How to Prepare for a Halifax Snow Storm This Winter
Halifax storms can change plans in a matter of hours. In January 2026, about 20 cm of heavy, wet snow left roughly 140,000 Nova Scotia Power customers in the dark at the peak. Coastal storms here often arrive as a mix of wind and wet snow, which is a hard combination for power lines. This guide covers what a Halifax snow storm typically brings and how to stay warm if lines come down. It also explains how weather alerts and the HRM parking ban work, then sets out a simple before, during, and after checklist.
What a Snow Storm in Halifax Typically Brings
Halifax sees well over 200 cm of snow in a typical winter, based on Environment and Climate Change Canada records at Halifax Stanfield International Airport. Many of the biggest storms arrive as nor'easters. Those systems bring heavy wet snow and strong wind at the same time.
Notable Halifax Snow Storms
Storm
Date
What Happened
White Juan
February 18 to 19, 2004
About 95.5 cm at the Shearwater heliport, a record for the site, with province-wide states of emergency in Nova Scotia and PEI
February 2024 storm
February 3 to 5, 2024
84 cm of snow at Halifax Stanfield International Airport, with widespread closures
January 2026 storm
January 18 to 19, 2026
About 20 cm of heavy, wet snow and roughly 140,000 customers without power at the peak
February 2026 nor'easter
February 23, 2026
Up to 30 to 50 cm forecast for southeastern Nova Scotia, gusts to 80 km/h, and Nova Scotia Power activated its Emergency Operations Centre
Wet snow is the detail that matters most. It weighs far more than dry powder, so it bends branches onto lines and loads conductors directly. That is why a Halifax snow storm so often becomes an outage story rather than a shovelling story. Since these systems usually track up the coast, preparing for a nor'easter in Canada means planning for snow and wind together rather than separately.
Heavy, wet snow and wind are exactly what bring power lines down. That makes staying warm and powered the first thing to plan for.
Staying Warm and Powered When a Halifax Snow Storm Cuts Power
 Staying Warm and Powered When a Halifax Snow Storm Cuts Power Staying Warm and Powered When a Halifax Snow Storm Cuts Power
When a storm knocks out power here, heat is usually the first worry. Furnace blowers, heat pumps, and well pumps all need electricity to run. Statistics Canada found Nova Scotia households split almost evenly in 2021 between forced air furnaces, baseboards, and heat pumps, at 23, 21, and 21 percent. Every one of those depends on the grid.
Tracking and Reporting the Outage
Nova Scotia Power publishes a live outage map at outagemap.nspower.ca, and its outage line is 1-877-428-6004. Checking the map first tells you whether the problem is your street or your region. Outages here can reach a remarkable scale. At the peak of Fiona in 2022, about 415,000 customers were out, which Nova Scotia Power called roughly 80 percent of its customers.
Restoration estimates move as crews assess damage. Following a power outage in Halifax through that live map is the quickest way to see whether your neighbourhood is part of a larger event.
Why Fuel Generators Are a Poor Fit Indoors
A generator seems like the obvious answer until you read the safety guidance. Health Canada says a generator must never run indoors, in a garage, or in a shed. It should sit at least 6 metres from any building, with the exhaust pointed away from windows and doors.
That is a difficult rule to follow in a blizzard. Standing outside in blowing snow to refuel is the opposite of staying safe and warm. A home battery works the other way around. It lives indoors, produces no exhaust, and takes over the circuits you nominate the moment the grid drops. EcoFlow's TITAN series is built as modular home backup for precisely those winter priorities.
EcoFlow TITAN Plus
• Up to 10kW Total System Output: Delivers 7.2kW from the battery alone. With compatible solar, X-Fusion 2.0 PV Boost raises total system output to 10kW. • Starts Big Loads Without Buying Bigger: The 40160 tabless 2C LFP cell provides high power from a 5kWh start. In a defined test scenario, it starts a 3-ton central AC without a soft starter while running about 1kW of essential loads. • Modular 5kWh to 30kWh Capacity: Every unit has a built-in 5kWh LFP battery. You can add capacity in 5kWh plug-in increments as your needs grow.
Not every home needs ten managed circuits or 240 V capacity. If your winter shortlist is simply the furnace blower, the fridge, and the lights, the entry model in the series handles those loads on 120 V.
EcoFlow TITAN Classic
•120 V Essential Backup: Keeps a refrigerator, lighting, and your router running during an outage. •Built for Smaller Homes: A good fit for apartments and smaller homes that don’t need 240V appliance support. • Modular 5kWh Starting Capacity: Built on the same TITAN platform, with a 5kWh LFP battery that expands in 5kWh increments.
With the home covered, the next step is knowing when a storm is coming and what the city expects from residents.
Storm Alerts, Parking Ban and Snow Clearing in Halifax
Storm Alerts, Parking Ban and Snow Clearing in HalifaxStorm Alerts, Parking Ban and Snow Clearing in Halifax
Two organizations shape your storm day. Environment and Climate Change Canada issues the weather alerts, and Halifax Regional Municipality runs the parking ban and snow clearing. Following both lets you plan ahead instead of reacting.
Reading the Alerts
Since November 2025, ECCC alerts carry a colour. Yellow means moderate, localized impacts. Orange means severe and widespread effects. Red is rare and signals very dangerous, possibly life-threatening conditions.
Three warning types matter most in winter. A snowfall warning covers heavy accumulation. A winter storm warning covers a combination of hazards such as snow, ice, and wind. A blizzard warning adds sustained wind and very poor visibility. Each level of a winter storm warning in Canada comes with its own set of sensible steps, from watching the forecast to staying off the roads entirely.
For local notifications, sign up for hfxALERT by phone, text, push notification, or email. You can also call 311.
The Overnight Winter Parking Ban
The municipal ban runs from December 15 to March 31 each year. It applies from 1 a.m. to 6 a.m., and it is enforced only during declared weather events and ongoing clearing operations, not every night.
Zone 1 covers the Halifax Peninsula and downtown Dartmouth inside Highway 111, plus some surrounding areas. Zone 2 covers the designated areas outside it. The zones can be lifted separately, so check your own address. Vehicles can be ticketed or towed, and anything blocking a plough can be towed at any time of year.
Snow Clearing Service Standards
The clock starts at the end of the declared weather event, not when the first flakes fall. Halifax Regional Municipality publishes these targets:
Surface
Target From End of Storm
Priority 1 streets, including arterials, emergency routes, and transit routes
12 hours
Priority 2 residential streets and gravel roads
24 hours
Priority 1 sidewalks, downtown and school zones
12 hours
Priority 2 sidewalks on transit routes
18 hours
Priority 3 residential sidewalks and walkways
36 hours
These are service targets rather than guaranteed completion times. Heavy snowfall, blizzard conditions, continuing precipitation, and changing weather can delay clearing operations.
Alerts and city rules give you the timeline. A short checklist turns that timeline into action.
Before, During and After a Halifax Snow Storm
The Nova Scotia government asks households to be ready for 72 hours without power or running water. Most storm stress comes from small things left undone. Supplies are only half of it, and preparing a home for severe storms covers the frozen pipes and roof loads that follow a heavy snowfall.
Before the Storm
  • Build a 72-hour kit with at least six litres of water per person, a three-day supply of prescription medication, and a wind-up or battery-powered flashlight and radio
  • Charge phones and any backup power, and fill the vehicle with fuel
  • Move vehicles off the street when the parking ban is in effect
  • Bring in or tie down anything the wind could lift
During the Storm
  • Stay off the roads where you can, since ploughs work faster on clear streets
  • Keep furnace and dryer vents clear of drifting snow to prevent carbon monoxide build-up
  • Take frequent breaks when shovelling heavy, wet snow
  • Keep the fridge and freezer closed if the power goes out
After the Storm
  • Clear snow around the fire hydrants and storm drains near your home
  • Check on older or vulnerable neighbours
  • Watch for heavy snow loads on roofs, decks, and carports
A snow storm in Halifax usually brings heavy, wet snow, wind, and outages together, so preparation counts for as much as the forecast. Follow the ECCC alerts, sign up for hfxALERT, learn the parking ban rules, and keep a 72-hour kit ready. Knowing the snow clearing targets helps you plan the days after. For heat and other essentials through a storm outage, the EcoFlow TITAN Plus and TITAN Classic keep priority circuits running indoors without fuel or exhaust.
How much snow does Halifax get each winter?
Halifax typically sees well over 200 cm across a winter, measured at Halifax Stanfield International Airport. Single storms vary enormously, from a few centimetres to the 84 cm recorded in February 2024.
When is the Halifax winter parking ban in effect?
It runs from December 15 to March 31, between 1 a.m. and 6 a.m. It is enforced only during declared weather events and clearing operations, not automatically every night.
How do I find out if the parking ban is on tonight?
Check halifax.ca or sign up for hfxALERT notifications. Zones can be lifted separately, so confirm the status for your own address rather than the city as a whole.
How long does it take Halifax to clear residential streets after a storm?
The target is 24 hours for Priority 2 residential streets, measured from the end of the declared weather event. Snowfalls over 30 cm can extend that.
How do I report a power outage during a snow storm in Halifax?
Call Nova Scotia Power at 1-877-428-6004, or check and report through the outage map at outagemap.nspower.ca.
What was the biggest snow storm in Halifax history?
White Juan in February 2004 remains the benchmark. The Shearwater heliport recorded about 95.5 cm, a record for that site, and the province declared a state of emergency.
Home Solutions
