Truck Camping: How to Set Up Your Pickup for Camping
Truck camping is the simple way to turn the pickup you already own into a practical sleeping setup: instead of towing a trailer or spending the price of a new vehicle on a slide-in camper, the cargo box becomes a dry, elevated, lockable place to sleep — and you can be in your sleeping bag ten minutes after you shut the engine off.
This guide covers the basic gear you need, how to set up power and food storage, how to prepare for Canadian weather, and what to check before heading out for the best truck camping experience.
What Is Truck Camping and How Does It Work?
Truck camping puts the sleeping and living setup straight into the cargo bed of a pickup. The truck stays a truck, so you can still haul firewood, a quad, or a week’s worth of gear, while the bed serves as your bedroom, kitchen, and living room once you add an awning.
Truck Camping vs. Tent Camping and Truck Campers
Every style of camping involves a trade-off between comfort, cost, and how far into the bush you want to go. A ground tent can mean pounding pegs into rocky ground after dark. A slide-in camper gives you hard walls and, in many models, running water — then bills you twice: once at the dealership, and again at the pump. When a prairie crosswind starts shoving the rig around, you’ll notice the extra height, too.
Truck bed camping lands in the middle:
Setup TypeSetup TimeMobility & Trail ClearanceWeather ProtectionApproximate Cost
Ground Tent15–30 minutesLimited only by your energyBasic; pitched where water pools$150 – $600
Truck Bed CampingUnder 5 minutesHigh; goes wherever your 4x4 willExcellent; up off cold, damp ground$300 – $2,500
Slide-in Camper10–20 minutes (unloading and levelling)Moderate; raises the centre of gravitySuperior; insulated hard walls$15,000 – $60,000+
Your living quarters stay inside the footprint of the vehicle. Tight switchbacks on an old logging road are still manageable, and you can squeeze into a parallel parking spot on a small-town main street when you come out for groceries.
Why Pickup Trucks Work Well for Camping in Canada
When considering trucks for camping, pickups suit this country's long distances, rough surfaces, and unreliable weather:
  • Ground Clearance & 4WD: Enough to handle washboard gravel, rutted campsites, and a muddy shoulder after an overnight dump of wet snow.
  • Payload Capacity: Room for water, firewood, recovery gear, a power station, and bedding without unpacking half the truck to reach the coffee.
  • Elevated Sleeping Area: You sleep above the frost, the puddles, and the rocks under your hip.
  • Wildlife Protection: An enclosed topper keeps raccoons, mice, and curious deer out of your food, but it isn't bear-proof: in bear country, scented items go into a bear locker or locked cab.
What Gear Do You Need for Truck Camping?
When gathering your car camping essentials, build the kit around five jobs: sleeping warm, cooking, keeping food fresh, seeing after dark, and getting yourself out of trouble.
Sleeping Gear for Comfortable Overnight Camping
Steel and composite truck beds insulate about as well as bare metal, which is to say, not at all. A thin yoga mat will have you shivering by three in the morning, so go with three or four inches of high-density foam or a dual-layer self-inflating pad. Pack a sleeping bag rated well below zero (or a duvet if you want room to move), and keep a toque handy for nights colder than forecast.
A plywood sleeping platform is the best upgrade most people make: a flat surface for the mattress, plus slide-out storage underneath for bins, camp chairs, and the stove.
Cooking and Food Storage Essentials
A two-burner propane or butane stove handles most of your cooking needs and stows flat, while a basic mess kit and a decent knife can quickly turn a tailgate into a functional kitchen. Fuel-burning stoves should remain outside: carbon monoxide is odorless and can build up in a topper, cab, or closed-in awning before you realize it.
A cooler usually works fine for a short weekend, but on longer trips, managing melting ice and keeping food dry can become a hassle. For extended travel, a portable fridge, such as the EcoFlow GLACIER Classic, offers a reliable alternative to bagged ice. It maintains a consistent temperature for meat and produce, making it a practical option for multi-day camping and road trips.
Camp Safety Tip: A portable fridge within reach is tempting to leave beside your pillow at night. In active bear country across BC, Alberta, or Northern Ontario, it goes into the locked cab or a bear box instead.
Keep fresh and frozen foods separate, with a maximum temperature difference of 22°C maintained within ±1°C for ultimate freshness. Holds up to 58 cans (35L), 72 cans (45L), or 90 cans (55L) of 330ml soda.
Lighting and Camp Comfort Gear
Under a topper or a thick stand of spruce, darkness falls early and completely: mount warm-toned LED strip lights along the topper rails for ambient light without the harsh, blinding glare of a headlamp bouncing off bare metal. A magnetic work light earns its keep at the tailgate, and a headlamp kept within arm’s reach of your pillow keeps you from stumbling around the campsite at two in the morning. Add a folding chair and a small table that sits level across the tailgate.
Safety and Emergency Gear for Remote Trips
Cell coverage drops quickly once you leave main highway corridors, especially along active logging roads where complete self-sufficiency is a necessity.
  • Tire Maintenance: A 12V portable tire inflator, a plug kit, and a pressure gauge you trust.
  • Vehicle Recovery: Traction boards, a kinetic tow strap, rated shackles, and a compact folding shovel.
  • Wilderness Safety: Bear spray within quick reach of the tailgate, a first-aid kit stocked for blisters and burns, and an offline GPS app or satellite messenger.
EcoFlow DELTA 3 Classic Portable Power StationEcoFlow DELTA 3 Classic Portable Power Station
How Do You Power a Truck Camping Setup?
Power is the piece people either overthink or forget entirely, often wishing they had packed a reliable portable power station when the phone hits four percent on day two.
Identify the Devices That Need Power
Start with a list before you buy anything: phones, tablets, a GPS unit, camera batteries, LED lights, a camp fan, and a portable fridge or freezer. The GLACIER Classic, for example, runs off an AC outlet or its own plug-in battery. Then add the hungrier items: a heated blanket, a laptop, or a travel kettle.
Choose a Portable Power Source for Camping
Once you know the power loads, match the station to the trip length, available bed space, and your planned recharge method.
For weekend outings focused on running small electronics like phones, LED lights, cameras, and camp fans, a portable power station like the EcoFlow DELTA 3 Classic provides a practical, compact option. With a 1,024Wh capacity, it can recharge typical camp devices multiple times over a trip. Pairing the unit with portable solar panels allows you to recharge the battery during the day. This setup reduces the need to idle the truck engine or look for spare wall outlets at campground facilities, keeping your gear powered directly from the truck bed.
1800W Powerful Output: 3600W surge output. With X-Boost™ tech, it supports high-demand devices up to 2600W, such as microwaves, refrigerators, laptops, and heated blankets.
How Can You Make Truck Camping More Comfortable in Canada?
Canadian weather can turn on you fast. A mountain pass can hand you 22°C and sunshine at four in the afternoon, then a damp 4°C drizzle by midnight. A Chinook rolling through southern Alberta can swing the temperature twenty degrees.
Prepare for Rain, Wind and Changing Weather
A properly sealed topper with fresh weatherstripping along the tailgate gap keeps out road spray and sideways rain. Condensation is the sneakier problem: open the sliding side windows slightly or lift a roof vent an inch to let moist air escape, or your breath will frost the underside of the shell and drip onto you all night.
Protect Sleeping, Cooking and Power Gear
Dust and water find the smallest gaps, and a rubber tailgate seal kit saves your bedding from gravel dust after a day on forestry roads. A major part of camping with food is keeping ingredients clean and dry, so store your pantry staples, electronics, and the power station in weather-sealed totes under the bed platform, because whatever coats the box eventually coats everything in it.
Adapt the Setup for Longer Trips and Remote Campsites
Longer routes reward a stable routine:
  • Mosquito Mesh: Magnetic bug screens over the side windows pay for themselves during black fly season, which in Northern Ontario and Quebec runs from late May into July.
  • Levelling Blocks: Stepped plastic blocks under the tires keep your bed level on a sloped clearing.
  • Tailgate Awning: A quick-deploy awning or a tarp over the rear gives you dry standing room to cook when the rain settles in for the night — and on the BC coast in November, it will.
EcoFlow GLACIER Classic Portable Fridge FreezerEcoFlow GLACIER Classic Portable Fridge Freezer
How Do You Plan a Truck Camping Trip?
Before leaving, check your campsite, weather, road conditions, supplies, and truck setup.
Choose a Campsite That Matches the Truck Setup
Decide between a provincial park site and dispersed camping on Crown land, based on your route and how much solitude you want. Apps like iOverlander and Gaia GPS, along with provincial Crown land maps, make it easier to find legal spots that suit your truck’s length and clearance. Rules on stay limits, fires, and dispersed camping vary by province, so confirm them before committing after dark.
Check Weather, Road Conditions and Campground Rules
Check the forecast, road conditions, fire bans, and campground rules before you leave. On active resource roads in British Columbia or Alberta, learn the local radio protocol before you go, since loaded logging trucks share these roads and need much more room to stop.
Test the Truck Camping Setup Before Leaving
Set up the entire system in your driveway first: make the bed, light the stove, run the fridge, and check how the storage works when you reach for things half-asleep. One night at home, or even a few hours, will reveal the missing gear and the cable that is too short, at far less cost than discovering it six hours from the nearest town.
Truck camping doesn’t need an elaborate build or a spreadsheet. Get the sleep system right, carry a way to cook and keep food cold, pack for the weather you might get rather than the weather you’re hoping for, and give yourself enough power to keep the essentials alive. The best truck camping setup isn’t the fanciest one; it’s the one that gets used on a random Tuesday because everything is already packed and ready to go.
Disclaimer & Safety Notice
Crown land camping regulations, fire bans, and resource road protocols vary by province. Always verify local rules (e.g., Ontario Crown Land Use) and adhere to BC Forest Safety radio protocols when driving active logging routes. In bear habitat, strictly follow Parks Canada Bear Safety guidelines by keeping all food and coolers locked inside a hard-sided vehicle.
Is Truck Bed Camping Safe?
Yes. You sleep above damp ground inside a rigid, lockable shell that handles sudden weather and keeps scavengers out of your food. The rest is camp discipline: lock the topper, park facing your escape route, and keep scented items and the cooler in the locked cab rather than in your sleeping space, especially in bear habitat.
Can You Sleep in the Back of a Pickup Truck?
Yes, provided you have insulation underneath you and weather protection above you, like a canopy or a truck bed tent. A 6.5-foot or 8-foot bed gives you room to stretch out. A 5.5-foot bed calls for a sleeping platform, a tent extension, or a tailgate-down setup, unless you’re content to sleep on the diagonal.
What Is the Most Forgotten Item When Camping?
Lighting is easy to forget: people pack carefully for daylight, then eat dinner in the dark with a phone held between their teeth. Close behind are a backup lighter, levelling blocks, paper towels, and spare charging cables.
Can You Put a Regular Tent in a Truck Bed?
Yes, with limitations. A compact one- or two-person freestanding tent may fit a 6.5-foot or 8-foot bed, while anything larger fights the wheel wells. A dedicated truck bed tent fits better, with more headroom.
Camping
