Solar Panels for Boats UK: Marine Solar, Battery Charging and Portable Power
- Using Solar Power on a Boat
- Types of Solar Panels for Boats
- Marine Conditions That Affect Solar Performance
- Sizing a Solar System for Onboard Electricity Needs
- Choosing the Best Solar Panels for Boats UK
- Portable Power Stations for Boating and Solar Charging
- Safe and Practical Solar Setup on a Boat
- Conclusion
- FAQs
Extended trips at sea frequently mean limited shipboard power. Navigation equipment, phones, lighting, refrigeration and other necessary devices can slowly deplete a boat battery, especially without shore power. The power produced by solar panels for boats is especially useful for generating electricity while they are in the water and eliminates the need to rely on marine power or on-board charging.
Marine solar systems may be permanently mounted rigid panels, flexible arrays or portable systems which can be put around limited deck space. There are several factors that determine the most appropriate setup - boat size, space, exposure to sunlight, weather, and daily electrical consumption.
Careful planning is particularly critical for UK boat owners, as weather variations, shading from masts, and space constraints on decks may impact the performance of the solar cells. So, understanding how solar generation will integrate with the boat’s existing battery and electrical systems is the first step in choosing the right storage solutions before selecting panels or portable power equipment.
Solar generation can provide for various onboard electrical needs; however, the use of solar generation will be best if considered in conjunction with the size of the solar panels, battery storage and onboard daily electrical consumption. However, boat owners should think of solar panels as a finite source of electricity rather than a power source for unlimited use and plan accordingly.
Solar Electricity Away From Shore Power
The benefit of a solar panel for a boat would be the capacity to produce power whilst in motion, moored not in the marina or using time in more remote areas.
Solar panels can be used to charge during the day while onboard without having to install permanent shore power. On top of the fact that the actual generation will vary based on the size of the panel, orientation, cloud cover and shading, solar is generally more effective if it is used in conjunction with other power generation on board.
Charging Boat Batteries With Solar Panels
When connected to appropriate charging equipment, solar panels can charge appropriate onboard batteries. A solar charge controller controls the power from the panels and assists in regulating charging to the battery.
If the boat owner is not familiar with this part, they can take a look at how a solar charge controller works to control the output of the solar panels and the charging of the batteries. To operate safely, all of the following must match: Controller, Battery voltage, Panel specification.
Powering Navigation and Communication Equipment
Navigation systems, GPS devices, radios and communication equipment are important loads on many boats. While these devices might not use as much energy as larger appliances, they can also be used for extended periods of time and thus play a significant role in one's daily energy consumption.
During the day, these systems can be charged by a well-sized solar panel setup for boats in the UK. However, all navigation and communications systems should still be capable of retaining sufficient battery power and backup facilities, without relying solely on immediate solar production.
Running Lighting, Refrigeration and Small Appliances
Power needs for lighting, refrigeration, phone charging and smaller appliances can significantly increase power usage, especially when staying on board overnight or on longer trips.
Refrigeration will run at odd times during the day and night, and lights and personal devices will contribute to evening usage. Solar panels will produce energy during the day, but to power these loads after dark, batteries or portable storage will be required.
This is why successful marine solar planning should start with the understanding of daily consumption and then the various types of boat solar panels.
After learning about the fundamental function of a solar panel on a boat, the next step is selecting the type of solar panel that best fits the vessel. There are fixed, flexible, walk-on, and portable solar panels for boats, offering varying levels of performance based on deck space, mounting surface and the permanency of use.
Fixed Solar Panels for Permanent Marine Installations
Rigid solar panels for boat installations can be used in the generation of a stable, long term generation source if there is enough cabin-roof, arch or deck space. These can be used permanently if the structure is strong enough to securely hold the panel.
Fixed panels are best suited for locations away from shading from masts, sails and other equipment. After installation, they need very little relocation, so it is important to be careful in selecting the mounting location.
Flexible Solar Panels for Boats With Curved Surfaces
The flexible solar panels for boats can be used when a traditional rigid module is challenging to install. But they take up less vertical space and can be built on the lower profile of their cabin roofs or other appropriate surfaces.
But flexibility doesn't mean bending to the max or durability. Long-term performance can be influenced by heat, repeated flexing and the mounting method. Owners of boats who are considering the format may find this guide to flexible solar panels versus rigid panels helpful when it comes to considering flexibility and structural support.
Walk-On Solar Panels for Limited Deck Space
Solar panels for boats can be designed to walk on them when there is limited space available, and it might be necessary to place the panels in areas where people occasionally walk.
They can assist with maximising the use of limited space; however, the owner should be aware of the manufacturer's load and installation requirements. Not all flexible panels are intended to be walked on, so a product should only be used for this purpose if it is specifically rated for this purpose.
Portable Solar Panels for Temporary Setups
Portable panels are great for boat owners who don't want to go with a permanent installation. These can be used when the boat is anchored, facing the sun and stowed away when on the move.
This can be particularly beneficial in environments where there are frequent shade conditions in the fixed wall or ceiling mounting locations. The downside is that the portable panels need to be set up and stored and need to be secured when the wind blows.
Solar Panel Kits for Boats
Solar panel kits for boats are available to make planning the system easier, since they package compatible components like the boat's solar panels, cables and charging equipment.
Even with a kit, the voltage of the boat, available storage space, and electricity consumption should be considered. But instead of picking only on the advertised wattage, boat owners need to ensure that the complete system, including the electrical system, is marine-friendly and fits into the current system.
Once the type of panel has been selected, the next big factor is how saltwater, changing orientation, shading and UK marine weather conditions will impact solar performance.
Selecting the correct panel type is not the only setup. Solar panels for boats need to withstand movement, saltwater, varying directions and limited space for installation, all of which can impact output and longevity of the system in question.
Available Deck and Cabin-Roof Space
Generally, boats have a lot less space for uninterrupted mounting than a home or other structure. Hatches, vents, antennas or safety equipment may already be in cabins, arches, and deck areas.
That is why the best solar panels for boats UK are not always the biggest solar panel that you can purchase. Sometimes a smaller, unshaded panel is more useful than a larger panel surrounded by other apparatus.
Shading From Masts, Sails and Onboard Equipment
Solar panels can be shaded by masts, rigging, sails and antennas throughout the day. Even relatively small amounts of shading can have an effect on useful generation depending on the particular type of panel and how the system is configured.
When deciding on the placement of panels, one should therefore keep in mind the usual use of the boat and where shadows will regularly fall and not just pick the largest surface available.
Saltwater, Moisture and Weather Exposure
Moisture, salt and weather are all part and parcel of marine installations. Cables and mounting hardware, connectors, and panels should thus be appropriate to the environment and periodically checked for corrosion or physical damage.
The durability of the panels depends also on their quality and installation, which is also a long-term affair. When planning for the maintenance and replacement expectations of their solar panels, this overview of how long solar panels may be useful to boat owners.
Panel Positioning as the Boat Changes Direction
A fixed home array is the same orientation as a boat that can swing at anchor or turn as it proceeds through the water. This is because a solar panel for boats can be pointed into strong sunlight one moment and an unfavourable direction the next.
Portable panels are more flexible as they can be moved when moored, whilst permanently mounted panels rely more on the location to perform reasonably in the different orientations.
Secure Mounting in Wind and Rough Conditions
Solar panels for boats in the UK should be safe from wind, vibration and boat movement. The mounting hardware needs to be appropriate for the type of panel and structure of the boat, while not obstructing access ways or safety equipment.
Portable panels must also be securely positioned in order to prevent them from moving, falling or getting damaged in strong gusts. With this environmental understanding comes the next step: determining the amount of solar generation and battery capacity that is required to power onboard electricity consumption.
Again, the amount of sunlight received at the panels will depend on the marine conditions, and the system must also be designed to match the amount of electricity the boat actually uses. Properly sizing solar panels for boats involves considering the daily load, solar panel generation and battery capacity, rather than just looking at the wattage of the panels.
Estimating Daily Electricity Consumption
Make a list of the electrical equipment that is used on a typical day, such as navigation, lights, refrigeration, phones, pumps and entertainment equipment. Write down the power rating for these devices and the approximate number of hours they are usually in use.
This will help to have a clearer picture of the daily energy demand. If you are not familiar with the calculation, you can follow this guide on how to calculate kWh usage to understand how appliance power and run time translate to overall consumption for boat owners.
Solar Panel Output and Available Sunlight
The rating of a solar panel for boat use is what it will produce under certain test conditions and is not guaranteed to produce 24 hours a day.
Real-world production can be affected by cloud cover, panel temperatures, shading or orientation. However, as boats often shift in direction, a margin should be given, and it should not be assumed that panels will be on full production for every daylight hour.
Boat Battery Capacity and Required Runtime
Battery capacity is a way of increasing the amount of time that onboard equipment can run without solar generation. This is particularly crucial at night or on cloudy days and while the boat is anchored in the shade.
The battery should have sufficient energy in it to power critical loads without being deeply discharged repeatedly. Selecting the appropriate capacity will thus entail a compromise between the consumption requirements and the frequency of recharges that solar or shore power can provide.
Matching Solar Charging to Navigation and Appliance Loads
A solar panel system for boats should be able to produce sufficient power to offset a significant proportion of daily usage.
Discretionary loads should be turned off if they are not essential systems like navigation equipment and communications equipment. Then the refrigeration, lighting and smaller appliances can all be factored in to see if the planned panel capacity can truly support the daily use.
Planning for Longer Trips Away From Shore Power
The distance travelled needs to be more flexible due to weather and solar generation conditions changing from day to day. A system that is used comfortably on a sunny weekend may not have as much reserve during a few cloudy days.
For longer journeys, it makes sense to use sufficient battery storage, realistic solar power, and, if possible, an additional power source. This will make the onboard power system more resilient and set up the boat for the next step, which is to select the best solar panels for boats in the UK for the available space, construction and purpose.
After knowing the daily electrical demand and the solar generation that can be expected, it will be easier to select the appropriate panels. The best solar panels for boats in the UK will fit into the available space, be capable of withstanding marine conditions and be able to generate sufficient useful output to meet the boat's typical battery-charging needs.
Panel Size Versus Available Installation Space
The amount of wattage a panel will be able to handle should be kept in balance with the physical space available on the boat. A large rigid panel can be more productive with rated output but can be of no value if it obstructs hatches, impedes deck motion or spends a significant portion of the daylight hours in the shade of onboard equipment.
When selecting solar panels for boats, size the space that can be used on the cabin roof/deck and decide if it makes more sense to install multiple small panels or a single large one.
Fixed Versus Flexible Solar Panel Designs
Fixed panels can be used on boats that have a good permanent mounting surface, and flexible solar panels for boats are best for slightly curved roofs and other surfaces that may not have a suitable framed panel mounting surface.
The selection should take into account more than flexibility. The long-term performance can be influenced by ventilation, mounting, heat exposure, durability and access for maintenance.
Solar Panel for Boat Battery Charging
When designing a solar panel for a boat battery charging system, the capacity of the solar panel should also be taken into account in conjunction with battery capacity and the amount of battery usage per day. The aim is to replace enough of the electricity used during the day without exceeding the limits of the charge controller or battery system.
The rated panel wattage is an initial indication since generation may vary depending on sunlight and installation conditions. This calculation of solar panel output in watts gives further context for calculating realistic solar output.
Best Flexible Solar Panels for Smaller or Curved Areas
Flexible solar panels on boats are best suited to a surface that won't be bent too much and will stay in place in the marine environment. Low-profile designs may be beneficial for smaller boats with limited cabin-roof or deck space.
The importance of electrical compatibility, weather resistance and the manufacturer's mounting instructions outweighs the choice of just a thin and flexible panel.
Matching Solar Panel Choice to Boat Type and Usage
Energy priorities vary from boat to boat. A cruiser that is only used for day cruising may require only sufficient solar energy to keep the batteries charged and provide power to personal electronics. Still, a cruiser that can be used on overnight cruises might require energy to power refrigeration and lighting/navigation gear.
So, the best solar panel for charging a boat battery will hinge on the length of time the boat is away from shore power, the space available to mount a solar panel and the quantity of power consumed daily. If those requirements are beyond what a simple onboard battery can provide, the next practical consideration is portable power storage.
A portable power station can be used to store electricity for extra power on longer journeys where solar generation and onboard battery capacity are limited. People who use solar panels for boats should consider the right solar panel to make the most out of the capacity, output, portability and amount of solar charging available, instead of just ordering the biggest one.
EcoFlow DELTA 3 Plus for Everyday Onboard Power
EcoFlow DELTA 3 Plus, with a capacity of 1024Wh and an AC output rate of 1800W, is suitable for lighter boating requirements. It can power a phone, laptop, lighting, communication equipment and other small onboard equipment, and it's easier to move around than larger equipment. It can also handle up to 1,000W solar input via two 500W inputs, which is ideal for boaters who want to charge from portable solar panels for boats.
EcoFlow DELTA 3 Max Plus for Longer Trips and Multiple Devices
EcoFlow DELTA 3 Max Plus offers 2,048Wh capacity and 3,000W rated AC output, making it ideal for extended trips or powering multiple electrical appliances on board. This provides increased clearance for refrigeration, lighting, electronics and some higher-powered appliances.
It has a larger capacity and can be used for longer periods when away from shore power, but at 22.1kg it will be worth considering where it can safely be stored onboard.
EcoFlow DELTA Pro 3 Paired with a 400W Portable Solar Panel
For boats with higher onboard electricity demand, the EcoFlow DELTA Pro 3 provides 4,096Wh of battery capacity and up to 4,000W AC output, giving it considerably more stored energy and appliance-running capability than smaller portable power stations. This makes it better suited to longer stays aboard, multiple devices and higher-demand equipment where a larger energy reserve is useful. Pairing it with the separate 400W Portable Solar Panel provides one practical solar-charging option for boating and off-grid use.
This configuration is better suited for longer off-grid trips, where volume is more critical than size. At 51.5kg, however, the power station is relatively heavy, so it should be positioned securely in a suitable dry onboard location rather than treated as lightweight deck equipment.
Matching Portable Power Capacity to Onboard Loads
Prior to selecting a power station, determine what appliances should be powered at the same time and how long. Electronics and lighting can easily be served by a smaller system; Refrigeration and more powerful appliances add to the capacity and output needs.
Combining Solar Charging With Shore-Power Access
Mobile power isn't necessarily dependent on a single charging source. When conditions are favourable, a unit may be recharged from compatible solar panels on the boat, and when marina electricity is available, it may be recharged from shore power.
When both are used, boaters have more flexibility to use during longer trips, but equipment should be kept dry, in place, and operated according to the charging and environmental directions. Properly making the entire solar and portable-power system marine-safe is the next priority, however.
Moisture, movement, and confined spaces are a reality in marine electrical equipment, and that's why safety is crucial when implementing solar panels for boats. A well-planned setup will include connection protection, cable organisation, and proper ventilation around batteries and power equipment.
Protecting Electrical Equipment From Water and Corrosion
The solar panel for a boat could be subject to salty air, rain and spray, so it is very important to have protected connections and weather-resistant equipment. Electrical components such as connectors and controllers should be maintained at appropriate locations, and periodically inspected for corrosion, damaged insulation or moisture infiltration.
Portable power stations should also be stored in a dry, safe place, and not on an open deck.
Managing Cables Around Deck and Cabin Areas
Cables for solar panels for boats UK systems should be kept out of walkways, sharp edges and moving equipment. Loose wiring can result in a trip hazard and can be repeatedly abraded as the boat moves.
To keep installation tidy and reliable, suitable cable protection, fixing points and connectors are used.
Maintaining Ventilation Around Batteries and Power Equipment
There should be sufficient space around battery and power equipment to allow for heat dissipation and ventilation. This is especially critical in tight spaces such as cabinets or storage areas, where heat can build up.
Equipment should be installed and operated in compliance with the manufacturer's environmental and clearance requirements, whether a fixed battery system or a portable power station featuring solar panels for boats.
Checking Solar Connections Before Longer Journeys
Prior to a long trip, check the panel mounts, connectors, cables and charging equipment for wear or looseness. Portable panels should also be inspected for damage before being put in place.
Checking the solar panels for the boat battery charging setup can easily be done and can assist in checking for any problems before shore power is harder to come by. Carrying out good maintenance not only helps to ensure safe operation but also more reliable electricity generation on longer journeys.
Selecting the appropriate solar panels for a boat involves considering factors such as the amount of electricity needed, the size of the boat's batteries, and the type of boat it will be used on. There are a variety of panel types – fixed, flex, walk-on and portable panels to suit different marine applications, and realistic planning for shading, weather and charging time helps to avoid undersized panels.
On longer voyages off shore power, it is possible to use solar generation along with appropriate energy storage systems to offer additional flexibility. DELTA 3 Max Plus is a convenient solution for those who want to bring more onboard refrigeration, lighting, navigation and other equipment. In either case, proper installation, electrical connections, and regular inspections are crucial for ensuring reliable and safe boat power.
Can Solar Panels Charge a Boat Battery While Sailing?
Yes, solar panels for boats can continue to produce electricity while the boat is in operation, as long as the panels are properly exposed to sunlight and linked to the charging system with appropriate charging equipment. As the vessel may change direction or experience shading from masts, sails and other structures on board, the battery charging rates may vary during the voyage.
Do Flexible Solar Panels Last as Long as Rigid Panels on Boats?
Flexible Solar panels for boats have a service life that depends on product quality, installation technique, heat exposure and marine conditions. Flexible panels can be applied to curved surfaces or in limited areas; however, durability may be impacted by frequent flexing and inadequate ventilation. Where appropriate permanent mounting space is available, rigid panels may provide increased protection for the structure.
Can Solar Panels Run a Boat Fridge Overnight?
It is not possible to use solar electricity after dark, as a solar panel for a boat only produces electricity when the sun is in the sky. But solar energy can be generated during the day and used to power an appropriate battery or portable power station that can provide refrigeration at night. The duration of operation is dependent on fridge usage, storage size and other loads.
How Much Solar Power Is Needed for a Weekend Boat Trip?
The number of solar panels for a boat in the UK varies based on the electricity consumption of a boat and the amount of sunlight available. Lighting, refrigeration, navigation equipment, phones, and other electronics should be considered for a weekend setup to compare lighting and other load requirements to the panel generation and usable battery capacity instead of simply selecting a panel wattage.
Can a Portable Power Station Replace a Boat’s Permanent Electrical System?
Usually not; a portable power station can be a helpful source of additional power for certain electronics and appliances, but should not be a substitute for a well-planned permanent marine electrical system. Solar panels for boat battery charging and portable storage can be used in conjunction with other fixed equipment to give extra flexibility without compromising the correct installation of the equipment for longer journeys.
