DIY Power for Your Shed or Workshop: A Step-by-Step Guide to Installing a Small Solar Panel System in Canada
Your shed or workshop is your domain—a space for creativity, repairs, and projects. But without accessible power, its true potential remains locked. You're likely tired of noisy gas generators and the hassle of running long, hazardous extension cords from the house. You're ready for a clean, quiet, and robust power solution you can set up yourself.
This guide is your complete blueprint. We'll walk you through the entire process, from planning your power needs to installation. We will cover the basics of a traditional component build and introduce you to a modern, all-in-one solution that makes powering your Canadian shed easier, safer, and more powerful than ever before.
Step 1: Planning Your Power Needs (The Universal First Step)
Before you buy anything, a smart plan will save you time and money. First, let's calculate how much power you actually need. This is measured in Watt-hours (Wh). The formula is simple:
DeviceWatthours(Wh)=DevicePower(W)×RunTime(Hours)
Create a list for a typical day in your workshop to find your total daily need.
Example Workshop Power Calculation:
  • 2 x 15W LED shop lights running for 4 hours = 120 Wh
  • 1 x Cordless tool battery charger (60W) running for 2 hours = 120 Wh
  • 1 x Small speaker/radio (10W) running for 3 hours = 30 Wh
  • Total Daily Need: 270 Wh
This calculation is your foundation. It will tell you exactly what size system you need to power your projects reliably.
Step 2: Choose Your Path – A Traditional Build vs. A Modern Power Station
To get power to your shed, you have two distinct options.
Path A: The Traditional Component Build
This is the classic DIY route. It involves researching, sourcing, and wiring several separate components together:
This path can be a rewarding challenge but requires a solid understanding of electrical principles to safely match component voltages, calculate wire gauges, and avoid damaging your equipment or creating a fire hazard.
Path B: The Modern All-in-One Power Station
This is the evolution of personal power. An all-in-one power station integrates all the complex components—a long-lasting, high-tech battery, a smart MPPT solar controller, and a powerful Pure Sine Wave inverter—into a single, portable, ready-to-use unit.
This modern approach offers clear advantages:
  • Plug-and-Play Simplicity: It eliminates complex wiring and component matching.
  • Certified Safety: The unit is engineered and tested as a complete system, removing the risks of DIY electrical work.
  • Portability: Power your shed for a project, then take the unit with you camping, to a job site, or use it for home backup during a power outage.
  • Advanced Power: Run high-wattage tools that would overwhelm a basic DIY kit, thanks to advanced technology like EcoFlow’s X-Boost.
Step 3: Your Shopping List (Presented with Two Clear Options)
(Note: Pricing is for example purposes and is subject to regional variation. Please check the Canadian EcoFlow store for the most accurate pricing and availability.)
Option 1: For a Traditional Build
  • Solar Panel(s) and mounting hardware
  • MPPT Charge Controller
  • 12V AGM or LiFePO4 Battery
  • Pure Sine Wave Inverter
  • Correctly-gauged wiring, in-line fuses, and connectors
Option 2: For an All-in-One Power Station System (The Recommended Path)
Power your outdoor adventures with RIVER 2 Pro. Fast recharging, 800W output, and lightweight design—perfect for camping, road trips, or emergency backup.
Choose Your Power Station:
  • For Light Use (Lighting & Charging): The EcoFlow RIVER 2 Pro
  • Key Specs: 768Wh Capacity | 800W Output (1600W X-Boost) | LiFePO4 Battery
  • Best for: Powering all your shed lights, charging multiple tool batteries simultaneously, and running smaller tools like rotary tools or sanders. It’s lightweight (18.2 lbs / 8.2 kg) and is the first power station to earn a TÜV Rheinland safety certification, guaranteeing its reliability.
  • For General Workshop Use (Power Tools): The EcoFlow DELTA 2
  • Key Specs: 1024Wh Capacity | 1800W Output (2400W X-Boost) | LiFePO4 Battery
  • Best for: The serious hobbyist. With a massive 1800W of continuous power, the DELTA 2 confidently runs demanding tools like circular saws, drills, and grinders without breaking a sweat.
  • For Maximum Power & Pro Use: The EcoFlow DELTA 2 Max
  • Key Specs: 2048Wh Capacity | 2400W Output (3400W X-Boost) | LiFePO4 Battery
  • Best for: The no-compromise workshop. With 2400W of pure power (and the ability to handle up to 3400W with X-Boost), you can reliably run a table saw, a small air compressor, or multiple tools at once. It’s the ultimate, silent replacement for a gas generator.
Choose Your Solar Panel(s):
Pair your power station with our high-efficiency portable solar panels. The 220W Bifacial Portable Solar Panel is a fantastic match for the RIVER 2 Pro and DELTA 2, while one or two 400W Solar Panels can be used to create a powerful solar array for the DELTA 2 Max.
Step 4: The Installation Process (A Tale of Two Setups)
The Power Station Installation: A Simple 3-Step Process
This is where the modern path truly shines. The installation is incredibly simple and can be completed in under an hour.
Mount Your Solar Panel.
Securely fasten your EcoFlow Solar Panel to your shed roof or a sunny spot on the ground, facing south for maximum sun exposure.
Run the Solar Cable.
Safely run the included solar cable from the panel into your shed. Use a weatherproof entry gland for a clean, sealed pass-through.
Plug and Play.
Plug the solar cable directly into the solar input port on your power station.
That’s it. You now have a silent, clean, and powerful source of electricity, ready to go.
A large 400W solar panel array is set up for a DIY installation to power a demanding Canadian workshop.A large 400W solar panel array is set up for a DIY installation to power a demanding Canadian workshop.
2 Key Advantages for Canadians: Regulations & Winter
Simplified Regulations
As EcoFlow power stations are CSA-certified, portable appliances, they typically do not require the same complex electrical permits as a permanently wired-in system. This can save you significant time and administrative hassle. (As always, it's a good practice to check your local municipal rules).
Superior Winter Performance
Worried about the cold? Our systems are built for the Canadian climate.
  • Low-Temperature Operation: The advanced LiFePO4 batteries in these models can safely power your devices in temperatures as low as -10°C (14°F), perfect for a chilly autumn or spring day in the workshop.
  • Charge Anywhere: On the darkest winter days, you have ultimate flexibility. Simply carry your power station inside and charge it from a standard wall outlet. The DELTA 2 charges from 0-80% in just 50 minutes—a feature impossible with a fixed system.
FAQ: Your Power Station Questions Answered
Q: Can the EcoFlow DELTA 2 really run my mitre saw?
A: Absolutely. A typical 10-inch mitre saw requires about 1800W to operate. The DELTA 2 provides 1800W of continuous power and can handle the tool's startup surge of up to 2700W, making it a perfect match.
Q: How long will the battery last? This seems like a big investment.
A: It’s a long-term investment in quality. The LiFePO4 batteries in these units are rated for over 3000 charge cycles. This means you can use and recharge the unit every single day for nearly 10 years before its capacity shows any significant degradation.
Q: How fast can I recharge with solar?
A: Charging speed depends on the panel size and sun intensity. For example, you can fully recharge a DELTA 2 with a 400W solar panel in as little as 3 hours in ideal sunny conditions.
Conclusion: Power Your Passion Project
Stop planning complex wiring diagrams and start planning your next project. An all-in-one power station is the simplest, safest, and most powerful way to bring your Canadian shed or workshop to life. You get more power, more flexibility, and more time to focus on what you love to do.
Ready to simplify your power project? Explore the EcoFlow DELTA Series today and discover the perfect power station for your workshop.
Solar Panels
