How Do You Clean an Electric Blanket? Safe & Easy Steps
While an electric blanket may make those chilly nights feel cozy, taking care of it during the wash is very important if you want to make sure it works properly. If you want find out how do you wash an electric heated blanket properly, the secret depends on reading the care tag, detaching the controller, washing it correctly, and letting it dry properly prior to using it again.
Furthermore, it always makes sense to have a relatively good power backup just in case there could be a blackout in winter.
1. How Do You Wash an Electric Heated Blanket Safely?
Having an electric heated blanket can be very useful in your home. However, it also has its downside; dust, sweat, oils, and dirt get stuck on it, so to keep it clean you must wash it regularly. However, keep in mind that you cannot treat it like regular blankets since it is electrically heated.
Thus, before you begin washing it, you should go through the instructions from the manufacturer and disconnect all the electric parts.
Check the Care Label and Washing Instructions
The first thing to do is check the care label of the heated blanket. There might be different instructions regarding washing depending on the model and type of blanket.
Also, there might be different instructions related to:
Whether the blanket is machine-washable or can only be washed by hand
What temperature is recommended for washing
What washing cycle is better
What detergents are acceptable
What drying techniques should be used
Whether tumble drying is allowed
Whether you should avoid soaking, ironing, or dry cleaning.
The best way to clean your electric blanket is to go according to the instructions provided by the manufacturer so that you don’t cause any damage to the heating elements or electrical insulation.
Disconnect the Controller and Power Cord
First of all, before starting to clean the electric blanket, it is crucial to disconnect it from the power supply and to remove the control unit and removable power cord as long as the model permits. Do not wash the control unit nor any electrical connection.
After that, you should inspect the blanket for broken wires, damaged insulation, loose joints, or burnt areas. If you find something suspicious in this regard, do not use or wash the blanket until it is checked or repaired.
How to Wash an Electric Heated Blanket
When washing is permitted by the care instructions of the item, use gentle washing techniques and mild detergent. Make sure to use special detergents only when instructed.
In case of machine washing:
Remove and disconnect all the electrical components.
Put the item into the washing machine without bundling or suppressing it.
Select the temperature and washing cycle specified in the washing instructions.
Add a small quantity of washing detergent.
Make sure that the machine is not overloaded. Use a rinse cycle if any soap traces are left in the finished product.
Pro Tip: For hand washing the blanket, wash it in cool or lukewarm water, carefully avoiding twisting, wringing or rubbing the material too hard.
Can You Wash an Electric Heating Blanket in a Washing Machine?
It is true that there are electric heating blankets which can be washed in a machine but it entirely depends on the manufacturer's specifications. One should not presume that electric blankets can be washed in a machine.
If machine washing is allowed, make sure to use the correct temperature and wash cycle as per the manufacturer's guidelines. It is particularly important to make sure to take off the controller and electric connections first.
Finally, follow the washing instructions on the care label instead of following a general washing cycle in case the label specifies hand wash only.
How to Dry an Electric Heating Blanket Safely
Drying is as important as washing. A soaked electric blanket needs to be thoroughly dried before it can be plugged in as moisture creates a dangerous type of electrical situation.
After washing:
Follow drying instructions provided by the manufacturer.
Flat drying or hanging drying of the blanket should be done according to the instructions.
The blanket has to be completely dried before reconnecting any cables or plugs.
Wringing and twisting the blanket is not allowed.
Don’t dry the blanket at a higher temperature unless wanted by the label.
Make sure that the blanket is completely dried (especially the connectors) before using it.
Common Electric Blanket Washing Mistakes to Avoid
Mistakes that are minor might cut down the lifespan of an electric blanket, as well as lead to safety hazards. These are:
Not washing the power cord or the controller
Doesn’t disconnect the electronics when washing
Using bleach or cleaning products that are aggressive
Wringing or twisting
Disregarding the care label from the manufacturer
Drying it with excessive heat
Plugging it in before it dries completely
Using it while wires are exposed
With the blanket clean and dry, we can think not only about its maintenance but also about other aspects of its operation.
In winter, for instance, thermostatic blanket operation, electric consumption, and sudden power outage can influence its efficiency when heating your home.
2. Electric Blanket Safety, Heating Costs & Winter Power Outages
After the electric heated blanket has been cleaned and dried to perfection, the next step to think of is its nice daily usage. An electric blanket can warm you up during winter, however, if one knows how exactly to use it, its consumption may be kept on a reasonable level.
It's important to keep winter power outages in mind in advance if you include the blanket into your cold weather routine.
Safe Electric Blanket Use During Cold Weather
It is necessary to check your electric blanket for any signs of damage before its use, including defects in wiring, burns, odd odors, and malfunctioning control mechanisms. It is best to keep the blanket flat when it is on, and adhere to the recommendations of the manufacturer about operating time and temperature.
For winter Use:
Check the blanket and controller for any external signs of damage.
Keep the blanket flat while it is heating.
Obey the temperature recommendations.
Keep the blanket away from any liquid materials.
Do not use a wet blanket.
Switch the blanket off when it is no longer needed.
Use the blanket according to the instructions given by the manufacturer.
Safe operation is just one aspect of effective winter heating. The wattage and length of time an electric blanket is used can also affect the amount of electricity that it consumes.
How Much Electricity Does an Electric Blanket Use?
The power rating, the amount of usage time of the electric blanket and the heat settings affect the energy consumed by the blanket. A simple way to compute the energy consumed is using the following formula:
Energy consumed (kWh) = Watts x Hours in use / 1000.
For example, if the electric blanket is rated at 100 watts and is used for 8 hours, it would consume about 0.8 kWh of electricity. One must bear in mind that consumption may vary as the blanket might not continuously operate but rather turn its heating function on and off.
Knowing the wattage of the blanket helps one estimate how much it would cost to run it and organize energy usage in winter more efficiently.
However, when there is a snowstorm or blackout, one has to be very concerned about power consumption.
What to Do If a Winter Power Outage Cuts Off Your Heating
Loss of power in winter time can render home devices and essential heating systems powerless. In such instances, first of all, it is important that all non-essential electrical equipment is unplugged, and safety measures are followed wherever necessary.
For better winter preparedness:
Have warm clothes, extra blankets, and comforters on hand.
Have mobile devices charged and ready for use.
Be equipped with flashlights or rechargeable lights.
Do not operate potentially faulty electrical equipment after accidents.
Find out whether all your heating options require power.
Be ready with the right power supply method.
An electric blanket may ensure warmth, but it also requires power connection. There is a place for home power supply systems in case of any eventualities.
Keep Essential Devices Running During a Power Outage
Having an appropriate home energy-storage system means backup electricity can be supplied to critical equipment in case of the grid failing.
The devices that can get powered depend on the efficiency and capacity of the home power-storage solution. Such equipment includes lighting devices, means of communication such as radios, and other appliances and tools for everyday tasks around the house.
When making use of an electrically heated blanket and switching to backup energy, it is vital to check the blanket's watt rating along with the continuous output compatibility of the power source. You should not exceed the limitations set by the manufacturer.
Having provided basic information in regard to electric blanket safety, how it consumes power, and how to prepare for blackouts, it is possible to move on to the practical aspects of how home battery storage works in terms of providing electricity in case of cold weather-related hardships, which will provide a reasonable introduction to EcoFlow STREAM series.
3. Home Backup Power for Winter: EcoFlow STREAM 5000
With the arrival of winter, colder temperatures, longer nights, and the increased need for electricity in the home, the importance of a generator becomes apparent. EcoFlow STREAM 5000 is an excellent solution in the area of energy storage and management, and it will ensure the availability of energy supply at home in winter.
How EcoFlow STREAM 5000 Supports Home Energy Backup
Using Backup Power With an Electric Heated Blanket
Electric heated blankets are useful when you need localized heating without heating your whole home.
They come in handy during cold winter nights and even during the times when there’s no electric power.
When working in conjunction with a home backup system such as EcoFlow STREAM 5000, the stored energy can help supply the power needed to run a compatible electric heated blanket when grid power is absent.
Check Blanket Wattage and Battery Output Compatibility
Before plugging in the electric heated blanket into the backup power supply, check its power usage and compare it to the capabilities of a backup power supply.
The blanket needs to be compatible with EcoFlow STREAM 5000 and other devices to avoid exceeding the maximum load.
EcoFlow STREAM AC 5000 as an Alternative Home Backup Option
4. Winter Electric Blanket Safety Checklist
During the cold months, the electric blanket can provide consistent warmth and comfort, however it is still necessary to ensure safety of operation, especially when the blanket is powered by an alternative source.
A basic list of safety tips may help to avoid common issues and help the blanket work efficiently in the winter.
Before Washing
Unplug the electric blanket from the socket and detach the remote control.
Refer to the instructions from the manufacturer regarding washing and drying instructions for the blanket.
Never wash the blanket if you can see that the cord, remote or plug are damaged.
The blanket must be completely dried out before the electricity supply is resumed.
Before Using the Blanket
Check the blanket and its power cord, plug, and remote for any fraying wires or burns, cracks, or some type of damage.
Place the blanket flat and avoid folding, wrinkling, or covering it while in use.
Make sure that your remote and electric connections are dry and out of moisture.
Review the wattage of the blanket and check whether the power outlet can bear the load of the electricity of the blanket.
If using an alternative power source like EcoFlow STREAM 5000, make sure to compare the blanket's power consumption with the available power output.
While using a home backup unit or a portable power station, connect the blanket according to the requirements provided by the manufacturer.
Avoid putting too much strain on the backup device by using too many devices requiring high energy at once.
Always lay the blanket flat on the surface without putting anything on top of it.
The blanket should be turned off when it is not being used anymore, which is important to remember when leaving the room or going to bed, especially if the manufacturer does not suggest that the blanket can be used during sleep.
Keep an eye on how much battery is left in case it needs to be used for something else.
When to Replace an Electric Blanket
Change your electric blanket and do not use it anymore if you can see any signs of fraying, melting, smell something burning, or have experienced overheating. An old blanket should be inspected thoroughly for possible damage.
If you know how do you wash an electric heated blanket safely, then you can protect its wiring, controls, and heating elements while keeping it in good condition for winter use. If you are wondering, can i wash an electric heated blanket, then it is advisable to refer to the care guide before washing and ensure that all the removable controls are separated.
In the case of power outages, the battery backup system can be useful in providing power to an electric blanket and some necessary electrical appliances.
Can You Wash an electric Heated Blanket With Built-In Controls?
Unless the manufacturer indicates otherwise, electric heated blankets equipped with electric controls should not be washed by the user. Be sure to adhere to the washing instructions and the care tag carefully and avoid getting non-removable components wet.
Can You Wash an Electric Blanket Without Removing the Wires?
If it is not possible to take off electrical components or wires, you should refer to the product manual before washing. Do not immerse in electrical parts or utilize any kind of washing method that the manufacturer does not recommend.
How often should you wash an electric blanket?
The suggested washing frequency depends on the care instructions by the manufacturer and the usage of the blanket. It is important to know how to wash an electric heating blanket properly because too frequent or wrong washing can damage its electrical equipment.
Can Solar Battery Storage Keep an Electric Blanket Running During a Power Cut?
Yes, solar battery storage can power an electric blanket in a power outage, provided the battery has stored enough energy and sufficient output capacity. Before you plug the electric blanket into the battery, make sure to check both the blanket's wattage and the battery's output capacity, and if it's sufficient to power any other appliances you may need at the same time.
