Power Box: What It Is, How It Works, and How to Choose One
When the power goes out, the campsite has no outlets, or a job site is far from the nearest socket, a battery-powered power box can keep your equipment running. These portable battery packs store energy and provide power through AC, USB, and DC outlets. They can charge a phone, power a laptop, keep a mini-fridge cold, run power tools, and more without the noise and fumes of a gas generator.
Let’s look at what a power box is, how it stores and distributes energy, and how to choose one, including capacity, output power, charging speed, and solar system compatibility.
What Is a Power Box?
A power box is actually a catch-all term, so it helps to know which kind someone means. At its simplest, it’s an enclosure that holds or distributes electrical power. Some store energy in a battery, while others only route and protect circuits. In some regions, the term even refers to a street-side utility cabinet.
Common Types of Power Boxes
DIY battery boxes for camping, electronics and emergency power.
RC power boxes that manage power for receivers and servos in remote-controlled models.
Ready-made portable power stations with built-in batteries, outlets and charging, often called a portable power box.
An eliminator power box is usually a specific retail product line of compact power packs, not a universal category.
How Does a Power Box Work?
A battery power box stores energy in cells; fuses and switches protect it, charging inputs refill it, and an inverter converts DC to AC when needed. Distribution-only boxes, like an RC power box, route power without storing any.
Choosing a Power Box for Home Backup and Portable Power
Capacity, output, charging, portability and safety will determine which system is right for you. First, battery capacity (Wh) tells you how long you can run equipment, and output power (W) tells you what you can run at once. Then consider charging options and how easy it is to move the system. Whole-home backup systems and smaller portable stations serve different needs, so choose the right tool for the job.
Higher-Capacity Backup for Essential Home Circuits
If you want to keep several household circuits running during an outage, a ready-made system makes more sense than a basic DIY battery box. The EcoFlow TITAN 5000 combines a 5kWh LFP battery with 7,200W of 120V/240V output and can expand to 30kWh with compatible TITAN batteries.
Add the Smart Home Panel 10 (sold separately) to back up up to 10 selected circuits; a licensed electrician must complete the installation. At 54 kg and designed for dry indoor spaces, it’s a floor-standing home unit, not something you carry around.
Expandable Home Backup With More Solar Capacity
If you’d rather skip building a custom battery enclosure, the EcoFlow TITAN 5000 Plus is a ready-made, expandable alternative. Its 5 kWh LFP battery can expand to 30 kWh with compatible TITAN batteries, giving you more capacity when you need it. It delivers 7,200 W of 120 V/240 V AC output, which increases to 10,000 W when powered by battery and solar together. Two independent 4 kW MPPT inputs make it easy to support up to 8 kW of solar.
Paired with Smart Home Panel 10, you can plan backup for up to 10 selected circuits, subject to professional installation. More solar input doesn’t guarantee a specific charging speed or appliance runtime. At 55 kg, this is a modular home system, not a carry-anywhere unit.
DIY Power Box vs Portable Power Station: What’s the Difference?
The main difference is how much you need to assemble yourself versus how much is ready to use out of the box. A DIY power box fits hobbyists who enjoy choosing each component, while a portable power station combines the battery, inverter, and charging in one convenient, ready-made unit.
Feature | DIY Power Box | Portable Power Station |
Battery | Selected separately | Integrated |
Inverter | May need separate installation | Typically built in |
Charging | Depends on the design | Integrated charging options |
Customization | High | Limited to supported accessories |
Setup | Requires technical knowledge | Generally simpler |
Typical applications | RC projects, camping, custom electronics | Home backup, outdoor appliances, emergency electricity |
Neither is better in every case. The right choice of eliminator power box depends on your electrical needs, your technical skill and what you’ll use it for.
How to Choose the Right Power Box
Four checks narrow the field quickly: capacity and output, charging, safety and weight.
Check Battery Capacity and Output
Watt-hours (Wh) measure how much energy is stored, while watts (W) measure how much power you can draw at once. A 100W device should run for 10 hours on a 1000Wh battery in theory, but in practice you will get less due to losses in the conversion process. More capacity means longer runtime, while higher output lets you power higher-wattage equipment if it’s compatible.
Compare Charging Options
Find out how quickly each option charges by checking for AC wall charging, solar input and vehicle charging where supported.
Check Portability and Safety
Make sure you have the right fuses, overload protection, battery management, good ventilation, a weight that you can comfortably handle and somewhere safe to store it. Any DIY power box should use correctly rated parts and be assembled by someone with the right skills. For safety, leave any connection to household circuits to a qualified electrician.
DIY battery boxes, RC power boxes, and integrated portable power stations may share a name, but each serves a different purpose. Before you buy or build, take a moment to consider what you need to power, how much output it requires, and the battery capacity you’ll need. When you’re ready to compare options, explore EcoFlow’s backup power solutions for your home and on the go.
What is a powerbox?
A power box, sometimes written as “powerbox,” is a broad term for an enclosure that stores, converts, or distributes electricity. It could be a DIY battery box, a power distribution unit for RC models, or a ready-made battery station with a built-in inverter and outlets. Its purpose depends on how it’s designed.
What is the electrical power box called?
In a house, the main electrical power box is often called a breaker box or an electrical panel (or, in Canada, a loadcentre). It draws power from the utility meter and distributes it to circuits, each protected by a breaker. You may also hear it called a service panel or distribution board. For safety, leave any work inside it to a licensed electrician.
What is the best power box to buy?
There isn’t one best option for everyone; it depends on what you need to power. A small, portable power box can be a great fit for phones, lights, and laptops. If you need to support several household circuits, a ready-made home system like the EcoFlow TITAN 5000 or TITAN 5000 Plus is designed for that purpose.
How much does a powerbox cost?
Prices can vary quite a bit. Compact, jump-starter-style power packs listed by Canadian retailers typically range from about $120 to $480. DIY builds can also vary depending on the parts you choose. Home systems are a bigger investment: EcoFlow Canada lists the TITAN 5000 and TITAN 5000 Plus with the Smart Home Panel 10, plus professional installation, which costs extra.
How does a powerbox work?
In a battery power box, cells store the energy, a battery management system and fuses protect it, and an inverter converts DC to AC for standard plugs. Charging comes from the wall, solar or a vehicle. A distribution-only box doesn’t store anything. It just routes and protects power from a source.
