Panne d’électricité: How to Check Power Outages in Quebec
When the lights go out and the refrigerator stops humming, you may wonder whether the outage is limited to your building or affecting the entire street. You can then use your phone to search for “panne d’électricité aujourd’hui” and determine whether the interruption extends to your neighbourhood.
panne d’électricité is the French term for a power outage. This guide covers where to check current outages, how to find restoration estimates, when to report an interruption, and how to keep essential devices running safely until the power comes back.
What Does Panne d’Électricité Mean in English?
In English, it simply means a power outage. Panne d’électricité means an interruption in electrical service, often called a power outage or power cut. Most outages are unexpected, but some are planned: utilities schedule planned interruptions so crews can work safely on the network. Ice storms are a classic cause, so see how to prepare your home for an ice storm.
On utility maps and municipal notices, Quebec residents may see slightly different French terms.
French Term
English Meaning
panne d’électricité
Power outage
Power outage today
panne de courant
Power outage or power cut
interruption planifiée
Planned service interruption
heure prévue de rétablissement
Estimated restoration time
Info-pannes
Hydro-Québec’s outage information service
Searches for “panne d electricité” without the apostrophe are a common typing variation. You may also see “hydro québec panne d’électricité” and “panne d’électricité hydro quebec”, which people type to find the utility’s own outage information.
How to Check Panne d’Électricité Aujourd’hui in Quebec
The most reliable way to check an outage is through the electricity provider that serves your address.
Use Hydro-Québec’s Info-pannes Map
Hydro-Québec’s Info-pannes service is the official source for most of the province. Open the outage map, or use the Hydro-Québec mobile app, and select the outage near you. You’ll see the estimated restoration time, the current stage of the crew’s work, the number of customers affected and the cause, when it’s known. You can also enable notifications for selected addresses in the app.
Treat the details as guidance. Outage boundaries and restoration estimates are approximate, and some interruptions may not appear on the map right away.
Check Local Electricity Outage Maps
Not every Quebec address is served by Hydro-Québec. Some municipalities operate their own electricity distribution systems, and a few publish outage information.Some municipalities operate their own electricity distribution systems. If your address is not served by Hydro-Québec, check your local distributor’s website for outage information and reporting instructions. If your power comes from a municipal distributor, check its map or social channels first.
Quebec-Power-Outage-backup-power-solutionQuebec-Power-Outage-backup-power-solution
How to Prepare Your Home for a Panne d’Électricité
A little planning before the storm makes an outage far easier to manage. Quebec power outages can interrupt lighting, refrigeration, internet access and the electrically powered controls on your heating. Keep flashlights, charged power banks, cables, water, non-perishable food, and medications somewhere easy to find in the dark.
A portable power station can support compatible electrical loads, but it can’t guarantee continuous heating or power an entire home indefinitely. Save Hydro-Québec’s outage number and decide which devices to power first.
Backup Power for Multiple Essential Home Circuits
For homeowners who want to keep several essential circuits running, the EcoFlow DELTA Pro Ultra is a higher-capacity option. It combines a 6,144Wh LFP battery with 7,200W of continuous AC output at 120V/240V, and storage expands up to 30kWh with extra batteries. It’s rated to operate from −20°C to 45°C, and it works with the Smart Home Panel 2 to integrate selected essential household circuits.
Actual backup duration depends on your connected loads and battery configuration. A qualified electrician should handle any home electrical integration.
1. The only portable power station certified to both UL1973 and UL9540, offering extreme reliability for home use. 2. 7.2-21.6kW output, powerful enough to run your whole home even with a central AC 3. 6kWh-90kWh capacity, whole-house backup for weeks with comfort 4. Auto-switchover, prolonged backup, and energy bill savings with EcoFlow Smart Home Panel 2 5. Charging Options, even plan B has a plan B
Portable Backup for Everyday Household Essentials
If you only need to keep a handful of essentials going, the EcoFlow DELTA 3 Ultra Plus is a more focused option for selected appliances, lighting and communication devices. Its 3,072Wh LFP battery and 3,600W AC output (7,200W surge) at 120V cover those needs, and capacity expands from 3kWh to 11kWh with compatible extra batteries. It can connect to selected home circuits through a manual transfer switch or inlet box, sold separately.
It’s a 120V unit, so it won’t run 240V appliances. It also discharges down to −10°C, so keep it indoors during a cold snap.
EcoFlow DELTA 3 Ultra Plus (3072Wh)
1. Smart Output Priority: Choose which circuits stay powered via the app. Prioritize what matters and extend runtime when it counts most. 2. 3-11kWh Expandable Capacity: Easily scale up, and can achieve longer runtime with an EcoFlow Smart Generator featuring automatic start and stop. 3. 6 Ways to charge, Ready in Just 48 Mins: Ready in Just 48 Mins (0-80%) with Solar + Generator Dual Charging 4. 3600W Powerful Output: 7200W surge output. With X-Boost™ mode, supports heavy-duty appliances up to 4600W such as clothing steamers, electric dryers, lawnmowers, and electric frying pans. 5. 10ms Auto-Switch: keep critical devices like NAS systems and servers running smoothly.
Reporting-power-outage-in-Quebec-via-mobileReporting-power-outage-in-Quebec-via-mobile
How to Report a Power Outage to Hydro-Québec
Check the map first, then report any outage that isn’t listed. If your interruption isn’t marked as planned, or it doesn’t appear on the outage map, tell Hydro-Québec.
Report a Panne d’Électricité Online or by Phone
You can report an outage through Hydro-Québec’s online outage-reporting form or by phone at 1-800-790-2424, available 24 hours a day. Reporting helps the utility identify affected locations. If a fire, road accident, downed wire or danger to someone’s life is involved, call 911.
What if Only Your Home Has Lost Power?
Check whether neighbouring properties still have electricity. If only part of your home is dark, inspect your breaker panel, but only when it’s safe to do so. Fallen power lines, damaged electrical equipment and exposed wiring need professional or emergency help, so don’t touch them. If your service mast or meter base is damaged, tenants should tell the landlord, and owners should call a licensed master electrician.
Panne d’électricité means a power outage, and the first step is checking the official map for your electricity provider. Report outages that aren’t listed, follow safety guidance, and stock your essentials before severe weather arrives. If you’re planning for future interruptions, explore EcoFlow home backup power solutions that match your household’s needs.
What does panne d’électricité mean in English?
It means power outage, or power cut. It’s the standard French term for an interruption in electrical service. Searches for “panne d'électricité”, without the apostrophe, mean the same thing.
How can I check if there is a power outage in Quebec today?
Open Hydro-Québec’s Info-pannes map or mobile app and select the outage near you. If a municipal distributor such as Hydro-Sherbrooke supplies your power, use its own map or channels instead. Whether you search “hydro québec panne d’électricité” or “panne d’électricité hydro quebec”, the official outage information is the source to trust.
How do I know when Hydro-Québ
Select your outage on the Info-pannes map to see the estimated restoration time, the crew’s current stage, the customers affected and the cause, when known. These estimates are indicative and can change, so check back for updates or turn on app notifications for your address.
Why is there a power outage in my area?
Common causes include severe weather such as ice, snow and wind, branches or objects touching lines, damaged equipment, animals and accidents. Hydro-Québec also schedules planned interruptions for maintenance and notifies affected customers beforehand. The map shows the cause when it’s known.
How do I report a power outage to Hydro-Québec?
Use the online outage-reporting form or call 1-800-790-2424, 24 hours a day. Call 911 instead if there’s a fire, an accident, a downed wire or danger to anyone’s life.
Home Backup
