Solar Panels in Series or Parallel: Which Setup Is Better for Your Home?
- Series vs Parallel Solar Panels: The Main Difference
- How Series and Parallel Wiring Affect Solar Performance
- MPPT and Inverter Limits That Influence the Choice
- Choosing Series or Parallel for Different Solar Setups
- Series or Parallel Solar Panels: Key Advantages and Limitations
- Safety and Compatibility Checks Before Connecting Solar Panels
- Solar Generation, Self-Consumption and Battery Storage
- Conclusion
- FAQs
When designing a solar installation for a home, choosing solar panels in series or parallel connections isn't purely a matter of wiring the panels together. The configuration affects array voltage and current, cable requirements, and whether the system will stay within the input limits of an inverter or MPPT controller.
Typically, series wiring is used because it boosts the voltage but does not increase the current to any great extent. In contrast, parallel wiring boosts the current with a voltage closer to that of an individual panel. Neither is necessarily the best solution for all homes in the UK. The right option depends on the roof layout, shading, number of panels, and specifications of the inverter.
By understanding these differences prior to installation, it will be easier to design a solar array that will operate efficiently and safely and allow for future energy storage solutions planning.
The fundamental difference between series and parallel circuits is the way voltage and current mix. Before evaluating various solar configurations, homeowners who are not well-versed in these electrical terms can first learn what volts, amps, and watts are.
Voltage Changes With Solar Panels in Series
In series connections, the negative terminal of a solar panel is connected to the positive terminal of the next one. The voltage of each panel is summed up, and the current is virtually the same as the current generated by one panel.
So when several panels that have the same operating voltage are connected in series, they can generate a very high string voltage. This can be handy if the inverter needs a specific low voltage to turn on.
But the total string voltage must not exceed the inverter's allowed voltage range, even in cooler weather, when panel voltage might rise.
Current Changes With Solar Panels in Parallel
When solar panels are in parallel, all the positive terminals are joined to each other and negative terminals are joined to each other. The voltage is the same as one panel, and the current of each parallel branch is added.
Increased current may affect cable size, connectors, and overcurrent protection. When multiple strings or panels are paralleled, this is especially critical in electrical design.
For systems where it is desirable to keep the array voltage low, however, parallel connections may be advantageous.
Total Solar Power in Series and Parallel Configurations
Under ideal conditions, switching between solar panels in parallel and series does not increase the amount of wattage available on the solar panels. However, the overall power is still largely affected by the total rated power of the panels.
The difference is in how that electrical power is delivered. If they are in series, then the voltage increases and the current decreases; if they are parallel, then the voltage decreases and the current increases. This can then be different in real-world scenarios due to shading effects, cable losses, inverter effects, and mismatch between the panels.
Series-Parallel Connections for Larger Arrays
Either technique can be utilized in larger residential arrays. Panels can be connected in series first, and then two or more series of similar panels are connected in parallel.
This series-parallel solar panel configuration of solar cells will enable the designer to obtain adequate voltage and current produced by the array that is not out of the inverter range. The detailed configuration should be determined not only by the number of panels, but also by the specifications of the panels, the input voltage and current range of the MPPT, and the electrical design of the entire solar system.
After a grasp of voltage and current behavior, the next question is how each configuration behaves under real household conditions. Beyond the rated wattage of the solar panels, other factors such as panel shading, panel mismatch, cable resistance, and roof orientation can affect how solar panels in series and parallel respond.
Partial Shading Across a Solar Array
Shading can cause a significant impact on solar output, especially if the solar panels are in series. The current flows through the entire string, and a heavily shaded panel can limit the current that other panels can provide to the string (unless bypass diodes are used to limit the effect).
Solar panels in parallel ensure that separate branches can be operated more independently. Thus, shading one branch can have less impact on the production of the other branches. However, the actual performance will vary according to the specifics of the panel, inverter technology, and the set-up of the array.
Panel Mismatch and Uneven Solar Output
Panels are not always under the same conditions. Variations in orientation, aging, manufacturing properties, dirt, or shading can result in unequal outputs.
A series string has the effect that the current is impacted by the poor-performing panel since each module carries the same current. For parallel arrangements, voltage compatibility is even more significant since the parallel branches need to be at a similar voltage.
Therefore, it is not advisable to mix panels with vastly different electrical parameters without consulting the system compatibility.
Cable Current and Electrical Losses
In general, a parallel circuit can carry more current than a series circuit of the same dimensions. If the size of the cable and the cable length are not selected appropriately, there is the risk of higher resistive losses with higher current.
Depending on the series configuration, the current can be reduced for the same power level, which can lead to less cable loss for longer cable runs. But as the voltage increases, there are other design and safety concerns.
A voltage loss calculator can also be used by the homeowner to do a comparison of cable routes and understand the impact that conductor length, current, and cable resistance can have on electrical performance.
Performance Across Different Roof Orientations
Panels can be seen on more than just one face of a UK home's roof. Peak sun exposure will occur at different times of the day on east, west, and south-facing sections.
Including panels of significantly different orientations in the same series string may lessen the ability of that string to function. Multiple strings that are connected to different MPPT inputs can at times offer greater flexibility, as each roof section can be operated according to its own set of conditions.
Series vs Parallel Solar Panels in Real-World Conditions
Hence, there isn't a universal answer to the series or parallel configuration for solar panels. Series wiring can be efficient if the panels are exposed to the same amount of sunlight and the inverter can operate at a higher string voltage. If shading or varying circumstances of the panels are taken into account, parallel wiring can provide more independence.
This optimum ratio should be as per the roof design, sun exposure, cable size, and inverter capacity. Those factors take on greater significance when the next step in the design process is to match up the array with an MPPT controller and inverter.
The roof condition is just one of the factors. The inverter and the maximum power point tracking system from the inverter ultimately define the range of inverter voltage and current in which the solar array should operate. The wiring design should then be based on the electrical limits of the equipment that will be powered from the solar input when series or parallel connections are used in conjunction with MPPT.
MPPT Operating Voltage Range
An MPPT finds the point on the solar array's operating characteristics that gives the maximum amount of useful power. Each MPPT is given a voltage range, and when the modules are connected in series, the resulting voltage should be within the range of each MPPT when the system is operating normally.
The number of panels in series could either result in an insufficient voltage to operate properly or exceed the allowable number of panels per array. For those who wish to learn more about the technology, they can check out the difference between MPPT and PWM charge controllers.
Maximum Solar Input Current
Parallel wiring adds current, so the maximum input current for the inverter is important. Adding more parallel strings may increase the total current to be too high for the MPPT or inverter.
Therefore, simply building a parallel or series circuit with solar panels, depending on the number of panels available, is incorrect. The total electrical properties of the finished array should not exceed the manufacturer's input limits.
Multiple MPPT Inputs for Split Roof Arrays
There are inverters with more than one MPPT input. This may be valuable for properties in the UK where solar panels need to be installed on multiple sections of the roof that face in different directions or are in different areas that are shaded or not.
For instance, when a string is installed on the east roof and the west roof, it is not required to install the strings together on a single MPPT input. Now each tracker can react to the sun available on its part of the array.
Inverter Start-Up Voltage and Solar String Design
The inverter typically requires some minimum voltage from the solar array in order to start working. Here, series wiring can be helpful since the voltages on the panels are additive.
But designers should take into account not only minimum start-up voltage, but also the maximum allowable voltage. Do not assume that a string which performs well in warm weather will have the same open-circuit voltage in cooler weather, so care must be taken when determining the number of panels that can be connected in series.
Manufacturer Limits and Equipment Compatibility
Before installation, the panel voltage, current, and power rating should always be compared to the inverter/MPPT specifications. The decision on whether to use solar panels in series or in parallel can be determined by factors such as maximum open-circuit voltage, operating voltage range, short-circuit current, and allowed input power.
General wiring rules must be supplemented with manufacturer requirements since the limits of equipment applicable to various systems vary. These checks are also crucial steps in ensuring the array's safe and reliable operation in grid-connected residential installations.
If the inverter limits are understood, it is quite easy to compare the various wiring arrangements and determine which one is most practical for a particular roof and solar installation in a household.
Once the inverter and MPPT limits are set, the next step is to put that into practice on the property. There is no general rule as to whether it is better to arrange solar panels in series or parallel, just as there is no general rule for the number of panels to be used: it depends on the quantity of solar panels, on the shading, on the orientation of the roof and on the electrical characteristics of the installation.
Two Solar Panels on a Small Unshaded Roof
If the two solar panels in series or parallel are facing each other and receiving the same amount of sunlight, and the voltage they can produce in series is within the operating range of the inverter, then using series wiring can be feasible.
Alternatively, parallel wiring may be employed for systems requiring lower voltage, as long as current is not over the equipment and/or cable capacity. The method used must in the end be determined by the panel and inverter specifications.
Solar Arrays With Partial or Intermittent Shading
If there is recurring shade caused by chimneys, trees, or adjacent buildings, wiring design needs to be studied more closely. A shaded panel in a series string can impact the current flowing through that string, and parallel strings can make the groups more independent.
Shading performance should also be considered in conjunction with the equipment used and can be affected by modern inverter and optimizer technology and how they are configured.
Panels Installed Across Different Roof Sections
If the roof surfaces of panels are divided between east-, west-, or different angled surfaces, the solar condition to which each panel is exposed can vary during the day. In fact, separate strings with individual MPPT inputs may be the better way to deal with these differences, rather than all of the panels being grouped into a single string.
Even the roof's design can affect mounting and array configuration. When planning the placement of solar panels and electrical design, it is useful for homes with alternative roof designs to know the practical aspects of solar panels on a flat roof.
Larger Residential Solar Arrays
Several series strings can be used in parallel in larger home systems. This series-parallel method can be used to obtain the desired voltage, yet spread the array out over several strings.
It can therefore be both, when homeowners ask whether solar panels connected in series or parallel. A professionally designed residential system can incorporate both techniques based on the layout of the roof, the panels themselves, and the capacity of the inverter. The main thing is that every string and parallel connection is within the limits of the system in terms of voltage, current, and safety.
There are a number of wiring configurations that address design issues. Instead of determining if a particular scenario is best suited for series or parallel, it is more beneficial to compare the pros and cons of each setup in terms of voltage, current, shading and equipment limitations.
Benefits and Limitations of Series Wiring
In series wiring, the voltage of the array is increased, and the current remains relatively low. This can minimize cable losses and enable the array to reach the required operating voltage of the inverter.
The fundamental disadvantage is that panels in the same string affect each other. If one of the panels in the string has a good amount of shading or is not working properly, the current that passes through the string will be lowered. The total voltage should also not exceed the voltage input limit of the inverter.
Benefits and Limitations of Parallel Wiring
When the solar panels are connected in parallel, the voltage of the array is kept at a relatively low level, but the current is increased as the number of branches increases. When one part of the tree is not exposed to as much light, the separate parts of the tree may react in a more independent manner.
However, the larger the current, the larger the cable size and the protection equipment may need to be. Additionally, the current to be fed into the inverter/MPPT from all the parallel branches should be acceptable.
Situations Where Series-Parallel Wiring Makes Sense
Series-parallel wiring is a combination of panels connected in series strings, then in parallel. It may be helpful for larger arrays in which a long series string or full parallel string is not appropriate for the voltage and current requirements of the system.
Generally, strings should be of similar electrical properties so that the whole string array can be operated in a predictable manner.
Choosing Based on System Conditions Rather Than a Universal Best Option
Finally, roof conditions, panel specifications, inverter limits, shading, and cable routes should be taken into account as the basis for deciding whether to connect the solar panels in series or in parallel.
Factor | Series Wiring | Parallel Wiring |
Voltage | Increases as panels are added | Remains close to individual panel voltage |
Current | Remains relatively similar | Increases with additional branches |
Shading | Can affect the wider string | Branches may operate more independently |
Cable requirements | Lower current may simplify long runs | Higher current may require larger cables |
MPPT compatibility | Useful for reaching operating voltage | Must remain within input-current limits |
Typical use | Similar panels under similar sunlight | Installations needing greater branch independence |
The right choice could even be a combination of both in many UK homes. The key element is not to take the choice of one of these methods as a default, but to design the array for the real electrical and environmental situation of the property.
After determining the desired wiring configuration, the final test should be on electrical compatibility and installation safety. When solar panels are in series or parallel, all components should be within their specified voltage and current limits.
Matching Panel Electrical Specifications
The electrical characteristics of panels in a string or parallel group should be compatible. If there is a significant difference in operating voltage/current, it may result in a decrease in performance and unpredictable system behavior.
When installing solar panels in series or parallel, installers should check the panel voltage, current, power, and manufacturers' instructions, and not just the nominal wattage.
Connector, Cable and Current Ratings
Cables and connectors should be appropriate for the voltage, current, and environment of the solar installation. Branches in parallel are significant, as more current is added together.
Proper cable sizing, proper connectors, and proper protection minimize overheating, voltage drop, and connector failure.
Staying Within Inverter and MPPT Input Limits
It is important for the combined array not to exceed the inverter's voltage, current, and power limits. Series strings must be carefully designed to account for voltage, and parallel strings require special consideration for input current.
Panel ratings should not be used alone, and these limits should be determined under expected operating conditions
Professional Design for Grid-Connected Home Solar Systems
Installing solar panels isn't the only part of a grid-connected residential solar installation. The array wiring should be a safe connection to the inverter, isolation equipment, and household electrical system.
When homeowners are contemplating changes to electrical equipment in their home, they can see the overall requirements of an electrical safety check.
Professional solar design and installation can ensure that PV configuration, protection equipment, and inverter settings are able to operate in harmony for permanent, grid-connected solar installations. With these basics in mind, the next step is to identify how the electric power produced by the array can be utilized or stored for future use.
After wiring the array safely and matching it to the inverter, the next question is: What do you do with the electricity that the array generates? The key to installation is to ensure generation, consumption, and storage are all aligned around the daily electricity use of the home, whether installed in series or parallel.
Using Solar Electricity as It Is Generated
When solar panels generate electricity, solar electricity can be used to power household loads. Solar energy can thus be used directly for appliances operating during the day before any additional electricity is called from the grid.
The way the wiring is configured affects the manner in which the array supplies power to the inverter, but the fundamental path that energy takes to the house remains the same. Readers wishing to learn more about this broader system can find out how solar panels can be integrated with home electricity systems.
Managing Surplus Solar Production
Solar power isn't always in sync with home consumption. There are moments when panels can produce excess power for the home during bright moments.
Surplus electricity may be exported (depending on system configuration) without storage. With battery storage, another alternative is to add capacity to the battery, which then enables some of that additional generation to be stored and utilized later in the day, when solar generation is lower, such as in the evening.
EcoFlow STREAM 5000 for New Solar and Storage Planning
For those who are in the process of designing a home energy system, EcoFlow STREAM 5000 can be integrated into a larger system that includes solar generation and battery storage.
The battery does not affect whether the solar panels are wired in series or parallel. Still, it functions further along the energy path, stores electricity available from the solar system, and converts it for use in the home.
This can assist new solar consumers in designing their generation and storage in a way that aligns with their usual daily electricity consumption.
EcoFlow STREAM AC 5000 for Existing Solar Systems
Homes with existing solar installations may want to consider EcoFlow STREAM AC 5000 when installing storage but are not looking to replace an existing solar installation that is otherwise suitable.
The purpose of this is different, but here the existing array configuration is still an important technical consideration, since more surplus solar electricity will be stored for later household use.
Matching Solar Generation, Storage and Household Demand
Battery storage should be based on realistic generation and consumption and not on panel wiring. The size of the solar array is not necessarily a clue to the size of the battery, nor is the change between solar panels in parallel and solar panels in series necessarily a clue to the size of the battery.
All of these factors: daily electricity use, typical solar surplus, evening demand, and available installation space, should be taken into account. This helps to balance the system to ensure the panel configuration allows for efficient generation, and the battery storage will allow for better utilization of the electricity generated.
The decision of whether to use solar panels in series or parallel depends on the interplay between voltage, current, shading, roof orientation, and inverter constraints in the overall system. Series wiring can be suitable for arrays where high voltage and low current are desired. In contrast, parallel wiring may be more appropriate for an array where different sections are subject to different conditions. In many residential applications, both methods may be necessary to give the most feasible design.
After making an array configuration, the next step is the effective utilization of the generated electricity. For those households choosing solar and storage as a combined solution, STREAM 5000 can enable a more harmonized home energy system, storing excess solar power for use later on. The entire system should still be based on the domestic needs of the home, solar electricity generation, electrical wiring, and professional installation.
Does Series or Parallel Wiring Change the Total Wattage of Solar Panels?
Under ideal conditions, the rated wattage of the solar panels in series or parallel is not affected. The difference is how the voltage and current flow through the array. In series, the voltage is increased, and in parallel, the current is increased. There can also be variations in actual energy production due to shading, cable losses, inverter efficiency, and panel mismatch.
Can Panels With Different Power Ratings Be Used in the Same Array?
Panels of varying wattages sometimes may be used in conjunction, but compatibility should be carefully taken into consideration before connecting solar panels in series or parallel. The varying voltage and current can reduce the output of the stronger panels or be an improper operating point for the inverter. Typically, the more similar the panels are when it comes to electrical performance, the more predictable the system design and performance.
Is Series Wiring Better When Solar Panels Are Far From the Inverter?
For longer cable runs, series wiring may be useful as higher voltage and lower current (relatively) may result in less loss. This doesn't necessarily make it best to use solar panels in series or parallel for all long-distance installations, though. Before determining the wiring arrangement, the cable size, array voltage, inverter limits, and safety requirements should all be considered.
Can Different Roof Sections Use Different Wiring Configurations?
Yes, when the inverter has multiple MPPT inputs, sometimes different panels on different roof orientations and/or under different shading conditions can be connected in separate strings, depending on the particular conditions. In such cases, the solar panels can be wired in series or parallel to an MPPT that allows each panel on the roof to be under the right voltage and current conditions, rather than having to be in the same configuration.
Does Adding Battery Storage Change the Best Series or Parallel Setup?
Panels can be wired in series or in parallel and are not necessarily determined by battery storage. Panel specification, shading, roof layout, and inverter / MPPT limits are still the primary factors that affect the best configuration. Solar panels can be connected in series or parallel to provide the battery with a generally higher energy level within the energy system after it has been generated and manipulated by solar equipment.
