NL Power Outage Map: Check Outages Near You and Report an Outage
Newfoundland and Labrador can experience power interruptions during blizzards, freezing rain, high winds and other system events. The correct NL power outage map depends on which utility serves the address: Newfoundland Power or Newfoundland and Labrador Hydro. Confirming the provider first helps you find the relevant status and reporting channel.
This guide explains where to check current outages, how to report an unlisted interruption, how to interpret an estimated restoration time and how to prepare for a longer winter outage.
NL Power Outage Map: Check Current Outages Near You
Newfoundland and Labrador has two main electricity providers, each with its own outage information. The overview of NL power outages helps distinguish their service areas and reporting channels before you choose a map.
Newfoundland Power
Newfoundland Power distributes electricity to most customers on the island. Its Newfoundland Power outage map provides current event details for its service area, including affected customers and available restoration estimates.
NL Hydro operates generation and major transmission assets and provides retail service in Labrador and several rural or isolated island communities. Use the NL Hydro power outages map for current and planned events in its service area.
How to Find Your Electricity Provider
Check the latest electricity bill for the provider name and account details. Newfoundland Power serves many towns and urban areas on the island, while NL Hydro provides retail service in Labrador and a number of rural or isolated island communities. Confirm the provider before using a map or reporting an outage.
EcoFlow TITAN 5000 Plus Whole-Home Backup PowerEcoFlow TITAN 5000 Plus Whole-Home Backup Power
How to Check and Report a Power Outage in Your Area
If power goes out, start with the current utility outage map. An NL power outage that is already listed may include affected customers, status and an estimated restoration time. If the event is not shown, report it directly to the provider serving the address.
Detailed Steps to Check a Power Outage
Step 1: Open the Official Outage Map
Each utility keeps its own live map:
Open the one that matches your provider, then search your address or area.
Step 2: Search Your Address or Area
Search by address, postal code or community using the options provided by the map. Select the event affecting your area to review available details.
Step 3: Check the Estimated Restoration Time
Select an outage to view its available status, reported cause and Estimated Time of Restoration. Treat the ETR as the best current estimate rather than a guarantee because it may change as crews assess damage, access and repair requirements.
How to Report a Power Outage
If power is out and the event is not shown, report it to the appropriate utility. Customer reports help utilities identify localized interruptions and compare them with system information.
Newfoundland Power
Newfoundland Power customers can use the official outage reporting page or call 1-800-474-5711. Provide the service address and describe any safety concern. If an outage is already listed, another report is usually unnecessary unless conditions change.
NL Hydro customers can view or report an outage through myNLHydro or call the 24-hour outage and emergency number at 1-888-737-1296. Provide the service address and report downed lines, damaged equipment, sparks or other hazards immediately.
What Information Should You Have Ready?
Your street address and account information cover the basics. It also helps to know whether the neighbours’ homes are out as well and whether you’ve spotted anything irregular, such as a damaged transformer, a branch across a line or a pole down.
What to Do If Your Outage Is Not Showing on the Map
If your home is dark but the map is clear, first check the breaker panel from a safe location. If nearby homes are also out or service does not return after a breaker check, report the interruption to the correct utility. Small or newly reported events may not appear immediately.
How Long Does It Take to Restore Power in NL?
Restoration time depends on the cause, damage, weather, access and required equipment. Utilities address immediate hazards and work through affected system sections, but the sequence can change as field assessments continue. A power station can support selected household loads while repairs proceed, although it does not affect restoration timing.
How to Get Power Outage Alerts in NL
Newfoundland Power customers can register for outage notifications through the utility’s services. NL Hydro customers can use myNLHydro for planned and unplanned outage notifications by text or email. For an NL power outages map update, confirm the service address and check the timestamp shown by the correct provider.
EcoFlow TITAN 5000 Classic Whole-Home Backup PowerEcoFlow TITAN 5000 Classic Whole-Home Backup Power
What to Do During a Power Outage in Newfoundland and Labrador
A winter outage can quickly affect heat, food storage and communications. If you rely on a portable power station, keep it charged and confirm which devices it can support before severe weather arrives. Use safe lighting, conserve indoor heat and follow official utility updates.
Keep Your Home and Family Safe
Unplug computers, televisions, and smart devices so the voltage bump when power returns doesn’t damage them. Keep exterior doors shut, draw the curtains, and gather everyone in one room to hold the heat in. Keep the fridge and freezer closed, since a refrigerator keeps food cold for about 4 hours, and a full freezer for up to 48 hours. For lighting, reach for LED flashlights, headlamps, or battery-powered lanterns instead of candles.
Use a Generator or Portable Power Station Safely
Battery backup can support communications, lighting and selected household devices without producing exhaust at the point of use. Size any system for the intended loads and follow its operating instructions. Fuel-burning generators must remain outdoors and well away from doors, windows and vents because of carbon monoxide risk.
For selected household essentials, EcoFlow TITAN 5000 Classic Whole-Home Backup Power provides expandable battery storage and up to 4kW of AC output. It can support appropriately sized loads during an outage, but actual runtime depends on connected demand, battery configuration and operating conditions.
EcoFlow TITAN Classic delivers up to 4kW of AC output, with expandable capacity from 5kWh to 30kWh. This flexible setup can support essential household loads during outages and adapt to different backup power needs.
Prepare for Longer Outages
Phones alone may not cover a winter outage that lasts into the next day. List the appliances and controls that matter most, measure or confirm their running and surge demand, and plan enough capacity for the expected duration.
The EcoFlow TITAN 5000 Plus Whole-Home Backup Power is intended for longer outages and higher household loads. Smart Home Panel 10 lets households select up to 10 essential circuits, such as a refrigerator, lighting, router, computer, garage door or key outlets, so backup power can be directed to the loads that matter most. During an outage, Smart Home Panel 10 can automatically switch to backup power in as little as 0.02 seconds, helping minimize interruptions to connected devices. The TITAN 5000 Plus offers expandable battery capacity, while Smart Home Panel 10 integrates with the home’s selected circuits when properly sized and professionally installed. Actual runtime and coverage depend on connected loads, battery capacity, solar conditions and system configuration.
The EcoFlow TITAN 5000 Plus starts at 5kWh and delivers 7.2kW of battery output, expandable to 30kWh in 5kWh increments. With up to 8kW of solar input and X-Fusion 2.0, it works with Smart Home Panel 10 to provide whole-home backup, automatically switching within 20ms of a grid outage and managing up to 10 selected circuits.
When power goes out in Newfoundland and Labrador, start with the correct utility map, check whether the interruption is already listed and report an unlisted outage. During a longer winter interruption, a planned source of backup power can help support refrigeration, lighting, communications and selected heating controls while restoration work continues.
Is there a power outage in Newfoundland right now?
Check the official maps. Newfoundland Power and NL Hydro each publish current outage information for their own service areas, so first confirm which utility serves the address.
How often is the NL power outage map updated?
Update frequency and detail vary by utility and event. Check the timestamp shown on the map, and treat an Estimated Time of Restoration as an estimate that may change when crews assess new damage or access conditions.
How do I find out when my power will be restored?
Select the outage affecting your area on your utility’s map to check the estimated restoration time. If no outage shows for your area, report it; smaller ones don’t always post to the map until someone calls.
What should I do if I see a downed power line?
Stay away from the line and anything it may be touching. Assume every downed line is energized, keep people and pets at least 10 metres away, and call 911 when there is an immediate hazard before notifying the appropriate utility.
Home Backup
