualifying Dwelling Services and Feeders
NEC 310.12 permits reduced conductor sizing for qualifying dwelling services and feeders supplying the entire load of a dwelling. For a 200-amp service, 83% of the service rating is 166 amps, which allows 2/0 AWG copper or 4/0 AWG aluminum when the applicable conditions are met. At their 75°C ratings, both conductor sizes have sufficient ampacity to meet the 166-amp requirement.
NEC Section 310.16: Dedicated 200 Amp Subpanels and Feeders
The 83 percent allowance under 310.12 is limited to qualifying dwelling services and feeders that supply the entire load of a dwelling. When a feeder does not qualify for that allowance, you must use the applicable full-ampacity requirements, which is where NEC 310.16 comes in. For a dedicated 200-amp feeder or subpanel that does not qualify for the dwelling allowance, you generally need conductors with sufficient ampacity for the full 200 amps, such as 3/0 AWG copper or 250 kcmil aluminum at 75°C, subject to the applicable installation requirements. These are typical full-ampacity conductor sizes for a detached garage panel, workshop, or other downstream panel when the feeder does not qualify for the residential dwelling allowance.
Every 200 amp wire chart implies a pretty short run. For longer runs, voltage drop may become an important design consideration in addition to ampacity. The NEC generally recommends limiting voltage drop to 3% for a feeder or branch circuit and 5% for the feeder and branch-circuit combination. These are generally recommendations rather than blanket NEC requirements, so the actual conductor size should be determined from the calculated load, run length, installation conditions, and applicable local requirements.
The Common 3% Voltage-Drop Design Recommendation
The NEC generally recommends limiting voltage drop to 3 percent for a feeder or branch circuit and 5 percent for the feeder and branch-circuit combination. At 240 volts, a 3 percent voltage-drop target corresponds to approximately 7.2 volts. Longer runs may require larger conductors to manage voltage drop, even when the conductor already meets the applicable ampacity requirement. Use the actual calculated load and one-way run length rather than assuming that a standard 200-amp conductor will meet a target voltage drop. As run length increases, the wire's own resistance starts dropping the voltage to the point where all sorts of appliances, motors, and sensitive electronics can take a hit.
Example Voltage-Drop Calculations for Long Runs
Use this table as a general plan for longer runs. Always do the exact voltage drop calculation for your specific load before you decide on a lengthy feeder. Use the actual calculated load rather than assuming the full 200-amp rating.
One-Way Distance | Recommended Copper Size | Recommended Aluminum Size |
100 ft | 2/0 AWG | 4/0 AWG |
150 ft | 3/0 AWG | 250 kcmil |
200 ft | 4/0 AWG | 300 kcmil |
300 ft | 250 kcmil | 350 kcmil |
Detached Garages, Workshops, and ADUs: Long Feeder Considerations
Detached garages, barns, workshops, and ADUs are where 200 amp wire size calculations tend to fall apart. This is because the run from the main panel is often much longer than anyone accounts for during planning. While a feeder might appear adequate for a shorter run, voltage drop can become significant as the run gets longer, particularly when the feeder supplies sensitive equipment or high-draw loads such as an EV charging station.
For these disconnected applications, the EcoFlow DELTA Pro and EcoFlow DELTA Pro Ultra can serve as high-output power sources for selected loads. For an outbuilding that only needs backup power for selected loads, a portable power station can provide a localized alternative to powering those loads from the main panel. However, it is not a substitute for a properly sized permanent feeder when the building requires a conventional electrical service.
Your 200 amp wire size decision also determines how much conduit and what type of cable jacket you'll need, and both depend heavily on how the run is installed.
Wire Types: SER, SEU, THHN/THWN-2, and Mobile Home Feeder (MHF)
Choosing the correct service wire for 200 amp installations really comes down to matching the cable type to the environment it's installed in. USE-2 conductors are listed for direct burial where the specific listing and installation conditions permit. “URD” is a common industry term for underground residential distribution cable, but its actual listing and permitted use depend on the specific product. THHN/THWN-2 conductors are pulled through conduit, whether that conduit runs overhead, underground, or inside a wall.
SEU is a similar service entrance cable typically used for the meter-to-panel riser on the outside of the home, while SER is the jacketed version generally used for interior feeder and subpanel runs. Mobile home feeder (MHF) cable is a comparable jacketed option designed specifically for electrical installations in manufactured housing. Matching the wire type to the installation method isn't optional. Using the wrong jacket for a wet or buried location is one of the fastest ways to fail an inspection.
How to Calculate Conduit Size for 200A Conductors
You can't assume a blanket 2-inch or 2.5-inch conduit works for every 200A installation. According to NEC Chapter 9, Table 1, the sum of the cross-sectional areas of the conductors in a raceway shall not exceed 40% of the raceway's internal area when more than two conductors are installed.
Conduit sizing requires summing the cross-sectional area of the conductors in the raceway, including any equipment grounding conductor required for a feeder, then checking that sum against the 40% fill column for your specific raceway type in NEC Chapter 9, Table 4.
Worked Example, 200A Aluminum Service in Schedule 40 PVC
Suppose you are pulling an aluminum dwelling service entrance bundle consisting of
Two 4/0 AWG XHHW-2 conductors (ungrounded phases)
One 2/0 AWG XHHW-2 conductor (reduced neutral)
Find individual conductor areas (NEC Ch. 9, Table 5)
4/0 AWG XHHW-2 area = 0.3197in2
2/0 AWG XHHW-2 area =0.2190in2
Calculate total conductor fill area Total Area = (2 × 0.3197in2) +0.2190in2= 0.6394 + 0.2190 =0.8584in2
Compare against 40% usable area (NEC Ch. 9, Table 4 for Schedule 40 PVC)
2-inch Schedule 40 PVC 40% fill capacity = 1.316in2. Because 0.8584in2is under 1.316in2, a 2-inch Schedule 40 PVC conduit satisfies the 40% fill calculation for this conductor set.
Note on Schedule 80 PVC. If the run is subject to physical damage and requires thicker-walled Schedule 80 PVC, the 2-inch conduit's 40% capacity drops to 1.150in2, which still accommodates this bundle but leaves less margin for additional conductors if the installation requires them.
Always calculate using the actual conductor insulation type (THWN-2 vs XHHW-2 vs USE-2 have different outer diameters) and raceway wall thickness (EMT, Sch 40, Sch 80) rather than relying on guesswork.
200 amp wire size comes down to three questions covering material, destination, and distance. Is the conductor copper or aluminum, is it feeding the main service or a downstream subpanel, and how far does it have to travel? Get those three answers right and you have the starting point for applying NEC 310.12, 310.16, and the other requirements that may apply to the installation.
A properly sized 200-amp service is also essential for real household energy resilience. If you want to add backup power without a full panel overhaul, modular options like the EcoFlow DELTA Pro and EcoFlow DELTA Pro Ultra are worth considering, with integration depending on the home's existing electrical configuration and the required transfer and load-management equipment.
1. What size wire is needed for a 200 amp service?
A qualifying 200-amp dwelling service can typically use 2/0 AWG copper or 4/0 AWG aluminum at 75°C under the NEC's 83 percent sizing allowance. This is based on NEC's 83 percent residential diversity allowance under 310.12. This is a common answer to the 200 amp wire size question for qualifying single-family dwelling services. A dedicated feeder or subpanel that doesn't get that allowance needs the full 3/0 copper or 250 kcmil aluminum instead.
2. What size cable can carry 200 amps?
At a 75°C rating, 3/0 AWG copper or 250 kcmil aluminum has sufficient ampacity for a 200-amp feeder without relying on the residential sizing allowance under NEC 310.12. These are typical full-ampacity sizes for a 200-amp feeder when the applicable requirements call for 200-amp ampacity.
3. How to wire a 200 amp panel?
Wiring a 200 amp panel means running correctly sized service or feeder conductors from the meter or upstream panel, landing the service or feeder conductors correctly, bonding the neutral where required, and providing the appropriate grounding electrode and equipment grounding connections for the installation. This is main panel work that should be done, or at minimum inspected, by a licensed electrician, since mistakes here affect the safety of the entire home.
4. How many 20 amp breakers can I put in a 200 amp panel?
There's no single fixed number, since it depends on the panel's physical slot count and your total connected and continuous load, not just the main breaker rating. A panel's physical space and listed breaker configurations determine how many 20-amp breakers it can accommodate, while the actual load calculation determines whether the electrical system can safely support the connected circuits.
5. Can 2 AWG copper handle 200 amps?
No. 2 AWG copper is rated for 115 amps at 75°C, which is far short of what a 200 amp service or feeder requires, even with the 83 percent residential allowance. You'd need at minimum 2/0 copper for a qualifying residential main service, or 3/0 copper for a full-rated feeder.
