Heat Pump Cost Ontario: 2026 Prices, Installation Costs, and Rebates
Heat pumps are an excellent, energy-efficient choice for heating or cooling your home. Many Ontarians are considering installing one. The heat pump cost Ontario homeowners pay depends on the system type, home size, efficiency, and installation needs. Installed prices can range from about CAD $4,000 for simpler systems to more than CAD $20,000 for larger or more complex jobs.
This guide covers equipment prices, installation costs, and running costs. It also explains rebates and how to plan your household electricity needs.
How Much Does a Heat Pump Cost in Ontario?
If you're wondering how much a heat pump costs in Ontario, a typical installation may range from about CAD $4,000 to more than $20,000, depending on the system type, home size, and installation requirements. Geothermal systems can cost more because of the ground-loop work involved.
Examples include ductless, central ducted, cold climate, hybrid, and geothermal systems.
The following table shows estimated heat pump prices in Ontario for different system types, including installation costs in Canadian dollars.
The following figures are indicative installed-price estimates in Canadian dollars, before tax and eligible rebates. Actual quotes vary by equipment, home layout, electrical and ductwork requirements, and local labour costs. Confirm current pricing with qualified local contractors.
System Type
Indicative Installed Price (CAD)
Good Fit For
Ductless single-zone
$4,000 – $9,000
Additions, garages or single rooms
Ductless multi-zone
$5,500 – $20,000+
Homes without ducts
Central ducted, cold-climate
$8,000 – $18,000+
Homes with existing ductwork
Hybrid (heat pump + furnace)
$7,500 – $15,000+
Homes with a newer furnace
Geothermal (ground-source)
$20,000 – $40,000+
Long-term, higher-budget projects
What Factors Affect Heat Pump Prices in Ontario?
Several factors affect the cost of heat pumps Ontario homeowners may pay. These include:
Heat Pump Type, Size, and Efficiency
Air-source, ductless, cold-climate, and geothermal heat pumps vary in cost. Geothermal is usually the most expensive because it requires ground loops. Large homes will require larger systems. More efficient systems can sometimes cost more to install.
Beyond your property's square footage, ask your contractor to professionally calculate the heating load. This will ensure that if your system is undersized/oversized, you won’t incur extra costs.
Installation Labor and Home Modifications
Installation can be quite costly. Other costs can include:
  • Ducting
  • Refrigerant Lines
  • Electrical Panel Upgrades
  • Various other upgrade costs.
Planning electrical and ductwork upgrades before installation can help control costs. Older homes may cost more because they may require major upgrades.
How to Manage Home Electricity Needs Alongside a Heat Pump
ontario-winter-home-heat-pump-portable-backup-power-station-energy-management-snowy-eveningontario-winter-home-heat-pump-portable-backup-power-station-energy-management-snowy-evening
A heat pump can affect your electricity usage, so it is a good idea to check your overall capacity, heating requirements and outage plan.
With a high-efficiency heat pump, your regular heating costs will be reduced. However, a backup power source can help if the grid goes down. EcoFlow backup power can be an optional addition to your energy plan. It can't replace a heat pump, but it can be a great option. To see more options, check out EcoFlow's portable power stations.
Prepare Your Home for Extended Power Interruptions
home-battery-backup-power-system-canadian-winter-power-outage-electrician-inspection-snowy-landscape home-battery-backup-power-system-canadian-winter-power-outage-electrician-inspection-snowy-landscape
Imagine a January cold snap causes a blackout. Your house starts to get cold, your fridge shuts off, and your phone is down to 15%. You don’t know when the power will come back.
The EcoFlow DELTA Pro Ultra Whole Home Backup Power is a large-scale backup system for homeowners who want to be prepared. With a 6144Wh capacity and 7200W of continuous AC output, it can power compatible household appliances, including your fridge, lights, and communications devices. Check your heating system’s power requirements and consult a qualified electrician.
1. The only portable power station certified to both UL1973 and UL9540, offering extreme reliability for home use. 2. 7.2-21.6kW output, powerful enough to run your whole home even with a central AC 3. 6kWh-90kWh capacity, whole-house backup for weeks with comfort 4. Auto-switchover, prolonged backup, and energy bill savings with EcoFlow Smart Home Panel 2 5. 5 Charging Options, even plan B has a plan B
Keep Essential Household Devices Powered During Winter Outages
If you don't need to power your whole house, you may only want to keep your refrigerator, Wi-Fi router, and a few lights running during an outage.
The EcoFlow DELTA 3800 Gen4 is a compact system with a lot of power. It has a 3763Wh capacity and a fridge runtime boost to help keep your fridge running. This system is designed for essential devices such as a fridge, Wi-Fi router and lighting. Not intended to power the heat pump in your home. You can expand the capacity to store around 12 kWh of power.
1. Longest Runtime: Powers a refrigerator for up to 70 hours — 17 hours (32.6%) longer than the industry average for 3-4kWh portable power stations. 2. Powers Most Home Appliances: Delivers 3,600W of continuous output and 7,200W of surge power. 3. Compact Yet Powerful: The smallest and lightest portable power station in its class with 3-4kWh capacity and 3,600W output. 4. 4–12 kWh Expandable Capacity: Compatible with EcoFlow DELTA Pro 3 Smart Extra Battery and EcoFlow DELTA 3 Max Plus (2,048 Wh) Smart Extra Battery. 5. UPS Backup with <10 ms Transfer Time: Switches to backup power within 10 ms when an outage occurs.
How Much Does It Cost to Run a Heat Pump in Ontario?
The cost depends on your tariff, how much you want to heat, outside temperature, your system's efficiency, and how well insulated your home is.
The coefficient of performance (COP) shows how efficient a heat pump is. A COP of 3 means about three units of heat for each unit of electricity. In very cold weather, the COP drops. That means the heat pump uses more electricity on the coldest days.
Here is a simple example. Suppose your heat pump uses 4,000 kWh over a heating season. If your energy rate is 12 cents per kWh, the energy charge is 4,000 × $0.12 = $480. This rate is only an example. Check your own rate with your utility.
Your overall electricity bill will include additional delivery charges. As a result, the energy charge will be only part of your total. You won't save a fixed amount each month. How much you save will depend on your property and tariff.
Is a Heat Pump Worth the Cost in Ontario?
To judge the value, compare four things:
  • Your upfront investment
  • Heating and cooling efficiency
  • Ongoing electricity costs
  • Maintenance
The benefits you will receive depend on the type of heating system you have. If you are looking to switch from electric heating, oil, or propane, you will often see greater savings. If you’re currently using natural gas, you may see less savings because prices are low. If you have a suitable system in place, you could see energy savings in the long term. Your payback period depends on your current heating system and local energy prices.
How to Reduce Heat Pump Installation and Operating Costs
You can manage costs in a few simple ways:
  • Compare quotes from several contractors.
  • Choose equipment that is the right size for your home.
  • Improve your insulation.
  • Keep your filters clean.
  • Check rebate eligibility before you install
Overall, consider the total cost of ownership. To find out more about incentives, please refer to this guide.
The cost of heat pumps Ontario homeowners pay depends on the system type, installation needs, household energy use, and eligible rebates. A properly sized and installed heat pump can efficiently heat and cool your home, keeping it comfortable year-round. It’s still important to plan your household electricity use.
For unexpected outages, the EcoFlow DELTA Pro Ultra and the EcoFlow DELTA 3800 Gen4 are optional backup solutions for compatible essential devices. Backup for a heat pump needs its own electrical compatibility check.
When planning your home's energy needs, consider EcoFlow’s home backup power options, such as the EcoFlow DELTA Pro Ultra Whole-Home Backup Power.
How much does a heat pump cost in Ontario including installation?
Most heat pumps will cost around $4,000 to $20,000+ to install. Ductless systems will often be at the lower end of the price range, whereas geothermal systems will be the most expensive.
How much does a 2,000-square-foot heat pump cost in Ontario?
Air source heat pumps tend to cost around $10,000 to $15,000 to install. This will depend on the system you choose and whether your home has ducting and wiring.
Are heat pumps cheaper to run than gas furnaces in Ontario?
It depends. Your savings depend on gas and electricity prices, your home, and the heat pump’s efficiency. Heat pumps often save more against electric, oil, or propane heating than against natural gas.
What is the Ontario heat pump rebate in 2026?
Under Ontario's Home Renovation Savings Program, eligible homeowners may receive up to $7,500 for a qualifying cold-climate air-source heat pump if their home is primarily heated with electricity, oil, propane, or wood. Eligible Enbridge Gas customers whose homes are heated with natural gas may qualify for up to $2,000. Qualifying ground-source heat pump systems may also be eligible for incentives of up to $12,000 for certain homes. Rebate amounts depend on system capacity and program requirements, so check the official Home Renovation Savings website and confirm eligibility before committing to an installation.
How long does a heat pump last in Ontario?
Air source heat pumps typically last 15-20 years. Geothermal can often last longer, between 20-25+ years. Regular maintenance will help.
Will a heat pump work in Ontario winters?
Yes! Cold climate models are designed to work in low temperatures. Some homes also use a heat pump with a furnace for the coldest days.
Can a portable power station run a heat pump?
Not as a standard rule. Heat pumps differ in power draw and startup needs, so this needs a separate electrical compatibility check. A portable power station is better suited to essential devices such as a fridge, Wi-Fi router, and lights.
Home Backup
