Common Power Options for Tailgating
What Power Source Works Best for Tailgating?
Tailgating in Canada brings people together with food, music, and fresh air—but none of that works without electricity. It's easy to forget about electricity when planning snacks and seating. But without it, things go downhill fast—music cuts off, drinks warm up, and there's no way to cook or charge a phone. The right power setup ensures you're not dealing with technical problems while everyone else is trying to have a good time. Especially in the evening, when lights, fans, audio gear, and warming equipment might be running at the same time, power consumption spikes. If you haven't calculated your usage needs ahead of time, you may run out of juice halfway through. Every tailgate setup is different, and the power needs depend on how many people you're hosting and which appliances you plan to run.
There are four main ways to bring power to your tailgate. Each option comes with its own strengths and drawbacks. Consider size, noise, run time, and how much maintenance you're willing to deal with.
Gas Generators Offer: Raw Power with Some Trade-Offs
Planning to use an electric grill, induction cooker, large speaker system, or even a TV? A gas-powered generator might be your only viable option. These machines typically deliver between 1,000W and 5,000W, enough to run multiple high-wattage appliances at once.
But they're not subtle. Generators are noisy and must be placed in well-ventilated areasdefinitely not next to your car or under a canopy. You'll also need to store fuel safely and keep an eye on oil levels. After use, wait for the unit to cool down before packing it away. And if you're tailgating at night, remember that the noise and fumes can disturb others nearby.
Battery Power Stations: Keep Things Quiet and Easy
If you are tailgating in an area that is not very trafficked or would prefer an area less crowded, battery-powered power stations are excellent options. The units possess sturdy lithium batteries and require no gas or emissions.
They're perfect for powering LED lights, small refrigerators, Bluetooth speakers, laptops, and portable fans. Their capacities are between 300Wh and over 2000Wh, and most of them have multiple outlets, quick charging, and USB-C ports. Some even allow you to add additional batteries, solar panels, or car chargers.
All new stations will indicate how much power you are consuming, how much power you still have, and the temperature inside. Premium models may offer wireless charging zones and advanced safety features—great for tech-heavy setups.
Solar Power: Keep You Running All Day
A solar generator is useful in sunny areas or for extended usage during the day. It will not provide you with all the energy you can want, but it will charge the battery as you utilise it.
Solar panels on wheels are often compact and portable. Some even can change their stand or frame to receive as much direct sun as they are able. Solar energy is effective in sunny locations, but less so in cloudy regions or locations away from the equator. Keep them as a supplement, not as the sole means.
Conversion rates for solar panels are typically between 18% and 23%. The greater surface area and better angle, the more power you will generate. Altering your panels every two hours that the sun is out can significantly increase efficiency.
Solar Panels: Keep You Running All DaySolar Panels: Keep You Running All Day
Car Battery and Inverter: Best for Low-Demand Use
For light-duty power needs or budget-friendly setups, using your car battery with a small inverter is still an option. A 12V inverter plugged into your cigarette lighter can supply 100W to 300W of AC power—enough for phones, cameras, or low-wattage lights.
Larger inverters can connect directly to the car battery and deliver up to 600–1000W, but this should be done cautiously. Drawing too much power can leave you with a dead battery and an engine that won't start. Be sure to start the car periodically to recharge.
This method is fine for short-term use, like charging devices or running LED light strips, but shouldn't be used with large appliances or multiple devices at once. Too much load could damage your car's electrical system.
Side-by-Side Comparison for Quick Reference
Power Source
Portability
Noise Level
Energy Type
Run Time
Best Use Cases
Gas Generator
Moderate
High
Gasoline
Long with refueling
Large appliances, full-day events
Excellent
Silent
Lithium-ion
4–10 hours
Quiet areas, city parking lots
Solar Panel + Battery
Good
Silent
Solar
Continuous (sunlight)
Long daytime setups, eco use
Car Battery + Inverter
Moderate
Low
12V DC
2–3 hours
Light gear, basic phone charging
Depending on your requirements, the right power source can make your tailgating experience more seamless, with gas generators for high power requirements, battery power stations and solar for quiet and green use, and car batteries with inverters for lighter appliances.
Think Ahead Before Choosing Your Power Setup
It is simple to just work with the power solution you've got and see what happens, but spending five minutes planning can make a significant difference. Consider the following:
How Long Will You Be Staying?
You can do a brief tailgate until lunch on a medium battery. If you attend an all-day or nighttime event, you are going to want a generator or a larger battery and solar power. To determine what you need, multiply the wattage of each piece by the number of hours you will be using it. If your activities take more than a few hours—such as if you are camping overnight or overnights—the EcoFlow RIVER 2 Pro is worth considering. It will power 80% of high-wattage devices, so it is a safe bet for cooking equipment, small projectors, or essential electronic devices.
The battery lasts for days on the charge it has. You can recharge it without connecting to the grid, with solar panels that are up to 220W, so you don't have to worry about needing to plug it into a wall outlet.
Power your adventures with EcoFlow RIVER 2 Pro — charge in only 70 minutes and enjoy reliable, long-lasting power for all your needs
How Many Are Going to Come?
The more guests, the more devices—phones, fans, speakers, and lights. You will require more outlets and a more powerful power source. Choose a power source that can power many devices simultaneously and is not prone to overheating.
Do They Have Regulations Regarding Noise or Fuel?
Certain areas, particularly around parks or stadiums, are not permitted for fuel-burning or noise-producing machines. Check the rules in your area before using them. Solar-powered or battery-operated instruments are perfect for quiet areas.
What Is Weather Forecasting?
If it's sunny and mild, solar panels can help keep your system charged. But if rain is in the forecast or skies are overcast, rely on a pre-charged battery or a backup generator. Use waterproof covers for outlets and devices.
Don't Overlook Safety When Using Power
The last thing you want is a hazard while everyone's trying to relax. Here are a few basic rules to follow:
Never use gas generators in enclosed or covered spaces
Keep all cords dry and off the ground
Use outdoor-rated power strips and extension cords
Do not overload one outlet with several high-wattage items
Store fuel in sealed, approved containers away from heat
Organize Your Setup to Save Time
Arriving early to your spot doesn't help if you're untangling cords for 20 minutes. Label everything in advance. Bring extras. Use a folding table or a large plastic bin to keep devices off the ground and dry. Zip ties, Velcro straps, and a small toolbox make setup quicker and neater.
Good Power Makes Everything Feel Easy
When your equipment runs smoothly and guests don't have to ask for a charger, the mood stays light and fun. The food stays hot, the music stays on, and no one's phone hits 1%. That kind of convenience often goes unnoticed—until something doesn't work. Plan ahead, and your party will stay focused on fun instead of power problems.
FAQs about Power Options for Tailgating
Q1: What if a power plant is overwhelmed with work?
All the new units are protected against overload. When you plug in too many high-power appliances and draw more current than the unit is designed for, it shuts OFF automatically to prevent overheating or damage. Switch OFF all the appliances, reset the unit (if necessary), and plug in the required appliances only within the safe ratings.
Q2: Do I require a power supply for an electric kettle or an electric grill?
It also depends on the amount of power utilized. The majority of electric grills and electric kettles require 1000–1500W. Only powerful generators or large power stations (rated around 2000Wh/2000W or higher) can support such appliances safely. Otherwise, you may overload the system and force the device to shut down automatically.
Q3: Is it possible to directly charge a phone using solar panels?
Indeed, you can, but you must not. The solar electricity is subject to light, and occasionally, charging can be inconsistent or cease. The most appropriate option is to charge your power station in advance and subsequently charge your telephone from the stable output.
Portable Power Stations
