10 Best Camping Coffee Makers in 2026 for Perfect Coffee Anywhere
Great coffee doesn't have to stay at home. Whether you're deep in the wilderness or parked at a scenic campsite, the right coffee maker can turn any morning into a perfect start. In this guide to the 10 best camping coffee makers in 2026, you'll find everything from compact French press options to portable espresso machines—each designed to deliver rich, satisfying coffee wherever your adventure takes you.
For those who rely on electric coffee makers, portable power stations offer a reliable way to brew anywhere without traditional outlets. They provide clean, quiet energy, making them an ideal companion for off-grid coffee lovers who don't want to compromise on quality.
The 10 best coffee makers for camping
With so many coffee makers on the market, finding the right one can feel overwhelming. To help you decide, we've listed some of the best camping coffee makers below and compared their key features. This makes it easier to quickly evaluate your options and choose the one that best suits your camping needs.
Coffee Maker
Brewing method
Key features
Power source
Best use for
MiiR Pourigami
Pour-over
Collapsible 3-panel stainless steel dripper, packs flat for travel
1 cup
Hot water
Ultralight backpacking and minimalist camping
AeroPress Coffee Maker
Immersion press
Quick brewing, durable plastic design, rich espresso-like coffee
1–3 cups
Hot water
Campers who want strong coffee fast
ESPRO Ultralight Travel Press
French press
Double micro-filter system, insulated body
12 oz
Hot water
Smooth French-press coffee while traveling
GSI Outdoors Ultralight Java Drip
Pour-over
Clip-on drip cone with reusable mesh filter
1–2 cups
Hot water
Backpackers needing a simple brew setup
COLETTI Bozeman Camping Coffee Pot
Percolator
Stainless-steel kettle, durable campfire design
9–12 cups
Campfire or stove
Group camping and outdoor cooking
Bialetti Moka Express
Stovetop espresso
Classic moka pot that produces strong espresso-style coffee
1–6 cups
Camping stove
Espresso lovers at camp
Hario V60 Plastic Dripper
Pour-over
Lightweight cone-shaped dripper with spiral ridges for controlled extraction
1–2 cups
Hot water
Campers who want precise pour-over coffee while traveling
Wacaco Nanopresso
Manual espresso
Hand-pump pressure system for real espresso shots
1 shot
Manual pressure + hot water
Espresso enthusiasts on the go
GSI Outdoors Mini Espresso
Stovetop espresso
Compact espresso maker for camping stoves
1 cup
Camping stove
Small camp kitchens
Jetboil Silicone Coffee Press
French press
Silicone press accessory designed to fit Jetboil cooking systems
1–3 cups (depending on Jetboil pot size)
Camping stove (Jetboil system)
Jetboil users who want fresh French press coffee at camp
Let's get into the details of these portable coffee makers for camping:
  1. MiiR Pourigami
The MiiR Pourigami is a compact stainless-steel pour-over coffee maker designed specifically for travel and camping. Its three interlocking panels fold completely flat, making it one of the most space-efficient brewing tools for backpackers. Simply place a filter with coffee grounds and pour hot water to brew a clean cup of coffee.
Price: £22
Weight: 3–4.9 oz
Pros
Cons
  • Folds completely flat for packing
  • Very easy to clean
  • Compatible with paper or reusable filters
  • Takes almost no space in a camping kit
  • Requires paper filters
  • Only brews one cup at a time
MiiR Pourigami - best travel coffee maker for camping
  1. AeroPress Coffee Maker
The AeroPress Coffee Maker is a popular travel brewer thanks to its hybrid immersion-and-pressure brewing method. It produces smooth, rich coffee similar to espresso in about one to two minutes. Its durable plastic design makes it ideal for camping, hiking, or road trips.
Price: £35
Weight: 9–11 oz
Pros
Cons
  • Produces strong, flavorful coffee
  • Durable and nearly unbreakable
  • Easy cleanup with coffee puck ejection
  • Versatile brewing styles
  • Requires a hot water source
  • Slightly bulky for ultralight backpacking
Areopress coffee maker for camping
  1. ESPRO Ultralight Travel Press
The ESPRO Ultralight Travel Press is a French press coffee maker for camping. It features a patented double micro-filter system that produces smooth, grit-free coffee while preserving rich flavor. The vacuum-insulated stainless-steel body keeps coffee hot for longer, making it a reliable option for early mornings at the campsite.
Price: £29
Weight: 8–9 oz
Pros
Cons
  • Excellent filtration system
  • Durable stainless-steel build
  • Insulated body keeps coffee warm
  • Smooth French-press flavor
  • More expensive than simple brewers
  • Heavier than pour-over devices
ESPRO Ultralight Travel Press - an effective outdoor coffee maker
  1. GSI Outdoors Ultralight Java Drip
The GSI Outdoors Ultralight Java Drip is a minimalist pour-over device built for backpackers who want fresh coffee with almost no extra pack weight. It clips onto most mugs and uses a reusable mesh filter to brew coffee directly into your cup.
Price: £8
Weight: 0.4 oz
Pros
Cons
  • Extremely lightweight design
  • Very affordable option
  • Packs flat in backpacks
  • Quick setup
  • Brews only one cup
  • Plastic construction
GSI Outdoors Ultralight Java Drip - top-rated camping coffee maker in the UK
  1. COLETTI Bozeman Camping Coffee Pot
The COLETTI Bozeman Camping Coffee Pot is a traditional stovetop percolator made from stainless steel. It's built for campfire cooking and can brew multiple cups at once, making it ideal for group camping trips. The percolator design cycles boiling water through coffee grounds repeatedly to create strong coffee.
Price: £25
Weight: 2 lbs
Pros
Cons
  • Work on a campfire or stove
  • Classic outdoor brewing style
  • Long lifespan
  • Can be used either indoors or outdoors
  • Heavier than portable brewers
  • Longer brewing time
  1. Bialetti Moka Express
The Bialetti Moka Express is a stovetop espresso machine that brews coffee by forcing hot water through the grounds using steam pressure. This method produces a bold, concentrated coffee similar to espresso. Its classic aluminum design has been used for decades and works well with camping stoves.
Price: £64
Weight: 7.4 oz
Pros
Cons
  • Available in multiple sizes
  • Reliable design
  • No kettle required
  • Simple brewing method
  • Aluminum can dent
  • Requires practice for perfect brewing
Bialetti Moka Express - a well-known camping coffee maker
  1. Hario V60 Plastic Dripper
The Hario V60 Plastic Dripper is a lightweight pour-over brewer widely used by coffee enthusiasts and campers. Its cone-shaped design with spiral ridges allows precise control over water flow, helping extract balanced flavors from coffee grounds. Because it's made from durable plastic, it's a practical option for travel and outdoor brewing.
Price: £13
Weight: 200g
Pros
Cons
  • Very affordable compared with other brewers
  • Lightweight and easy to pack
  • Produces clean, bright pour-over coffee
  • Easy to clean and dishwasher-safe
  • Needs careful pouring technique
Hario V60 Plastic Dripper - a reliable coffee maker for camping
  1. Wacaco Nanopresso
The Wacaco Nanopresso is a compact handheld espresso maker designed for travelers who want real espresso anywhere. It uses a manual pumping system that can reach up to 18 bars of pressure, enabling proper espresso extraction. The device is small enough to fit in a backpack yet powerful enough to produce café-style shots.
Price: £64
Weight: 11.9 oz
Pros
Cons
  • Durable construction
  • Great for coffee enthusiasts
  • Produces real espresso with crema
  • Compact portable design
  • Small water capacity
  • Needs hot water separately
Wacaco Nanopresso - portable coffee maker for camping
  1. GSI Outdoors Mini Espresso
The GSI Outdoors Mini Espresso is a compact outdoor coffee maker designed for stovetop brewing during camping trips. It works well with small camping stoves and produces a strong espresso shot in just a few minutes. Its small, compact design makes it simple to carry with other camping kitchen equipment without occupying much room.
Price: £30 Weight: 10–11 oz
Pros
Cons
  • Durable metal body
  • Easy brewing process
  • Strong espresso flavor
  • Affordable price
  • Not ideal for large groups
  • Limited brewing capacity
GSI Outdoors Mini Espresso - an easy-to-use camping coffee maker
  1. Jetboil Silicone Coffee Press
The Jetboil Silicone Coffee Press is a camping accessory that turns compatible Jetboil cooking systems into a French press. It fits directly inside Jetboil pots and allows campers to brew fresh coffee using the same stove system they cook with. The detachable stem and basket make it easy to pack inside the cup after use.
Price: ~$20–$22 Weight: 1.3 oz
Pros
Cons
  • A micro-filter helps reduce coffee sediment
  • Packs neatly inside Jetboil cooking cups
  • Doubles as a steaming tool for food
  • Durable silicone ring ensures a secure fit
  • Only compatible with Jetboil systems
Jetboil Silicone Coffee Press - best camping French press coffee maker
Smart power solutions for a modern camping coffee maker
As outdoor coffee setups become more advanced, reliable power is essential to run electric coffee makers and other small appliances at campsites. Portable power stations provide a quiet and convenient way to brew fresh coffee anywhere without relying on traditional generators. Here are two reliable power solutions designed for modern camping coffee setups, including trusted options from EcoFlow:
Compact portable power station for small coffee machines
The EcoFlow DELTA 3 Plus is a compact yet powerful portable power station designed for outdoor adventures where reliable electricity isn't always available. With a 1024Wh battery capacity, it provides enough stored energy to run a variety of camping devices, including portable coffee machines, electric kettles, grinders, LED lights, and small kitchen appliances.
One of its biggest advantages is its high power output, delivering 1800W of continuous AC power with a 3600W surge capacity. This allows the unit to support most small coffee makers and other high-wattage camping appliances without stability issues. Whether you're brewing espresso in the morning or powering other campsite essentials, the strong inverter ensures consistent performance across multiple devices.
The DELTA 3 Plus is also designed to minimize downtime with its ultra-fast charging technology, capable of reaching around 80% charge in about 45 minutes through an AC outlet. In addition to wall charging, you can recharge it using solar panels or a car outlet using solar panels or a car outlet, giving campers flexible options for maintaining power during longer outdoor trips. This versatility is particularly useful for travel between campsites or remote outdoor setups.
To make power management even easier, the system includes multiple output ports such as AC outlets, USB-A, USB-C, and DC connections, allowing you to charge several devices at the same time. Through the EcoFlow mobile app, users can also monitor battery levels, track energy usage, and control power settings remotely.
Best for: Camping coffee setups, portable espresso machines, outdoor cooking stations, van life trips, and campers who want a reliable off-grid power source for brewing coffee and running small appliances.
DELTA 3 Plus (1 kWh)
- Expandable 1-5 kWh capacity with DELTA 3 Extra Battery, DELTA Pro 3 Extra Battery, DELTA 2 Extra Battery, or DELTA 2 Max Extra Battery. - 1800W AC output, with 2400W (3600W surge) using X-Boost technology. - 5 fast recharging methods: AC, Solar, 800W Alternator Charger, Smart Generator 3000 (Dual Fuel), and Multi-charging. - 5-year warranty.
High-capacity power station for espresso makers and multi-device use
For campers who run multiple appliances at once, the EcoFlow DELTA 3 Max Plus provides a larger and more capable off-grid power solution. With a 2048Wh battery capacity, it stores enough energy to support demanding devices such as espresso machines, electric kettles, portable induction cookers, mini refrigerators, and other campsite electronics.
The unit is built with a 3000W-rated AC output and up to 6000W surge power, enabling it to handle high-wattage appliances more comfortably than smaller portable power stations. Another advantage is its flexible charging capability, allowing the battery to recharge through wall outlets, car charging, generators, or solar panels.
With support for high-input solar charging, campers can generate power during the day and use it later for evening cooking, lighting, or brewing coffee. The system also supports expandable battery capacity, making it suitable for longer trips that require extended energy storage.
To simplify power management, the DELTA 3 Max Plus provides multiple connection options, including AC outlets, USB-A, USB-C, and DC ports, so several devices can be powered at the same time. Users can also monitor battery levels, track energy consumption, and control power settings through the EcoFlow mobile app, making it easier to manage electricity while camping or working outdoors.
Best for:
Outdoor coffee setups with espresso machines, group camping trips, van life kitchens, outdoor filming and content creation, and extended off-grid adventures that require reliable high-capacity power.
DELTA 3 Max Plus (2 kWh)
- Industry-leading 3000W AC output, 6000W surge output - Industry-First Full-Tab LFP Cells, exclusive smart BMS with 24/7 protection - 5 fast recharging methods: AC, Solar, Alternator Charger, Smart Generator, and Multi-charging - <10 ms UPS Auto-Switch - Intelligent energy management system - Expandable 2-10 kWh capacity with DELTA 3 Max Plus Extra Battery, DELTA 3 Extra Battery, DELTA Pro 3 Extra Battery, or DELTA 2 Max Smart Extra Battery.
How to choose the best camping coffee maker?
Choosing the right camping coffee maker depends on how and where you plan to camp, as well as how much effort you want to put into brewing your morning coffee. From ultralight backpacking trips to relaxed car-camping weekends, the ideal outdoor coffee maker should balance portability, ease of use, and brewing quality. Here are some key factors to consider before picking one.
  1. Consider your brewing method
Camping coffee machines come in several brewing styles, such as pour-over, French press, percolator, espresso maker, and instant coffee systems. Every brewing method offers its own unique taste and coffee experience. For example, immersion methods like French press tend to create a richer body, while pour-over coffee produces a cleaner and more balanced taste. Choosing a brewing style that matches your taste preference can significantly improve your camping coffee experience.
  1. Think about portability and weight
If you're backpacking or hiking, weight and packability become critical. Compact devices such as single-cup brewers or lightweight drippers are often preferred because they take up minimal space in a backpack. On the other hand, if you're car camping, you can bring larger options like percolators or French presses since portability is less of a concern.
  1. Check brewing capacity
Another important factor is how many people you're making coffee for. Single-serve brewers are perfect for solo campers or couples, while percolators or large presses are better suited for families or group trips. Choosing the right capacity ensures you don't have to brew multiple batches every morning.
  1. Evaluate ease of use and cleaning
Camping mornings are usually relaxed, so a simple brewing process can make a big difference. Look for coffee makers that require fewer steps and are easy to clean after use. Models that allow you to quickly dispose of coffee grounds or rinse filters are especially practical when water is limited at camp.
  1. Look at materials and durability
Outdoor gear should be built to withstand rough conditions. Coffee makers made from stainless steel, aluminum, or durable plastic are usually better for camping because they resist damage from drops, heat, and weather exposure. Fragile materials like glass may not be suitable unless you're camping close to your vehicle.
  1. Consider your heat or power source
Most camp coffee makers rely on hot water from a stove or campfire, but some electric models can also be used if you have access to a portable power station. If you prefer electric coffee machines or espresso makers, pairing them with a reliable portable energy source allows you to enjoy café-style coffee even at remote campsites.
Finding the right coffee maker for camping depends on how you travel, how much gear you carry, and the type of coffee you enjoy most. From lightweight pour-over drippers to compact espresso makers, each option offers different advantages for outdoor brewing. Some campers prefer simple manual methods, while others enjoy using electric machines powered by portable energy solutions. By matching the coffee maker to your camping style, you can easily enjoy fresh, satisfying coffee anywhere outdoors.
  1. What is the easiest way to make coffee when camping?
The easiest way to make coffee while camping is by using instant coffee or simple brewing tools such as an AeroPress or a pour-over dripper, since they require minimal equipment and only hot water. These options are lightweight and easy to prepare in outdoor settings. If you want to use small electric coffee makers at camp, a portable power station like the EcoFlow DELTA 3 series can provide reliable off-grid electricity for brewing coffee anywhere.
  1. What is the best percolator coffee maker for camping?
One of the most recommended percolators for camping is the GSI Outdoors Glacier Stainless Steel Percolator, known for its durable construction and ability to brew several cups of coffee over a camp stove or campfire. It's a practical option for group camping where larger batches of coffee are needed. For campers who prefer electric coffee makers instead of stovetop brewing, a portable power solution like the EcoFlow DELTA 3 allows you to run coffee appliances even at off-grid campsites.
  1. Can you use a coffee machine in a campervan?
Yes, you can use a coffee machine in a campervan if you have a reliable power source such as a battery system, inverter, or portable power station. Many compact coffee machines require moderate wattage, so they can run easily with the right off-grid power setup. Portable stations like the EcoFlow DELTA 3 series are commonly used in campervans because they provide enough output to run coffee machines, kettles, and other small appliances while traveling.
Portable Power Stations
