Home Coffee Machine Electricity Bill: How Much Does Your Coffee Maker Cost to Run in 2026?
The UK's energy prices are still likely to be of concern for many homeowners, making it important for you to have an understanding of how much household coffee machine electricity bills. This guide will assist you in calculating the total amount of electricity consumed when using your coffee machine, and provide you with a comparison of how much electricity is consumed by other common kitchen appliances.
In addition, various solutions will be provided regarding ways in which you can save on your coffee machine electricity consumption. Homeowners who want to reduce energy costs even more should consider smart power options to enhance the efficiency of their homes and promote wise energy consumption.
Understanding Household Coffee Machine Electricity Bills in 2026
In 2026, energy costs will affect families' budget for food purchases on a large scale. Therefore, homeowners in the United Kingdom will have become conscious of how much it costs to run each appliance at home.
For instance, the cost of running a single cup coffee brewer will be relatively inexpensive; however, if you consistently produce multiple cups within the same 24 hour period, the cumulative costs of using one or more coffee brewers can add up quite fast. Knowing how much electricity your different types of coffee makers use is very important for everyone who wants to reduce their electricity bill as low as possible when operating these machines.
Coffee Machine Electricity Consumption Explained
The amount of energy consumed by coffee machines varies based on their wattage, how often they are used for brewing coffee, and any settings that are activated when the machine is in standby mode. For coffee makers in most homes, the majority of electricity used is during the process of heating; some coffee machines continue to require energy when they are not being actively used or are in a “standby” state. Homeowners can determine where to use energy more efficiently by familiarizing themselves with their coffee machine electricity consumption.
In order to understand the impact of energy consumption on coffee makers, we also need to look at how much of an overall impact coffeemakers have on total energy consumption.
Do Coffee Machines Use a Lot of Electricity?
Coffee makers usually rank lower on the list of home appliances that consume energy. Filter coffee makers generally consume less energy than espresso and bean-to-cup coffee makers, and together they contribute a small portion of our monthly energy expense.
The amount spent on energy for a coffee maker will depend on the model purchased and how frequently the coffee maker is used.
As a transition, when viewed alongside other kitchen appliances, coffee makers can have higher energy consumption.
Does a Coffee Machine Use a Lot of Electricity Compared with Other Kitchen Appliances?
Compared to kettles, microwaves, ovens, and dishwashers, most coffee machines utilize a relatively low amount of electric energy. The coffee brewing cycle usually lasts for only a few minutes in total with most coffee makers, whereas appliances such as electric ovens and dishwashers typically operate for much longer time periods. Therefore, even though coffee makers do use heat to produce coffee, they tend to have less of an impact on total household energy use than other electric appliances.
Understanding the factors of how to correctly determine the energy consumption of the coffee maker is important because it will help you to better understand how various variables will influence your costs.
Factors That Affect Coffee Maker Energy Usage
The consumption of electricity by a coffee maker can be determined by many factors. Knowing about these factors can help a household to reduce its energy bill and increase the efficiency of a beverage maker.
  • The more watts the coffee maker has, the more energy it will typically use while brewing coffee.
  • The more times you brew coffee during the day, the more energy your coffee maker will use.
  • Coffee machines that have espresso settings, bean-to-cup settings or built-in grinder parts tend to use more power than traditional filter-style coffee makers.
  • If you leave your coffee maker turned on in-between uses, it will continue to add to your energy bill even if you are not brewing any coffee.
  • Models that have hotplates to maintain the temperature of brewed coffee will also continue to draw electricity after brewing has been completed.
  • Any additional features associated with your coffee maker, such as milk frothing options, automatic cleaning cycles or digital displays, may also contribute to increased energy usage.
  • When brewing larger servings of coffee or stronger coffee, additional energy and heating time will be required.
  • A clean and well-maintained coffee maker will operate efficiently and use less energy.
  • In the UK, the current rise in electricity prices will directly affect the operating cost of using a coffee maker.
The article will represent a detailed analysis of the total energy consumption of a coffee maker and provide an estimated average cost to UK households in 2026.
How Much Electricity Does a Coffee Machine Use? Daily, Monthly, and Annual Costs
Many coffee lovers have asked the question of how much it costs to operate a coffee maker when they brew their daily cup of coffee. While energy usage per brew is quite low, these usages compound over weeks and months and can help households figure out better ways to control electricity consumption in their coffee maker.
How Much Electricity Does a Coffee Machine Use Per Cup?
Most coffee makers in the home use between 800 and 1500 watts to brew. Coffee brewing time is also typically under 5 minutes, so the amount of electricity used per cup is still relatively small. It will be comparatively inexpensive for an individual cup regardless of which coffee machine you purchase or what your local electricity prices are.
However, if households brew multiple cups a day, the costs will eventually add up over time.
When looking beyond individual cups of coffee brewed to make a better determination of what the true costs will be on the household coffee machine electricity bills.
Monthly and Yearly Household Coffee Machine Electricity Bills
Households in the UK who use coffee machines on a daily basis will see their electric bill increase only modestly. A basic filter coffee maker has an estimated cost of less than £1 per month to operate, while premium espresso or bean-to-cup machines with grinders and milk frothers may cost several pounds per month.
While these costs are relatively small compared to large appliances, they still add up and contribute to your total household energy costs for the year.
Electricity Costs to Run Commonly Used Home Coffee Machines
Coffee Machine Type
Estimated Daily Cost
Estimated Monthly Cost
Estimated Annual Cost
Filter Coffee Machine
£0.02–£0.03
£0.60–£1.00
£7–£12
Pod Coffee Machine
£0.03–£0.05
£1–£1.50
£12–£18
Espresso Machine
£0.05–£0.08
£1.50–£2.50
£18–£30
Bean-to-Cup Machine
£0.07–£0.12
£2–£4
£25–£45
Note: These are general estimates and use the average daily use. Electricity costs are calculated using the average UK energy unit prices as determined by the UK energy regulator Ofgem and can change between regions and tariffs.
The running costs will vary significantly depending upon the energy prices at the time, so it's helpful to consider electricity prices specifically for UK householders in 2026.
How Much Electricity Does a Coffee Machine Use UK Homeowners in 2026?
In UK households, average electricity prices will still be determined by the Ofgem energy price cap – currently £25 to £26 per kilowatt-hour. As a result of this price cap, average electricity costs approximately £2.00 per month for coffee makers. However, a lot of coffee makers (and other kitchen appliances) have higher energy usage than average due to being left on for long periods or not used often enough to maintain their left-on status.
Fortunately, selecting the best model can significantly reduce both the ease of use and the electrical usage for kitchen appliances like coffee makers.
Kitchen appliances are not all equally energy-efficient; some coffee maker models may inherently use less electricity than others.
The average electricity unit price for households on Direct Debit from 1 July to 30 September 2026 is 26.11 pence per unit of electricity, Ofgem says. The above cost estimates are based on this rate.
Espresso Machines vs Pod Machines vs Bean-to-Cup Models
The power requirements and energy use of each type of coffee maker varies:
  1. Espresso makers produce cafe-style coffee but require large amounts of heat (and therefore electricity) to operate.
  2. Pod-type coffee machines are quick and offer great convenience, but generally use only moderate amounts of electricity to make each cup of coffee due to the short brewing time.
  3. Bean-to-Cup coffee makers provide the most features (having both an integrated grinder and an integrated milk system) and therefore tend to use the most energy.
Ultimately, the best option for you will depend on an evaluation based on the trade-off between convenience, quality of coffee, and energy efficiency.
Although coffee makers do not account for the largest percentage of your total monthly electricity bill, there are a number of simple ways to reduce energy consumption from them even further and thus help to maximize your savings over the course of 2026.
Typical Electricity Costs for Popular Home Coffee Machines
Based on the UK Electricity Unit Rate published by Ofgem, the following table displays running costs for multiple coffee machine types; these estimates will be different from your actual costs based on power usage, frequency of your brew, whether you leave it on standby and what region you live in.
Coffee Machine Type
Typical Power Rating
Estimated Cost Per Day
Estimated Cost Per Month
Estimated Cost Per Year
800–1,000 W
£0.02–£0.03
£0.60–£1.00
£7–£12
Pod Coffee Machine
1,000–1,300 W
£0.03–£0.05
£1–£1.50
£12–£18
Espresso Machine
1,200–1,500 W
£0.05–£0.08
£1.50–£2.50
£18–£30
Bean-to-Cup Machine
1,400–1,800 W
£0.07–£0.12
£2–£4
£25–£45
Notes: These estimates are based on the average unit rates for electricity published by Ofgem as part of the Energy Price Cap. These figures are based on average per day household consumption and are provided as a guide only. The actual cost of electricity will vary from area to area, provider to provider, payment method to payment method, and user to user, with usage frequency.
Smart Ways to Reduce Coffee Machine Energy Costs
While coffee machines make up just a small portion of the total household electricity consumption, implementing some energy efficiency practices can create significant savings over the long term. By utilizing efficient brewing methods as well as tracking usage of appliances, UK homeowners have multiple ways to reduce their electric costs for coffee machines. Simple changes can assist you in reducing your power bill while increasing the amount of fresh coffee that you can enjoy at home.
Following a few practical techniques to improve efficiency is an easy way to reduce unnecessary energy usage.
Energy-Saving Tips for Home Coffee Machines
You do not have to make drastic changes to reduce how much energy your coffee machine uses; everyday behaviours can decrease electricity waste and keep your power bill low.
You can reduce the amount of electricity consumed by using your coffee maker by doing the following:
  • Turn off the machine as soon as you're done with it instead of leaving it on standby.
  • Make use of the auto shut-off feature built into the machine wherever possible.
  • Only brew as much coffee as you need at one time.
  • Descale and clean the machine regularly to keep it running at optimal performance.
  • Avoid keeping brewed coffee warm on a hotplate for long periods of time after brewing.
  • Use energy-efficient coffee makers that have programmable settings.
  • Unplug your coffee maker if you won't be using it for long periods of time.
When combined together, all of these small changes can add up to substantial savings throughout the year.
If you're looking for even more insight into your energy usage as a homeowner, consider using smart monitoring devices to have even greater control over your energy.
Using the EcoFlow Smart Meter to Monitor Appliance Electricity Consumption
EcoFlow Smart Meter
Real-time monitoring of household energy usage Electricity monitoring used by each appliance Works within the EcoFlow Stream Smart Ecosystem. Allows users to identify which appliances are using the most energy (e.g., coffee makers). Provides users with information to make better energy saving decisions.
Managing Household Coffee Machine Electricity Bills More Efficiently
When we think about how to manage the electricity used by our household coffee machines, it’s not about taking away our daily coffee rituals but rather about being more energy smart. There are a number of factors that can help reduce your coffee machine’s electricity costs, including choosing an efficient coffee machine and avoiding extra power used in standby mode as well as keeping up with regular maintenance and utilizing smart monitoring solutions.
As energy prices change over the next several years, it will be valuable for homeowners to utilize these strategies to enjoy their preferred drinks while keeping household budgets under much better control.
Having a clear understanding of how much electricity a coffee machine uses along with practical ways of reducing costs.
Pairing Your Home with the EcoFlow STREAM Ultra X for Smarter Energy Management
3.84kWh high capacity LFP battery 2300W AC output (on-grid) 4 MPPTs with maximum of 2000W from solar panels AI-based energy optimization system Designed to allow up to 23kWh of additional capacity if required. Can work with smart meters and changing tariff rates.
Recommended EcoFlow STREAM Series Solutions for Energy-Conscious Homes
In 2026, smart homes are putting more focus on energy efficiency and control versus convenience. The EcoFlow STREAM Series can help households manage their energy usage better by reducing energy waste and reducing electricity bills through the use of advanced energy storage and optimization technologies.
  • EcoFlow STREAM Smart Energy Hub
  • EcoFlow STREAM Battery Storage Unit
  • EcoFlow STREAM Smart Meter Integration
  • EcoFlow STREAM Solar Compatibility Module
  • EcoFlow STREAM AI Energy Manager
  • EcoFlow STREAM Mobile App Control System
Each of these solutions integrate seamlessly to provide an intelligent, efficient, and cost-saving energy ecosystem that can be especially helpful for managing appliances such as coffee machines and other kitchen equipment that consume significant amounts of energy.
Now that EcoFlow STREAM series solutions have been introduced into the market, it is time to discuss how homeowners will be able to implement them into their day-to-day life for coffee machine use in a manner that is more efficient and environmentally friendly from a financial perspective.
Why Smart Energy Monitoring Matters for Modern Coffee Lovers
Coffee culture has shifted to incorporating more than just flavour; it's now also focused on efficiency, awareness and making smarter choices in life. So with the rising cost of electricity in the year 2026, even small appliances we use, like coffee machines, have a huge impact on how much we spend on our families' household utility bills every month without being super obvious about it.
By using smart energy monitoring solutions, coffee drinkers can find out the precise amount of energy they're using to brew their coffee customers as well as identify exactly where they can save money.
Benefits of Real-Time Energy Tracking
Real-time energy tracking provides homeowners with a clear picture of their energy consumption in real-time, rather than after they receive their electricity bill.
  • Displays the instant use of coffee machines and kitchen appliances.
  • Aids in determining energy loss due to "Standby" or "Overuse"
  • Promotes more sensible alcohol consumption practices using real consumption information
  • Helps to make the comparison between the efficiency of various coffee makers easy.
  • Implements cost control measures by associating the cost of the electricity used with usage
  • Makes people aware of the energy-sapping activities in the kitchen
How EcoFlow STREAM Series Supports Sustainable Living
The EcoFlow STREAM line goes above and beyond the needs of monitoring energy use by allowing you to take actionable steps with that information.
  • Smart meters combined with energy storage and automation allow users to see how much power appliances pull from the grid and when to use certain appliances to cut down on peak demand charges.
  • Integrated with solar power can use cleaner renewable energy sources.
  • Distributing energy from a home’s sources is an intelligent way to reduce dependence on the grid.
  • Streamlines the path for homes to evolve into low carbon sustainable living.
  • Provides app-based access to view all aspects of energy consumption.
Building a More Energy-Efficient Kitchen in 2026
In 2026, a modern kitchen emphasizes efficiency and intelligent management, extending beyond just appliances.
  • Smart coffee machines can reduce unnecessary "standby consumption".
  • Energy monitoring tools help to create better everyday use.
  • By optimizing brewing times, electricity costs can be reduced.The electricity bill is reduced by saving electricity in an efficient brewing schedule.
  • With smart systems such as EcoFlow STREAM, energy balance is automatically achieved.
  • Sustainable kitchens are about waste minimisation and output maximisation.
We are ready to summarize our main points from this article and answer some of the most common questions many UK homeowners ask.
It's no longer enough to simply accept that knowing how much electricity a coffee machine uses is an unnecessary piece of information. It's now a key factor in determining your household coffee machine electricity bills and long-term sustainable behaviour. Most individual coffee makers do not draw significant amounts of power; however, when they are used regularly throughout the day in busy homes where many cups of coffee are produced, their total energy consumption can be considerable.
In addition, when considering the standby energy used by different types of machines, knowing which ones are more energy efficient may help you make an informed decision about your energy usage and what type of appliance you should purchase.
In addition, exploiting smart energy tracking assists you in reducing your energy usage. With devices such as the EcoFlow Smart Meter, you can track the actual amount of electrical energy your coffee maker uses in real time and, consequently, identify energy waste, use it more efficiently, and create a more sustainable kitchen routine.
Start controlling how much electricity a coffee machine uses in the UK today! Track its energy usage to help you reduce your overall energy usage for each cup of coffee brewed from your machine.
How much electricity does a coffee machine use per day?
An average coffee machine uses between 0.1 and 0.5 kWh per day based on the number of cups brewed and whether it is kept on standby; those equipped with warming plates or self-grinding typically draw more power.
How much electricity does a coffee machine use in UK households on average?
Most UK households use about 30-120 kWh a year, depending on their frequency and type of machine in their home. Daily use is fairly small but can escalate with multiple users or all-day standby.
Do coffee machines use a lot of electricity compared with kettles?
Not really. Kettles will typically consume more power each time they are used, as they boil the water at high wattage and quickly. However, coffee machines may consume more energy in the long run; coffee machines consume energy over time due to having warming plates and being in standby mode, which draws on the power grid while your coffee is not being brewed.
Which type of coffee machine is the most energy efficient?
Manual drip coffee makers and single-serve pod coffee makers are usually the most energy-efficient types of coffee makers because they only heat the required amount of water. Espresso makers with a boiler, or coffee makers that are "always on" consume more electricity.
Can the EcoFlow Smart Meter help track coffee machine electricity consumption?
Yes! You can use the EcoFlow Smart Meter to monitor your coffee machine's energy use in real-time and on a daily basis. Monitoring your coffee maker's energy use can help you to find out where your coffee machine is consuming the most energy, thus allowing you to reduce energy waste and improve overall kitchen energy-efficiency.
Home Solutions
