How to Convert BTU to Watts the Right Way
You've spotted a BTU/h rating on an air conditioner or heater and you want a straight answer: what does that mean in watts? BTU to watts conversion is simpler than it looks once you have the right formula — but here's the catch. BTU/h and watts don't measure the same thing. One tells you how much heat an appliance can move, the other tells you how much electricity it draws to do it. So a straightforward btu to watts conversion figure isn't always the full story.
This guide walks through what each unit actually measures, how to convert between them using a btu to watts calculator or a quick formula, and why an appliance's efficiency rating changes the real electricity cost behind that number — a figure worth knowing if you're sizing a home battery storage setup to run one of these units. By the end, you'll be able to read an appliance's specification sheet properly — not just convert a number on a page.
Understanding BTU/h and Watts
What Does BTU/h Measure?
BTU/h — British Thermal Units per hour — is a measure of heating or cooling capacity. It tells you how much heat an air conditioner can remove from a room, or how much heat a heater can add, every hour. A 12,000 BTU/h air conditioner, for instance, can shift 12,000 British Thermal Units of heat out of your living room each hour it runs flat out. It's a capacity figure, not a power-draw figure — and that distinction matters more than most spec sheets let on.
What Does Watts Measure?
Watts measure electrical power consumption — the rate at which an appliance pulls electricity from the wall to actually run. This is the number your electricity meter cares about. Two appliances can offer the same BTU/h cooling capacity and still draw very different wattages, depending on how efficiently each one converts electricity into heating or cooling output.
Why Heating and Cooling Appliances Use Different Units
Manufacturers list BTU/h for capacity and watts for power draw side by side because shoppers genuinely need both. The BTU/h value will indicate your appliance's ability to heat and cool a room size. Other than that, Watts tells you the cost of running and if your circuit can withstand it. Looking only at the first or second figure does not provide a complete picture.
This is exactly why a plain btu to watts conversion figure only tells part of the story — it's a useful starting point for comparing appliance capacity on paper, but it isn't a substitute for reading both numbers on the spec sheet properly. Some listings even phrase the same conversion as a btu h to watts conversion, since BTU/h is often written simply as "BTU h" or "BTU hr" on appliance labels and international spec sheets — it's the same figure either way.
With the units sorted, let's get into the actual formula.
Converting BTU/h to Watts
The BTU-to-Watts Conversion Formula
The standard btu to watts conversion formula is:
Watts = BTU/h × 0.293071
That constant, 0.293071, comes from the fixed relationship between the British Thermal Unit and the joule (the SI unit of energy) — 1 BTU equals roughly 1,055.06 joules, and since 1 watt is 1 joule per second, dividing through gives you 0.293071 W per BTU/h.
Worked example: a 9,000 BTU/h air conditioner converts to roughly 9,000 × 0.293071 = 2,638 W. This is your first stop when you need to convert btu to watts for any appliance rating — and it's the same maths a convert btu to watts calculator runs behind the scenes, so doing it by hand once is enough to trust the shortcut afterwards.
BTU-to-Watts Conversion Table for Common Air Conditioner and Heater Ratings
Here's a quick reference table — bookmark this one if you're comparing appliances often. Use it instead of running a btu to watts converter every time:
BTU/h Rating
Watt Equivalent (approx.)
5,000 BTU/h
1,465 W
9,000 BTU/h
2,638 W
12,000 BTU/h
3,517 W
18,000 BTU/h
5,275 W
24,000 BTU/h
7,034 W
Treat this table as a starting point rather than gospel, though — as the next section explains, the watt figure here is a thermal equivalent, not necessarily what the appliance draws from the wall. If your appliance's rating sits between the figures above, you can always convert btu hr to watts yourself using the formula in the previous section rather than rounding to the nearest row.
Converting Watts Back to BTU/h
Sometimes you're working from the other direction — you know the wattage and want the BTU/h figure. The reverse watts to btu conversion formula is:
BTU/h = Watts ÷ 0.293071
So if you need to convert watts to btu, a 2,000 W heater works out to roughly 2,000 ÷ 0.293071 = 6,825 BTU/h. This kind of watt to btu calculation comes up most often when you're checking a heater's rated power draw against its stated heat output, or sizing a replacement unit against an old one's plate rating. Any watts to btu calculator you use should apply exactly this formula — there's no hidden complexity beyond the constant itself.
Why BTU Output Doesn't Equal Watts Consumed
Thermal Capacity vs. Electrical Power Consumption
Here's the part that trips people up. A 12,000 BTU/h appliance does not necessarily consume 3,517 W of electricity. That 3,517 W figure — the one you'd get from a btu to watts calculator — is the thermal-to-electrical equivalent, not the appliance's actual measured power draw. It tells you what 12,000 BTU/h of heat energy corresponds to in wattage terms, not how many watts the unit pulls from your socket to produce it.
This distinction matters because heat pumps, air conditioners, and even resistive heaters don't all convert electricity into heat at the same rate. A resistive electric heater is close to 100% efficient — nearly every watt in becomes a watt of heat out — but a heat pump or air conditioner can move considerably more heat energy than the electrical energy it consumes, because it's transferring heat rather than generating it from scratch.
How COP, EER and SEER Affect Real Electricity Use
This is where efficiency ratings come in. COP (Coefficient of Performance), EER (Energy Efficiency Ratio), and SEER (Seasonal Energy Efficiency Ratio) all describe how much BTU/h output an appliance delivers per watt of electricity it actually consumes.
  • COP compares heat output to electrical input, both in the same energy units — a COP of 3 means the unit delivers three units of heat for every one unit of electricity it uses.
  • EER measures BTU/h of cooling output per watt of electrical input at a fixed test condition.
  • SEER does something similar but averages performance across a full cooling season, giving a more realistic year-round efficiency figure.
A higher-efficiency appliance can deliver identical BTU/h output for meaningfully less electricity than a lower-rated one — which is exactly why the conversion table above only gets you halfway to knowing your actual running costs.
Why Two Appliances With the Same BTU Rating Can Use Different Amounts of Power
Put the last two points together and you get a genuinely useful insight: two air conditioners can both carry a 12,000 BTU/h rating and still land on very different electricity bills. The one with the higher EER or SEER rating draws fewer watts to hit the same cooling target. Capacity tells you what a unit can do; efficiency tells you what it costs to do it. Understanding both is the difference between guessing at running costs and actually planning for them — which brings us to the practical side of things.
Planning Household Electricity Use Around BTU Ratings
Estimating Running Costs for Heating and Cooling Appliances
To estimate what an appliance will actually cost to run, use its rated wattage — the genuine power draw figure, not the raw BTU/h-derived number — alongside your electricity tariff. Multiply the wattage by hours used, divide by 1,000 to get kWh, then multiply by your per-unit rate.
For example, a 2,638 W air conditioner (our 9,000 BTU/h figure from earlier) running for four hours a day uses roughly 10.5 kWh a day — multiply that by your unit rate to see what it's adding to your bill weekly or monthly. Doing this once for each major appliance in your home gives you a far more accurate picture than eyeballing BTU/h ratings alone.
Note: Rates for electricity can fluctuate quite regularly, and there are different suppliers for different areas – so any given pence-per-kWh figure is only a guideline and not an exact price. Always check Ofgem's official website for the current price cap and up-to-date unit rates before budgeting around a specific figure.
Checking Whether Your Home's Electrical Supply Can Support High-Power Appliances
Before installing a high-BTU/h air conditioner or heater, it's worth checking whether your circuit or supply can actually handle the load — particularly for larger units pulling several kilowatts. A dedicated circuit, correctly rated fusing, and a professional installation check matter more here than the BTU/h figure on the box. This becomes especially relevant for whole-home units or anything drawing close to 3,000 W or more on a single circuit.
If you're weighing up a few appliance options, it helps to run each one through a btu to watts calculator at the planning stage rather than after installation — that way you know upfront whether your existing wiring needs an upgrade, or whether an electrician needs to sign off on the job before the appliance arrives.
Managing Electricity Use When Heating or Cooling Demand Is High
High-BTU/h appliances can create sharp demand spikes, particularly if a heater or air conditioner kicks in at the same time as your kettle, oven, or washing machine. Managing when these appliances run — and what else is drawing power at that moment — matters just as much as the appliance's own efficiency rating. This is where a bit of flexibility in how your household stores and draws on electricity starts to earn its keep.
Storing and Managing Power for High Heating and Cooling Demand
Keeping High-Demand Appliances Running When You Need Them
An appliance's BTU/h and wattage figures only tell you what it needs — your household still has to be able to supply that power reliably, especially if several high-draw appliances run close together. For homes without any existing solar or storage setup, a home battery sized for genuinely high-power appliances can take some of that pressure off. For example, the EcoFlow STREAM 5000 offers up to 3000W of AC output and 5kWh of storage, expandable well beyond that as needs grow, so it's built to handle stove-level, dryer-level, or air-conditioner-level demand rather than just topping up smaller electronics. Its Plug & Play+ design and compact footprint mean it can go into a utility room, garage, or hallway without much disruption to install. Worth noting: it also supports solar charging, though no current home battery on the UK market — including this one — meets the formal regulatory definition of a "plug-in solar" system, so it's best understood as a flexible storage unit rather than a plug-in solar product in the strict sense.
EcoFlow STREAM 5000
5024Wh capacity supports all-night home power use, expandable to 90kWh Up to 3000W AC output, ready for high-demand appliances like stoves, dryers, or kettles 4000W solar input makes full use of your solar generation 3000W AC charging for fast recharge True Plug & Play+ setup — every part of the system, from smart meter to main unit to solar panels, connects easily Compact 45.9kg body with a built-in handle for easy moving Residential-grade safety: pressure-release and fire-resistant materials, no overheating even at high voltage 10,000-cycle lifespan — charge to 100% or discharge fully without affecting battery health Local Mode keeps the system running and communicating even if the network drops
Adding Reserve Capacity to an Existing Energy Setup
If your home already has solar panels or another storage system installed, starting over isn't usually the goal — you just want more headroom for demand spikes from heating or cooling equipment. That's the scenario the EcoFlow STREAM AC 5000 is built around. It uses AC coupling, so it can be retrofitted onto an existing solar or storage setup rather than replacing it, adding reserve capacity specifically for those moments when a high-BTU/h appliance strains what your current system can supply. Smart energy management and further expansion options mean it can scale alongside your household's electricity use rather than becoming a ceiling on it.
100% compatible with existing rooftop PV systems, home battery systems, and leading third-party meters 5024Wh capacity covers overnight home needs, expandable to 90kWh Up to 3000W AC output powers heavy household appliances 4000W solar input captures maximum solar energy from an existing setup AC coupling adds storage to your current solar setup — no rewiring needed to expand later Compact 45.1kg body, easy to fit into any indoor space 10,000 cycles for durable, long-term battery health Pair with Gateway for straightforward system expansion
Converting btu to watts comes down to one formula — multiply BTU/h by 0.293071 — but the number that formula spits out is only ever a thermal equivalent, not a guarantee of what an appliance actually draws from your wall. Watts measure the electricity going in; BTU/h measures the heat coming out. Efficiency ratings like COP, EER, and SEER are what actually connect the two in the real world, and they're the reason two appliances with identical BTU/h ratings can land you with very different bills.
With both numbers in hand, you should have a much better chance of comparing appliances effectively, estimating running costs and verifying if the quantity you want to install is compatible with your home's energy supply. That's the whole idea of learning this conversion in the first place, to get a number and not to understand what it means for your household.
Ready to plan your household's electricity use around high-demand heating and cooling appliances? Explore the Ecoflow STREAM series to see how home energy storage fits into the picture.
How do you convert BTU to watts?
Multiply the BTU/h rating by 0.293071. A 12,000 BTU/h appliance works out to roughly 3,517 W using this btu to watts conversion formula — though that's a thermal equivalent, not necessarily its actual power draw.
How do you convert watts to BTU?
Divide the wattage by 0.293071. A 1,000 W heater converts to roughly 3,412 BTU/h. This is a useful watts to btu conversion to help verify the watt rating of a heater versus the btu rating.
How many watts is 12,000 BTU?
Using the standard btu to watts converter formula, 12,000 BTU/h converts to approximately 3,517 W. That's the thermal-equivalent figure though — the appliance's actual electricity draw depends on
