Single Phase and Three Phase Power: Differences, Uses & What's Right for You
For the majority of the UK population, the concepts of single-phase and three-phase power are rarely considered. However, there's a notable exception — a new EV charger, a large industrial device, a solar battery, or a business expansion — and it suddenly becomes a significant issue.
It does not require an electrical engineer to understand the difference between single-phase and three-phase power. Some things must be known, of course: what each system is, how they differ, and when one system may be superior to another. When you're also searching for a method to utilise less energy in your own home, home solar battery storage is one of the most useful tools you have.
From basics on how each system operates, to what conversion entails, and which power setup is right for you, this guide covers all your bases.
What is single-phase and three-phase power?
A single-phase power supply
This is the type of electricity that the majority of UK homes are connected to, and it is known as single-phase power. It is designed for delivering alternating current (AC) electricity, which fluctuates at 50Hz, and comprises two conductors – a live conductor and a neutral conductor – and an earth.
The voltage supplied is 230V, and the power is supplied in a single unbroken wave. There are times during each cycle when the voltage drops to zero, due to the direction change 50 times per second. This is undetectable for most household appliances — they simply function. This is a drawback to high-power equipment or motor-driven equipment when compared to a three-phase supply.
Single-phase supply is easy to provide, cheap to distribute, and is sufficient for most domestic loads – lighting, heating, and kitchen appliances, home entertainment systems, and more and more, EV charging and home battery storage.
A three-phase power supply
Three-phase power has three conductors of live (current) wires with alternating currents that are displaced from each other by 120 degrees. That makes power delivery far more consistent and continuous: At any point, at least one of the three phases is close to being at its maximum power, and power delivery is much smoother than with a single-phase.
Three-phase supply of 400V between the phases and 230V between any phase and neutral is delivered in the UK. The higher effective voltage and the more stable voltage output make three-phase the preferred option for industrial equipment, large commercial buildings, and high-power electrical equipment.
Another big advantage of the industry using a three-phase supply is the fact that the three-phase motor is more efficient than a single-phase motor of the same size and simpler to construct.
How are they generated and distributed in the UK?
They are both the same: three-phase electricity is generated at power stations, increased in voltage, and sent through the National Grid. The voltage is then stepped down again at substations for local distribution. At the last step, the 3-phase supply is divided, and each one is given to different properties, so in the same street, your neighbour could be on a different phase than you. Usually, a single-phase (single-phase and 230V) is installed in a house, while a larger commercial or industrial building may request all three installed.
Single-phase vs three-phase — Key differences explained
Difference between single-phase and three-phase power
The fundamental difference between single-phase and three-phase power comes down to how electricity is delivered and how smoothly that delivery happens.
Feature
Single-Phase
Three-Phase
Number of live conductors
1
3
UK voltage
230V (live to neutral)
400V (phase to phase)
Power delivery
Pulsating (peaks and zero crossings)
Smooth and continuous
Typical use
Homes, small businesses
Industry, large commercial
Maximum practical load
~14–15 kW (at 63A)
Much higher
Motor efficiency
Lower
Higher
Installation cost
Lower
Higher
Single-phase is the right choice for most homes. Three-phase is the right choice when you need more power than a single phase can reliably deliver, or when running equipment specifically designed for three-phase supply.
The difference between single and three-phase power supply
There are three obvious differences between single and three-phase power supply:
Maximum power capacity. In a domestic electrical supply in the UK (single phase), a standard fuse would be 60 – 100A, with a maximum of about 13 – 23 kW. A 3-phase supply can provide several times that and is appropriate for large machinery, commercial kitchens, EV fleet charging, and industrial processes.
Power quality. Three-phase power provides a steadier and more stable power supply. This is important in the case of sensitive equipment or large motors. With household appliances, it doesn't really matter.
Cost of supply. The installation of single-phase connections is simpler and less expensive. Three-phase upgrades cost more and take longer because we need to invest in additional infrastructure and involve our DNO.
Power formula for single-phase and three-phase
Knowing the power formula for single-phase and three-phase systems will allow you to determine the real power used and make accurate comparisons between the two.
Single-phase power formula:
P = V × I × PF
Where:
  • P = Power in watts (W)
  • V = Voltage (230V in UK)
  • I = Current in amps (A)
  • PF = Power factor (typically 0.8–1.0 for resistive loads)
Example: A 230V single-phase circuit at 32A with a power factor of 1.0 delivers 7,360W (7.36 kW).
Three-phase power formula:
P = √3 × V × I × PF
Where:
  • √3 = 1.732 (a fixed constant)
  • V = Voltage between phases (400V in UK)
  • I = Current per phase in amps (A)
  • PF = Power factor
An example of a 400V, 3-phase circuit of 22,170W (22.17 kW) at 1 power factor is approximately three times the single-phase circuit of 32A.
The geometric relationship between the three phases is shown by the √3 multiplier. That is the reason why three-phase provides about three times the power of a single phase at the same current and voltage.
Single-phase and three-phase power supply in UK homes and businesses
Which Properties Use Single-Phase Power?
Almost all homes in the UK are single-phase. If you are in a house, flat, or small cottage, then you will have a single-phase supply almost certainly. This includes:
  • Detached, semi-detached, and terraced houses
  • Flats and apartments
  • Small shops and offices
  • Agricultural outbuildings with standard power needs
  • Most garden offices and home studios
A single-phase supply is usually adequate for many common power demands, such as adding heat pumps, electric vehicles, and home battery storage systems.
Which Properties Use Three-Phase Power?
Three-phase supply is the standard for:
  • Factories and manufacturing facilities
  • Large commercial premises and office buildings
  • Farms with heavy agricultural machinery
  • Workshops with industrial equipment
  • Large hospitality venues (hotels, event spaces)
  • Properties with multiple EV chargers or very high total electrical demand
  • Some larger residential properties that have specifically requested a three-phase connection
How to tell which supply you have at home
The best method of discovery is to refer to your electricity meter and consumer unit (fuse box):
Single-phase supply: The meter and main isolator switch will be present in the consumer unit. Usually, the supply cable to your property will have three conductors: live, neutral, and earth.
Three-phase supply: You will either have three separate meters or one three-phase meter, with three main isolator switches on your consumer unit, or a three-phase main switch on your consumer unit. The supply cable will carry 5 conductors (three live, neutral, and earth).
If in doubt, it will be evident on your electricity meter, or you can request to speak to your DNO, as they have records of all connections on their network.
Single-phase convert to three-phase — When and why it's done
The conversion from single to three-phase power is just not necessary for most homes in the UK. However, there are times when it is truly needed:
  • Installing a three-phase rated industrial machinery or workshop equipment
  • Operating a business at home that requires a lot of electricity
  • When installing multiple EV charge points at the same time
  • Running large heating, ventilation, and cooling systems or commercial kitchen equipment
  • Agricultural application that needs three-phase motors/pumps.
A well-upgraded single-phase system is adequate for the majority of domestic applications like solar battery installations, EV charging, and larger power appliances.
Single-phase to three-phase converter — How it works
A single-phase to three-phase converter (also known as a single-phase phase converter, a single-phase VFD — variable frequency drive) converts single-phase power to a simulated or derived three-phase power. They come in two categories:
Rotary phase converters:
Rotary phase converters are comprised of a motor-generator configuration to generate true three-phase power from a single-phase input. They are mechanically sturdy, give three-phase output, but are big, expensive, and maintenance-intensive.
Static phase converters
Static phase converters convert single-phase to three-phase using capacitors and electronics. They're less expensive and less complicated, but yield an unbalanced output suitable for motors and not for sensitive electronics.
Variable frequency drives (VFDs)
Variable frequency drives (VFDs) are used to convert single-phase AC to DC and then, electronically, to three-phase AC. They are compact, efficient, and suitable to drive 3-phase motors from a single-phase supply, which is the most popular solution for workshop machinery.
Keep in mind, a single to three-phase converter does not provide more power from the grid; it merely changes the form of the power supply. You still can't exceed the power limits of your single-phase connection.
Three-phase to single-phase converter — When you need it
A three-phase to single-phase converter can be used in situations where it is desired, but it is less common. If you own a three-phase supply (as might have been passed down on a commercial property) but wish to use single-phase equipment, a simple transformer can be used to step down from three-phase to single-phase 230V without having to undertake any complicated conversion.
More commonly, equipment that is designed for single-phase is just connected between one phase and neutral in a three-phase supply, and this is electrically the same as single-phase 230V.
Costs and considerations for conversion in the UK
Single-phase to three-phase transformation is not an easy and inexpensive process. You will have to approach your Distribution Network Operator (DNO), and they will determine if the additional capacity is warranted in your network. Infrastructure enhancements may be necessary, lead times could be several months, and the costs of the total site may be quite variable depending on your location and distance from the nearest three-phase network.
Choosing the right power solution for your home
This is an important point to grasp: three-phase power isn't required to power an efficient home solar battery system. In most cases, a single-phase supply is used in the UK for home solar and storage systems, and this works perfectly fine.
A single-phase system is used at home with a solar battery system, such as the EcoFlow STREAM series. In the daytime, the solar panels produce DC electricity, which is then converted to AC power by the inverter included in the battery and sent to the house circuit. For those who are new to the process, here is a guide on how to connect solar panels to home electricity, which will take you through the entire process in easy detail. Your appliances use stored solar power first and then use the energy from the grid. Your bill is reduced, and your electric meter shows it.
The big benefit is intelligent energy management – this is where the system determines when to use stored solar energy, when to consume grid energy, and how to keep the battery charged up for evening use. All this operates on a normal UK single-phase connection.
Best solar battery solutions for single-phase UK homes
For those who live in the UK and have a regular 1-phase electricity supply, the ideal solar battery storage system allows you to make the most of the electricity you have produced – instead of sending it to the grid for an artificially low price or losing it completely.
Both of the solutions below involve using a standard single-phase UK power supply and will work in the majority of UK homes with no changes to the power supply needed.
EcoFlow STREAM Ultra X — Smart energy storage for single-Phase Homes
The STREAM Ultra X is a residential solar battery and inverter unit that can be directly connected to the existing single-phase home wiring. It stores solar heat during the day and releases it at night, so your home appliances can use stored solar power instead of consuming electricity at high rates during the day.
Up to 1200W of continuous output power, 3.84 kWh of storage. It can be expanded to 2,300W when a second unit is added, making it suitable for high-energy appliances such as ovens, dishwashers, washing machines, and more. The storage capacity can be increased to 23 kWh by adding more battery units, without needing to upgrade to a three-phase supply.
Up to 2,300W AC output in dual-unit configuration 2,000W solar input with 4 MPPTs and Low-Light Cells — captures useful energy even on cloudy days Expandable from 3.84 kWh up to 23 kWh by adding extra batteries 15-year lifespan with high safety standards Compatible with Tiber, Matter, and Shelly smart home protocols Save up to £1,729 annually on electricity bills
EcoFlow STREAM All-in-One Home Storage Kit
This kit comes with solar panels, a battery unit, and all the hardware for a full solar + storage system for households who prefer to buy everything in one. All are compatible, and the EcoFlow app monitors generation, storage, and consumption in real time, which is helpful to understand what is generating, storing, and using your single-phase supply and how to optimise it.
EcoFlow STREAM Ultra X All-in-One Home Storage Kit
Save up to £1,729 annually on your electricity bills. Enjoy up to 2300W AC output, easily powering high-demand appliances. Expandable capacity from 3.84 to 23kWh provides energy coverage throughout the day and night. With a 2000W solar input, 4 MPPTs, and Low-Light Cells, this system captures more solar energy. Features a 15-year lifespan, ensuring high safety and long-term reliability. Set up is effortless and requires no electricity. Compatible with third-party devices that use Tiber, Matter, and Shelly protocols.
Common misconceptions about single and three-phase power
The three phases are always better. Not for homes. Three-phase power is used in industrial and high-demand commercial applications. So a single-phase supply is quite sufficient for a typical UK household, even if they want to use an EV charger, heat pump, and solar battery. For the vast majority of homeowners, upgrading to 3-phase is both expensive and complicated, but it doesn't offer any real advantages.
Solar battery storage requires three-phase power. A well-known misconception. Even the high-capacity Home Solar Batteries, such as the EcoFlow STREAM series, are single-phase compatible. Upgrading your supply doesn't mean you need to upgrade your storage to enjoy solar storage.
Three-phase gives you three times the voltage. Not quite. Even in a UK three-phase circuit, the voltage between any phase and neutral is still 230V, as in a single-phase circuit. The 400V figure is in reference to the voltage between 2 of the 3 'live' phases. They still have 230V for individual appliances and phase-to-neutral connections.
Converting single to three-phase is straightforward. It's rarely straightforward. There is the possibility of getting specific equipment to operate with a phase converter, but a complete grid upgrade requires your DNO, a lot of work in the grid, and a good amount of time and money.
Single-phase power is the correct supply for the vast majority of UK domestic consumers, and it is more effective than many users think. New demand items such as EV charging, heat pumps, and home solar battery systems are all sized to fit within the limits of a single-phase supply and, in many cases, are intelligently managed to make that single-phase supply stretch further.
Three-phase power is necessary for a true purpose in industry and high-demand commercial applications, and when necessary, conversion is 100% possible. However, for the majority of households that ask the question, there is no need for them to install a new supply, as their current single-phase system is perfectly adequate if it is managed wisely.
The most practical solution to make more use of a single-phase supply is to install a solar battery system at home. This allows you to store energy from the sun when it is available, and consume it when you need it, which means you consume less energy from the grid and save on power bills without any alterations in power supply infrastructure. We've compiled a guide to solar panels and battery storage that is perfect for planning a system that will suit your home.
  1. What is single-phase and three-phase power?
Single-phase power is electricity that is supplied by a single live conductor with a potential of 230V (which is the standard voltage for a UK home). Three-phase is three live conductors offset by 120 degrees with 400V between conductors and is used throughout industrial and commercial premises. They both come from the same infrastructure, but use different methods of power distribution at the point of use.
  1. What is the difference between a single-phase and a three-phase power supply?
The main differences are the number of live conductors (one vs three), voltage (230V vs 400V phase to phase), smoothness of power delivery, and max capacity. Single-phase suits domestic and small business applications; three-phase suits industrial and large commercial applications.
  1. Can I convert single-phase to three-phase at home?
A phase converter or VFD can be used to power certain three-phase loads from a single-phase power supply, but it will NOT increase the amount of power you receive from the power supply. An application to your Distribution Network Operator (DNO), possible infrastructure work, and a high cost are required to perform a full upgrade to 3-phase. Please seek advice from a qualified electrician and DNO before taking any action.
  1. What's the difference between single and three-phase power for homes?
Most UK homes are single-phase, which is enough power for every home's normal usage – including EV charging, heat pumps, solar battery storage and more. Three-phase is not usually required for domestic applications unless it's for industrial equipment or if electrical demand is very high. For the majority of homeowners, the difference is negligible.
  1. Do I need three-phase power for solar battery storage?
Yes, all Home Solar Battery Systems (including high-capacity models like the EcoFlow STREAM Ultra X) will operate from a standard single-phase UK supply. Solar energy can be stored and utilised in large quantities, and high-power-consuming machines can be powered by stored solar energy. The size of the system can be expanded without modifying the existing single-phase supply.
Portable Power Stations
