What Are the Symptoms of Carbon Monoxide Poisoning? Winter Safety Tips for Canadian Homes
For months at a time, many Canadian homes stay closed against the cold while furnaces, fireplaces and wood stoves run more often. If you are wondering what symptoms of carbon monoxide poisoning can look like, remember that carbon monoxide has no smell, colour or taste and early effects can resemble the flu. This article explains symptoms from mild to severe, why winter can raise exposure risk and how households can reduce that risk.
What Are the Common Symptoms of Carbon Monoxide Poisoning?
Understanding what the symptoms of carbon monoxide poisoning are can be difficult because carbon monoxide interferes with oxygen delivery and use in the body. Symptoms are variable and nonspecific, and severity cannot be judged reliably from a household reading alone. Headache, dizziness, weakness, nausea, vomiting, chest pain or altered mental status can occur. Confusion, fainting, trouble walking, chest pain or breathing difficulty requires emergency assessment.
Severity Level | Typical Symptoms | Immediate Danger |
Mild | Dull tension headache, fatigue, mild dizziness, slight nausea | Can resemble flu-like illness; leave immediately and seek medical advice |
Moderate | Throbbing head pain, vomiting, confusion, blurred vision, loss of coordination | Impaired judgment; victims may struggle to evacuate independently |
Severe | Seizures, collapse, loss of consciousness, respiratory arrest, cardiac damage | Medical emergency; coma, death or delayed neurological complications may occur |
Mild Symptoms of Carbon Monoxide Poisoning
Headache is one of the most common early symptoms of carbon monoxide poisoning. Exposure can also cause fatigue, light-headedness, nausea, shortness of breath and flu-like symptoms without fever. Symptoms that improve outdoors and return inside can suggest an indoor exposure, especially when several people feel unwell at the same time, but medical evaluation is still needed.
Moderate Symptoms of Carbon Monoxide Poisoning
With longer exposure or a higher concentration, the headache can start to throb, and dizziness, vomiting, blurred or poor vision, and chest pain can come with it. Thinking can turn muddled, confusion can set in, and coordination can slip, seen as trouble walking or keeping your balance.
Severe Symptoms of Carbon Monoxide Poisoning
Severe poisoning can cause disorientation, loss of coordination, seizures, loss of consciousness, abnormal heart rhythms, coma or death. Emergency clinicians assess symptoms, exposure history and testing rather than relying on a single household reading. Long-term symptoms of carbon monoxide poisoning may include memory, concentration, mood or other neurological changes that appear or persist after the initial exposure, so follow-up instructions should be taken seriously.
What Increases the Risk of Carbon Monoxide Exposure in Canadian Winters?
In winter, homes are often closed against the cold, heating equipment runs longer, snow or ice can block vents and an outage may lead to generator use. These conditions can increase the chance of carbon monoxide accumulating indoors when fuel-burning equipment is damaged, poorly vented or used incorrectly.
Increased Use of Fuel-Burning Heating Systems
Through a Canadian winter, natural gas furnaces, oil boilers, wood stoves, and fuel-burning basement space heaters run almost continuously. A cracked heat exchanger in an aging furnace, a warped flue pipe, or a wood stove that isn’t drafting the way it should can quietly let combustion byproducts into the house while the family sleeps.
Blocked Ventilation and Exhaust Pathways During Snowstorms
Blizzard drifts can bury the intake and exhaust pipes on an outside wall, and freezing rain or falling ice can seal them shut. High-efficiency furnaces and tankless water heaters vent through PVC pipes set low on the side of the house, so once a snowbank closes over those pipes the exhaust can back up into the basement or crawl space. Brush the vents clear by hand after a snowfall, and pile what you shovel anywhere but on top of them.
Unsafe Use of Backup Generators During Power Outages
During an ice-storm outage, never run a fuel-powered generator in a home, garage, shed, vehicle, camper or other enclosed or partly enclosed area. Engine exhaust contains carbon monoxide that can enter living spaces through doors, windows, vents and structural gaps. A portable power station does not produce combustion exhaust at the point of use, but it still must be operated according to its manufacturer’s safety instructions.
How Can Canadian Homes Prevent Carbon Monoxide Poisoning in Winter?
Prevention depends on working alarms, properly maintained heating equipment and fuel-burning devices used only in approved locations. A power station can support selected electrical loads during an outage, while combustion equipment must remain outdoors and away from the building.
Install and Maintain Carbon Monoxide Alarms
In Ontario, homes covered by the Fire Code must have CO alarms adjacent to each sleeping area and, from January 1, 2026, on every storey, including storeys without sleeping areas. The requirement applies to homes with specified fuel-burning equipment, fireplaces, attached garages or qualifying shared heating arrangements. Install, test, maintain and replace alarms according to the manufacturer’s instructions, and never disable or remove their batteries.
Inspect Heating Systems Before the Cold Season
Book a qualified contractor before the cold sets in. In Ontario that may mean a TSSA-registered one, and in other provinces a gas technician, gas fitter, or heating contractor licensed or certified under the local safety authority. What the visit buys you is a check you cannot do yourself, covering burner alignment, whether the exhaust still drafts, a nest or creosote in the flue, and hairline cracks in the combustion chamber.
Use Fuel-Burning Equipment Outdoors and Away From the Home
Portable fuel-burning equipment belongs outdoors in open air. Health Canada advises operating a fuel-powered generator at least 6 metres (20 feet) from any home or building. Maintain that portable generator distance from doors, windows and vents, direct exhaust away from occupied spaces and never use the unit in a garage, even with the door open.
Reduce Reliance on Fuel-Burning Generators During Power Outages
Winter blizzards and freezing rain can cause power outages across Canada, leaving households without essential electricity for refrigeration, lighting and communication devices. While fuel-burning generators can provide backup power, they produce carbon monoxide during operation and must be used outdoors, away from doors, windows and vents.
For households looking to maintain essential power while reducing reliance on fuel combustion and engine exhaust, the EcoFlow TITAN 5000 Classic Whole-Home Backup Power offers a battery-based backup solution. It supplies electricity without burning fuel during operation and features a 5 kWh battery capacity with 4 kW of 120V AC output. During winter outages, it can support compatible household essentials such as refrigerators, lights, routers and communication devices, depending on their power requirements and the available battery capacity.
For households that need to support more or higher-powered appliances during an outage, the EcoFlow TITAN 5000 Plus Whole-Home Backup Power delivers 7.2 kW of battery output and supports 120V/240V split-phase power. Starting at 5 kWh of capacity, it gives households the option to include compatible water pumps, kitchen appliances and other 240V equipment in their backup power plans.
What Should You Do If You Suspect Carbon Monoxide Poisoning?
If the alarm goes off or several people in the house feel dizzy, nauseous, weak, or confused, treat it as an emergency.
Leave the Home and Get Fresh Air Immediately
If a CO alarm sounds or poisoning is suspected, get everyone, including pets, outside immediately. Do not delay to collect belongings or investigate the source, and do not stop to ventilate the building on the way out.
Call Emergency Services and Stay Outside
Once outside, call 911 or the local emergency number. Report any headache, dizziness, weakness, nausea, chest pain, confusion, fainting or breathing difficulty, and follow the dispatcher’s instructions. Anyone with symptoms should receive prompt medical assessment.
Avoid Re-Entering Until the Home Is Declared Safe
Remain outside until emergency responders or the relevant authority says the building is safe to re-enter. A silent alarm is not an all-clear, and occupants should not return to investigate or restart equipment on their own.
Every risk here comes back to the same season, a closed-up house, heat running for hours, and snow over the vents. The answers are ordinary things, tested alarms, the heating system checked before the cold, the vents kept clear, and a portable power station for the hours the power is out. What carries the weight is knowing the early signs, the difference between airing the house out and getting everyone out of it. Get the work done before the first storm, and winter is one less thing to worry about.
How Long Does It Take For Carbon Monoxide To Start Affecting You?
There is no single safe timetable. Symptoms depend on the concentration, exposure duration, individual health and activity level, and they may be nonspecific. If an alarm sounds or exposure is suspected, leave immediately and call emergency services rather than waiting for symptoms.
How Much Carbon Monoxide Will Make You Sick?
A household CO reading alone cannot determine how sick someone is. Clinical guidance emphasizes symptoms, exposure history and appropriate medical testing because measured carboxyhemoglobin levels do not always match illness severity. Leave the building and seek emergency advice if exposure is suspected.
Is Carbon Monoxide An Instant Killer?
Carbon monoxide can cause sudden illness, loss of consciousness and death when exposure is high enough. People who are asleep or otherwise unable to recognize symptoms may not receive warning. Treat every sounding CO alarm or suspected exposure as an emergency.
Would A Carbon Monoxide Alarm Go Off For No Reason?
Do not assume a sounding CO alarm is false. Leave the building immediately, call 911 from outside and do not re-enter until the cause has been investigated and the building has been declared safe. Afterward, follow the manufacturer’s instructions for fault codes, end-of-life signals, maintenance or replacement.
Does A Carbon Monoxide Detector Work Without A Battery?
It depends on the type. Hardwired or plug-in alarms can usually run on household power alone, though many chirp or show an error when the backup battery is missing. During a power outage, however, they need a working backup battery to keep monitoring. Battery-only alarms rely on those batteries alone, so test the alarms regularly and replace the batteries before they run out.
