The Best Camper Van Fridge Guide for UK Trips
Are you getting ready for a UK trip in your camper van? A good fridge is essential for keeping your food fresh and your drinks cold, making your journey much more comfortable. To power it reliably on the road, many travellers use portable power stations, which provide clean, quiet, and flexible energy wherever you go. With so many choices out there, picking the right fridge can seem tricky. This guide breaks down the different types, features, and sizes of camper van fridges to help you find the best fit for your travels and enjoy a worry-free adventure across the UK.
Why choosing the right fridge for camping matters
Picking the best 12V camper fridge for your van keeps your food and drinks fresh during long journeys. It helps you save money by cutting down on waste and making fewer trips to the shop. A quality camper fridge also uses less energy, so your battery lasts longer. Most of all, it makes your camping trips easier and more comfortable.
Types of camper van fridges
When it comes to picking a fridge for a camper, knowing the different types helps you make the right choice. Each fridge works differently and suits certain travel styles and power setups. Knowing their pros and cons will make your UK trips easier and more enjoyable.
Compressor fridges
Compressor fridges work like a regular home fridge, using a compressor to cool efficiently. They perform well in hot weather and on steep hills, making them ideal for UK road trips with varying terrain. These RV camper fridges are energy-efficient and can run on 12V, 24V, or mains electricity.
Absorption fridges
Absorption fridges use heat from gas, 12V, or mains power to cool, and they have no moving parts. They run quietly and can use LPG, which is useful for camping in remote UK spots. However, they are less efficient in hot weather and take longer to cool down.
Thermoelectric coolers
Thermoelectric coolers move heat from inside to outside using the Peltier effect. They are light, compact, and easy to carry, making them great for short trips or small vans. However, they are not as efficient for long journeys or hot days, since they can't cool much below the outside temperature.
Top 5 camper van fridge recommendations
The right camper van fridge can make your UK trips much more comfortable. Whether you want a small, affordable model or a high-end fridge with smart features, there's something for every journey. Here are the top 5 picks to help you decide:
1. EcoFlow GLACIER Classic portable fridge freezer
The EcoFlow GLACIER Classic Portable Fridge Freezer is the best choice for UK camper van trips, delivering flexible cooling and smart control. It comes in 35 L, 45 L, and 55 L sizes with a compact design that fits well in tight van spaces. Dual‑zone cooling on larger models lets you keep fresh and frozen items at different temperatures.
Equipped with a high‑efficiency copper compressor, the GLACIER Classic cools quickly while consuming less power, making it ideal for off-grid camping. It offers multiple power options: 12V/24V DC, mains power, or solar input, giving you complete flexibility. Eco mode extends battery life for long trips, while Max mode drops temperatures rapidly for frozen goods.
Built for durability and convenience, the fridge features thick insulation to maintain stable temperatures and minimize energy loss. Smart app control allows you to monitor temperature, battery status, and modes directly from your phone. Dual‑sided access, sturdy handles, and a robust build make it easy to use on the road.
Additional highlights include:
  • Low vibration and quiet operation, so it won’t disturb your sleep or conversations.
  • Rapid cooling for beverages and perishable food, even in hot UK summers.
  • Expandable storage compatibility, so you can pair it with portable power stations for longer off-grid trips.
  • Energy-efficient design, ideal for camper vans, caravans, or boat use.
Price: £629–£899 (depending on size)
Best for: Long trips, off-grid camping, tech-savvy travellers
Pros
  • Dual-zone design keeps fresh and frozen items separate.
  • Efficient cooling with low power consumption for long battery life.
  • Smart app control for temperature and mode adjustments.
  • Compact design with high storage capacity.
Cons
  • Expensive compared to basic portable fridges.
  • Plug-in battery sold separately for extended off-grid use.
- –20 °C up to 20 °C, suitable for both deep‑freeze and fridge‑level cooling. - 11–30 V DC (car/solar) and 100–240 V AC, enabling use with van battery, solar panels, or mains. - ~165–190 Wh per 24 h in refrigeration mode (varies by capacity and Eco mode). - Up to ~43 hours at 4 °C on a 298 Wh battery (tested at 25 °C ambient).
2. Dometic CFX3 35 portable fridge freezer
The Dometic CFX3 35 is a high-end portable compressor fridge designed for serious campers. It keeps food and drinks fresh even in extreme UK weather conditions. The fridge features a clear digital display and smart app control for easy temperature adjustments. Its robust construction makes it durable enough for rugged adventures.
Price: £739–£799
Best for: Long trips, mixed fridge and freezer use, tech-savvy campers
Pros
  • Strong cooling range down to deep-freeze levels.
  • Digital controls and app connectivity.
  • Energy-efficient with battery protection.
  • Durable and rugged build.
Cons
  • Expensive compared to simpler models.
  • Slight compressor noise during operation.
3. Alpicool C20 portable fridge freezer
The Alpicool C20 is a small, lightweight fridge/freezer that's perfect for smaller vans or solo travellers. It cools down to –20 °C, so you can store both food and frozen items. It runs on 12V or 24V DC, making it energy-efficient and great for short trips. Its portable design means it fits easily in tight spaces without losing performance.
Price: £180–£200
Best for: Couples, solo travellers, short trips
Pros
  • Very affordable for a compressor fridge.
  • It can function as both a fridge and a freezer.
  • Low power consumption.
  • Compact and easy to fit in small vans.
Cons
  • Limited storage capacity.
  • Basic temperature controls.
4. Mobicool MCF40 portable compressor fridge
The Mobicool MCF40 offers a practical balance of size, performance, and affordability. It has a 38 L capacity, enough for weekend trips or short holidays. Its adjustable temperature lets you use it as a fridge or freezer, depending on your needs. The fridge can run on a vehicle battery or mains power, making it flexible for various travel setups.
Price: £149–£200
Best for: Budget-conscious campers, weekend trips
Pros
  • Affordable mid-range option.
  • Adjustable temperature settings.
  • Dual power options: 12/24V DC or mains.
  • LED interior light.
Cons
  • Build quality is lighter than that of premium models.
  • Handles may not be very robust.
5. Indel B TB31A portable fridge freezer
The Indel B TB31A is a sturdy, reliable compressor fridge made for frequent campers. Its 29L capacity is good for longer UK trips and keeps your food and drinks cold. It works with both 12/24V DC and 110–230V AC, giving you flexible power options. ECO and MAX modes help save energy, and its tough build handles rough conditions.
Price: £700+
Best for: Frequent campers, longer trips, reliable performance
Pros
  • Dual-voltage for flexible power use.
  • Efficient Secop compressor.
  • ECO and MAX modes for energy savings.
  • Digital display and LED lighting.
Cons
  • Expensive compared to basic models.
  • Slightly heavy for small vans.
What to consider when choosing a camper van fridge
No matter if you're heading out for a weekend or a long UK road trip, picking the right camper fridge freezer is important. It affects how fresh your food stays, how much power you use, and how well it fits in your van. Thinking about these key points will help you choose the best fridge for your journey:
  1. Size and capacity
The size of your 12V camper fridge decides how much food and drink you can take with you. Bigger fridges are good for families or long trips, while smaller ones work well for solo travellers or couples. Be sure to check your van's space before picking a size.
  1. Power consumption
A camper van fridge freezer uses either DC, AC, or gas, and efficient power usage is crucial for long trips. Low power consumption helps protect your van battery and reduces the need for frequent charging. Consider models with ECO or energy-saving modes for better efficiency.
  1. Operating temperature range
The operating temperature range affects what you can store and how well your mini camper fridge works in different weather. Compressor fridges handle high temperatures better, while absorption models may struggle in hot conditions. Ensure the fridge can reach your required cooling or freezing levels.
  1. Installation flexibility
Some Dometic camper fridges stand alone, while others can be built into your van. Portable fridges are easy to move and can be used in different places. Think about whether you want a fixed fridge or one you can carry for weekend trips.
How to power your camper van fridge
To keep your camper van fridge running well, you need a reliable power source. While some people use leisure batteries or solar panels, EcoFlow portable power stations offer a flexible and convenient solution. They're perfect for off-grid trips, weekend camping, or locations without mains electricity, providing dependable energy to keep your fridge and other devices running smoothly.
Portable power stations for fridge support
The EcoFlow DELTA 2 Max Portable Power Station is ideal for running a camper van fridge on long trips. With a 2048 Wh LFP battery, it can keep a 12V fridge running for hours without recharging. Multiple charging options—including AC, solar (up to 1000 W), and car input—make it perfect for off-grid adventures across the UK.
Its long-lasting LFP battery delivers up to 3,000 full cycles, roughly 10 years of daily use. An advanced Battery Management System (BMS) protects against voltage, current, and temperature issues, while reinforced ports and a rugged, portable design ensure safety and durability on the road.
With X-Boost technology, the DELTA 2 Max can reach up to 3100 W output, enough to power almost any fridge or camping device. Despite its high capacity, the unit is manageable for travel, giving reliable and stable power wherever your van adventures take you.
EcoFlow DELTA 2 Max (2 kWh)
- DELTA 2 Max offers 2–6 kWh capacity, up to 6144 Wh with extra batteries. - The LFP battery lasts 10 years with 3000 cycles. - Store solar energy to save on peak-hour power. - AC output up to 3100 W, powers 13 devices, including 4 outlets. - Fast AC+Solar charging up to 1000 W, full charge in ~2.3 hours. - 99% MPPT efficiency maximises solar energy. - Manage battery and power via the EcoFlow app. - Comes with a 5-year warranty.
Leisure battery setup
A leisure battery setup is a common way to power a camper fridge freezer on the road. These deep-cycle batteries store energy separately from your van's starter battery, so you don't risk draining it. Depending on the battery and fridge size, they can run a 12V fridge for days. Using a battery monitor helps you track usage and get the most out of your power on longer trips.
Solar panels and controllers
Solar panels and controllers give you renewable energy to keep your camper fridge running off-grid. The panels charge your leisure or portable battery during the day, so you don't have to rely on mains or your vehicle's power. An MPPT controller helps convert energy efficiently and protects your batteries from overcharging.
How to maintain your camper van fridge
Taking care of your camper fridge helps it work well and last longer. Good maintenance stops food from spoiling, saves energy, and helps you avoid expensive repairs. The care tips listed below will keep your mini or full-size fridge reliable for every trip:
  1. Regular cleaning
Clean your camper fridge freezer often to get rid of spills, crumbs, and smells. Use mild soap and a soft cloth so you don't damage the surfaces. Regular cleaning keeps your food safe and fresh, and stops mold or bacteria from building up.
  1. Check seals and gaskets
Check the door seals and gaskets on your fridge regularly to make sure they're tight and working well. If seals are damaged or dirty, cold air can escape, and the fridge has to work harder. Replace any worn or cracked gaskets quickly to keep your fridge cooling properly.
  1. Keep ventilation clear
Ensure your camper fridge has enough space around it for proper airflow and consistent cooling. Blocked ventilation can cause overheating and reduce overall cooling performance. Keep vents clean, clear, and unobstructed for optimal operation and safety.
  1. Winter/off-season care
If storing your camper fridge freezer during winter or off-season, empty it and clean it thoroughly beforehand. Leave the door slightly open to prevent mold, mildew, and unpleasant odors. Store in a dry, frost-free area to maintain its overall condition and performance.
Picking the right camper van fridge can turn any UK road trip into a more comfortable and easier experience. The right fridge keeps your food fresh, your drinks cold, and means you don't have to shop as often. It also lets you visit remote places without worrying about power or storage. Planning helps you find a fridge that fits your van, travel style, and trip length.
For off-grid trips, EcoFlow products like the GLACIER Classic fridge freezer and DELTA 2 Max power station work well together. Their smart features, efficiency, and tough design keep your fridge running smoothly on long journeys. With these products, your food stays fresh, and your power needs are sorted wherever you travel.
  1. What is the best fridge for a camper van?
The best camper van fridge depends on your trip and van size. Top options include the Dometic CFX3 45 and CFX3 35 for long trips, the compact Alpicool C20 for short trips, and the rugged ENGEL MT35 for off-grid adventures. Choose based on capacity, efficiency, and power setup.
  1. How long will a 12V fridge run on a 100Ah battery?
A 12V fridge typically uses 4–7 Ah per hour, depending on temperature and size. On a fully charged 100Ah battery, it can run roughly 12–24 hours. Using solar panels or a secondary battery can extend the runtime for longer trips.
  1. Can I put a normal fridge in a camper?
A standard home fridge is not designed for a moving vehicle and can be inefficient. It may struggle with 12V/24V power, vibrations, and uneven surfaces. A proper RV camper fridge is safer, more efficient, and designed for travel conditions.
Portable Power Stations
