The Ultimate Guide to Wildfires in Canada: Risk, Season, and Preparedness
Canada has logged some of its most destructive wildfire seasons on record since 2023. The smoke from a fire in one province now routinely closes schools and cancels flights hundreds of kilometers away. This guide covers which regions face the highest risk. It covers when the season actually peaks. It covers how to track fire and smoke conditions in real time. It also covers how to prepare a home or trip for the disruption that follows.
Where Wildfires Are Most Active in Canada
British Columbia, Alberta, and the Northwest Territories consistently rank as the highest and most sustained fire-risk regions. Long-standing precipitation deficits and dry interior forests drive that risk, and the forest takes years to recover even after a quieter season.
Northwestern Ontario has emerged as a major hot spot in recent seasons too. Smoke from its fires reached far enough to give Toronto some of the worst air quality of any major city in the world on July 15, 2026, according to IQAir's global rankings. Fires burning hundreds of kilometers away pushed the Air Quality Health Index to a "very high risk" reading of 10-plus in the city.
Quebec, Manitoba, and Nunavut see sharp spikes later in the summer as dry conditions build through July and August. That's a later start than the spring seasons typical of BC and Alberta. The timing difference means no single month is "safe" nationally, even if any region has a narrower window of peak risk.
The 2026 season also included major wildfires in northwestern Ontario, including the Thunder Bay 36 fire, which burned more than 318,000 hectares according to satellite-based tracking. That makes it one of the largest single wildfires in the province's recorded history and a major contributor to the smoke that later blanketed Toronto.
Knowing which regions carry the most risk only matters if the timing lines up when you're actually there.
When Wildfire Season Peaks Across the Country
Canada's wildfire season generally extends from March through October, although timing varies significantly by region. The timing of peak risk shifts by region as the summer progresses, though.
BC and Alberta typically see their sharpest risk build through May and June, driven by rapid snowmelt and early-season drying. The Prairies tend to peak in July. Ontario and Quebec's highest fire danger often lands in August, after weeks of summer heat have dried out ground vegetation.
Some seasons start slowly and still turn severe. The 2026 season is a case in point. Canada's government noted it began more slowly than the historically bad 2023 and 2025 seasons. Yet by late August, the country had still logged over 5,248 fires and burned more than 4.4 million hectares nationally. A quiet spring is not a reliable signal that the rest of the summer will stay calm.
Once you know roughly when your region is most exposed, the next step is making sure your home and vehicle can handle a disruption if it happens.
Preparing Your Home and Vehicle Before Wildfire Season Hits
Preparing for wild fires CanadaPreparing for wild fires Canada
Wildfires don't need to reach a property to disrupt it. Smoke advisories, extreme heat, and grid strain during active fire events can all knock out power well outside the fire zone itself, sometimes hundreds of kilometers from the nearest flame.
A portable power station kept charged and ready means essential devices, phones, and medical equipment keep running whether the outage is planned or sudden. Keeping essential devices powered through an outage is worth setting up in more detail for anyone building backup power for the first time.
For anyone who might need to evacuate by vehicle or RV, a way to recharge on the road matters just as much as the power station itself.
EcoFlow DELTA 3 Ultra Plus (3072Wh)
•3600 W Powerful Output: 7200 W surge output. With X-Boost™ mode, supports heavy-duty appliances up to 4600 W such as clothing steamers, electric dryers, lawnmowers, and electric frying pans. •Smart Output Priority: Choose which circuits stay powered via the app. Prioritize what matters and extend runtime when it counts most. • 3-11 kWh Expandable Capacity: Easily scale up, and can achieve longer runtime with an EcoFlow Smart Generator featuring automatic start and stop. •6 Ways to charge, Ready in Just 48 Mins: Ready in Just 48 Mins (0-80%) with Solar + Generator Dual Charging
That power station still needs a reliable way to recharge if the grid is down for longer than expected, especially for anyone evacuating by road rather than staying put.
• Turbo Charging: 800 W turbo alternator charges 8× faster than traditional in-vehicle auxiliary power outlets, topping up 1 kWh in only 1.3 hours. •3-in-1 Design: Functions as a fast charger, battery maintainer, and emergency jump starter to keep your battery in mint condition. •Vehicle Compatibility: Suitable for a variety of vehicles including SUVs, pickups, and RVs. • Capacity Expansion: Expands existing RV house battery capacity for extended off-grid trips. • Easy Installation: Clean, straightforward setup designed to integrate seamlessly without permanent modifications.
Anyone planning to evacuate by RV specifically benefits from getting the vehicle's charging setup sorted before fire season, not during it. Our guide to choosing the right battery setup for a camper walks through this in more depth.
With the home and vehicle covered, the next question is how to actually know when conditions are changing.
Tools to Track Fire Risk, Smoke, and Power Outages
Tool
What It Shows
Best For
CIFFC National Situation Report
Daily fire counts, active fires, national preparedness level
Tracking the overall national picture
FireSmoke.ca (BlueSky Canada)
48-hour ground-level smoke concentration forecasts
Checking if smoke is headed your way
ESRI Wildfire Climate Map
Longer-range fire risk and climate trend mapping
Understanding risk trends over a season
WeatherCAN app
Local weather alerts and warnings
Real-time alerts specific to your area
The CIFFC situation report is the most authoritative single source for how many fires are active and how stretched national firefighting resources currently are. It aggregates data from every province and territory in one place.
FireSmoke.ca's forecasts matter even for people nowhere near an active fire. Smoke plumes routinely travel hundreds of kilometers and affect air quality far from the fire line, as the 2026 Toronto event showed clearly.
If wildfire activity in your area has already led to outages, tracking them as they're reported is its own separate step. Our guide to tracking outages as they're reported breaks down that process province by province.
Checking the tools tells you what's coming. What you do indoors once smoke actually arrives is the next piece.
Staying Safe From Wildfire Smoke Indoors
Wildfire smoke can push air quality into unhealthy territory even hundreds of kilometers from the nearest fire. Toronto experienced this firsthand during the 2026 season, when it briefly ranked as having the worst air quality of any major city on earth.
Close your windows to keep smoke outside. Run an air purifier or filtered HVAC system to clean indoor air. Check the Air Quality Health Index before spending extended time outdoors.
People with asthma, heart conditions, or other respiratory sensitivities should treat smoke advisories more seriously than the general public and limit outdoor exertion during them. This matters even if the smoke looks like a distant haze rather than an immediate threat.
Whether you're sheltering in place or need to leave, having the right gear packed ahead of time makes the difference.
What to Pack for an Evacuation or Smoke Advisory
  • Pack essential papers, medicine, a hand-crank radio, and a way to charge your phone before you leave.
  • Keep N95 masks ready if you must go outside in heavy smoke, because cloth masks do not block tiny ash pieces.
  • Keep a portable power station charged all year so it is ready right away during an emergency.
  • Always follow local evacuation rules from your city or province, as Canada does not use one single federal plan.
Wildfire risk in Canada varies sharply by region and by month. The smoke and power disruptions that follow now reach far beyond the fire zone itself.
Know your region's peak months. Keep a way to track fire and smoke conditions handy. Have backup power ready before a season starts rather than during one. The DELTA 3 Ultra Plus and 800W Alternator Charger linked above cover the essentials whether you're sheltering in place or evacuating by road.
What part of Canada has the most wildfires?
British Columbia, Alberta, and the Northwest Territories face the highest fire risk, while Northwestern Ontario is also a major hot spot.
When does wildfire season peak in Canada?
The peak changes by region. BC and Alberta peak in May and June, the Prairies in July, and Ontario and Quebec peak in August.
How can I check if wildfire smoke is affecting my area right now?
You can use FireSmoke.ca to see smoke forecasts or check the WeatherCAN app for local air quality alerts.
Is it safe to travel to Canada during wildfire season?
Most of the time, yes. However, you should always check local fire and smoke news before you go.
What should I pack in case of a wildfire evacuation?
Pack important papers, medicine, a battery radio, a phone charger, and N95 masks if the air is smoky.
How long does wildfire smoke usually linger after a fire is contained?
Smoke can linger for days after a fire is put out. How long it stays depends on the wind and how big the fire was.
