SEG Solar Panels Guide: Plug-In Solar, Export Rates and Storage
While solar panels can reduce the electricity a home draws from the grid, solar's value isn't limited to generation. Electricity is consumed immediately in the house, and if generation exceeds domestic consumption, the excess is exported.
For households researching SEG solar panels, this creates a choice between using electricity directly, exporting eligible surplus through the Smart Export Guarantee, or storing energy for later consumption. The best approach depends on daytime electricity consumption, export options, export tariff, and whether battery storage is part of a larger energy system.
This guide will help UK households understand where electricity exports fit into the overall value of solar and how this relates to plug-in solar generation, self-consumption, and home energy storage options.
Plug-In Solar Generation, Surplus Electricity and UK Grid Export
Before comparing export tariffs, you need to know where your solar electricity is going. You can use electricity produced at home straight away, save it for later, or send it to the grid as surplus (where possible and compatible with the storage system). These paths affect both grid purchases and the electricity available for export.
Using Plug-In Solar Electricity Before Exporting Surplus Generation
Plug-in solar generation can help power appliances during the day when the sun is out. For instance, if a solar system generates 500W and the house requires 700W, solar will meet some of the immediate demand, and the rest will be drawn from the grid.
This is considered to be direct use and is commonly referred to as solar self-consumption. It means electricity is generated and used locally instead of being exported first. If readers require more background on the process, then they can check out how plug-in solar works.
Any surplus production beyond the household's immediate needs is used to produce other commodities. If the installation and connection arrangements allow, the electricity network can then receive the surplus, if it is eligible.
Measuring Solar Generation, Self-Consumption and Exported Electricity
The export figures do not reflect total solar generation. A system at one location might produce a few kilowatt-hours in a day, but some of that energy might be used by appliances in the home before it is sent to the grid.
Consider three figures: how much electricity the solar system produces, how much the property consumes, and how much it exports once the property's immediate needs are met. The latter is especially relevant to SEG calculations for solar panels, as export payments are based on electricity exported to the network and not all electricity generated by the solar panel.
If the daily energy usage of a household is high, it could be that the solar energy can be used more directly, and if the energy use of the household is low, then the solar energy can be supplied with a greater surplus.
Exported Solar Electricity and the Role of Smart Metering Data
Accurate measurement matters when a household wants to be paid for solar electricity exported to the grid. Export readings are not readings of electricity consumed on site, but instead reflect the amount of qualifying electricity that has left the property.
A suitable export-capable meter can provide this information and can also separate exported units from existing solar unit production. This serves as the basis for the assessment of the electricity that has been recorded under an SEG arrangement.
The pertinent question is whether a high solar-generation figure necessarily means high export income. The value of SEG solar panels depends on the amount of electricity produced in excess of what is needed, the amount exported, and the tariff paid for the exported electricity.
Once that's established, the next step is to examine the Smart Export Guarantee itself – who can opt in, what metering is required and why export rates may vary between the different suppliers.
Smart Export Guarantee Rules for Plug-In Solar Households in the UK
Paying for solar electricity once you have surplus electricity to export requires more than exporting electricity back to the grid. The Smart Export Guarantee contains eligibility, certification and metering criteria and the tariff rates and the terms of the contracts available will be determined by individual suppliers.
SEG Eligibility and Export Meter Requirements for Solar Households
Solar PV is one of the renewable technologies which is covered by the Smart Export Guarantee, however, an export payment is not guaranteed if SEG solar panels are owned. The installation must meet the applicable eligibility requirements, and for domestic solar systems, both the installation and installer generally require the appropriate certification.
Ofgem's guidance is that if the solar PV system is 50kW or less, the applicant should be asked to show evidence that the installation has been properly installed and that the installer is certified to do so. MCS certification is most frequently utilized, but similar certification may be accepted. Therefore all householders who are thinking about smaller systems should make sure that they have first checked SEG requirements and the UK-wide rules that apply to plug-in solar before taking it for granted that a specific system is eligible.
Export also has to be measured. The meter for SEG must be a meter that records exported electricity in 30-minute intervals and an export MPAN must be installed. Some smart meters can capture export data, but homeowners should check compatibility with their SEG supplier, as they cannot simply rely on their current meter.
SEG Suppliers and Export Rates Across Different UK Tariff Options
Eligible households apply through an SEG licensee, which may not be the same supplier of their imported electricity. This provides homeowners with some room to shop around for SEG tariffs without having to negotiate their electricity supply contract.
Suppliers set their own tariff rate, contract length, and other conditions, as long as the SEG rate is positive. Consequently, solar panel SEG charges may differ from firm to firm as suppliers adjust their offers.
However, finding the best SEG tariff for solar panels isn't just about the highest advertised pence per kWh. Homeowners should also consider the contract length, a maximum tariff with extra requirements tied to other services the supplier provides, and payment terms.
Fixed and Variable Export Tariffs for Different Solar Usage Patterns
The form of an export tax may be as important as the actual level of the export tax. Typically, a fixed export tariff works as a set price per kWh exported, as per the tariff terms, and export income is easier to estimate if household generation is relatively predictable.
There may be different rates for variable or time dependent arrangements depending on the timing of the export of the electricity or as per the supplier's tariff structure. These can suit households with export patterns that coincide with higher-value periods, but payments may be less predictable.
For this reason, it's important that the best SEG rates UK for solar panels are considered in conjunction with the volume and timing of the solar panel exports. A home that consumes a lot of its solar energy directly may export a small portion of its solar energy while another home that consumes less energy during the day may export a greater percentage of solar energy.
Balancing Solar Self-Consumption, Export Income and Battery Storage
Once a home understands how SEG payments work, the next question is what to do with the surplus electricity generated by solar in practice. Exporting can provide a modest income, and if consumption is higher, more solar could be used at home to reduce demand from the grid. Battery storage is an alternative as it enables some of the excess generation to be deferred until later.
Comparing Solar Self-Consumption With SEG Export Payments
Solar self-consumption has an economic benefit that crucially depends on the spread between the price of imported electricity and the price paid for exported electricity. If the retail price of grid electricity is higher than the export rate from the household's SEG, it may be cheaper to use solar electricity than to import more expensive grid power.
That doesn't imply exporting is unhelpful. If surplus generation isn't immediately needed, it may still be useful through the Smart Export Guarantee. Practical comparison is therefore not solely between the electricity consumed by the household and the electricity exported, but the amount the household can actually consume when it is produced.
Some households may use more solar production naturally if they run appliances during the day, while others may produce more surplus when they are empty during the day. Reviewing both electricity-use patterns and solar panel SEG rates gives a clearer picture than relying on generation figures alone.
Using Battery Storage to Shift Surplus Solar Into Evening Demand
Some solar energy can be stored in a battery instead of being exported immediately, which shifts the timing of the solar energy. This can help when a lot of electricity is produced during the day but customers need more in the late afternoon and evening.
Solar battery storage lets you use electricity generated during the day for lighting, cooking, and evening loads after solar production drops. This increases the proportion of locally produced electricity used in the building and can help reduce electricity imports later on.
But keeping all the units available is not necessarily the most cost-effective approach. The result depends on battery capacity, charging losses, domestic consumption, and the value of the export tariff. The goal is to shift electricity to later times when it will be of value, not to maximize battery charging.
Deciding When to Use, Store or Export Surplus Solar Electricity
What is the best mix between use, storage and export may differ for each home. One house may want to export more at good times on an attractive SEG solar tariff; another household may want to limit evening electricity purchases.
Useful factors to compare include:
  • the household’s daytime and evening electricity demand.
  • the amount of surplus solar typically available.
  • the current import price and SEG export rate;
  • available battery capacity and charging efficiency.
This is where home energy management proves more beneficial than considering solar panels and SEG payments in isolation. Households can choose how they use each unit of solar electricity by coordinating generation with consumption, storage, and export.
If your house consistently generates excess and has high evening demand, the next step is to ask which battery configuration makes the most sense for your home, while keeping the rest of your solar system simple.
Home Energy Products for Plug-In Solar and Wider Storage Needs
While SEG payments provide some monetary value for excess solar generation, households can benefit from solar electricity in other ways without exporting. If demand is still high in the evenings, then some of the surplus generated by the solar panels during the day can be stored, reducing the need for imports to the grid later in the day and providing increased control over homeowners over the use of their generated electricity. The right setup can vary significantly based on the household's existing PV installation, or if they are planning a solar and storage system at the same time, or if they are just getting started with a small solar system.
EcoFlow Plug-In Solar Kit for Flexible Small-Scale Generation
If you have a small solar installation, an EcoFlow plug-in system can help you start small-scale PV generation at home before making a bigger leap to a larger system. Compact panels can reduce daytime electricity demand, lowering what you draw from the grid when the sun is available.
This can be a good option for people with limited roof space or households that want to understand daytime production and consumption before making a larger investment. However, a plug-in system does not necessarily qualify for SEG payments. Metering, certification and grid-connections needs to be addressed separately.
EcoFlow STREAM 5000 for New Solar and Battery Storage Systems
Households that plan solar and storage together can match generation and battery capacity up front for more flexibility. EcoFlow STREAM 5000 is tailored to these scenarios, offering roughly 5kWh of capacity to store excess solar energy.
It can deliver up to 3,000W of battery-system discharge power and can expand if the household battery storage needs change in the future. This is especially useful when solar generation is high during the day but demand is high in the evening.
Instead of automatically exporting surplus electricity, you can use stored electricity in the household later.
EcoFlow STREAM 5000
5.24kWh energy storage capacity for household energy management. Supports up to 4000W PV input for a professionally planned solar installation. Provides up to 3000W off-grid AC output for supported off-grid operation. Intelligent Mode+ manages stored and generated energy according to household demand. Compact 45.4kg design reduces the space required for installation. Expandable up to 90kWh if household storage requirements increase later.
EcoFlow STREAM AC 5000 for Existing Solar Homes Adding Storage
The situation is different for households that already have solar panels installed. However, you may not need to replace or redesign a working PV system just to add storage, and an AC-coupled battery can offer a better path.
EcoFlow STREAM AC 5000 is designed for existing solar households looking to expand their solar power system with about 5kWh of storage capacity, but without direct PV charging via the battery. The existing household system can handle solar overproduction and store it for later use.
This is especially beneficial if a homeowner already exports a lot of electricity during the day but imports it back in the evening. The storage option is not an either/or, it's an additional option for that household to have in addition to SEG export.
Designed for households that already have solar panels and want additional storage capacity. Provides 5.24kWh of battery storage for retaining surplus solar electricity for later household use. Supports 800–3000W grid-connected AC output. Local Mode lets the system keep running when internet connectivity is unavailable. Intelligent energy management coordinates existing solar generation, battery storage and household consumption. Can operate as an extended storage device within an existing photovoltaic installation.
SEG Planning Checks for Solar-Only and Solar-Plus-Battery Homes
It is advisable to consider operation of the entire system before selecting an export tariff or incorporating battery storage. SEG solar panels can generate export income; however, this depends on eligibility, metering, household consumption, and how much electricity they can export after storage.
1. Confirm Eligibility and Suitable Export Metering Arrangements
First, make sure the solar installation meets the selected SEG supplier's requirements and that the exported electricity can be measured appropriately. Households should verify certified status, export MPAN set-up and meter compatibility before depending on the estimated SEG income.
2. Compare SEG Rates Across Different Supplier Tariff Options
Don't just choose the tariff with the highest SEG rate for solar panels advertised by one provider. Look at payment rates, contract terms, tariff structure, eligibility requirements, and any offer requirements. A slightly lower export rate, with appropriate terms, may better reflect a household's actual export rate than a higher rate that is less readily available.
3. Estimate How Much Generated Electricity Is Used Before Export
Assess the potential for solar self-consumption before calculating export income. Even if solar electricity is generated during the day, some household appliances use it and other energy demands such as electric heating can decrease the amount of electricity available for export. Realistic consumption data ensures that the home owner is not assuming that the total panel generation is the amount they will export as SEG.
4. Compare Export Value With Later Battery Self-Consumption
If solar battery storage is being considered, weigh the value of each kWh of solar power that is exported against the potential future value of that kWh being used. Depending on import price, SEG rates, battery efficiency, and evening demand, exporting and storing are not necessarily the best choice for every household
5. Review Tariff Assumptions After Adding or Changing Storage
Storage can affect the amount of electricity delivered to the grid and, therefore, SEG export payments. Homeowners should redo calculations if the battery size and/or household use change or tariff structures change. By monitoring generation, consumption, storage, and export levels regularly, the system can stay aligned with the home's actual electricity usage.
SEG solar panels are one aspect of a domestic energy plan and the Smart Export Guarantee can have an added value in generating surplus solar energy. The maximum benefit typically depends on electricity consumption (direct and indirect), the electricity export tariff, and whether battery storage captures excess electricity for use during peak demand times.
If solar power sends a smaller percentage of electricity to the grid, generating more electricity for a home may be appropriate. Others may find it more advantageous to expand solar use in combination with storage. A battery storage system like EcoFlow STREAM 5000 or STREAM AC 5000 can accommodate that flexibility, if the property can accommodate it, and the solar setup does.
Keep in mind that generation, consumption, storage, and export should be considered as a group, rather than SEG income alone.
Can I choose a different SEG supplier from my electricity supplier?
Yes, residents/households can request a SEG solar tariff from a different company from which they get their electricity from. Ofgem confirms that the SEG licensee doesn't necessarily have to be the same company as the household's electricity supplier.
But tariffs may still apply on a case-by-case basis. The rate offered for export callers may be higher or for special export; such higher rates or special export may be offered only if the customer also implements an import tariff, or takes other requirements. So it's wise to review the full tariff details before switching.
Do all electricity suppliers offer the Smart Export Guarantee?
Not every electricity supplier operates as an SEG supplier. Larger suppliers - if they reach the applicable customer threshold - must participate and smaller suppliers can opt to become voluntary SEG licensees. Ofgem publish a new list of participating suppliers each SEG year.
Households are reminded to verify the current list and not assume their current supplier offers a qualifying export tariff.
Can a small solar installation receive SEG payments?
If the installation is based on an approved technology and if it complies with the scheme requirements. The Smart Export Guarantee applies to solar PV installations up to a certain limit, in Great Britain.
For small SEG solar panels, households will also require appropriate certification and export metering. SEG payments are not dependent on the size of the installation.
What should I compare before changing SEG tariffs?
The headline SEG export rate is significant but it's not the only one to consider. Prior to altering tariff compare:
  • the payment per exported kilowatt-hour;
  • whether the rate is fixed, variable or time-dependent;
  • contract length and switching conditions;
  • any requirement to use the same supplier for electricity imports;
  • additional eligibility requirements linked to solar or battery equipment.
The actual tariff does not have to be zero: SEG suppliers can choose their own tariff and contract terms as long as the tariff is positive, which gives a better idea of potential export income.
Does adding a battery mean I have to stop exporting solar electricity?
No, with solar battery storage you don't always lose the option of exporting. The surplus generation can partially charge a battery and then send the excess electricity to the grid if there is too much power generated to be stored.
The tariff treatment of battery related exports can vary depending on the specific tariff and supplier terms selected, especially when electricity might also be imported and later exported. Therefore, before planning a strategy to charge batteries and export to the grid, homeowners should verify their SEG provider's method of tracking eligible exports.
