Nova Scotia Wildfires: Current Risk, Season, and How to Prepare
- Where Wildfires Are Most Common in Nova Scotia
- Nova Scotia's Wildfire Season and Burn Restrictions
- Preparing Your Home and Vehicle Before Fire Season Starts
- How to Check Current Wildfire Risk and Conditions in Nova Scotia
- What to Do If a Wildfire Threatens Your Area
- What to Pack If You Need to Evacuate
- Conclusion
- FAQs
Nova Scotia's most damaging wildfire in decades tore through the Tantallon area in 2023. It destroyed more than 150 homes and forced over 16,000 people out in a matter of days. The province has run under active fire watches nearly every summer since. This guide covers where the risk is highest in the province. It covers how the fire season and burn restrictions work. It covers how to check conditions in real time. It also covers how to prepare a home or vehicle before a fire forces a decision.
The Halifax Regional Municipality's wooded fringes, including the Tantallon, Hammonds Plains, and Pockwock areas, have seen some of the province's most destructive fires. Dense forest sitting close to residential subdivisions is exactly the setup that turns a fire in the woods into a fire that threatens homes within hours.
Southwestern Nova Scotia, around Shelburne County and Barrington Lake, has also produced some of the largest single fires on record. A 2023 blaze there grew to roughly 23,500 hectares. That made it the largest wildfire in Nova Scotia's recorded history. It forced more than 6,000 people from their homes over the weeks it burned.
More recently, a wildfire on Mooseland Road, roughly 100 kilometers northeast of Halifax, burned out of control for days in July 2026. It grew to about 1,700 hectares before crews brought it under control and lifted the evacuation order. It forced well over a hundred residents along a 22-kilometer stretch out of their homes, showing the risk isn't limited to the areas hit hardest in 2023.
What these locations have in common is proximity between dense forest and residential development, sometimes called the wildland-urban interface. Nova Scotia has a higher share of homes built directly against forested land than many other provinces. That's part of why fires here can threaten structures faster than in regions with more separation between neighborhoods and wooded areas.
Knowing where fires tend to start matters less than knowing when the risk is actually elevated.
Wildfire season in Nova Scotia runs from March 15 to October 15. That's the window when dry vegetation and warmer weather combine to raise ignition risk province-wide.
The province uses a daily colour-coded burn restriction system, updated every afternoon based on that day's weather data:
Color | What It Means |
Green | Open fires allowed after 2 p.m. |
Yellow | Open fires restricted to after 7 p.m. |
Red | Open fires banned outright |
No open fires are ever permitted between 8 a.m. and 2 p.m., regardless of the day's colour rating. These restrictions apply even without a permit requirement. Checking the current colour before lighting anything outdoors is a legal obligation, not just a safety suggestion.
Once you know the season and the daily restrictions, the next step is making sure your home and vehicle can handle a disruption if a fire does start nearby.
A wildfire doesn't need to reach a property to disrupt it. Evacuation orders, road closures, and localized power outages during an active fire can all hit homes well outside the burn area itself. Sometimes entire municipalities feel the effects without ever seeing flames directly.
Keeping a charged power station on hand means essentials like phones, medical devices, and communication gear keep working through an outage.This can help whether you are preparing for a possible evacuation or responding to an unexpected power outage. Keeping essential devices powered through an outage is worth setting up well before fire season starts, not once smoke is already visible on the horizon.
For households that might need to evacuate by vehicle, having a way to recharge on the road matters just as much as the power station itself.
That power station still needs a reliable way to top back up if the outage or evacuation stretches longer than expected and a wall outlet isn't an option.
One thing worth confirming before you rely on this pairing: the DELTA 3 Ultra Plus needs the separately sold Custom Fit Output Cable to connect to the 800W Alternator Charger, it doesn't work with the charger's standard included cable. Pick one up ahead of time so it's already in the car, not something you're tracking down the day an evacuation order goes out.
Tool | What It Shows | Best For |
NS Fire Restrictions / BurnSafe Map | Daily burn restriction colour by region | Checking if outdoor burning is allowed today |
CWFIS Interactive Map | Fire weather index and active fire polygons across Canada | Seeing exactly where fire danger is elevated |
ESRI Wildfire Climate Map | Longer-range fire risk and climate trend mapping | Understanding risk trends across a season |
The province's own fire restrictions page is the most direct source for whether burning is currently allowed in your area. The colour resets daily based on that day's weather data rather than a fixed seasonal schedule.
The CWFIS interactive map layers the Fire Weather Index over the province. It's useful for seeing whether a specific county or municipality is trending toward higher risk before a burn ban is announced. It's a good tool for spotting a worsening pattern before it becomes an active fire.
If a fire in your area has already led to outages, tracking them as they're reported is a separate step. Our guide to tracking outages as they're reported breaks down specifically how to do that for the province.
Checking these tools tells you what's happening. What to do if smoke or an evacuation order actually reaches you is the next piece.
Follow evacuation orders from the Halifax Regional Municipality or your local county immediately. Orders in Nova Scotia come from the municipality or the province, not from a single provincial-wide alert. Knowing which authority covers your area matters.
Report a wildfire or a suspected burn-restriction violation by calling 1-800-565-2224 or 911. Don't assume someone else has already reported it. Fires can spread significantly in the time it takes for a report to reach crews, so early reporting genuinely matters.
Keep windows closed and limit outdoor activity if smoke is affecting your area, especially for anyone with asthma or a heart condition. Even fires that stay well out of town can push local air quality into unhealthy territory for days at a time.
Whether you're sheltering in place or heading out the door, having the right gear packed ahead of time makes the difference.
Pack your ID, important papers, medicine, a hand-crank radio, and a way to charge your phone before you leave.
Keep N95 masks ready if you must go outside in heavy smoke, because cloth masks do not block tiny ash pieces.
Keep a portable power station charged all year so it is ready right away when an evacuation order comes.
Pack a multi-day supply of non-perishable food and bottled water for every member of your household, including pets.
Include a fully stocked first-aid kit containing bandages, antiseptic wipes, and any necessary personal hygiene supplies.
Nova Scotia's wildfire season runs March through October. Both the 2023 Tantallon fire and the 2026 Mooseland Road fire show how quickly a fire near Halifax or the South Shore can force an evacuation.
Check the daily burn restriction colour. Know the CWFIS and BurnSafe tools. Have backup power ready before fire season starts rather than during it. The DELTA 3 Max Plus and 800W Alternator Charger linked above cover the essentials whether you're sheltering in place or evacuating by road.
Where in Nova Scotia are wildfires most common?
The wooded fringes of the Halifax Regional Municipality, including Tantallon and Hammonds Plains, along with southwestern Nova Scotia around Shelburne County and Barrington Lake, have seen the province's most destructive recent fires.
What is Nova Scotia's wildfire season?
It runs from March 15 to October 15 each year, the window when dry vegetation and warmer weather combine to raise ignition risk province-wide.
How do I know if there's a burn ban in my area of Nova Scotia today?
Check the province's daily colour-coded burn restriction map, updated every afternoon based on current weather conditions, green, yellow, or red depending on fire risk.
How can I check the current Nova Scotia wildfire map?
The province's BurnSafe map shows daily restrictions, while the CWFIS interactive map layers the Fire Weather Index over active fire locations across the country.
What should I pack if a wildfire evacuation order is issued?
ID and documents, medication, a battery-powered radio, a way to charge your phone, and N95 masks if smoke is a factor in your area.
How do I report a wildfire in Nova Scotia?
Call 1-800-565-2224 or 911 immediately rather than assuming someone else has already reported it, since early reporting gives crews the best chance of containing a fire quickly.
