Battery Power Lawn Equipment: Best Picks, Reviews & Buying Guide for UK Gardens
Previously, the process of maintaining a UK garden involved using a petrol mower and its pull cord, all of which had to be dragged, and the engine fumes and sound endured. Not anymore. Battery-powered lawn machinery has evolved quickly and, by 2026, the performance of the most effective cordless machines is on par with – and, for some tasks, better than – the petrol-powered equivalents in the garden. There is a battery-powered system for every size of lawn, from a small suburban lawn to a larger plot.
Using garden equipment at home does increase your electric bill, though. When you complement a lawn kit with a home solar battery storage system, you can use the solar power you have stored to charge tools, as well as the power provided by the grid, which leads to decreased running costs season after season.
Why battery-powered lawn equipment is taking over UK gardens
Rather than being just a fad, the trend of moving from petrol to battery is a clear indication of the real advancement of lithium-ion battery technology, the increasing consciousness of noise and emissions, and the expanded availability of tools making battery systems genuinely practical for most UK homeowners.
In many urban areas in the UK, petrol tools will be phased out because of noise limits, and many local councils have limits on the use of petrol tools on certain days. Lawn equipment that uses batteries circumvents all of that, starts up quickly, is quiet, and has almost no maintenance other than keeping batteries charged.
Battery vs petrol vs corded — how do they compare?
Feature
Battery-Powered
Petrol
Corded Electric
Startup
Instant button start
Pull cord required
Instant
Noise level
Low
High
Low–Medium
Emissions
Zero
Yes
Zero
Mobility
Fully cordless
Fully cordless
Limited by cable
Ongoing costs
Low (electricity
Fuel + servicing
Very low
Power output
High (modern tools)
Very high
Moderate–High
Maintenance
Minimal
Regular servicing
Minimal
Best for
Most gardens
Large/commercial
Small, near outlet
Battery-powered lawn care equipment makes perfect sense in 2026 for most UK gardens of less than half an acre. While petrol remains dominant for the most demanding commercial or large-scale use, it has become much closer.
How long do lawn equipment batteries last?
The runtime of a battery will vary based on the tool, the battery's amp-hour (Ah) capacity, and the level of use. A general guideline:
Tool
Typical Runtime (4Ah battery)
Lawn mower
30–60 minutes
Strimmer/edger
25–45 minutes
Hedge trimmer
45–75 minutes
Leaf blower
20–40 minutes
Most modern systems can now change batteries while in use, and fast chargers can charge a 4Ah pack in 30–60 minutes. If it is a larger garden, it is simple and inexpensive to purchase a second battery and use one while charging the other.
The life of the battery, or how many times it can be charged and discharged, is usually between 500 and 1,000 cycles for good-quality Lithium-ion batteries. With seasonal use, it means 5-10 years of good service.
Types of battery-powered lawn care equipment
Knowing the functions of each tool and when to use it can help to determine the appropriate tooling for your garden.
Battery lawn mowers
The battery lawn mower is the cornerstone of most garden tool kits. The cutting width of modern cordless mowers ranges from 33cm (which is adequate for small gardens) up to 46cm or more in large lawns. They are much more efficient with brushless motors, resulting in longer playtimes and better performance in the thicker grass.
If you want to put the nutrients back on the lawn, search for adjustable cutting heights (5-7 positions), a mulching option, and a rear collection box. On steeper gradients and greater expanses, self-propelled models require less work.
Battery strimmers and edgers
Even hard-to-reach corners and edges that a mower cannot reach are possible with battery strimmers. Most of them are dual-line auto feed heads with adjustable speed settings to ensure a good balance between power and runtime. Others are edgers that have a rotating head, providing versatility for any kit.
For UK gardens with mixed terrain or established borders, a battery strimmer is nearly essential alongside a mower.
Battery hedge trimmers
One of the most innovative and successful battery-powered landscaping tools has been the cordless hedge trimmer. A no-tail cable makes shaping tall or oddly positioned hedges a dramatic change in safety and ease. They are between 45cm and 60cm+ in length, and many are now available with rotating handles, so they can be used for horizontal and vertical cuts.
Battery leaf blowers
Fall in the UK brings leaves — with a battery leaf blower, it's much easier to mow, rake, and clear away paths, patios, and lawns than to do it by hand. If you are interested in both collecting and moving debris, search for adjustable air speed and vacuum/mulching options. It takes less time to run, so a higher-capacity battery is desirable here.
Battery-Powered commercial lawn equipment
Groundskeepers and landscapers use battery-powered commercial lawn equipment more and more in contract landscaping. There are now specialist brands coming out with commercial-grade cordless mowers, ride-on mowers, and high-powered backpack blowers. They are usually designed to operate on a higher voltage system (60V or 80V+) and will use larger batteries to enable them to be used for extended periods at work.
Best battery-powered lawn equipment in the UK (2026)
Best battery lawn equipment for small gardens
Tools that are compact and lightweight work with just about any garden, up to about 200m², without costing as much as you will ever need to use.
Mower: Small lawns are cut easily by a 33-36cm cutting width cordless mower that has a 2Ah or a 4Ah battery.
Strimmer: Lightweight 18V–20V strimmer to maintain clean edges with minimal effort.
Hedge trimmer: For most small-garden jobs, use a compact 45cm blade trimmer.
The key attributes are low weight, ease of storage, ease of controls, and a budget-friendly battery platform that can be expanded later on.
Best battery-operated lawn equipment for large gardens
When the garden size is between 500m² and half an acre, run time and power are the primary concerns.
Mower: A 46cm self-propelled mower with a 6Ah battery (or dual battery) can perform longer cutting sessions without stopping.
Strimmer: A brushless 36V or 40V strimmer is enough power for thicker growth.
Leaf blower: A 4Ah/5Ah battery-powered cordless blower with a high CFM removes leaf piles swiftly and efficiently.
Large gardens will benefit from sticking to the same brand's battery system, as it means batteries are shared between tools, which will save money, and charging will be easier.
Best battery-powered commercial lawn equipment for professionals
This is a complete lineup of battery-powered commercial lawn equipment options for professionals.
Commercial users require tools that can be used daily for a long period. In 2026, the top commercial lawn products on batteries are on a 56V, 60V, or 82V platform with batteries that range from 7.5Ah to 10A for longer battery life.
  • IP-rated weather resistance
  • Commercial-grade motors with reduced wear – without brushes!Motors for commercial applications – brushless and reduced wear!
  • A wide variety of charging speeds are available, including fast charging (under 30 minutes for key batteries).
  • Supply of replacement parts and UK manufacturer support.
Battery-powered lawn equipment reviews: Top brands compared
Ryobi battery lawn equipment
Ryobi is a leading brand for battery lawn equipment in the UK and has adopted a system of interchanging 18V batteries for more than 200 tools, known as the ONE+ system. This means that the battery can be used in a Ryobi lawn mower or strimmer, and can be used by homeowners who already have Ryobi equipment.
Ryobi's lawn mower lineup includes small push models up to larger self-propelled models. Medium to large performance in the UK, broad availability in retailers (Screwfix, B&Q, Amazon), and accessories easily sourced. Ryobi also has a 36V HP range for those who don't require the full power of a commercial platform.
Best for: Homeowners who want a broad, compatible ecosystem tool at a reasonable price point.
Echo battery-powered lawn equipment
Technology for echo battery-powered lawn equipment is at the middle level of the market, between semi-professional and commercial ends. Their 56V ARC Lithium "echo" platform is used on high-performance mowers, trimmers, blowers, and chainsaws. The brand is especially known for its strimmers and backpack blowers that are equal in power to petrol strimmers and blowers.
Echo is generally heavier and more expensive than brands found in stores, but with durability and performance to handle heavy use. In the eyes of serious gardeners or small landscaping companies, Echo's battery-powered lawn equipment is a good option compared to petrol!
Best for: Power users, semi-professionals, and those maintaining larger or more demanding garden plots.
Other leading battery lawn equipment brands
Brand
Platform Voltage
Known For
Greenworks
40V / 60V / 80V
Strong value, good runtime
EGO Power+
56V ARC Lithium
Premium performance, long runtime
Bosch
18V / 36V
Compact, reliable, good for small gardens
Makita
18V / 36V LXT
Professional quality, wide tool range
Husqvarna
36V / Aspire
Premium garden tools, excellent build quality
Stihl
AK / AP / AR series
Professional-grade, outstanding durability
If you need to pick a brand, think about having other tools already in that ecosystem. The batteries that power this type of outdoor equipment can be costly, and if they can be connected to other equipment within the same system, then it is almost always a better long-term investment.
How to choose the right lawn equipment battery
A battery's capacity is measured in two ways: voltage (V) and amp-hours (Ah).
voltage (V)
The power output is determined by the voltage. The higher the voltage, the more cutting force and performance in tough situations. 18V–20V is used for light domestic work, 36V–56V for larger gardens and more demanding jobs and 60V–82V is the commercial range.
amp-hours (Ah)
Amp-hours determine runtime. A 4Ah battery will have about twice the life of a 2Ah battery of the same voltage. In the UK, 4Ah should be the minimum size, and anything 6Ah or above may be recommended for larger gardens.
An easy way to estimate energy is to use the voltage and amp-hours, which are watt-hours (Wh). A 40V 5Ah battery has a capacity of 200Wh — a convenient reference to keep in mind while comparing brands.
Cross-Compatible Battery Systems — Are They Worth It?
Mostly, the batteries are made by the brand and can only be used on its respective devices; there are also third-party adapters. True cross-compatibility (batteries that will work with tools from several different brands) is uncommon and typically not dependable enough to rely on.
So, there's an exception in the brand range. Ryobi ONE+, Makita LXT, EGO 56V, and Greenworks 40V are all such platforms. If you are starting to assemble a garden tool collection from the ground up, one ecosystem would be the most economical choice.
Key features to look for
Feature
Why It Matters
Brushless motor
More efficient, longer lifespan, better performance
Battery indicator
Know your remaining charge mid-task
Fast charging compatibility
Reduces downtime between sessions
Weather resistance (IP rating)
Important for UK conditions
Ergonomic design
Reduces fatigue on longer jobs
Warranty length
Quality brands offer 3–5 year tool warranties
Powering your garden and home: smarter energy solutions
During the gardening season, charging battery-powered lawn products puts a regular strain on your home's electric bill. Those charges are taken from the grid each charge cycle, and over the course of the entire spring-to-autumn season, they add up. This is a true and regular expense for gardeners operating several cordless tools.
The better way to go is to power your tools with a solar bank of batteries instead of electricity from the grid, which means less cost per charge and, over time, substantial savings in running your entire garden system.
The home solar battery system stores energy from the sun during the day for use later, in your garage or shed, for instance, while you're charging garden tools. This is ideal for gardeners who own their own equipment, as peak solar production is closely matched to the hours they may be using the equipment between their mowing visits.
A storage system means that whenever you generate electricity, it can be used immediately and doesn't have to be exported back to the grid at a low rate and then purchased back later at a higher cost. Lower electrical bills throughout the house — and ultimately, much less cost for the garden tools.
Best solar battery solutions for garden homeowners
EcoFlow STREAM Ultra X — Home Solar Battery
Best for: Garden homeowners wanting a straightforward, expandable solar storage system to charge tools and power the home.
The STREAM Ultra X is a home solar battery with a built-in inverter. It is plugged directly into your home's electrical outlets and starts cutting your electricity use right away, meaning it converts electricity stored from the sun into electricity that can be used in your home without the need for separate inverter equipment.
That translates to garden owners running their battery-powered lawn mowers, strimmers, hedge trimmers, and leaf blowers off solar energy instead of connecting to the grid each time. This could be a difference over an entire gardening season.
Up to 2,300W AC output in dual-unit configuration 2,000W solar input with 4 MPPTs and Low-Light Cells — captures useful energy even on cloudy days Expandable from 3.84 kWh up to 23 kWh by adding extra batteries 15-year lifespan with high safety standards Compatible with Tiber, Matter, and Shelly smart home protocols Save up to £1,729 annually on electricity bills
EcoFlow STREAM Ultra — Home Solar Storage Kit
Best for: Households with higher energy demands or those wanting flexible, scalable solar storage.
The STREAM Ultra features the same built-in inverter as the STREAM Ultra X, and is connected directly to the electrical system at home. The flexibility it offers is its greatest strength, as it can be used in combination with other STREAM AC Pro units to increase storage without adding to the existing hardware, making it ideal for homes that are planning to add storage space as they go.
It provides 1200W of continuous output when used in its single unit configuration, and may be paired with a second unit to produce 2300W of stored solar power supply for a busy household, using garden equipment, kitchen appliances, and home office devices at the same time.
EcoFlow STREAM Ultra X All-in-One Home Storage Kit
Save up to £1,729 annually on your electricity bills. Enjoy up to 2300W AC output, easily powering high-demand appliances. Expandable capacity from 3.84 to 23kWh provides energy coverage throughout the day and night. With a 2000W solar input, 4 MPPTs, and Low-Light Cells, this system captures more solar energy. Features a 15-year lifespan, ensuring high safety and long-term reliability. Set up is effortless and requires no electricity. Compatible with third-party devices that use Tiber, Matter, and Shelly protocols.
Battery lawn equipment maintenance tips
How to store and care for lawn equipment batteries
Good storage can add a lot of life to batteries. Here are some tips to help you keep your investment safe:
  • If the tool is not to be used for some time or over winter, store the tool at partial charge (40-60%). Fully charged or fully depleted cells will cause faster degradation of the chemistry of the cells.
  • Store batteries outside of the house during the winter months in the UK. Lithium-ion cells lose capacity when temperatures drop into freezing range, and should never be stored in unheated sheds or garages below 0°C.
  • Keep out of sunlight and moisture. A dry, cool cupboard or utility room shelf is best.
  • To prevent parasitic drain from onboard electronics, remove batteries from tools when storing them for extended periods.
How to extend battery life and runtime
  • Be sure to use the right charger for the battery. Third-party chargers will charge it faster, but could reduce battery life.
  • Don't allow batteries to become fully depleted while in use. Refraining from complete discharge is less harsh on the cells than stopping at 10-15% remaining.
  • Maintain clean contacts with batteries. A dry cloth will remove dirt and oxidation that can decrease the charging efficiency.
  • If your brand will allow it, update tool firmware — some manufacturers provide efficiency improvements through software updates.
Common mistakes to avoid when buying battery lawn equipment
Investing in a platform that has few tools. Some budget brands are only available with one or two tools on their battery platform. Before investment, ascertain that the same battery runs a variety of tools like a mower, strimmer, blower, and trimmer.
Choosing the wrong size battery. The 2Ah battery is good for a 50m² lawn, and will not satisfy the needs of a larger lawn. Don't attempt to purchase too high an Ah rating for the size of your garden, and be honest with yourself about how much you actually need.
Ignoring motor type. Brushed motors have a lower efficiency and shorter lifespan, but are less expensive. Brushless motors are more expensive but will work to pay for themselves in performance and longevity. Always use brushless tools for those that are used often.
Overlooking charging time. If you have to run several sessions in a day, a tool that runs for 60 minutes with a 3-hour charge time is not practical. Look at the charger spec, NOT battery runtime!
Selecting by cost. Not all the best lawn equipment is necessarily the lowest price. A high-quality mid-range tool from a trusted brand with a solid battery range will be less expensive over five years than two low-end tools that don't have access to the same types of batteries.
In 2026, battery-powered lawn equipment is the sensible and practical option for UK gardens. Today's quieter, cleaner, easier-to-clean, and more versatile battery-powered lawn equipment can cut, mow, and trim hedges for the whole season, from weekly mowing to seasonal hedge trimming and beyond.
The right setup involves knowing how big your garden is, ensuring you get the voltage and Ah that fits your needs, and making sure you get a battery platform equipped with the right tools to help you grow, even if it's a Ryobi, Echo, EGO, or other well-known brand.
For the homeowners who wish to take their efficiency to the next level, battery lawn care products can be coupled with home solar storage products for the ultimate in clean, home-generated charging — not paying a grid charge each time. The EcoFlow STREAM Ultra X and STREAM Ultra are practical, expandable solutions for doing just that.
  1. What is the best battery-powered lawn equipment for UK gardens?
EGO Power+, Ryobi, and Greenworks are consistently popular choices for battery lawn equipment in the UK, known for their durability, compatibility, and impressive power output. It will depend on your garden size, budget, and whether you already have tools in a specific battery platform.
  1. How long does battery lawn equipment last on a single charge?
Running time is dependent on the tool and battery size. The typical range of time that a 4Ah battery will power a lawnmower is 30-60 minutes; a Strimmer is 25-45 minutes, and a Hedge trimmer is 45-75 minutes. The figures are about doubled with larger 6Ah batteries. If you have a bigger garden, it makes sense to purchase a spare battery and charge the other one, allowing you to use both simultaneously.
  1. Is battery-powered lawn equipment as powerful as petrol?
When it comes to domestic and semi-professional lawn equipment, modern types of batteries are now not far behind petrol in most situations. Brands such as EGO, Echo, and Husqvarna produce high-voltage platforms (40V-56V) that are comparable to petrol power in mowing, trimming, and blowing in a typical UK garden. Petrol has only a slight edge for the most extreme commercial or heavy-duty uses.
  1. Which battery lawn equipment brands are compatible with each other?
Most battery platforms are company-specific and not really cross-compatible. But in a brand, compatibility counts as a big selling point. Ryobi ONE+ (18V), Makita LXT (18V/36V), EGO 56V, and Greenworks 40V/60V all have a wide selection of tools that use the same battery. There are third-party adapters available, but they are not recommended for reliable performance.
  1. Can I use the same battery across different lawn equipment tools?
Yes — in a suitable brand ecosystem. That's one benefit to opting for a single platform. For instance, a Ryobi 18V battery can power a Ryobi mower, strimmer, hedge trimmer, blower, and hundreds of other tools. Manufacturers do not typically support cross-brand compatibility, and do not rely on it.
Portable Power Stations
