Best Direction for Solar Panels in the UK: How to Choose the Right Orientation
- What Is the Best Direction for Solar Panels in the UK?
- How Do Roof Direction, Tilt Angle and Shading Change Solar Output?
- How Should Your Household Energy Use Shape Solar Panel Direction?
- How Can Battery Storage Help You Use Solar Power Whichever Way Your Panels Face?
- Making the Most of Your Roof Whichever Direction It Faces
- Conclusion
- FAQ About Best Direction for Solar Panels
When planning solar panels, most homeowners want a straightforward answer: which way should the panels face? The best direction for solar panels in the UK is generally south, but that does not mean east- or west-facing roofs are unsuitable. The direction affects not only how much electricity a system generates, but also when that electricity becomes available. That matters when planning home energy storage, especially if your household uses more electricity in the evening than during the day. Roof pitch, nearby trees, available space and everyday routines all influence the final decision. Here is how to assess your roof, choose a practical panel arrangement and make better use of the electricity your system produces.
So, what is the best direction for solar panels UK homeowners should choose? For most properties, south-facing panels deliver the highest annual electricity generation when other conditions are comparable. A suitable installation also accounts for shading, roof design and household demand.
Why South-Facing Panels Usually Maximise Total Daily Output
The sun travels across the southern part of the sky in the UK, making south-facing roofs a strong choice for solar generation. Panels receive useful sunlight throughout the day, particularly around midday, when the sun is generally highest.
For homeowners researching the best direction for solar panels to face, south is the usual starting point. It is also the preferred best facing direction for solar panels when the main objective is to maximise annual generation from a given installation.
There is an important distinction between an ideal orientation and a good real-world installation. A south-facing roof shaded by a neighbouring building might perform worse than a clearer roof facing south-east or south-west. The roof's condition and usable area matter just as much as its compass direction.
Why East- and West-Facing Panels Can Match Morning or Afternoon Demand
East-facing panels begin generating useful electricity earlier in the day. They suit households that prepare breakfast at home, run appliances in the morning or use electricity before leaving for work.
West-facing panels produce more of their electricity later in the afternoon. That suits families who return home after work, prepare evening meals or run appliances towards the end of the day.
These are two of the best directions for solar panels when matching generation to a household's routine matters more than maximising total output. Annual generation is generally lower than for a comparable south-facing system, but electricity produced when the household needs it is often more useful than a midday surplus.
Best Roof Directions for Solar Panels in the UK: South-East and South-West
A roof does not need to face due south for a solar installation to work well. South-east roofs start generating earlier in the day. South-west roofs make better use of the afternoon and evening sun.
For anyone comparing the best roof direction for solar panels UK homes can accommodate, both are worth a place on the shortlist. The best direction for solar panels UK households end up with is usually the one that balances roof condition, shading and when electricity is needed.
The Energy Saving Trust gives a general estimate that east- or west-facing systems produce around 15–20% less electricity than comparable south-facing systems. Roofs sitting between south and those two directions generally lose less. Actual results vary with the roof, installation and local conditions.
Direction is only one part of solar performance. Panel tilt, shading and the amount of usable roof space all influence the electricity a system generates throughout the year.
How Tilt and Orientation Work Together
The best angle and direction for solar panels are closely linked. Orientation determines which part of the sky the panels face, while tilt affects how directly sunlight reaches their surface. A south-facing roof with a suitable pitch generally provides strong annual performance. An east-facing roof is better for morning sunlight and a west-facing roof would be better for afternoon generation. The choice of the best tilt also will be dependent on the roof structure and mounting system.
Choosing the best direction and angle for solar panels therefore requires more than following a standard recommendation. An installer should assess the actual roof and estimate annual generation before settling on a design.
Pitched, Flat and Ground-Mounted Installations
The best direction for solar panels on roof installations depends partly on the type of surface available.
Pitched roofs: The existing slope largely determines the panels' orientation and tilt. South, south-east and south-west slopes are generally favourable.
Flat roofs: Mounting frames provide greater freedom to adjust panel direction and tilt. Structural strength, wind loading and spacing still need careful consideration.
Ground-mounted systems: Panels can be positioned independently of the house, provided there is sufficient suitable land and a safe mounting location.
The aim is to achieve useful generation without creating unnecessary installation costs or compromising structural safety.
Shading From Trees, Chimneys and Neighbouring Buildings
A chimney, tree or neighbouring building can block sunlight during important production hours. In some cases, this has a greater effect on output than a modest difference in roof orientation.
Installers assess shadows across different seasons because the sun sits lower in the sky during winter. Where shading is unavoidable, microinverters or power optimisers can help reduce the effect on other panels, depending on the system design. Choosing a direction is not enough; it is more useful to have a clear assessment of what to install prior to beginning the installation.
Awkward Roof Layouts and Limited Space
The best direction of roof for solar panels is not always available on properties with extensions, dormer windows, skylights or several small roof sections. In these cases, installers assess the usable roof area, expected generation and practical panel arrangement. The best house direction for solar panels is ultimately the one that makes effective use of the available space while meeting the property's electrical and structural requirements. A combination of roof slopes can be more practical than forcing the entire system onto one side.
The best direction for solar panels should reflect when your household uses electricity, not simply the amount generated over a year. A system that produces power during busy household hours can reduce the need to buy electricity from the grid.
Morning-Heavy and Evening-Heavy Households
East-facing panels suit households that use more electricity early in the day. Morning generation can supply appliances, lighting and breakfast preparation while the sun is rising. West-facing panels are often a better match for homes that become busier in the afternoon and evening. Their later generation can help meet cooking, lighting and appliance demand.
Households with someone working from home throughout the day often have more opportunities to use solar electricity as it is generated. Reviewing your electricity bills and smart-meter readings helps reveal which pattern fits your property.
Splitting Panels Across East and West Roof Slopes
Panels on the east and west facing slopes distribute generation over a wider period. The eastern array supplies electricity early, the western array supplies electricity later. This arrangement is useful when both roof slopes are suitable and the household uses electricity from morning until evening. It also avoids concentrating all generation around midday. The total output depends on the roof, panel count, shading and system design. Ask your installer to compare an east-west arrangement with a single-facing array before deciding.
Balancing Generation Against Self-Consumption
The best direction for solar panel installations should support self-consumption: using the electricity generated at home instead of buying it from the grid. Imagine two households with similar solar systems. One is used all day and the other is emptied only at 6 pm. The first house has more direct solar energy consumption opportunities. The second is in greater deficit of generation compared to demand.
Battery storage helps bridge that gap, but it is still important to consider panel direction, appliance schedules and expected generation together. No single orientation guarantees a particular reduction in energy bills.
Home energy storage allows households to retain surplus solar electricity and use it later. It does not change the roof's orientation, but it helps make daytime generation useful after the sun has moved on.
Why Surplus Solar Electricity Is Often Wasted
Solar panels frequently produce their strongest output around midday, when many households are empty. When the generation is in excess of the immediate demand the surplus electricity is usually fed into the grid if an export scheme exists.
The Smart Export Guarantee provides a framework through which participating electricity suppliers pay eligible customers for exported renewable electricity. Export rates and import prices differ, so exporting power does not necessarily deliver the same financial benefit as using it at home. That makes it important to consider how much electricity your household consumes directly and how much remains available for storage.
Note: Smart Export Guarantee rates, eligibility and tariff terms vary by supplier and can change. Check current offers with your supplier before relying on export payments in your calculations. |
How Battery Storage Saves Surplus Energy for Later
A battery stores surplus electricity and releases it when household demand rises. For example, energy collected during the afternoon can help power lighting, cooking and appliances in the evening.
This reduces reliance on grid electricity when sufficient stored energy is available. The actual benefit depends on usable battery capacity, conversion losses, electricity tariffs and household consumption.
Storage also works with the various orientations of panels. East facing panels will be more useful early in the day, west facing panels will be more useful late in the day. A battery provides a link between those production hours and when electricity is required.
Choosing Storage Around Your Installation
Before choosing a battery, check its compatibility with your existing solar panels, inverter and electrical installation. Households starting from scratch have the opportunity to plan generation and storage together, while existing solar owners need a solution suited to their installed equipment.
Compare usable capacity, charging limits, output power and expansion options. This should also be checked by a qualified professional, with regard to connection arrangements and UK electrical and network needs.
Understanding Plug-in Solar Requirements
Plug-in solar is not the same as a conventional rooftop solar installation paired with a home battery. Great Britain introduced a regulatory framework for compliant plug-in solar products in 2026, but products must meet the applicable requirements before being marketed or connected under that category. If basic plug-in solutions aren't enough, a well-designed solar panel and battery storage solution plays a more methodical path to increased capacity and future growth for households. Installation and connection need to be confirmed by a qualified professional.
The right setup starts with the roof you have and the electricity your household needs. Storage can improve the usefulness of solar generation, particularly when production and consumption occur at different times.
Planning Storage and Solar Together for a Household Starting From Scratch
EcoFlow STREAM 5000 is designed for households planning a more complete solar and storage system without existing solar panels. Considering the best direction for solar panels alongside battery storage helps align generation with household demand from the outset. Its 5 kWh capacity supports overnight household use, with expansion up to 90 kWh. Solar input of up to 5,000W and automatic energy management help households make practical use of available generation. Its compact design and built-in handle also simplify positioning within a suitable space.
Adding Battery Storage to Panels Already on the Roof
EcoFlow STREAM AC 5000 is intended for homeowners who already have rooftop solar and want to add storage later. Even if the best direction for solar panels was not considered when the original array was installed, a compatible battery can help retain surplus electricity for evening use. The system will be compatible with existing rooftop PV installations and third-party meters. Pairing with a Gateway can enable expansion up to 90 kWh and will not require rewiring for future expansion. Fit only by a competent electrician after ensuring compatibility and necessary electrical connections.
Note: EcoFlow STREAM 5000 and STREAM AC 5000 are home battery storage systems that need professional installation. They are not sold as plug-in solar products, and a battery does not qualify as a compliant plug-in solar microgenerator just because its setup is straightforward. Check current GOV.UK guidance and speak to a qualified installer about the requirements for your home.
Panels facing south are likely to generate the most annually in the UK, whilst those facing east or west provide a good alternative for households that have morning or afternoon demand. Roof pitch, shading, available space and daily routines all affect the final decision. Battery storage adds flexibility by retaining surplus electricity for later use, helping households make better use of the power their panels generate.
EcoFlow offers storage options for households planning a new solar installation and those adding a battery to existing panels. For more information on the STREAM 5000 and STREAM AC 5000, explore EcoFlow UK and get a head start on your home's solar and storage solutions.
Do solar panels work on a north-facing roof?
Yes. North-facing panels generate electricity from daylight, but north-facing pitched roofs generally produce less energy than comparable south-facing roofs in the UK. Ask an installer to assess the roof before deciding whether installation is practical.
Does the best direction for solar panels differ between the north and south of the UK?
The general preference for south-facing panels remains the same across the UK. Latitude, seasonal daylight and local weather affect generation, so an installer should assess the property individually.
How can I find out which direction my roof faces?
Use a compass, phone compass app or online map to estimate the roof's orientation. A professional survey confirms the direction, roof pitch, shading and practical installation options.
