Power Outage in Orillia: How to Check, Report and Prepare
To check a power outage in Orillia, start with Hydro One's official outage map. Confirm the distributor on your electricity bill, then look up your service address.
The map provides the utility's latest information, including a restoration estimate when one is available. That estimate can change as crews inspect the damage, so check its update time.
If you see a fallen wire or another immediate danger, stay back and call for help first. Otherwise, check the incident, report any missing interruption, and use the steps below to plan while you wait.
How Do You Check a Power Outage in Orillia?
Use the Hydro One outage map to check the service address affected by the interruption. Searching the address helps you find the incident that applies to your home.
If you remember the Orillia Power name, note that Orillia Power Generation directs distribution enquiries to Hydro One. Use Hydro One's outage reporting routes below, rather than the generation company's general contact number.
To check a Hydro One power outage in Orillia, follow this order:
  1. Confirm the distributor on your bill, especially for a property outside the city.
  2. Search your address or postal code on the official map.
  3. Select the matching incident and review the details available.
  4. Check the cause, crew status, and estimated restoration time, if shown.
  5. Look at the map's last-update timestamp before relying on the information.
Hydro One updates its map every 10 minutes. Its map guide explains the incident details and where to find the timestamp in the summary.
Treat the estimated time of restoration, or ETR, as a planning estimate. Crews may revise it after finding more damage or learning what the repair needs.
A nearby street can use a different circuit, so its status may differ from yours. If the map won't load, use Hydro One's outage tools or call the reporting line. Don't assume an empty map means your service is working.
 Utility bill, address map, and phone icons for checking and reporting an outage Utility bill, address map, and phone icons for checking and reporting an outage
How Do You Report an Orillia Power Outage?
Report an Orillia power outage to Hydro One if your electricity is off and you can't find a matching incident. You can use its online, telephone, or text route.
Hydro One lists these options on its outages and safety page:
Reporting option
Where to report
When it helps
Online
Hydro One's outage-reporting form
You have internet access and can follow the form.
Telephone
1-800-434-1235
You need the outage and emergency line, available 24/7.
Text
Send “outage” to 92887 (WATTS).
You have mobile service. Messaging and data charges may apply.
For future updates, register for Hydro One outage alerts. You can manage alerts through myAccount or follow the utility's text-registration instructions. The service also covers upcoming planned outages.
Signing up for alerts is separate from reporting an interruption. If there's an immediate electrical hazard, call 911 and Hydro One rather than waiting for a routine map update.
Why Can Storm Outages in Orillia Last Longer?
Storm outages can last longer when damage affects many locations and crews can't reach them safely. A single local repair may restore service quickly, while widespread damage needs several repairs.
Ice adds weight to branches and overhead equipment. Wind can bring down weakened limbs, and blocked roads can delay access. Crews must check the damage and make the site safe before repairing it.
The March 2025 Orillia ice storm power outage shows how serious that disruption can become. The City's 2025 operations report records an emergency declaration on March 30 after prolonged freezing rain. Trees suffered major damage, and power restoration took up to a week in some areas.
For longer interruptions, plan backup for the plug-in loads you need most. EcoFlow TITAN Classic provides 5 kWh of base storage and 4 kW output at 120 V.
•5 kWh LFP battery capacity, expandable from 5–30 kWh with compatible TITAN Batteries • 4 kW AC output for a planned group of compatible essential loads •120 V output only, so it doesn't support 240 V appliances • Up to 3.2 kW solar input through one MPPT
You can plan for compatible refrigeration, lights, or a router within its output and startup limits. Internet access still depends on your provider's network, even if your router has power.
Direct plug-in use doesn't require Smart Home Panel 10. To back up household circuits, Classic needs the compatible 120 V panel and professional installation.
Keep the unit indoors, dry, and with its vents clear. It doesn't supply 240 V loads, and runtime depends on every connected device and operating conditions.
The 2025 storm is a dated event, not a forecast for your current outage. Use today's utility update rather than expecting that repair timeline to repeat.
For current weather, check Environment and Climate Change Canada's Orillia forecast and alerts. Keep weather warnings separate from Hydro One's service updates because each answers a different question.
 Ice-coated branches beside a residential street in central Ontario Ice-coated branches beside a residential street in central Ontario
What Should You Do While the Power Is Out?
Use safe lighting, protect cold food, and stay clear of electrical hazards while service is interrupted. Check on household needs before spending time refreshing the map.
Start with these simple actions:
  • Use flashlights instead of candles.
  • Turn off the stove, oven, and other cooking appliances left on.
  • Keep fridge and freezer doors closed as much as possible.
  • Save phone power for calls, alerts, and useful updates.
  • Keep a battery radio available if internet service stops.
Health Canada's food-safety guidance says an unopened fridge keeps food cold for about four hours. Check the temperature with a fridge thermometer, and follow the guidance when deciding what to keep. Don't store perishable food outside in the snow.
Stay at least 10 metres from a fallen powerline or anything touching it. Ontario's Electrical Safety Authority advises calling 911 and the local utility immediately. Don't try to clear a branch from a wire.
Stay out of floodwater near electrical equipment, including a flooded basement. Don't touch a wet panel, meter, outlet, or damaged service connection.
Operate portable fuel generators outdoors at least 6 metres from buildings, with exhaust away from openings. Never run them in a garage or shed, even with doors open. Keep barbecues and camping stoves outside too, following Health Canada's carbon monoxide precautions.
If your home becomes too cold or otherwise unsafe, follow local directions and move somewhere safer. The City of Orillia's emergency information explains Alertable notices. Check current facility information before travelling to a warming location.
How Can You Prepare Before the Next Storm?
Keep an accessible emergency kit, written contacts, and charged communication devices ready before an Orillia storm power outage. Plan to meet your household's needs for at least 72 hours.
That preparation period covers more than electricity. Your emergency supplies for a power outage should include water, ready-to-eat food, a manual can opener, lights, a radio, warm clothing, and pet supplies.
Save Hydro One's number offline and keep charging cables beside the kit. Test your lights and backup equipment before winter. Make a plan that still works if mobile data, elevators, or your garage opener are unavailable.
Test your planned backup loads while utility power is available, following the equipment's manual. A 72-hour household plan doesn't mean one battery charge must power every device for that whole period.
Water, food, flashlight, radio, blanket, and charging supplies in an outage kitWater, food, flashlight, radio, blanket, and charging supplies in an outage kit
How Much Backup Power Do Your Priority Loads Need?
Size backup from the loads that run together and the energy they use over time. Check power, stored energy, voltage, and the connection method separately.
Calculate Power and Stored Energy
Watts and kilowatts measure power at one moment. Watt-hours and kilowatt-hours measure energy used or stored. One kilowatt-hour equals 1,000 watt-hours.
List your priority loads and add their running watts. Motors and compressors may need extra power to start, so use this preliminary output check:
Initial output target (W) = simultaneous running watts + largest additional startup demand
The total alone doesn't tell you whether the setup will work. Check voltage, outlet limits, and which motors might start together. Your installer also needs to check the limits on each 120 V side.
For stored energy, use the average combined load and your planned operating time:
Estimated energy needed (Wh) = average load (W) × operating time (h)
An assumed 250 W average load over eight hours uses 2,000 Wh, or 2 kWh. This is an illustration before losses and reserve, not a measured appliance rating or a runtime promise.
Cycling, temperature, settings, battery condition, and recharge access change the actual result. Some stored energy is lost when the system converts it to AC power.
Plan Selected-Circuit Backup
Hardwired loads need a compatible installed system rather than a direct plug-in connection. Plan the circuits and their demand before an outage.
EcoFlow TITAN supplies 7.2 kW with 120 V/240 V support and 5 kWh base storage. For the selected-circuit setup, it pairs with the compatible 120 V/240 V Smart Home Panel 10. Hire an Ontario Licensed Electrical Contractor to install it and handle the required permits and inspections.
EcoFlow TITAN
• 5 kWh LFP battery capacity in the base unit • Expandable from 5–30 kWh with compatible TITAN Batteries • 7.2 kW AC output with 120 V/240 V split-phase support •Up to 4 kW solar input through one MPPT
Classic remains a 120 V choice and can support selected 120 V circuits through its compatible installed panel. Both models start with the same stored energy, so TITAN's higher output doesn't by itself mean longer runtime.
Compatible added batteries increase stored energy, not rated inverter output. Keep the system indoors and dry, and never feed household circuits through a wall outlet or an improvised connection.
Check Your Address and Plan Your Backup Loads
For a power outage in Orillia, use the official update for your address and report service that hasn't returned. Save the reporting number, keep supplies nearby, and check municipal notices when local services are affected.
Before choosing backup equipment, list your priority loads, connection needs, and planned operating time. With those details recorded, compare portable power stations against your power and capacity needs.
How do I check if there's a power outage in my area?
Confirm the distributor on your bill, then search your address on its official outage map. For a Hydro One property, check the incident and timestamp. If the map or internet isn't available, call 1-800-434-1235 for outage information.
How can I check how many customers are without power in Ontario today?
Hydro One's map summary shows its own affected customers, not everyone across Ontario. A province-wide total needs current information from other distributors too. Customer accounts aren't a count of people, and the utility-wide figure doesn't describe Orillia alone.
Why is my power off when nearby homes still have electricity?
Your home may use a different connection, or damage may affect only its service equipment. A neighbour's electricity doesn't prove the cause. Report the interruption and arrange licensed repairs if customer-owned electrical equipment is damaged.
What should I do if my area is marked restored but my home is still without power?
Report the remaining interruption to Hydro One rather than assuming every connection is repaired. Damaged customer-owned equipment may need a Licensed Electrical Contractor before reconnection. Renters should also notify their landlord or building manager about property damage.
Power Outages
