Ottawa Ice Storm Prep: How to Keep Your Home Powered
Ottawa sits in one of Canada’s most ice storm prone regions. Freezing rain events in 1998 and 2023 both knocked out power to large parts of the city for days. When an Ottawa ice storm hits, the biggest risk isn’t the ice itself. It’s losing heat, refrigeration, and communication for an extended stretch. This guide looks at why Ottawa gets hit so often, what past storms revealed about outage length, and how homeowners can realistically prepare to ride out a multi-day outage at home.
Why Ottawa Weather Makes Ice Storms So Common
Ottawa’s location puts it directly in the path of winter systems that bring rain, not just snow. A specific mix of warm and cold air layers turns that rain into ice on contact with the ground. Understanding why this keeps happening here helps explain why outage preparedness matters more in Ottawa than in many other Canadian cities.
Ottawa sits near the boundary where warm air from the south regularly overrides a shallow layer of subzero air at the surface. Rain falls as liquid through the warm layer, then freezes instantly when it touches cold roads, trees, and power lines. The Ottawa Valley and the St. Lawrence corridor see this pattern more often than most of the country, which is part of why the city has faced severe freezing rain more than once in recent decades. Ice accumulation of even a few millimetres can add significant weight to tree limbs and power lines, and that weight is what causes most storm-related outages.
Freezing rain warnings from Environment Canada are the main signal to watch for an approaching Ottawa ice storm. When one is issued, outages become a real possibility within hours, not days.
What the 1998 and 2023 Ice Storms Taught Ottawa Homeowners
ice storm 98 ottawaice storm 98 ottawa
Ottawa has lived through two major ice storms in recent memory, and both left lasting lessons about how long an outage can actually last. Looking at what happened in each event gives a realistic sense of what to plan for, rather than relying on guesswork.
The January 1998 ice storm remains the benchmark for severity in eastern Canada. It knocked out power to more than four million people across Quebec, Ontario, and parts of Atlantic Canada, with some areas waiting over a week for restoration, according to The Canadian Encyclopedia. Kingston saw an 80 percent downtown blackout, and the storm is still linked to several deaths across the region.
The April 2023 ice storm was smaller but still serious. Freezing rain coated Ottawa before dawn on April 5, and by the time crews finished repairs, about 1.3 million people across Ontario and Quebec had lost power, according to a summary of the event. Hydro Ottawa alone reported 56,000 customers without electricity. Most outages were resolved within five days, though some areas took closer to a week.
Event
Date
People Affected (regional)
Typical Outage Length
Great Ice Storm
January 1998
4+ million
Up to 1-2 weeks in hardest-hit areas
2023 Canada Ice Storm
April 2023
1.3 million
Mostly within 5 days, some up to a week
Both events point to the same conclusion. An Ottawa outage caused by ice is rarely a quick fix, and households need a plan that covers several days, not a single evening.
Knowing that multi-day outages are a realistic possibility raises a practical question. What kind of backup power actually holds up for that long, and what should homeowners look for.
Backup Power Options for a Multi-Day Ottawa Outage
When the power goes out for days instead of hours, the priority shifts from convenience to keeping a home functional. That means refrigeration, lighting, communications, selected kitchen and laundry loads, and in many homes, heating-related circuits need to keep running. Portable power stations help with smaller loads, but they run out of capacity fast when a whole house needs coverage.
EcoFlow’s new TITAN Series was built for exactly this kind of extended outage. It keeps EcoFlow’s modular design and performance, but EcoFlow has leveled up the cells, architecture, and intelligence behind it. The core idea is simple: whole-home backup shouldn’t require the $20,000 to $30,000 CAD price tag that conventional home batteries typically carry.
For larger Ottawa homes, TITAN Plus is the flagship option. It can reach up to 10kW of total system output when its 7.2kW battery output works together with compatible solar, though the battery alone does not produce 10kW on its own. It supports up to 8kW of DC solar input through two independent MPPTs, includes a 50A high-power outlet, and supports EV charging. Time-of-use scheduling through the EcoFlow App can also auto-charge during low-rate hours and discharge during peak hours, which matters for anyone on an Ontario time-of-use electricity plan.
EcoFlow TITAN Plus
•5 kWh LFP battery capacity, expandable from 5–30 kWh with compatible TITAN Batteries •7.2 kW battery-only output, reaching up to 10 kW when compatible battery and solar output work together •Up to 8 kW solar input through two independent 4 kW MPPTs • Works with EcoFlow Smart Home Panel 10 to back up and manage up to 10 selected circuits, with automatic switchover within 20 ms
For an apartment or smaller home that only needs basic 120V backup for a refrigerator, lighting, and a router, TITAN Classic is the lower-cost entry point. It isn’t built for 240V appliances like central air, so it suits a narrower set of households.
EcoFlow TITAN Classic
• 5 kWh LFP battery capacity, expandable from 5–30 kWh with compatible TITAN Batteries •4 kW AC output for a planned group of compatible essential loads •120 V output only, so it doesn't support 240 V appliances • Up to 3.2 kW solar input through one MPPT
Both TITAN and TITAN Plus replenish through solar or a generator, which matters during an Ottawa ice storm when sunlight can be limited for days. Setup relies on modular, factory-wired components designed for straightforward DIY installation. Any connection into a home’s electrical panel, including EcoFlow’s Smart Home Panel, still needs a licensed electrician to meet local code requirements.
With outages already shown to stretch past a week in past storms, the next question is how to actually get through those days safely.
Staying Safe and Comfortable Through an Extended Outage
ottawa weather ice storm preparednessottawa weather ice storm preparedness
Backup power solves part of the problem, but safety during an extended outage depends on a few other habits too. Carbon monoxide risk, food safety, and communication all become bigger concerns the longer an outage runs.
Running a generator, barbecue, or any fuel-burning appliance indoors is one of the most dangerous mistakes during an ice storm outage. Public health officials recorded over 100 carbon monoxide poisoning cases during the 2023 ice storm alone, many linked to people using outdoor appliances inside for heat. A battery-based backup system avoids this risk entirely since it produces no combustion byproducts indoors.
Keeping refrigerators and freezers closed as much as possible preserves cold air longer, and a plan for charging devices during a lengthy blackout keeps households connected to storm updates and emergency services. Layering warm clothing and closing off unused rooms also reduces how much heating load a backup system needs to carry.
Ottawa’s history with ice storms, from 1998 to 2023, shows that outages here often last days, not hours. Preparing means more than a flashlight and candles. It means having enough backup power to run a refrigerator, lights, and communications through an extended blackout. EcoFlow’s TITAN Series offers a whole-home backup option built for exactly that kind of outage, without the price tag of a traditional home battery system.
How long do power outages typically last after an Ottawa ice storm?
Past Ottawa-area ice storms show outages commonly lasting several days. The 2023 storm saw most repairs completed within five days, while the 1998 storm left some areas without power for over a week.
What caused the 1998 ice storm in Ottawa?
A warm, moist air layer moved over a shallow pocket of freezing air near the surface. Rain fell as liquid, then froze instantly on contact with trees, roads, and power lines across the region.
Can a home battery system like TITAN run air conditioning or heating equipment?
TITAN and TITAN Plus support 240V output, which covers air conditioning and central systems, depending on the home’s wiring and which circuits are connected. TITAN Classic is limited to 120V backup only.
Do I need an electrician to install a TITAN system?
Any connection to a home’s electrical panel or a Smart Home Panel needs a licensed electrician to meet local code. EcoFlow does not currently operate an installer network in Canada, though the system itself uses modular, factory-wired components designed for simple setup.
Is freezing rain more dangerous than snow for power outages?
Ice adds significant weight to power lines and tree branches in a way snow typically doesn’t, which is why freezing rain events have historically caused some of the largest and longest outages in the Ottawa region.
Power Outages
