Tempete Verglas Quebec: Lessons From the 1998 Crisis
Quebec's 1998 ice storm, or tempête de verglas au Québec, showed why your outage plan needs more than charged batteries. Repeated freezing rain struck parts of eastern Canada from 4–10 January, but some communities faced weeks without power.
For your household, the lasting lesson is to plan separately for electricity, supplies, and safe warmth. This guide explains the historical crisis and how to prepare for longer disruption, without treating 1998 as a forecast for the next storm.
What Happened During Quebec's 1998 Ice Storm?
The disaster unfolded through repeated storms, followed by a much longer recovery. Keep those periods separate when you judge what the dates mean for household planning.
Separate the Storm Dates From the Recovery
Quebec's 1998 ice storm (verglas de 1998 au Québec) involved several episodes of freezing rain and ice pellets. Veterans Affairs Canada's chronology identifies the weather period and the later relief effort.
These milestones describe different stages of the event:
Date in 1998
Milestone
What It Means
4 January
The series of storms began.
Conditions developed over several days.
7–8 January
Provinces requested federal help, then Operation Recuperation began.
Recovery involved more than restoring electricity.
10 January
The series of storms ended.
The rain stopped before every home regained power.
28 February
Operation Recuperation ended.
This wasn't a single restoration date for all homes.
Military help included road clearing, shelter, and support for repairs. The operation's end date therefore doesn't describe how long rain fell at your address.
Keep Quebec Impacts Separate From Regional Totals
At the disaster's peak, 1,291,500 Quebec residences lacked power, according to the Canadian Disaster Database. That is a residence count, not a count of people or utility accounts across eastern Canada.
Eastern Ontario and New Brunswick were also affected. Keeping the locations and units clear prevents several different totals from becoming one misleading figure.
Damaging Quebec ice storms also predate 1998. An earlier southern Quebec ice storm in December 1942 disrupted power and transport. It was a separate event, not the beginning of the January 1998 crisis.
Why Did the Ice Storm Become a Prolonged Crisis?
Ice damaged the networks people relied on, so disruption continued after the weather improved. Glaze ice, or verglas, formed a coating that added weight to trees and electrical infrastructure.
Quebec's ice-storm crisis (crise du verglas au Québec) involved more than dark rooms. Ouranos reports that power outages lasted up to 35 days in some places. That wasn't the experience of every household or a prediction for future storms.
Use those service dependencies to identify the gaps in your own plan:
Disrupted Service
Household Consequence
Planning Question
Electricity
Lights, appliances, and some heating components stop.
Which loads need backup power?
Roads and access
Deliveries, repairs and travel may be delayed.
Where could you safely stay?
Communications
A charged phone may still lack network service.
What radio and check-in options remain?
Food and water
Refrigeration and some water systems need power.
What supplies remain usable?
Reserve Battery Energy for Selected 120 V Essentials
A fridge, efficient lighting, and communications create a different backup need from phone charging alone. List the equipment you need before choosing how much stored energy to buy. Check each appliance's instructions and starting demand before adding it to the group.
EcoFlow TITAN 5000 Classic gives that selected-load plan a 5 kWh starting battery and 4 kW AC output. It supports compatible 120 V equipment within its limits, but it can't supply 240 V appliances. If your backup plan only covers phone charging and a few small devices, you may not need this much storage.
1. 4,000W Whole-Home Essential Power. Run your fridge, microwave, Wi-Fi, lighting, and CPAP all at once. 2. 5–30kWh Expandable Capacity. Get 1 day to 1 week of essential backup. Add batteries anytime, with no installer needed. 3. <30 dB. Quiet enough for indoor use—quieter than a whisper. 4. ≤20 ms Automatic Switchover. The lights don’t even flicker. 5. OASIS 3.0 — Your AI-based Home Energy Manager. Charges off-peak, powers your home during peak hours, and helps lower your electricity bill every day.
If your assessed loads need higher output or 240 V, EcoFlow TITAN 5000 provides 7.2 kW of 120 V/240 V output. Its starting capacity is also 5 kWh, so higher output doesn't automatically give you longer runtime. These models are alternatives, not a pair you need to buy together.
EcoFlow TITAN 5000
1. 100% Whole-Home Backup. 7.2kW powers your 3-ton AC, refrigerator, and the rest of your home simultaneously, with no soft starter needed. 2. 100% Whole-Home Savings. Save up to $1,000/year. 3. Only 50% of Traditional System Cost. Industry-first 200V architecture, custom high-rate LFP cells, and a pre-wired SHP10 help lower costs across the entire lifecycle. 4. OASIS 3.0 — Your AI-based Home Energy Manager. Charges off-peak, powers your home during peak hours, and helps lower your electricity bill every day.
Compatible plug-in loads and household circuits require different connections. Circuit backup needs the appropriate Smart Home Panel 10 and a qualified, licensed electrician. Keep either battery dry, ventilated, and within its operating temperatures.
A sample arrangement of water, shelf-stable food, a radio and LED lighting.A sample arrangement of water, shelf-stable food, a radio and LED lighting.
How Can Your Household Plan for an Extended Outage?
Build a plan that can change as supplies run low or conditions worsen. A three-day kit is a starting point, not a deadline for power to return.
Build a Three-Day Base and a Continuation Plan
A refrigerator, LED light and phone considered in a household backup plan.A refrigerator, LED light and phone considered in a household backup plan.
Quebec's household emergency guidance calls for supplies covering your first three days. Keep drinking water, shelf-stable food, a manual can opener, battery lighting, and a radio accessible. Check the kit regularly rather than leaving it untouched between storms.
For Quebec glaze-ice conditions (verglas au Québec), your next decision is where you can go safely. Agree on a place to stay, a contact outside your household and an alternative travel route. Discuss the plan before icy roads make travel harder.
If you rent, ask about building notices, access arrangements and the evacuation plan. Don't assume your lift, entry system or usual charging point remains available during an outage.
As disruption continues, reassess the needs you've separated. Check water, food, warmth, remaining battery energy, and contact with others. Give each need its own next action, rather than waiting for one restoration estimate to solve them all.
Keep your destination and contact details on paper as well as your phone. A working plan should still be usable when your screen is dark, or the network fails.
Why Does Electric Heating Need a Separate Plan?
Electric heat can use stored energy much faster than lighting or phone charging. The ability to run a load doesn't establish how long you can keep running it.
Consider a hypothetical heating load averaging 1.5 kW for eight hours:
1.5 kW × 8 h = 12 kWh before losses or reserve.
That demand exceeds either model's 5 kWh starting capacity. The calculation isn't a heater recommendation, a tested runtime, or an estimate of your home's heat loss. Follow Health Canada's advice to unplug portable heaters before sleep.
Follow Quebec's prolonged-outage guidance if your home becomes unsafe. Your municipality can tell you which warming or temporary shelter services are available. Leave when authorities direct you to, or when your safety is at risk.
Keep these safety limits separate from any battery purchase:
  • Never run a barbecue, camp stove or fuel-burning generator inside a home or garage.
  • Test and maintain smoke and carbon monoxide alarms as their instructions require.
  • Arrange another safe place before a lack of warmth, water, or communications becomes dangerous.
A fixed number of hours doesn't establish that every home remains safe. Your household's needs and local instructions control the decision.
When Does Selected-Circuit Backup Make Sense?
An electrician reviewing a household plan beside a closed electrical panel.An electrician reviewing a household plan beside a closed electrical panel.
Selected-circuit backup makes sense when priority equipment needs a planned connection to household wiring. Have the electrical requirements checked before buying equipment or counting on a particular appliance.
Give your electrician three pieces of information. Identify what must run, what may run together, and how long you need it. Running watts alone don't capture a motor's higher starting demand.
Classic uses the compatible 120 V Smart Home Panel 10 configuration. The standard TITAN model requires the compatible 120 V/240 V configuration for its circuit setup. The panel and installation are separate requirements from buying the main battery.
No general output rating confirms that your furnace, heat pump, or well pump is compatible. Have voltage, starting demand, connection method, and operating limits checked for the exact equipment. Don't improvise a connection to a wall socket or electrical panel.
Then assess how you'll replenish energy. Extra batteries increase stored energy, not the main unit's rated output. Cloudy winter weather, shorter daylight hours, ice, and unsafe outdoor conditions can limit solar charging.
A system that supports selected loads still needs a safe recharge plan and an alternative place to stay. Neither output nor expansion capacity guarantees weeks of household heat.
Where Should You Check Conditions for the Next Storm?
Use current official information for the next storm, not a remembered 1998 timeline. ECCC's weather alerts identify the hazard, affected area, timing, likely impacts, and actions.
Check your serving utility for outages, Quebec 511 for travel, and your municipality for local services. Each answers a different part of your household plan.
The Quebec freezing-rain outage guide explains that warning-to-outage workflow in more detail. Open the live sources before acting, because old screenshots and past restoration times don't establish today's conditions.
Build a Plan That Can Continue Beyond Day Three
Use the Quebec ice-storm lesson to make three separate decisions. Prepare supplies, assess backup for selected electrical loads, and agree on a safe place to stay if disruption continues.
Write down the unresolved part now, while you still have time to address it. If your checked load and connection plan calls for home battery backup, compare EcoFlow TITAN backup options against that plan. The largest output won't solve every need.
How long did the 1998 Quebec ice storm last?
The main series of storms ran from 4–10 January 1998. Power outages continued much longer in some communities, while Operation Recuperation ended on 28 February, so those dates describe different parts of the disaster.
Was the 1998 ice storm limited to Quebec?
No. Parts of eastern Ontario and New Brunswick were also affected. When comparing accounts, check whether a figure describes Quebec residences, another province's utility customers, or people across the wider affected region.
Does a freezing-rain warning mean another 1998 crisis?
No. A warning doesn't establish the same storm track, damage, or repair time as 1998. Read the full current notice and follow its actions for your area, rather than assuming a historical comparison predicts the outcome.
Does a three-day emergency kit guarantee three days of heat?
No. The kit's planning period doesn't establish your heating system's fuel supply, electricity use, or safe operating time. Check warmth separately and arrange somewhere safe to stay if your home can no longer meet your needs.
Home Backup
