Toronto Hydro Outage Map: How to Check Power Outage Status
The lights rarely go out at a convenient time, and the first question in the dark is always the same one: whether it's just your place or the whole block. A summer storm, winter weather, failing equipment, or a damaged power line can all knock the power out, and once it's out, the first thing worth checking is whether Toronto Hydro has already reported an outage in your area.
Toronto Hydro's outage map answers that in about thirty seconds, along with how many customers each incident affects and, once crews have looked, when the power should be back. This guide covers how to read it, what to do when your address doesn't show up, and how to follow a repair that's still underway.
What Is the Toronto Hydro Power Outage Map?
Think of it as a live picture of the grid, updated every 10 minutes. Every incident gets a shaded shape, and clicking one opens a summary with the customer count and, once a crew has been there, an estimated time of restoration.
Two caveats are worth knowing. The map covers Toronto Hydro’s own service territory, so out in Mississauga or Markham you’ll want Alectra’s map instead. And it can only show outages the utility already knows about, which is why reporting your own still matters.
How to Check a Power Outage on the Toronto Hydro Map
The map runs in any browser, phone or laptop, and no account is needed.
Search by Address or Location
Type your street address, a nearby intersection, or your postal code into its search bar, and the map centres on your block, so you can see whether your street sits inside a shaded incident area or whether the lines around you look clear. On a mixed street, the postal code is often more reliable.
Check the Affected Area and Customer Count
Clicking a shaded area opens a summary showing where the incident runs and roughly how many residents it has affected. That count is the number to watch. Under 20 can reflect something local, a transformer up a pole or a branch across a service line, whereas a few thousand can point higher up the system, at a feeder or a substation, where there is more to rebuild before the power comes back.
Review the Estimated Time of Restoration
Every incident carries an Estimated Time of Restoration (ETR), though early on it may read something like “Pending Assessment”. That isn’t a brush-off — nobody has reached the fault yet, and in a storm the crew may still be clearing fallen branches to reach it. Once they’re on site and know what they’re dealing with, the estimate becomes a window you can plan around, whether that means plugging your Wi-Fi into a portable power station to keep working, or shifting the fridge contents to a neighbour’s.
What to Do During a Power Outage in Toronto
Knowing what to do during a Toronto power outage starts with a quick look outside. If the dark stops at your own property, the panel is next, and only then is it worth phoning Toronto Hydro.
| Step | What to look for | What to do next |
| 1. Street scan | Are the streetlights and your neighbours' porch lights dark too? | Dark on both sides means it's the neighbourhood, not your house. |
| 2. Breaker panel | Has the main breaker tripped, or has a single switch flipped? | Reset it once. If it trips again, leave it alone and call an electrician. |
| 3. Outage map | Is your street shaded on the map? | If nothing shows up, report the outage yourself. |
| 4. Hazard Check | Downed wires, a leaning pole, smoke, or water near electrical equipment? | Stay back ten metres (33 feet) and call emergency services. |
Check Whether Nearby Homes Have Power
A look out the window or from your balcony can tell you whether nearby homes have power. If the streetlights along your street are dark and the building across the road is black as well, you’re dealing with an area-wide failure, and Toronto Hydro almost certainly knows. If your neighbour’s television is still glowing through the blinds (assuming they aren’t just running a quiet solar generator) while yours is the only dark unit, the fault is more likely inside your own place: a tripped breaker, or a blown fuse on the line from the pole. That is worth ruling out first, because it takes two minutes instead of two hours.
Check the Home Electrical Panel
A kettle, a space heater and an iron, all on one circuit, will trip a breaker long before they’ll take down the street. Take a flashlight down to the panel, whether it’s in the basement, a utility closet, or behind a hallway door in an older Toronto house, and look for a switch sitting halfway between ON and OFF. Push it firmly to OFF and then back to ON, just once. If it snaps straight back, leave it be and call in a licensed electrician, because a breaker that keeps tripping is telling you something.
Report Power Outages Not Shown on the Map
For all that, the map has its blind spots. Some older equipment doesn’t report back on its own, and an outage touching a handful of houses can sit unlogged until somebody calls. So if you’re in the dark and nothing shows at your address, submit a Toronto Hydro outage report yourself, online or by phone. Those first calls are how Toronto Hydro works out the shape of a fault, and in a storm they can move your street further up the list.
Contact Toronto Hydro for Electrical Emergencies
Downed wires, a leaning pole, sparks off an overhead line, water pooling around electrical equipment: stay well back. Toronto Hydro asks for ten metres (33 feet), roughly as long as a TTC bus, and that goes for anything touching a line, including the branch that brought it down. Never approach or touch anything in contact with a power line. Report urgent electrical hazards to Toronto Hydro’s 24/7 emergency line, or call 911 first if there is an imminent threat to life.
How to Stay Updated During a Toronto Hydro Power Outage
Toronto Hydro pushes updates out in four ways: text and email alerts, the mobile app, the automated phone line, and social media. Set one up before you need it.
Sign Up for Text or Email Outage Notifications
Sign in to your account, choose text or email, and updates arrive on their own: when Toronto Hydro knows your hydro is out, when someone is on the way, and when the power is back. You’ll need the account number from your bill. A text also keeps working once the Wi-Fi doesn’t.
Use the Toronto Hydro Mobile App
The app puts mobile-friendly Toronto Hydro outage maps right in your pocket, laid out for a phone screen. You can check current outage details, report an outage, and access your account. Away from home, it’s how you tell whether the dark stops at your street or covers half the neighbourhood.
Use the 24/7 Automated Phone Line
When the internet goes down with it, or you’d rather hear a voice, the automated line at 416-542-8000 never closes. Follow the prompts and key in your postal code or the account number on your bill. It’ll read back the outages it knows about near you, hand you a restoration window if one exists, and let you report an outage that hasn’t hit the map yet. Save the number before you need it.
Follow Toronto Hydro on Social Media
When a big storm hits, Toronto Hydro’s feeds on X (formerly Twitter) and Facebook become the fastest way to see the bigger picture: photos from the field, storm damage summaries, and restoration updates as crews work through the city. Following them tells you how much of the city is in the dark with you.
How to Prepare Your Home for a Power Outage
The steps to prepare for power outages are all easy work on a Saturday afternoon. At nine at night by flashlight, none of it is, so get it done ahead.
Prepare Emergency Supplies
Keep one kit in one place, somewhere you can reach in the dark: a flashlight, spare batteries, a hand-operated can opener, food that needs no cooking, a first-aid kit, and four litres of water daily for each person in the house, the city’s own guideline. Water is what people forget, and it matters more the higher up you live, since the pumps in a multi-storey building stop with the power.
Plan for Essential Device Backup
Your phone, the Wi-Fi router, a couple of lamps: none of them works in a blackout, and they're what keep you connected to the updates above. A portable power station keeps that list running with no fuel, no fumes, and nothing to haul outside — the backup that's ready the moment the lights go out.
The EcoFlow DELTA 3 Max Plus Portable Power Station (2048Wh) is an ideal companion for everyday essential backup. Designed with ample output capacity, it can power personal communication gear, laptops, and vital small appliances. Moreover, its expandable battery architecture allows you to scale up storage capacity according to your household's unique runtime needs, giving you dependable flexibility for short interruptions.
Set Up Home Backup Power for Extended Outages
Ice and wind cause the outages that last. When a storm takes out primary feeders across Ontario, the repair is measured in days rather than hours, and past the 24-to-48-hour mark, you’re managing rather than waiting. Keeping a phone alive stops being the point. What matters then is the fridge, any medical equipment, the sump pump in a basement, and enough light to move around.
When dealing with multi-day disruptions, a larger system like the EcoFlow DELTA Pro Ultra Whole-Home Backup Power provides practical whole-home backup. With high AC output and scalable battery capacity, it supports heavy-draw loads such as full-sized refrigerators, communication hubs, home office equipment, and secondary heating fans. This setup bridges the gap during extended Toronto winter outages, keeping essential household systems running safely until the municipal grid is restored.
The routine is four steps: look outside, check the panel, open the map, report it if nothing’s there. What follows is waiting, and waiting goes better with a kit in the closet and a backup that keeps a phone and a lamp running.
Put the outage number in your phone tonight. Save your account number somewhere you can find it without a light. Next time the lights go out, you’ll know where to look.
What caused the Toronto power outage?
Weather, most of the time. Freezing rain, lightning and high wind bring lines down, and in a city with Toronto’s tree cover, a wet April snow or an ice storm will put limbs across wires across the city. After weather come vehicles hitting poles, equipment wearing out, and planned maintenance.
How long do power outages usually last?
Most outages are measured in hours. Widespread incidents caused by severe ice storms, high-wind events, or major underground cable faults can take anywhere from 12 hours to several days to fully repair, because the job is a rebuild rather than a reset. For an ETR measured in days, plan for the long end.
How accurate are power outage maps?
Toronto Hydro’s map refreshes every 10 minutes using automated telemetry and whatever crews report back from the field, so it’s current and dependable for anything logged. ETRs are the soft part. They’re a first estimate, and they move once somebody gets to the fault and sees what’s broken.
Can you predict a power outage?
Not an unplanned one. Environment Canada warnings will tell you when conditions are lining up for trouble, a freezing rain warning or a wind warning, and that’s about as close to a forecast as it gets. Planned maintenance shutdowns are the only outages you can genuinely see coming.
How do I find out if there is a planned power outage in my area?
Toronto Hydro notifies affected customers ahead of time by phone or in writing, so check that the contact details on your account are current. Upcoming planned work also shows up on the utility’s construction map, which is worth a look before you book anything that needs the power on.
