How to Convert Watt to BHP the Right Way
If you've landed here trying to convert a watt to bhp figure — for some reason, possibly because you've seen a number in the specification sheet for a generator or motor or even an engine listing. Fair enough. This guide provides you with just that: a working formula, a reference chart of common power ratings and worked examples of in and out conversions. But there's a catch worth flagging upfront — watts and brake horsepower measure power in different contexts, so a straight watts to bhp conversion isn't always the whole story. We'll also examine the rationale for having separate units for electrical and mechanical equipment, as well as the meaning behind a device's power rating when connected to an electrical circuit in your home, whether that's a generator, an appliance, or a home battery storage system. This is NOT a sales pitch. It's a reference piece; it's constructed to serve a purpose.
Understanding Watts and Brake Horsepower
What Does Watts Measure?
A watt is the SI unit of power — it measures the rate at which energy is transferred or converted, one joule per second, full stop. It's the standard unit for electrical power, which is why you'll see it on everything from a kettle (around 3000W) to a laptop charger (65W) to a household heat pump (several kilowatts). When someone asks about a watt to bhp conversion, they're usually starting from one of these electrical ratings and trying to compare it against something mechanical.
What Does Brake Horsepower (BHP) Measure?
BHP measures an engine's usable mechanical power output — specifically, the power measured at the crankshaft, before it's lost to the gearbox, drivetrain, or other mechanical linkages. It's called "brake" horsepower because historically it was measured using a brake mechanism that applied resistance to the engine's output shaft. BHP has stuck around as the go-to unit for engines and heavy mechanical equipment — cars, generators, compressors — rather than for electrical devices.
Why They Aren't Directly Interchangeable
The thing is, the watt-to-BHP conversion is not a one-size-fits-all number. Context matters. Do you have a theoretical power rating, or is it an actual measured output that has already taken into account losses? While converting a watt to bhp may appear straightforward, it isn't as simple as a unit conversion, since efficiency and mechanical losses aren't accounted for. The formula below will yield the mathematical answer, but do not assume that this reflects the equivalence in the "real world".
Converting Between Watts and BHP
The Basic Watt-to-BHP Conversion Formula
BHP = Watts ÷ 745.7 is the standard conversion
This constant, 745.7 watts per BHP, comes from the imperial horsepower definition established in the 18th century and still used across most engineering contexts today. If you are converting watt to bhp of a 5,000W motor:
5,000 ÷ 745.7 = 6.7 BHP
Straightforward — plug in the wattage, divide, done.
Watt-to-BHP Conversion Table for Common Power Ratings
Here's a quick-reference table for common power ratings, useful whether you're checking a watts to bhp converter result or doing the sum by hand:
Watts | BHP (approx.) |
500W | 0.67 BHP |
1,000W | 1.34 BHP |
1,500W | 2.01 BHP |
2,500W | 3.35 BHP |
3,000W | 4.02 BHP |
5,000W | 6.71 BHP |
7,500W | 10.06 BHP |
10,000W | 13.41 BHP |
Bookmark this if you're regularly converting bhp to watts or the other way round — it saves reaching for a calculator every time.
Converting BHP Back to Watts
Going the other direction — bhp to watt — the formula simply flips:
Watts = BHP × 745.7
So for a 10 BHP engine:
10 × 745.7 = 7,457 watts
This reverse calculation gets used a fair bit when someone's checking an engine spec against an electrical-equivalent rating — comparing a petrol generator's output against an electric alternative, for instance, or sizing an electrical system meant to replace mechanical drive. Knowing 1 bhp to watt as a fixed reference point (745.7W) makes that comparison quick.
Why Watts and BHP Are Used for Different Equipment
Electrical Power: Motors and Generators
Electrical equipment — motors, generators, household appliances — gets rated in watts because that's a direct measure of the electrical power going in or coming out. No conversion needed, no ambiguity. A 2,000W motor draws 2,000 joules per second from the supply. Simple, measurable, and it's why manufacturers stick with watts across the electrical side of nearly everything.
Mechanical Power: Engines
Engines, on the other hand, get rated in BHP largely for historical reasons tied to combustion engineering — but also because it's a genuinely useful measure of usable mechanical output at the crankshaft, before drivetrain losses eat into it. It's the figure that tells you what the engine can actually deliver mechanically, independent of how that power eventually gets transmitted to wheels, blades, or whatever the engine's driving.
Efficiency and Power Losses in Conversion
This is the part people miss when they do a quick watt to bhp sum and expect it to match a datasheet exactly. Converting electrical input power to mechanical output power — or vice versa — isn't a clean 1:1 exchange. Heat, friction, and drivetrain losses all take a cut. A 5,000W electrical input motor won't produce all 6.7 BHP of mechanical output; there will be losses due to heat in the windings and friction in bearings and gearing. That's why the manufacturer's spec and quick unit-conversion calculations can differ — there is a theoretical figure and an actual figure (which is a bit lower).
From Power Ratings to Real-World Electricity Use
How High-Wattage Appliances Affect Household Energy Consumption
Once you know a device's wattage — whether you got there via a watt to bhp comparison or just read it off the label — it directly affects how much that device adds to your household's electricity use. A 3,000W kettle running for five minutes uses a fraction of the energy a 3,000W electric heater uses running for three hours. High-wattage appliances, and particularly heating systems, are usually where household electricity bills get decided.
Managing When and How You Use High-Power Devices
Here's where it gets practical. Running several high-wattage devices simultaneously — an electric shower, a tumble dryer, an EV charger — compounds both the cost and the load on your electrical setup. Stack enough of them at once during peak tariff hours, and you'll notice it on the bill and possibly on the circuit itself.
Why Timing Matters for High-Demand Appliances
Shifting high-power usage to cheaper or lower-demand periods reduces cost and eases strain on your household's electrical setup at the same time. This is standard advice for anyone on a time-of-use tariff — run the dryer overnight, charge the car off-peak — but it only works if you have a way to actually manage that timing rather than just hoping appliances get used at convenient hours. That's where storing power for later use becomes genuinely useful.
Note: electricity tariffs, time-of-use pricing, and price caps change regularly and are outside our control. For current, accurate figures, always check the Ofgem official website.
Storing and Managing Power for High-Demand Devices
Giving High-Wattage Devices Power on Demand
Knowing a device's wattage is only half the job — the other half is making sure your household can actually supply that power when the device needs it, without tripping a circuit or paying peak rates. For households with no existing solar or storage setup, a home energy storage system offers a practical way in. For example, EcoFlow's STREAM 5000 provides up to 3000W of AC output alongside 5kWh of storage capacity, expandable for larger households, which covers most high-draw appliances without straining the supply. Its Plug & Play+ design and compact footprint mean it installs without the disruption of rewiring — useful if you'd rather not tear into walls just to add reserve power. It's a way of storing energy ahead of time so high-wattage devices have what they need, when they need it.
Adding Reserve Power to an Existing Energy Setup
If you've already got solar panels or another energy setup in place, the pain point shifts — it's less about starting from scratch and more about adding capacity for high-power devices without overhauling what's already there. The STREAM AC 5000, for example, is actually an AC coupling circuit that can be added to an existing circuit without having to remove it, providing additional power to households for heavy-duty appliances that could overload the system or cause circuit trips during peak demand. It can be used to provide increased storage space, and with smart energy management, it can be used without having to rebuild.
Watts and BHP measure fundamentally different kinds of power — one electrical, one mechanical — but the conversion factor of roughly 745.7 watts per BHP lets you compare them accurately when you need to. Whether you're working out a watt to bhp figure for a motor, checking bhp to watts for an engine spec, or just trying to understand what a device's rating actually means, the formula and table above should cover it.
Beyond the conversion itself, understanding power ratings helps you choose appropriately sized equipment for the job — an underpowered motor struggles, an oversized one wastes money. And it feeds into a bigger picture: knowing what your appliances actually draw, and thinking about when and how you power them, is the foundation of making genuinely informed decisions about household energy use. Ready to put your power calculations into practice? Explore Ecoflow STREAM series smart energy storage systems today to manage your household's heavy-duty electrical loads efficiently.
How do you convert watts to BHP?
Divide the wattage by 745.7. For example, a 3,000W motor works out to 3,000 ÷ 745.7 = 4.02 BHP. This is a typical formula that is used in most engineering references for calculating watt to bhp.
How do you convert BHP to watts?
Multiply the BHP figure by 745.7. So 8 BHP becomes 8 × 745.7 = 5,965.6 watts. This reverse calculation is the standard way to go from bhp to watt.
How many watts is 1 BHP?
1 bhp to watt works out to about 745.7 watts in the imperial system — that's the amount of mechanical power it takes to lift 33,000 pounds one foot in a minute. Metric horsepower is measured a bit differently, coming in at around 735.5 watts, but the 745.7-watt figure is still the standard most people use worldwide for converting mechanical power.
