Power Outage Markham: How to Check Outages, Report Problems, and Keep Your Home Powered
Dinner time in Markham, you flick the lights off, your fridge shuts down, and your Wi-Fi goes out. But how bad is your outage? Is it only your property? Is it a whole street? Or is it affecting your whole neighborhood? Without knowing, it can be hard to know what to do.
Power outages in Markham, Ontario, can happen because of extreme weather or other unexpected events. On August 13, 2026, more than 6,000 Alectra customers in Markham experienced a power outage.
This guide makes it easy to check for outages in Markham, find updates on restoration times and report any issues. You’ll also find tips to help you prepare for your next outage.
How to Check a Power Outage in Markham Today
First, determine how widespread the outage is. Is it just affecting your property, or your neighborhood? Use official sources from your electricity distributor.
Check the Alectra Utilities Outage Map
Alectra Utilities is the main source for most addresses in Markham. Use their outage map to see if there are any reported outages. Determine which area is affected, any updates, and the estimated time for power restoration. Estimates can change depending on how much damage there is.
Check Hydro One for Applicable Service Areas
Hydro One has its own outage map. If you get your service through Hydro One, you can use this tool to check outages. Click on any outage to see how many customers are affected, the crew's status, the cause (if known), and the estimated restoration time. Hydro One says its map and app are updated every 10 minutes.
How to Report a Power Outage in Markham
Sometimes you may have a power outage in Markham, but it is not showing on the map. Don’t assume someone has already reported it, report it using official channels.
Report the Outage to Alectra Utilities
Call 1-833-253-2872 (Option 1). They will have staff available 24/7. Alternatively, you can use the online form or web chat on their website.
Check Your Electrical Panel Before Reporting
Before calling, check your neighbors. Are their lights working? If only your property is affected, check your breaker box to see if a breaker has tripped.
If you see any of the following:
  • Frequent breaker trips
  • Smell of burning
  • Sparking or visible sparks
  • Damaged wiring
Do NOT get close to any downed power lines. Stay at least 10m away and call 911.
How to Prepare for Future Power Outages in Markham
canadian-family-winter-power-outage-preparedness-portable-power-station-emergency-suppliescanadian-family-winter-power-outage-preparedness-portable-power-station-emergency-supplies
A home battery backup or portable power station can be used to keep certain devices powered during an outage. Before choosing one, it helps to know a few key terms.
  • Capacity (Wh/kWh): How much energy the battery can store. The higher the capacity, the longer it will run.
  • Output (W): The amount of power it can deliver at once, which determines what you can run.
Know your appliances' wattage, their starting wattage, and how they connect. For more ideas on planning for an outage, read our winter storm checklist for markham power outages.
Backing Up Multiple Home Circuits During Extended Outages
whole-home-battery-backup-system-markham-ontario-power-outagewhole-home-battery-backup-system-markham-ontario-power-outage
Imagine an ice storm that takes out power on multiple streets in Markham for hours. You need your fridge, furnace fan, a few lights and your router to still be powered. You wish you could have just these circuits powered.
If you’re a homeowner looking for a larger capacity solution, the EcoFlow TITAN 5000 Whole Home Battery Backup 5-30kWh would be perfect. It comes with a 5kWh LFP battery and 7,200W of AC Output. Please note that some appliances may not be able to run for the entire outage. Any connections to your home should be done by a qualified electrician.
EcoFlow TITAN 5000
1. 100% Whole-Home Backup. 7.2kW powers your 3-ton AC, refrigerator, and the rest of your home simultaneously, with no soft starter needed. 2. 100% Whole-Home Savings. Save up to $1,000/year. 3. Only 50% of Traditional System Cost. Industry-first 200V architecture, custom high-rate LFP cells, and a pre-wired SHP10 help lower costs across the entire lifecycle. 4. OASIS 3.0 — Your AI-based Home Energy Manager. Charges off-peak, powers your home during peak hours, and helps lower your electricity bill every day.
Expanding Backup Capacity for Longer Home Power Outages
If your power is out for an extended period of time, and you have solar panels or want to install some, you will want increased storage space and more solar charging.
The EcoFlow TITAN Plus Whole Home Battery Storage 5-30kWh unit lets you charge more solar into your system. This unit includes the same 5kWh battery and 7,200W output as our TITAN 5000 Plus. Your backup time will depend on the connected appliances, battery configuration, and conditions.
EcoFlow TITAN 5000 Plus
1. 100% Whole-Home Backup. 7.2–10kW output and 5kW single-circuit capacity power your 3-ton AC, refrigerator, and the rest of your home simultaneously, with no soft starter required. 2. 100% Whole-Home Savings. Save up to $1,100 per year. 3. Only 50% of Traditional System Cost. Industry-first 200V architecture, custom high-rate LFP cells, and a pre-wired SHP10 help lower costs across the entire lifecycle. 4. OASIS 3.0 — Your AI-based Home Energy Manager. Charges off-peak, powers your home during peak hours, and helps lower your electricity bill every day.
What Causes Power Outages in Markham?
Power outage markham can affect an entire street or section of a neighborhood, depending on what the cause of the issue is.
Severe Weather and Storm Damage
High winds, icy rain, heavy snowfall, tree branches falling and flooding can all cause damage to the power lines and equipment. This can also cause delays in crews getting to the site.
Vehicle Collisions and Equipment Failures
Poles, Transformers, Underground Cables and much more can be damaged, causing a power outage.
According to the outage map provided by Alectra, this local outage on 13 August 2026 was due to a vehicle collision with equipment. There was also a serious incident reported nearby, but it was unclear if these were linked.
If you experience a power outage in Markham, Ontario, check your utility’s outage map, report any unlisted outage, and follow electrical safety guidance.
A backup power source keeps essential devices running during repairs. Our EcoFlow TITAN 5000 Whole Home Battery Backup 5-30kWh can be used depending on your household’s power requirements. For more safety tips, read our article on how to stay safe, warm and connected during a winter power outage Markham.
How do I check if there is an electricity outage in my area?
Check your power distributor’s power outage map. Most areas in Markham use Alectra. If your property uses Hydro One, check its map for affected areas, updates and estimated repair time.
How can I check for a power outage in my area?
Firstly, check if your neighbors are also losing power. If it is just your property, check that your breaker is working (if it is safe to do so). Check your utility’s official outage map and sign up for alerts.
Why did the power suddenly go out?
Common reasons include extreme weather, tree branches falling, damaged equipment and vehicle collisions with poles and transformers. Once the crews know the cause, it may show on your utility’s power outage map.
What should you do first when the power goes out?
Check your utility's Markham power outage today on map. If it does not show, report the outage. Keep the fridge door closed. If you see a power line down, stay 10 meters away and call 911.
How long will my fridge be OK during a power cut?
Normally, a sealed fridge will keep your food cold for around 4 hours. If your freezer is full, it can last around 48 hours. If it is half full, it can last around 24 hours.
Power Outages
