Energy Efficient Buildings: How to Reduce Energy Use and Improve Performance
Energy-efficient buildings use less energy to achieve a comfortable, functional indoor environment. There is a hierarchy, with the best results typically achieved by first removing unnecessary demands such as poor insulation, glazing, airtightness, and heating. After those basics are in place, appropriate properties can begin planning for solar and battery storage to account for the electricity still to be provided.
Making buildings more energy-efficient often isn't a single solution. Heat loss through the building fabric, uncontrolled air leakage and inefficient lighting, appliances or HVAC equipment can create additional electrical loads and increase heating demand. These issues also overlap: if a furnace replacement is done without considering significant heat loss from the home, the new furnace may operate harder than needed.
So, a first step in a practical improvement strategy is to identify areas of energy loss. Building owners can then reinforce the fabric, upgrade equipment, and implement smarter controls and prioritise upgrades based on measured consumption. This can be done in a home and larger commercial properties, but the size and extent of the measures will vary.
Where Buildings Lose Energy and Why It Matters
Before deciding how to improve energy efficiency in buildings, it is important to understand where consumption originates. Losses include physical losses, e.g., heat loss through roofing and windows and losses due to poor operational control of equipment. Knowing these sources will help identify a stronger foundation for selecting upgrades that target the actual weaknesses instead of using one-off upgrades.
Heat Loss Through Walls, Roofs, Floors and Windows
A considerable amount of heating requirement may be lost due to the heat flowing through poorly insulated walls, roofs, floors and glazing. In an energy-efficient building, these elements form a thermal envelope that delays heat transfer between indoor and outdoor air. If you improve one place, but not another, it can all be for nothing - for instance, if you install high-performance windows but don't get an adequately insulated roof, the windows won't help you. Evaluating the full fabric can also determine what improvements can be made to minimise heat loss and reduce the energy needed to keep people comfortable indoors.
Air Leakage and Uncontrolled Ventilation
The building envelope can have gaps around windows, doors, service penetrations and other areas that can allow heated air to leave the building while colder outdoor air enters. This uncontrolled leakage makes rooms colder than they should be and increases heating requirements, even if the thermostat is set to a fairly high temperature. Optimising building energy efficiency therefore requires minimising unwanted air movement while ensuring adequate, energy-efficient planned ventilation for indoor air quality and moisture management. Airtightness does not mean closing up a building with no ventilation; it means replacing uncontrolled air pathways with a more conscious, controlled ventilation policy.
Inefficient Heating, Lighting and Electrical Loads
Not all wasted energy is lost through the building fabric. Unnecessary lights, standby consumption and inefficient appliances, as well as older heating and cooling appliances, can also contribute to total demand. Office equipment and long hours of operation can create significant electrical loads in commercial buildings, while ventilation systems can as well. These systems are important to review as part of a building's energy efficiency strategy, as reducing energy use means the building will rely less on future energy systems and save money on running costs. A home energy monitor or building-level monitoring platform can help reveal where and when electricity is being used.
Improving the Building Fabric to Reduce Energy Demand
After identifying the key sources of heat loss, the next sensible step is to improve the building envelope. By improving insulation, glazing and controlled ventilation, less energy is required for maintaining comfortable conditions indoors, providing a better energy efficient building base before upgrading the heating system or renewable energy technology.
Insulation Upgrades for Better Thermal Performance
Insulation reduces the rate of heat flow from roofs, walls and floors, keeping an energy efficient building warmer in the winter and preventing unwanted heat gain in warmer seasons. Depending on the type of construction, the most suitable measures are loft insulation, cavity wall insulation (if suitable), or internal or external wall insulation in older solid-wall properties. Continuous thermal performance and avoiding moisture issues should be the top priority. Better insulation first can also lead to lower subsequent heating-system requirements, so the heating systems installed after the insulation will better fit the building's lower heating demand.
High-Performance Glazing and Draught Reduction
Windows and doors may be a source of conductive heat loss and/or draughts. Therefore, double or triple glazing, high-performance frames, and good seals can enhance a building's energy efficiency and make rooms more comfortable at a lower heating setting. Smaller uncontrolled gaps around doors, windows and appropriate service penetrations can be remedied by draught-proofing at relatively low cost. But these measures should be part of the overall building fabric concept and not stand alone. If glazing is upgraded but the biggest heat loss parts within the roof/wall are not addressed, it may not provide as much benefit.
Airtightness and Suitable Ventilation
While more airtightness may minimise uncontrolled air leakage, energy efficiency in buildings should not be compromised by a lack of healthy ventilation. Indoor pollutants and water vapour are produced through moisture, cooking, bathing and daily activities, requiring an adequate means of escape to the outside. Ventilation can be provided by background vents, extract fans, or more elaborate mechanical systems, depending on the property. It directs air in and out and prevents uncontrolled seepage through the structure. A balanced approach can minimise heating losses and maintain indoor air quality, reducing the risk of condensation and enhancing the long-term performance of the building fabric.
Improving Heating, Cooling, Lighting and Equipment Efficiency
While a more robust Building Envelope reduces the energy needed for comfortable conditions, much of the building's future energy use is still dependent on the systems used within the building. The efficiency of heating, cooling, lighting and equipment, therefore, extends the work already done on the fabric and helps to reduce the demand for energy efficient buildings without sacrificing comfort or function.
Efficient Heating and Cooling Systems
Sizing of the heating and cooling systems should be based on the buildings actual need and not on historic equipment sizing alone. Used with the right controls, proper commissioning, and an effective building envelope, efficient boilers, heat pumps, and modern HVAC systems help lower energy consumption. If you have a larger property, zoning can eliminate the heating or cooling of unused zones. Increasing a building's energy efficiency also requires maintaining equipment such as filters, pumps, heat exchangers, and controls, which must continue to function as designed. There may also be reduced demand for insulation, which can help accurately size replacement systems rather than automatically replacing equipment with a similar size.
LED Lighting, Occupancy Controls and Daylight
Energy efficiency in buildings can be enhanced even in areas such as lighting without much structural modification. Switching from older lamps to LEDs helps lower electricity demand; generally lamps will last longer and other lamps that may be installed in unoccupied rooms can be avoided using occupancy sensors. In offices, corridors, and communal areas, daylight controls can switch off artificial lighting when they detect sufficient daylight. Efficient fittings and sensible control zones are most effective, not one overall schedule. This makes lighting energy use more responsive to the presence of people and available daylight.
Efficient Appliances and Electrical Equipment
Smaller electrical appliances, office equipment, pumps, motors, and other electric loads can make up a large portion of total building consumption, especially if the equipment runs for long periods. Efficient replacements help, but so does operational behaviour. Automatic shutdown settings, standby management and scheduled operation can minimise unnecessary usage without compromising necessary services. Check electricity consumption for unusual levels or equipment operating outside the normal time frame. Energy-efficient buildings can be made more efficient by both choosing better equipment and controlling its use.
Smart Controls and Energy Management
Once the building fabric and major equipment are organised and effective, smarter controls can improve building management by minimising waste from poor timing or unnecessary use. This is where smart building energy efficiency can be put into practice: sensors, monitoring software, and management systems can adjust to occupancy, schedules, and changing demand rather than relying solely on set manual controls.
Sensors and Automated Building Controls
Sensors can improve building energy efficiency by making heating, cooling, lighting, and ventilation more responsive to actual conditions. Occupancy sensors can save energy in unoccupied rooms, and temperature, humidity, and daylight sensors can ensure equipment is used only when needed. Automated zoning can help eliminate unnecessary conditioning of whole floors or departments in larger buildings. It's not automation for automation's sake; it's about better aligning energy use with actual demand. With proper settings, controls can consequently minimise unnecessary usage, while still allowing building occupants to use each system independently.
Building Energy Software and Consumption Monitoring
Building energy efficiency software can make meter readings and equipment information more transparent, showing how the building uses energy over time. Dashboards can show things like unusually high overnight consumption, seasonal spikes, or equipment operating outside normal hours. Regular monitoring also helps owners ensure previous efficiency improvements are delivering the hoped-for results. Home energy monitors can also provide a similar view of electricity-use trends within the home for smaller properties. The most effective monitoring systems highlight actionable trends rather than collecting large volumes of data.
Building Energy Management Systems
An energy efficiency building management system (BMS) can manage multiple building services on a single control, such as heating, ventilation, cooling, lighting and selected electrical loads. This is especially beneficial for commercial or larger mixed-use buildings where separate systems might otherwise run independently. A BMS can be programmed with schedules, react to sensor data, and identify issues or inefficiencies in operation. But effective building energy efficiency still requires good commissioning and sensible control strategies. Even poorly programmed automation can waste energy, so it is important to review settings when occupancy and building use change.
Retrofitting Existing Buildings for Better Energy Performance
Many of these existing buildings were built before today's efficiency standards, and improving efficiency is typically a coordinated retrofit of multiple upgrades. The best way to do this is to identify the most vulnerable parts of the building, prioritise actions by impact and cost, and then list the improvements in sequence so subsequent heating or control improvements can be designed to meet a lower energy need for the building.
Energy Audits and Upgrade Priorities
An energy audit is a systematic first step toward building retrofits for energy efficiency. It can evaluate insulation, glazing, heating systems, lighting, controls, electricity usage and more to determine where the biggest losses lie. The results can be used to prioritise problems and improvements for owners to know which ones are more critical and which ones are not cost effective to spend a lot of money on. This process can be supported by monitoring actual consumption, which provides evidence of demand increases and the contribution of different systems. Having a clear baseline also makes it easier to assess how much energy is being saved as a result of the work done.
Phased Retrofits and Budget Considerations
Not all complete retrofits have to take place at once. Owners can phase work to control budgets while still improving building energy efficiency in a logical sequence. Some fabric characteristics (e.g., insulation and draught reduction) are frequently evaluated before replacing major heating equipment because they can change the capacity the new system must meet. Then, controls, lighting and equipment upgrades can be planned based on the remaining useful life and potential savings. Another consideration of a phased plan is to avoid future rework, for example, equipment that is too large to be used when significant fabric improvements are made.
Combining Fabric, Heating and Control Improvements
In most cases, the best retrofit outcomes are achieved when the building shell, heating system, and controls are treated as one, not three distinct projects. Improved insulation reduces the amount of heat needed, more efficient heating equipment delivers reduced heat demands more efficiently, and smart controls help prevent unnecessary operation. This whole-building approach can improve energy efficiency in buildings by reinforcing each other. It also provides a much more robust basis for future renewable-energy investments—after reducing consumption levels, and understanding the new energy footprint, solar generation and battery storage can be designed specifically for the building's new and more efficient energy profile.
Energy Efficiency Strategies for Commercial Buildings
While the principles for making homes more energy efficient are the same as those for making workplaces more energy efficient, commercial buildings may have larger systems and more diverse, flexible occupancy schedules, which can have a greater impact on energy consumption. For offices, retail stores and other commercial buildings this means that the efficiency of equipment is not the only issue to be taken into account, but also how building services react to actual building uses during the working day.
HVAC, Lighting and Equipment Loads
In commercial buildings, HVAC systems can be a significant component of energy-efficiency performance, especially if used throughout a large building or in a frequently used area. There's also demand from lighting, computers, refrigeration, lifts, and other equipment. Increase efficiency – include the assessment of whether systems are properly sized and maintained and controlled or whether new systems need to be installed. Selecting energy-efficient equipment and appliances can lower individual loads, and controlling equipment can prevent multiple high-load pieces of equipment from running concurrently.
Occupancy and Operational Schedules
Commercial buildings typically do not require the same amount of heating, cooling or lighting during each hour of the day. Occupancy schedules can therefore significantly affect energy efficiency in commercial buildings. Equipment can be scaled back during non-business hours when equipment needs permit, and meeting rooms, offices, and communal spaces can be conditioned based on actual use. This is especially significant, as reduced consumption can affect overall electricity costs as well as peak demand. Companies looking at energy costs in general can also see how UK business electricity prices relate to their operations.
Energy Audits, Commissioning and Optimisation
Regular audits determine whether efficiency measures are still delivering the desired results as usage patterns change with occupancy, equipment, and operating hours. Commissioning ensures that HVAC, controls, sensors, and other building services are working as designed, and optimisation helps remove inefficient settings before they become ingrained habits. A properly designed energy management system can aid this process by unifying consumption and control information. Thus, good building energy efficiency services should aim to improve performance, not just deliver one-off compliance exercises.
From Reducing Energy Demand to Smarter Energy Supply
After the non-essential electricity usage has been eliminated via the appropriate fabric, the efficient equipment and smart controls, a much more clearly defined profile of the electricity used by the building emerges. Then we can think of solar generation and battery storage in terms of around the remaining demand and not around avoidable consumption. This sequencing can help avoid oversizing and ensure that the investment in renewable energy is more closely aligned with the property's actual use.
Electricity Demand Guiding Solar and Battery Storage Planning
The type of solar and batteries needed will vary depending on the electricity's use and usage volume. Daytime loads, evening demand, seasonality, and future equipment influence how much solar electricity can be used directly or stored for later use. Therefore, a post retrofit examination of consumption provides a better foundation for system design compared to older bills prior to retrofit. Buildings considering storage may also explore how solar panels and battery storage complement one another before determining the balance between generation and storage.
EcoFlow STREAM 5000 for New Solar and Storage Setups
Where a building has a demand reduction and assessment, STREAM 5000 can be used in a coordinated new solar and storage installation for suitable buildings without an existing solar system. With 5,024Wh battery capacity, 5,000W PV input, and 3,000W AC output, it can be expanded to accommodate future growth. Thus, it is relevant for building solar generation and battery capacity, but not for adding solar generation and battery capacity to an inefficient building.
EcoFlow STREAM 5000
5.24kWh energy storage capacity for household energy management. Supports up to 4000W PV input for a professionally planned solar installation. Provides up to 3000W off-grid AC output for supported off-grid operation. Intelligent Mode+ manages stored and generated energy according to household demand. Compact 45.4kg design reduces the space required for installation. Expandable up to 90kWh if household storage requirements increase later.
EcoFlow STREAM AC 5000 for Existing Solar Systems
If a property already has rooftop PV, then EcoFlow STREAM AC 5000 is a more suitable option for the retrofit application. It can increase the amount of energy stored in the battery by 5,024Wh, so it can save electricity generated by the solar power generation system during the day for the next day's electricity demand rather than disposing of it. This is especially important after initial efficiency changes have reduced unnecessary demand as the battery can then be designed to the building's new energy use pattern instead of the building's previous energy use.
EcoFlow STREAM 5000 AC
Designed for households that already have solar panels and want additional storage capacity. Provides 5.24kWh of battery storage for retaining surplus solar electricity for later household use. Supports 800–3000W grid-connected AC output. Local Mode allows continued system operation when internet connectivity is unavailable. Intelligent energy management coordinates existing solar generation, battery storage and household consumption. Can operate as an extended storage device within an existing photovoltaic installation.
Building energy efficiency is best accomplished in a series of steps. Preparing to reduce heat loss, making the building airtight, upgrading heating and lighting, and adding larger energy investments are all supported by smaller investments in better controls and consumption monitoring, which reduce unnecessary energy demand. Audits, commissioning and operational schedules can further fortify long-term performance for commercial properties.
With reduced and better-understood building demand, solar generation and solar storage can be planned accurately. EcoFlow STREAM 5000 is best for homes and buildings that are building a new solar-and-storage system, while EcoFlow STREAM AC 5000 is best for homes and buildings with existing solar that are looking to add battery storage and utilize more of their solar electricity later in the day.
Which upgrade usually makes the biggest difference to building energy efficiency?
No single upgrade is the greatest improvement for all properties. The priority depends on where energy is being lost.
  • Poorly insulated buildings may benefit most from fabric upgrades.
  • Inefficient heating systems can create substantial ongoing demand.
  • Lighting and controls may offer quicker savings in commercial properties.
An energy audit can include an analysis of which actions are likely to have the biggest impact on building energy efficiency before money is spent.
Can older buildings become highly energy efficient without major reconstruction?
Yes, Often, older buildings can be improved significantly in terms of energy efficiency without a complete reconstruction. These can include loft or wall insulation, draught reduction, improved glazing, better heating controls, and more efficient equipment. Depending on the building's construction, and on heritage issues and moisture behaviour, the appropriate approach will differ. A phased retrofit can be especially helpful as the most critical vulnerabilities can be remedied first and other changes can be avoided that may cause unwanted ventilation or condensation issues.
How often should building energy data be reviewed?
Buildings should monitor energy data at regular intervals to detect variations in energy use and unusual patterns of equipment operation.
  • Monthly reviews can reveal broader seasonal trends.
  • Weekly monitoring may help larger commercial buildings spot unusual loads sooner.
  • Major upgrades should be followed by before-and-after comparisons.
How often this should be done will depend on the property and the monitoring system in place, but the data is of little or no value unless it is used to discover what can be done to improve efficiency in practice.
Can battery storage improve a building’s energy efficiency rating?
Not automatically, Battery storage primarily changes how electricity is stored and used, rather than directly improving insulation or reducing heat loss or appliance energy consumption. The impact of a battery on a formal energy-performance rating varies by methodology and system configuration. Typically, its practical benefits relate to higher solar self-consumption and a shift in the electricity used, with some import from the electricity grid avoided. Therefore, instead of opting for battery storage to achieve a higher rating, consider building-fabric and heating-efficiency improvements.
Should battery storage be installed before or after efficiency improvements?
It makes sense to consider and minimise unnecessary demand first in many cases before deciding on battery storage capacity.
  • Fabric upgrades can lower heating and electrical demand.
  • Efficient equipment may change the building’s consumption profile.
  • Post-retrofit data can support more accurate battery sizing.
While storage size can still be planned with a broader building renovation, it may be best to reduce the risk of over-investing in storage by basing it on the building's post-efficiency energy use.
