Storm to Hit Britain This Weekend and How to Prepare Your Home
When forecasts suggest a storm could hit Britain this weekend, it should be considered what the risks are in the household, not just the forecast. Strong winds, heavy rain and low temperatures may have an impact on travel, electrical and other local utilities and daily activities, and an extended power outage could take a toll on heating controls, refrigeration, lighting and communications.
By staying on top of the weather, households can take time to charge items, prepare supplies for emergencies, and identify which items require backup power. This guide shows you how to winterize your home ahead of bad weather, what to do with critical loads when the power goes out and how to determine or arrange supplemental power storage during extended winter outages.
Winter Storm Forecasts and Household Preparation
As a storm gets closer, weather forecasts can shift significantly, so get the information right before you start preparing your home. Early monitoring also allows for more time to prepare before travel will be challenging and before electricity networks are impacted.
Checking Winter Storm Warnings Before Conditions Worsen
A winter storm warning can indicate that severe weather may create disruption within a particular area or time period. Households should be aware of the intensity of the wind, rainfall/snow/ice, temperature and the time of the most severe conditions.
Warnings work best when they stimulate effective preparedness. Charging phones, testing torches, moving loose outdoor items and ensuring necessities are readily available can be done before the weather gets worse.
Weather Forecast Updates and Changing Storm Conditions
A winter storm forecast is not a guarantee. The track, intensity and timing shown in this graphic reflect the current forecast and can change as new weather data is incorporated; the earlier forecast may not represent the conditions anticipated later in the week.
Earlier checks of updates more closely to the event can help households make necessary adjustments to plans. If the weather forecast winter storm intensifies, more preparation may be warranted, especially if strong winds or cold temperatures could exacerbate travel and/or electric power issues.
Preparing the Home When Severe Weather Is Expected
A winter storm can impact the home without causing any direct damage to the building. The cold weather, lack of power, and restricted movement may make it harder to access food, charging and other necessary appliances.
Households can test their phones and batteries, group torches and cables together, inspect the contents of their refrigerator and freezers and arrange equipment to be easily accessible before conditions deteriorate.
The goal is not to take for granted that a power outage is going to occur, but rather to minimize the disruptions if it has.
How a Winter Storm Can Disrupt Everyday Home Life
Winter storms can disrupt life, even if they don't directly impact the home. Significant winds and colder weather, along with interruptions in power supply, can impact heating, communication and use of daily appliances, particularly if the outages last for hours.
High Winds and the Risk of Local Electricity Disruption
Winter storms, with their high winds, can cause problems with overhead lines, downed branches or other issues with the electricity system. Some homes may only lose their power for a short time, others may lose power until damaged infrastructure has been inspected and repaired.
The length of time it takes to get essentials working again may be hard to estimate, and households should get ready in advance for use of essential devices; don't wait for electricity to go out.
Cold Weather Increasing Heating and Household Energy Needs
A winter storm warning may also be accompanied by a drop in temperature, which makes it even more important to have heating and other critical household functions. Even houses with gas heat could rely on electrical power to run boilers, pumps, thermostats or control devices.
The cold weather can thus be more disruptive to a power outage than the power outage itself, if it occurs at a time when the weather is colder. As temperatures drop, it may be more important to conserve available backup electricity for heating controls, communication and other priority equipment.
Communication Lighting and Essential Devices During a Power Cut
Phones, rechargeable light and internet devices keep households connected and informed during a winter storm power cut. These devices can help them stay updated on the weather, instructions on how to restore the network, and emergency tips.
A practical solution for managing a power cut in the UK is also to have a way to communicate, light up and otherwise take care of basic needs when the grid is down.
Once an outage has been ongoing, focus may then turn to messages of protection of food and other appliances requiring power to be continuously maintained.
Protecting Food and Essential Appliances During Storm Outages
Refrigeration and other continuous household loads gain in importance as a winter storm outage continues. Food safety, priorities and careful application of stored electricity can all contribute to the homeowner's ability to cope with several hours of no mains electricity.
Refrigerators and Freezers During Longer Electricity Interruptions
If the power outage is expected to last more than a few hours, try to keep refrigerator and freezer doors shut as much as possible. If they are opened frequently they may lose their coldness and reduce the holding time of the food at a safe temperature.
If the outage persists, households should determine the safety of the food instead of just looking at the food. Understanding the duration for which food will remain safe in the refrigerator if the power goes out can be helpful in prioritizing the use of food and deciding which foods are safe to eat or discard.
Prioritising Essential Household Appliances When Power Is Limited
If a winter storm warning becomes a long duration power outage, some appliances will need more priority than others. Items such as refrigeration, heating controls, communication equipment, lighting or necessary personal equipment may need to be given priority over entertainment or convenience equipment.
Prioritizing the load helps to determine which loads will be placed on backup power. The type of appliances in use also plays a role, as high-consumption appliances have the potential to diminish the available runtime faster than phones, routers or LED lighting.
Reducing Unnecessary Electricity Use During a Longer Outage
In a winter storm, stored electricity should be used to serve the most important loads when the storm lasts for an extended period. Do not operate unnecessary equipment at the same time and turn off equipment that can be turned off.
There are high-wattage cooking or heating appliances that use up battery power rapidly, and before getting one of these, households should be aware of their needs and battery consumption. Reducing avoidable consumption can increase the time available for refrigeration, for communication and other necessary equipment. With priority loads out of the way, the next step is to get backup power in place before the storm starts to cause disruption.
Preparing Home Backup Power Before a Winter Storm
After essential household loads have been identified, the focus of preparation should be to ensure that batteries, cables and back-up equipment are prepared before a winter storm impacts local electric power. If possible, planning ahead is more effective than trying to organise devices after the power has been lost.
Charging Phones Torches and Portable Batteries in Advance
Prior to an incoming winter storm warning, fully charge phones and rechargeable torches, power banks and any portable backup batteries. Special attention should be paid to communication and lighting equipment, as they may be required at a time when the mains power is out.
Pre-charging smaller devices as well helps to conserve larger backup batteries for devices that use more power.
Checking Appliance Wattage and Backup Runtime Needs
The first step to a home backup power plan is to consider appliance watts. Identify the priority equipment such as refrigeration, routers, and lights and controls, and check the rated power to estimate the number of hours the equipment is required to run.
The amount of time is not a function of battery capacity. Various causes such as conversion losses, compressor cycling, and multiple appliances operating simultaneously can shorten the duration of stored electricity.
Keeping Essential Cable Chargers and Power Accessories Accessible
Having cables, adapters, extension leads appropriate for the equipment being charged and other power accessories in a single location when the weather forecast indicates a winter storm is in the forecast.
Emergency supplies can be prepared concurrently. A 72-hour emergency kit can help your family stay organized and have the necessary items to communicate, light, and other useful items all in one place before bad weather hits.
Planning Backup Electricity for Several Hours or Longer
For a brief winter-storm power cut, a cell phone, light and a router might be the essentials; with a longer outage, refrigeration, temperature controls for the heat, and other appliances could be more critical.
Households should thus prepare for backup power at varying outage times. Using low power requirements first will help to preserve stored energy for continuous loads.
When the load and the amount of time that a household can expect the power outage to last is known, households can consider the choice of portable power in terms of capacity and output.
Home Backup Power for Winter Storm Disruptions
When the critical loads and anticipated outage duration is understood, then home backup power can be selected based on the amount of energy that is stored, as well as the amount of output desired. For lighting, phones and internet equipment, a smaller one might suffice, but if refrigeration and a few appliances are used together, it may be better to opt for a larger unit.
EcoFlow DELTA 3 Plus for Lightweight Essential Home Backup
The EcoFlow DELTA 3 Plus offers 1024Wh of capacity and 1.8KW of AC output for shorter periods of disruption during a winter storm. X-Boost can power compatible devices up to 2,400W and capacity may be boosted to 5kWh if there is a need for backup power in the home.
Due to its relatively small size, it is suitable for smaller devices for essential use like phones, routers, laptops, LED light fittings and some home appliances. In a short interruption of service, this enables larger power usage to be prevented and provides communication and lighting essentials.
1024Wh capacity provides lightweight backup for essential winter household devices. 1800W AC output supports compatible lighting, communication equipment and selected appliances. X-Boost supports compatible devices up to 2400W when required. Expandable capacity up to 5kWh provides flexibility if winter backup needs increase. Multiple charging methods, including AC, solar and vehicle charging, provide alternative ways to restore stored energy. Suitable for phones, routers, lighting and lighter essential loads during shorter winter power interruptions.
EcoFlow DELTA 3 Max Plus for Higher Loads and Longer Runtime
Where a winter storm power cut may continue for longer, the EcoFlow DELTA 3 Max Plus provides 2,048Wh capacity, 3,000W AC output and 6,000W surge output. It can be scaled up from 2kWh to 10kWh, providing families with greater flexibility if they need multiple critical loads to be kept powered.
The extra capacity and output are ideal for refrigeration, lighting, internet machines and other compatible household appliances. This can be helpful if food supplies are a concern and multiple facets of daily living are becoming more critical as the length of the winter storm warning continues.
DELTA
2048Wh capacity provides additional stored energy for longer winter outages. 3000W AC output can support several compatible household appliances simultaneously. 6000W surge output accommodates suitable appliances with higher compressor or motor start-up demand. Expandable capacity up to 10kWh provides greater flexibility for prolonged winter disruption. Smart Output Priority can help preserve available battery energy for selected loads such as refrigeration or Wi-Fi. Suitable for a deep freeze freezer, lighting, communications and several other essential household loads.
EcoFlow DELTA Pro 3 for Extended Backup and Multiple Household Appliances
EcoFlow DELTA Pro 3 offers 4,096Wh capacity, 4,000W AC output and 8,000W surge power for winter storm households looking for long-lasting power. Capacity can be expanded up to 12kWh with compatible extra batteries and X-Boost can power compatible devices up to 6,000W.
This larger capacity version is better suited in situations where refrigeration, communication devices, lighting and a number of other compatible household appliances may require assistance for an extended duration.
EcoFlow DELTA Pro 3
4096Wh capacity provides substantial stored energy for extended winter household backup. 4000W AC output supports multiple compatible appliances and higher combined loads. 8000W surge capability provides additional headroom for appliances with demanding start-up loads. Expandable capacity up to 12kWh can extend backup during prolonged grid interruptions caused by severe weather. Suitable for refrigeration, communications, lighting and multiple household appliances during longer winter outages.
Keeping Backup Electricity Available During a Longer Storm
When a winter storm leaves you without power longer than anticipated, having backup power becomes a "need" to handle carefully. Energy stored should be used to meet basic home requirements and unnecessary energy use should be minimized wherever possible.
Prioritising Stored Power for Essential Household Loads
Refrigeration, heating controls, communication devices and essential lighting typically should be powered first during an extended winter storm power outage, followed by entertainment or convenience appliances.
It also helps to understand what appliances a portable power station can run before an outage occurs. Checking appliance wattage and avoiding several high-demand loads at the same time can help preserve available battery capacity.
Recharging Backup Power Whenever Grid Electricity Returns
Take advantage of temporary electricity coming back on the grid during a winter storm to charge portable power stations, mobile phones, torches, and smaller battery banks.
When restoration is brief, it does not necessarily mean the larger disruption is over, especially if severe weather is occurring in the area. Early charging can replenish a valuable energy reserve in case of another interruption.
Adjusting Appliance Use as Available Battery Capacity Falls
Households should reevaluate what devices they need to run as the stored energy begins to wane. In an extended winter storm warning, less critical loads may be turned off, and electricity may be used for refrigeration, communications, lighting and other critical equipment.
Using appliances only when they are needed can also help to prolong the running time. Some loads, such as some business processes, may not require constant operation, while refrigeration and some home systems might require more frequent support.
With careful energy management, backup power can last a lot longer, helping households to stay ready until power on the grid stabilises and the storm shows signs of abating.
Returning to Normal After the Storm Passes
Once the winter storm is over and electric power is back on, people can slowly resume their normal habits. Focus should be on safe restoration of critical appliances, re-powering backup equipment, and analyzing what went well during the disruption.
Reconnecting Appliances and Restoring Everyday Electricity Use
When the power comes back on after a winter storm, turn on devices one at a time. Appliances that can be restored first are refrigerators, freezers, heating controls, and communication equipment; lower priority appliances can be restored when the electricity source seems to be okay.
Any equipment, plugs or cables that may have been exposed to water, or damaged during the storm or acting strange should not be used until they have been checked out properly.
Recharging Portable Backup Power After an Outage
When the mains supply is working again, refill portable power stations, recharge phones, torches and power banks as soon as possible. A winter storm forecast can sometimes include multiple periods of severe weather, so if a second winter storm occurs, it may be necessary to restore battery capacity to be prepared.
Charging can also be used to inspect the outage cables, adapters and accessories and replace any damaged/broken accessories and adapters, and any missing cables.
Reviewing Home Backup Needs Before the Next Weather Event
Following a winter storm, households can check which items were most critical, how fast their stored electricity was consumed and whether the electricity runtime was what they had expected.
If more energy was used by refrigeration, lighting or communication equipment than anticipated, more capacity or tighter load prioritisation may be necessary in future backup plans. Documenting these observations when the information is fresh will help with preparation for the next winter storm warning.
Besides travel plans, a winter storm can also interfere with daily life at home—when strong winds, plummeting temperatures and outages of your home's power grid disrupt your daily life at home. To be prepared ahead of time, check the forecasts, charge any necessary electronics, store food and prioritize appliances that need to be used can help to make the outage much easier to deal with.
Portable home backup power can provide an extra layer of protection for households seeking to provide power for communication, light, refrigeration and other critical devices when the grid goes down. The appropriate set up should always be determined by the watts of the appliances, how long they will be used, and the extent of the disruption.
How Can I Check Whether a Winter Storm Is Forecast This Weekend?
When Britain is forecast for a storm this weekend, always refer to the latest Met Office forecasts and warnings; do not just rely on headlines. As the system moves closer to the UK, details of the forecast may change.
Pay attention to:
  • the affected regions and expected timing;
  • wind, rain, snow or ice warnings;
  • changes to warning severity;
  • updates issued closer to the weekend.
Regularly monitoring a winter storm forecast provides households with more time to plan travel, charging and home preparedness.
Can Winter Storms Cause Electricity Outages in the UK?
Yes, strong winds during a winter storm can cause localized power outages due to damage to overhead power lines, downed trees that affect equipment and repair work or make it harder to access it.
Not all weather warnings necessarily result in a power loss, and power loss can differ significantly from location to location. But people who live in areas under a winter storm warning can make preparations ahead of time, such as lighting, communication and backup power.
Which Household Appliances Should Be Prioritised During a Storm Outage?
Households should follow the priority of appliances based on safety, food preservation, and essential daily needs during a prolonged winter storm.
Typical priorities include:
  • refrigerators and freezers;
  • heating controls and pumps;
  • phones and internet equipment;
  • efficient lighting;
  • essential personal or care equipment.
When backup power is scarce, the general rule is that high-wattage convenience appliances should be given a low priority.
How Long Can a Portable Power Station Support Essential Home Devices?
Running time is a function of battery size, appliance watts, losses in the conversion and the number of appliances in use at the same time. Phones and LED lighting may require a relatively small amount of power, but refrigeration or higher-power appliances may be able to shorten the duration during a winter storm power outage.
Before bad weather occurs, determine the power requirement for each priority device and allow some margin for error instead of assuming that the battery is capable of its rated maximum power.
What Should Be Prepared Before a Winter Storm Reaches the UK?
Make basic emergency preparations and power needs before weather forecast winter conditions get worse.
Charge phones, torches, power banks and portable back-up units; verify refrigerator/freezer storage plans; store cables and chargers in an easy-to-grab location; tie down loose outdoor items; and determine which household appliances are important to have if the power goes out.
The measures are especially important following advice from the Met Office that Britain is expected to be hit by a storm this weekend, as the best things to do are the easiest to do early, before the wind, rain or cold gets too bad.
Home Solutions
