Calgary Snow Storm: How to Prepare Your Home for Heavy Snowfall
A Calgary snow storm can affect far more than the commute. Heavy snow may accumulate on roofs, block furnace vents, damage branches, and contribute to localized outages. Preparing before conditions deteriorate can reduce household risks and make a power interruption easier to manage. This article explains how winter storms affect Calgary homes, how to conserve heat, what to prepare before snowfall, and what to inspect after the weather improves.
What Happens to Calgary Homes During a Snowstorm?
A snow storm in Calgary can combine heavy snow, strong winds, reduced visibility, and extreme cold, with each hazard affecting the home differently.
Heavy Snowfall Increases Roof and Property Risks
Snow load builds up deceptively fast on roofs and overhangs. In Southern Alberta, a wet late-season snowfall can weigh several times more than light powder, the way a soaked sponge outweighs a dry one. Chinooks add a second problem: a warm spell melts snow on the roof, then a sub-zero snap refreezes the runoff at the eaves into a ridge of ice that acts like a dam. Water pools behind it and seeps under the shingles. Later the damage shows up as ceiling leaks, sagging, or a torn-away gutter.
Snowstorms Can Cause Winter Power Outages
Prairie winds, heavy snow, and ice-laden branches can damage overhead lines and local electrical equipment. Blowing snow and icy roads may also slow access to damaged areas. An outage can interrupt lighting, refrigeration, heating controls, and internet service, so households should follow ENMAX updates rather than assume a fixed restoration time.
Extreme Cold Disrupts Home Heating Systems
Even a gas furnace relies on electricity for its blower and controls, so an outage can stop central heating. Wind-driven snow may also block the intake or exhaust vents of a high-efficiency furnace and trigger a safety shutdown. How quickly indoor temperatures fall depends on outdoor conditions, insulation, air leakage, and the building, but extended heat loss can increase the risk of frozen pipes.
EcoFlow DELTA 3000 Gen4 Portable Power StationEcoFlow DELTA 3000 Gen4 Portable Power Station
How Can You Keep Your Home Warm During a Snowstorm?
If the furnace quits or the power goes out, the heat already in the house is all you have—like hot coffee in a thermos. Keep the lid on by sealing drafts first, then fall back on safe alternative heating.
Reduce Heat Loss Around the House
In high winds, drafty windows and gaps under exterior doors let cold in the way a door left ajar would.
  • Close thermal curtains or hang heavy blankets over windows to add an insulating layer against the cold glass.
  • Lay draft stoppers or rolled-up towels along the bottom of exterior doors.
  • Keep interior doors closed to hold leftover heat in one central "warm room," away from large bay windows.
Prepare Alternative Heating Arrangements
If you have a wood stove or fireplace that’s been inspected, keep plenty of dry, seasoned firewood on hand. Either way, focus on holding in your own body heat with thermal base layers, winter-rated sleeping bags and hot-water bottles. You can also run low-wattage electric blankets and heating pads off a portable power station.
Never bring gas barbecues, camp stoves, kerosene heaters or fuel-burning generators indoors. They pump out carbon monoxide, an odourless, invisible gas that can build to deadly levels fast in a closed-up house.
How Can You Prepare Your Home Before a Calgary Snowstorm?
If you are checking a Calgary snow storm today, read the current ECCC alert for its issue time, affected area, expected impacts, and recommended action. A current Calgary snowfall warning can help you prioritize preparations, but lead time and conditions vary by event.
If a battery-based solar generator is part of the household plan, charge it before conditions deteriorate and confirm its output, capacity, operating limits, and connection method.
Preparation Category
Key Action Items
Timing
Roof & Gutters
Clear debris, clear downspouts, check attic insulation
Fall / Pre-storm
Pipes & Plumbing
Drain outdoor faucets, insulate exposed basement pipes
Pre-storm alert
Supplies
72-hour non-perishable food, drinking water, medications, flashlights
24–48 hours prior
Outdoor Areas
Stow patio sets, clear driveways, salt stairs
12–24 hours prior
Emergency Power
Fully charge power stations, test transfer switches/cords
Immediate
Clean Gutters and Inspect Roof Conditions
Scoop leaves and debris out of the gutters and clear the downspouts, so meltwater drains away from the foundation instead of backing up. From the ground, scan the roofline with binoculars for loose shingles or damaged flashing. In the attic, check that the insulation lies evenly and the soffit vents are unblocked, which together keep the roof deck cold. A warm attic melts snow from underneath, and that meltwater runs down to the eaves and feeds the ice dams.
Stock Up on Food, Water, and Emergency Supplies
Store supplies for at least 72 hours, including drinking water and additional water for food preparation and hygiene. Public Safety Canada recommends planning for about four litres per person per day in total. Add shelf-stable food, first-aid supplies, prescription medication, battery-powered flashlights, a manual can opener, pet supplies, phone charging cables, and a battery-operated or hand-crank radio.
Secure Outdoor Furniture and Loose Items
Prairie blizzard gusts fling loose yard items into windows or siding. Move patio chairs, fire pit lids and barbecue covers into the garage or shed, and tie down larger items against a sheltered wall. Disconnect garden hoses, close the indoor shut-off valves for the outdoor faucets, then open those faucets to drain them, because water left inside freezes and splits the pipe. Wrap exposed basement pipes in foam sleeves while you’re at it.
Set Up a Home Backup Power Supply
Backup power only helps if it’s charged and set up before the grid goes down. When you’re comparing units, the two numbers to check are capacity and output. Think of capacity, measured in watt-hours (Wh), as the size of the tank, which sets how much energy the battery can hold. Output, measured in watts (W), is the tap, and the wider it opens, the more power comes out at once.
For households that want to keep phones, laptops, emergency lighting and a few small appliances running through a blackout, the EcoFlow DELTA 3000 Gen4 Portable Power Station is a dependable, portable backup option. Packing 3072Wh of capacity and 3600W of continuous output, it can power everyday personal electronics steadily. For families who want one all-in-one unit, that flexibility is the draw: it’s as ready for a sudden emergency at home as it is for life on the go.
1. Longest Runtime: Powers a refrigerator for up to 58 hours — 17 hours (41.5%) longer than the industry average for 3kWh portable power stations. 2. Powers Most Home Appliances: Delivers 3,600W of continuous output and 7,200W of surge power. 3. Compact Yet Powerful: The smallest and lightest⁵ portable power station in its class with 3kWh capacity and 3,600W output.
The EcoFlow DELTA 3800 Gen4 Portable Power Station is the step up for homes with larger electrical demands, or for anyone who wants scalable capacity for extended outages. Storage starts at roughly 4kWh and expands up to 12kWh, and because the design is modular, homeowners have the freedom to decide how much energy to keep in reserve based on which devices they plan to run and how long the blackout is expected to last.
1. Powers Most Home Appliances: Delivers 3,600W of continuous output and 7,200W of surge power. 2. Compact Yet Powerful: The smallest and lightest portable power station in its class with 3-4kWh capacity and 3,600W output. 3. 4–12 kWh Expandable Capacity: Compatible with EcoFlow DELTA Pro 3 Smart Extra Battery and EcoFlow DELTA 3 Max Plus (2,048 Wh) Smart Extra Battery.
Whichever unit fits the plan, check the starting and running wattage of every intended load. Pay particular attention to refrigerators, pumps, routers, and furnace blowers. Hardwired heating equipment requires an approved connection method; size battery capacity around measured loads and a realistic runtime target.
What Should You Do During and After a Calgary Snowstorm?
If a snow storm is affecting Calgary today, limit non-essential travel and follow current local updates. A reliable snow storm weather forecast should be paired with official road and municipal information. Afterward, clear snow steadily and check vents and equipment for blockage or damage before restarting them.
Monitor Weather Alerts and Snowfall Updates
Use WeatherCAN or ECCC alerts, Alberta Emergency Alert, City of Calgary notices, and ENMAX outage information for current updates. Check Alberta 511 before driving, and delay non-essential travel when authorities advise it. If travel is unavoidable, reduce speed, increase following distance, and follow current road restrictions.
Keep Driveways and Home Entrances Clear
Shovel manageable amounts rather than waiting for deep accumulation, and avoid overexertion. City of Calgary rules require property owners or occupants to clear adjacent sidewalks within 24 hours after snowfall ends. After clearing, use sand or an appropriate ice-control product on slippery high-traffic areas.
Check for Snow and Ice Damage After the Storm
Once the storm has passed, start outside by making sure snowbanks aren’t blocking the furnace and water heater exhaust pipes. Check whether the gutters are pulling away from the fascia (the board they hang from), and stand well back as you gently knock down any icicles over walkways with a long pole. Then head inside and look for stains or damp patches on the ceilings and walls below roof valleys, where two roof slopes meet.
Most of the trouble a Calgary snowstorm brings can be headed off before the first flake falls: clear the gutters, wrap exposed pipes, bring in loose outdoor items and stock up on supplies. If the power goes out, the job narrows to staying warm safely and keeping essential devices charged. Once the storm passes, make sure nothing is blocking the exhaust pipes, then check the gutters and ceilings for snow or ice damage.
Does Calgary Have Lots of Snow?
Calgary receives snow across fall, winter, and spring, but seasonal totals and snow type vary from year to year. City material has cited average annual snowfall of about 130 centimetres; use current ECCC climate normals and forecasts when planning for a specific season or event.
How Much Snow Weight Can My Roof Hold?
Roof capacity cannot be determined safely from snow depth alone because snow density, drifting, roof geometry, age, and structural condition all matter. Watch for unusual sagging, cracking sounds, leaks, or doors that suddenly bind, and contact a qualified roofing or structural professional rather than climbing onto a snowy roof.
At What Temperature Do You Worry About Pipes Freezing?
There is no single outdoor temperature at which every pipe freezes. Risk increases when cold persists, indoor heat is lost, or plumbing runs through uninsulated exterior walls, crawlspaces, garages, or rim joists. Monitor vulnerable areas and follow local emergency guidance during prolonged cold.
Should You Turn off Your Water During a Winter Storm?
No, you can leave the main shut-off valve open unless your home is without heat for an extended period, you suspect a frozen pipe or you find one has burst. If the furnace fails during a cold snap and indoor temperatures dip close to zero, shut off the main valve and open the taps to drain the lines. An empty pipe has nothing to freeze, so nothing to burst.
How Long Do Power Outages Usually Last During Winter Storms?
Winter outage duration varies with the cause, the number and location of damaged components, road access, weather, and crew requirements. Check ENMAX’s current outage information for the published restoration estimate, and treat that estimate as subject to change.
