Peak Load Explained: Peak Shaving, Load Shifting and Home Energy
- Peak Load Across a Household Electricity Profile
- Comparing Baseload, Average Load and Maximum Household Demand
- Peak Shaving, Load Shifting and Load Levelling Strategies Compared
- Household Situations That Commonly Create High Peak Electricity Demand
- Solar and Battery Storage for Managing Short High-Demand Periods
- Home Battery Storage for Peak Load and Household Energy Management
- Tips Before Planning Solar and Battery Storage
- Conclusion
- FAQs
A home's power consumption is seldom constant. The demand varies throughout the day as a result of different appliances being used, or people being at home, or equipment like electric heating or EV charging being in operation. The peak point of one of these periods is called peak load.
But peak demand can last only a few minutes and can affect the sizing of the household electrical system, inverter, and battery storage. When EV charging is combined with cooking or heating, the impact on the grid may be greater as the kettle is on its own, but if charged simultaneously, this could result in a much bigger temporary demand.
Peak electricity demand helps households distinguish short, high-demand electricity events from regular daily use. It also facilitates the use of concepts like 'peak shaving' or 'load shifting' in planning solar generation or battery storage.
The household electricity profile shows how household electricity demand varies throughout the day. Most households consume significantly less than they are able to. The peaks occur where many power consuming activities occur at the same time, or just one high power appliance is switched on.
Peak Load Meaning During High-Demand Periods in Modern UK Homes
Peak load is the maximum amount of electricity that is used during a specific time. It is measures in kilowatts, not kilowatt-hours, as it indicates the amount of power being demanded at one point in time, not the total amount of energy used over time.
For example, a home may have a demand of 0.5–1kW, but a cooking unit and a heating unit may temporarily push demand to over 5kW. This brief increase is part of the home's maximum electricity demand.
Peak load is thus a far cry from a monthly electricity bill. Two houses can have the same total energy use, but have widely different peak energy demands.
Household Appliances and Activities That Create Short Load Peaks
Short-term spikes in electricity usage are most likely caused by high-power appliances. Electric ovens, kettles, showers, tumble dryers and induction hobs can all cause a high demand when in use.
The effect is more pronounced if appliances overlap. An electric shower on its own, for instance, may produce a very small peak demand, but when combined with cooking dinner, it can produce a much larger household peak demand.
These times can be longer with EVs chargers and electric heating as these can consume significant energy for a longer duration than a kettle or a microwave. It is therefore important to know which activities overlap and the rated wattage of individual appliances.
Peak Demand Differences Across Homes, Seasons and Daily Routines
Each property has a unique peak electricity consumption profile. Peak-load timing depends on household size, heating system type, and daily routines.
In some areas, electrically heated homes may have larger peaks in the winter months, and larger peaks in the evenings when cooking and entertainment are combined with vehicle charging. Additionally, homes with solar generation may reduce grid demand during the day when solar power is generating strongly.
That is why a real household load profile is better than a generic estimate. After identifying a peak period, you can compare it to baseload and average demand to show how electricity consumption varies throughout the day.
Peak load is more meaningful when contrasted with the lower demand levels during the rest of the day. A typical household electricity profile has three key reference points: baseline load, average load over time, and peak load, which occurs when appliances operate simultaneously.
Continuous Baseload Compared With Short-Term Peak Electricity Use
Baseload electricity refers to the consistent demand from equipment operating for long durations, like refrigerators, routers and heating controls. Peak electricity demand, on the other hand, occurs when high-powered equipment temporarily sends electricity usage way up.
A house can have a steady baseline load of maybe a few hundred watts, but then spike to a few kilowatts for a few minutes when preparing meals or heating up. The difference is because cutting the baseload cuts actual energy use, while peak control is primarily about the amount of energy needed at one time.
Average Household Demand Between Minimum and Maximum Load Levels
Average electricity demand shows typical power usage in a selected time, not the lowest or the highest. It accounts for both the more sedate periods and those when several appliances are in use.
So, a household may have moderate average demand, with occasional high peaks. While comparing your own consumption with the average electricity consumption of properties can give you some context, every property is unique due to appliance selection, occupancy and type of heating.
The average helps estimate overall energy needs for solar and storage planning, and the peak helps estimate instantaneous power needs, which may also matter for solar and storage planning.
Load Profiles Showing How Electricity Demand Changes Through the Day
These changes are displayed in a household load profile over time. At night, demand can be near baseload, peak in the morning, dip in the middle of the day, and increase again at night.
These patterns not only indicate the amount of electricity that a home consumes, they also show when the peak electricity demand happens in a home. This timing turns into very helpful when dealing with peak shaving, load shifting or battery storage, as each approach addresses high-demand periods in a different manner.
If a household load profile shows high-demand periods, several methods can address them. Peak shaving, load shifting and load levelling are related concepts, but can address slightly different problems. The optimal strategy depends on the goal: reducing peak short-term demand, shifting flexible demand to other times of day, or flattening the overall electricity demand profile.
Peak Shaving Reducing the Highest Levels of Household Electricity Use
Peak shaving takes a direct approach at reducing peak demand in households. Some loads may be deferrable or partially powerable by a battery, rather than having to be drawn from the grid simultaneously by several high power appliances.
Stored energy could benefit the home, for instance, when cooking appliances and electric heating run simultaneously. Overall energy consumption throughout the day could stay the same, while the peak demand on the electricity grid is reduced.
Load Shifting Moving Flexible Electricity Use to Lower-Demand Periods
Load shifting doesn't necessarily mean less consumption; it shifts when you use electricity. Flexible activities like EV charging, laundry or dishwasher cycles can be shifted away from times of high electricity use.
A household with time-of-use pricing can also shift some consumption to less expensive off-peak periods. Electricity consumption monitoring can help determine which of the loads are truly flexible and which must run at certain times.
Load Levelling Smoothing Demand Across a More Consistent Time Window
Load levelling is a more comprehensive solution that aims to achieve a more level household load profile over time. This can include load shifting, battery charging, and controlled use of appliances to avoid repeated low and high loads.
It does not aim to achieve a perfectly flat electricity demand. Rather, it reduces unwanted extremes and establishes a more regular pattern.
These three approaches are especially helpful where multiple high-power technologies are present, such as electric cooking, heat pumps, and EV charging, which are likely to cause peaks in households.
Peak electricity demand typically occurs when multiple electricity-consuming processes take place simultaneously. The issue isn't that a home consumes excessive electricity throughout the day, it is that the amount of electricity required is high in a short time frame. This overlap can help determine load rescheduling and/or the need for solar and battery storage.
Cooking and Electric Heating Running Together During Busy Home Periods
A common source of household peak demand is during the evening. All these appliances (an induction hob, oven, kettle, and electric heating system) can be used at the same time, causing a rapid increase in power demand.
Although these peaks are short, they can often be higher than the home's typical electricity consumption. Unfortunately, high-power appliances often run at the same time; spreading flexible activities over time can save energy, even though they consume the same amount of useful energy.
EV Charging and Heat Pump Demand Increasing Household Peak Loads
Different maximum electricity demands can come from an EV charger and a heat pump, which may run longer than typical kitchen appliances.
The heat pump could be operating when the occupants are coming home, cooking supper and other electrical appliances. If an EV starts charging at the same time, the total load can be much higher than the property's daytime average.
Flexibility in EV charging demand can help here, as can the appropriate controls to avoid unnecessary demand during other large household loads.
Multiple Appliances Running Together During Household Peak Demand
Another cause of peak load is that everyday appliances happen to coincide. A power peak may be imperceptible with one device, but if you have a few of these devices all working at the same time, you may see a short term power peak on the meter.
That's where appliance ratings fall short. Wattage is important but so is timing.
Sometimes, you can identify load-shifting opportunities before buying additional equipment by studying the time of day when multiple pieces of equipment regularly use the system. If high-demand times can't be shifted, another option is to use solar generation and a battery storage system to help power the house and limit the amount of electricity used from the grid at any one time.
The use of high power appliances does not always have to be eliminated to achieve peak management. In contrast, solar generation and battery storage can provide some of the needed power and reduce the need for grid power during a brief peak-load event. Their effectiveness depends on timing, solar output, and the battery system's discharge capacity.
Daytime Solar Generation Supporting Part of Household Peak Demand
If a peak falls during the day, solar generation can provide some of the electricity consumed at that time. This can occur when there is a high solar production during cooking, washing, working from home devices and electric heating.
The benefit will depend on the level of generation matching the house peak demand. When the appliances need 5 kW and the solar is supplying 2kW, the grid or battery must supply the remaining 3 kW.
This is why solar does not always remove peaks from the grid, instead it can help reduce grid demand during some peaks. Some households can also take advantage of increased locally generated energy, such as solar battery storage, to store excess energy for later use.
Battery Storage Supplying Stored Energy During Short Demand Peaks
A battery will perform peak shaving by discharging when household demand suddenly increases. Stored electricity powers part of the load, rather than pulling the entire load from the grid.
This is especially convenient during the evening peak electricity demand, when solar power might be limited and other appliances in the household are being used simultaneously, such as for cooking, heating, etc.
This does not always lead to lower overall energy consumption throughout the day. It is used primarily to shift the power source during peak periods.
Inverter Output and Battery Capacity Limits During Peak Load Events
Capacity of batteries is not a definitive measure of the effectiveness of the system to meet peak demand in the home. The inverter must also be able to produce enough power when needed.
A large battery capable of high storage capacity may not be able to power multiple high-power appliances. On the other hand, high production and low usable capacity might only enable a high peak for a short duration.
Therefore, households should consider these three factors together when deciding on battery size for effective home energy management. These factors are particularly important when implementing a storage system to manage regularly occurring high-demand periods.
With awareness of peak demand times, battery storage can be designed around more than just a household's daily usage. The goal is to provide sufficient capacity to meet the demand for stored power during frequent peak power periods, while not oversizing the system for infrequent peak periods. This makes the battery capacity and the inverter output key considerations.
EcoFlow STREAM 5000 for New Solar and Storage Home Installations
The EcoFlow STREAM 5000 is a 5.24kWh solar storage battery that can be paired with a solar power system up to 4,000W for integrated solar generation and storage planning. This lets new installations store electricity generated during the day for later use during peak demand at home.
At night, the stored energy can be used to cook, entertain, heat, or power other concurrent needs instead of relying on the grid to provide the total energy. For homes with predictable peaks, this can be part of a larger peak-shaving approach.
EcoFlow STREAM AC 5000 for Existing Solar Homes Adding Storage
The EcoFlow STREAM AC 5000 is intended for households with existing solar panels that want to add solar storage. This 5.24kWh battery stores excess solar power for later use instead of sending it straight to the grid.
This can be beneficial in places where the peak electricity demand is after sundown, like in the evening for cooking or electric heating. Then solar energy can meet some of that demand and reduce the load on the grid during peak demand hours. Existing solar production and current inverter configuration should be taken into account when installing solar storage in a retrofit.
Matching Storage Capacity to Peak Demand and Everyday Electricity Use
When planning batteries, consider the balance between battery storage capacity, inverter output power, and the duration of typical peaks. A home with typical short duration of high power consumption may not need a large battery, but a high output, whereas a home that requires power for a longer period of time in the evening may need a large battery but not a high output.
Also consider normal daily consumption. If the battery is only the size of the maximum demand, then it may be under utilized much of the year.
The most practical method is to compare the maximum household demand that occurs repeatedly with daily energy consumption, solar surplus, and the duration of peak periods. This results in a storage plan that reflects actual household activities, rather than chasing the largest number ever registered on the meter.
A plan that uses solar and battery storage should match the household's actual electricity consumption. Before selecting the system size or output, consider the following: When does demand increase? What is the duration of the peak? Can some of the loads be scheduled to occur at a different time?
Identify recurring peak periods. Use smart meter or monitoring data to identify when peak electricity demand occurs regularly. One unusual spike is not enough as compared to the pattern seen most days.
Separate flexible and fixed household loads. Often load shifting can be done through EV charging, laundry and dishwashing, but cooking, heating or electric shower might be more difficult. This indicates which peaks require direct support and not rescheduling.
Check peak duration as well as maximum power. A five-minute short-term power peak requires a different storage strategy from several hours of elevated evening demand. Duration influences the usable battery capacity needed.
Compare battery output with appliance demand. Don't assume that a large storage capacity equals a good peak shaving performance. The battery inverter should also have a sufficiently high peak power for the loads that are expected to be operated simultaneously.
Consider solar timing before increasing storage. Check out the periods of solar generation that coincide with the household peak demand. Solar support may already be sufficient during daytime peaks and sufficient energy storage will be more important during evening peaks.
By understanding peak load, households can better appreciate why a small amount of high electricity consumption can be as significant as the overall amount of electricity consumed on any given day. A combination of cooking, heating, and multiple appliances may create a period of peak household demand that significantly exceeds the normal baseline.
Peak shaving, load shifting and load levelling are strategies which can help reduce or redistribute these short-term peaks. Solar can help meet daytime demand and battery storage can provide some of the load when peaks may be occurring later in the day.
The best way to do this is to plan around actual household activity. Considering peak size, duration, timing and solar availability, provides a better foundation for selecting storage capacity and inverter output.
Can a Smart Meter Show the Exact Peak Load Reached by a Household?
A smart meter can be used to make the user aware of the peak electricity demand. However, to what extent that information is recorded and displayed depends on the frequency of the recording. An in-home display can be helpful to identify when electricity demand is large, and more sophisticated monitoring can help to identify a better load profile for the household over shorter time spans.
Does Peak Load Affect Electricity Bills on Every UK Energy Tariff?
Most public power tariffs charge primarily for the overall amount of electricity used in homes and not so much on the maximum peak demand.
However, peak timing can still matter because:
Time-of-use tariffs may charge more during expensive periods.
Shifting flexible loads can reduce use during higher-rate hours.
Battery storage may help reduce grid electricity demand during those periods.
The financial benefit therefore depends on the tariff structure rather than peak power alone.
Can EV Charging Be Scheduled to Avoid the Highest Household Demand?
Yes, demand for EV charging can often be flexible and can be shifted away from the evening peak. An appropriate charger will allow them to be programmed to charge at night or during times of day when electricity costs are lower or solar charging is possible.
This shift could avoid EV charging coinciding with cooking, heating, and other high-load activities, reducing the household's maximum demand without limiting the electricity supplied to the vehicle.
Does a Heat Pump Always Create the Largest Peak Load in a Home?
No, while other appliances may use more power for short periods, a heat pump can take a big bite out of the household peak demand, especially during the colder winter months.
The highest peak is a function of the joint operation of the largest equipment:
Electric showers can create very high short-term loads.
Cooking appliances may overlap with heating demand.
EV charging can add several kilowatts for extended periods.
An integrated look at combined appliance use provides a better indication than a single technology.
Can Battery Storage Reduce Grid Demand Without Reducing Energy Use?
Yes, during peak hours, battery storage can reduce grid demand by supplying electricity from stored batteries, keeping household appliances running without increasing power usage.
This is known as peak shaving. Total energy consumption hardly changes, with a portion of the electricity coming from the battery rather than the power grid during peak hours.
