Which Appliances Use the Most Electricity? Top Energy Consumers in South African Households Explained
Many homeowners struggle with rising electricity bills, often without realising which appliances use the most electricity. Knowing what uses the most electricity in a house is the first step toward taking control of energy consumption and reducing monthly costs. When families identify high-energy devices, they can adjust usage habits, schedule appliances during off-peak hours, and even invest in backup solutions to maintain comfort during power outages. This approach helps save money, reduce unnecessary energy waste, and create a more efficient and cost-effective home environment. This article highlights which appliances are the biggest energy consumers and offers practical tips to help lower electricity usage.
Top 5 Appliances That Use the Most Electricity
To manage energy costs effectively, it is important to know which appliances consume the most electricity. Finding out which of these are the biggest energy users can also help reduce waste and keep monthly costs under control.
1. Heating and Cooling Systems
Keeping indoor comfort is costly if heating or cooling runs unchecked; small tweaks and regular upkeep cut large chunks from your monthly bill.
  • Typical consumption: Split-type aircons and reverse-cycle units commonly draw ~0.8–3.5 kWh/hr depending on size and load; portable heaters typically 1–2 kW.
  • Why they spike bills/maintenance: Dirty filters, blocked outdoor units and poor insulation force systems to run longer.
  • Saving actions: Set thermostats to ~23°C, use ceiling or pedestal fans to circulate air, clean filters and outdoor coils regularly, and seal/insulate gaps to shorten run-time.
2. Geysers
Hot water is frequently the single biggest household energy load; controlling when and how you heat water delivers big savings fast.
  • Typical consumption: Geysers often account for ~30–50% of a household’s electricity use, depending on size and habits.
  • Why they spike bills/maintenance: Poor insulation, high thermostat settings and limescale on elements increase cycling.
  • Saving actions: Fit a geyser blanket and pipe insulation, install a timer to heat during off-peak hours, and set the thermostat to ~60°C.
3. Refrigerators and Freezers
Fridges run nonstop, so small inefficiencies multiply; keep them well maintained and appropriately sized for your household.
  • Typical consumption: Modern efficient fridges use far less power than older models; exact draw varies with size and age but inefficiency compounds over 24/7 operation.
  • Why they spike bills/maintenance: Dirty condenser coils, damaged door seals and over-frequent opening force compressors to run harder.
  • Saving actions: Clean coils, check door seals, avoid placing hot food inside, and replace very old units with A+-rated models sized to your needs.
4. Clothes Washers and Dryers
Laundry choices determine whether washing stays cheap or becomes a major energy item; water heating and drying are the heavy hitters.
  • Typical consumption: Washing on hot and tumble drying are the main draws — tumble dryers commonly use ~2–4 kWh per cycle.
  • Why they spike bills/maintenance: Frequent small loads, heating water for every wash and over-use of the dryer drive consumption up.
  • Saving actions: Use cold-water cycles and full loads, hang to dry where possible, and when needed use dryer sensor or low-heat modes.
5. Ovens and Electric Stoves
Cooking energy is easy to control with better techniques; small behaviour changes cut noticeable kWh without changing meals.
  • Typical consumption: Large hob plates draw ~1.5–2 kW; ovens commonly use ~2–2.5 kWh per hour when baking.
  • Why they spike bills/maintenance: Long preheats, using oversized elements for small pots and poor oven door seals waste energy.
  • Saving actions: Use lids, batch cook, favour pressure cookers or air fryers for small meals, and match pan size to the element.
Estimated Running Costs for Top Appliances in South Africa
To give you a clearer picture of your monthly spend, here is a breakdown based on typical usage and an average electricity rate of R3.15 per kWh. These figures illustrate how high-wattage appliances impact your wallet over time.
Appliance
Daily Usage (Est.)
Monthly Consumption (kWh)
Estimated Monthly Cost (R)
Estimated Annual Cost (R)
Electric Geyser
2–3 hr heating per day
90–150
284 – 473
3 410 – 5 680
Air Conditioner
2–4 hr seasonal
36–72
113 – 227
1 360 – 2 720
Tumble Dryer
3 loads/week (~0.75 hr/load)
~6
~19
~230
Fridge/Freezer
Cycling ~24 hrs
~30–50
95 – 158
1 140 – 1 900
Electric Oven
0.5–1 hr/day
~15–30
47 – 95
570 – 1 140
Note: Estimates vary based on your specific municipality’s tariff block and the efficiency rating of your appliances.
Factors That Affect Household Electricity Consumption
The electricity consumption of household appliances varies for many reasons. Understanding these factors can help families identify high-energy devices and manage their electricity use more effectively.
Appliance Type and Function
High-energy appliances such as electric geysers, air conditioners, and ovens naturally consume significantly more electricity than smaller electronics.
In many South African homes, the geyser often accounts for a large portion of the monthly bill, while pool pumps and space heaters also contribute heavily during specific seasons. Devices that operate continuously, like refrigerators and freezers, maintain a steady draw on the grid. Identifying which types of appliances demand the most power allows households to prioritise energy-saving measures where they matter most.
Power Rating and Load
The wattage of an appliance determines how much electricity it draws during operation. High-wattage devices, particularly when running at full capacity during peak demand periods (usually 17:00 to 21:00), can noticeably increase the household energy consumption of appliances. Even occasional use of these heavy-load appliances, such as electric kettles or tumble dryers, can have a significant impact on monthly energy bills due to the sheer intensity of their power draw.
Duration and Frequency of Use
Even appliances with moderate power ratings can become major energy consumers if used frequently or for long periods. In South Africa, the frequency of use often changes due to load shedding schedules, leading many to run multiple appliances like washing machines and dishwashers simultaneously during "power-on" windows. This concentrated usage, along with the extended operation of entertainment systems or electric heaters during winter, can quickly increase electricity costs and overall household energy demand.
Appliance Efficiency and Age
Older or less efficient appliances often require more electricity to achieve the same output as newer models. Many South African households still use older, non-inverter appliances that lack modern energy-saving features. Upgrading to energy-efficient devices can help reduce overall consumption while maintaining performance. This shift can provide long-term savings and more sustainable household energy use compared to keeping outdated, power-hungry equipment.
Tips to Reduce Household Electricity Consumption
After identifying which appliances use the most electricity, households can take simple actions to manage their energy use more efficiently. Small changes in habits and routines can reduce waste, lower monthly bills, and improve overall energy efficiency. Here are some practical ways to reduce electricity consumption:
1. Use Appliances During Off-Peak Hours
Running high-demand devices like washing machines, dryers, or water heaters during off-peak hours can help households save on electricity costs. Shifting usage to these periods reduces strain on the electrical grid and lowers monthly bills, while still allowing appliances to operate efficiently when needed.
2. Avoid Standby Power Waste
Many appliances continue to draw electricity even when turned off but left plugged in. Unplugging devices such as TVs, chargers, and small kitchen appliances when not in use prevents unnecessary energy consumption.
3. Perform Regular Maintenance
Keeping appliances in good condition ensures they operate efficiently. Simple actions like cleaning air filters, defrosting freezers, or servicing heaters and air conditioners can reduce energy use without affecting performance.
4. Be Mindful of Usage Habits
Monitoring how long and how frequently high-energy devices are used can significantly impact monthly electricity bills. Limiting prolonged use of ovens, dryers, or space heaters and combining loads when possible helps reduce overall consumption.
5. Optimise Your Energy with a Portable Power Station
Integrating a portable power station into your home setup is a practical way to manage energy more effectively. These devices allow you to store electricity during off-peak hours when rates are lower or through solar panels, providing a dedicated reservoir of power to use when the grid is under pressure or electricity costs are at their highest.
The EcoFlow DELTA 2 Portable Power Station is a versatile option for South African households due to its lightweight and compact design. It is easy to move between rooms to power specific appliances as needed. Its expandable capacity allows you to add extra batteries if your energy requirements grow, making it a flexible choice for daily electricity management or as a reliable home backup system for essential devices.
The EcoFlow DELTA 2 Portable Power Station offers 1–3 kWh expandable capacity and 1800W AC output, capable of powering over 90% of household appliances. Even during power outages, your microwave, refrigerator, or coffee machine can run smoothly, and it supports up to 13 devices simultaneously. Thanks to its lithium iron phosphate battery, it retains 80% of its initial capacity even after years of regular use, supporting over 3,000 full charge cycles for reliable, long-lasting performance.
For larger homes with higher energy demands, the EcoFlow DELTA Pro 3 Portable Power Station offers a more robust solution with its significant capacity and high power output. It is capable of running multiple high-wattage appliances simultaneously, from kitchen equipment to home office setups. Its integrated UPS function is particularly beneficial during frequent loadshedding, as it provides a near-instantaneous switch to battery power, ensuring that your household remains operational and your sensitive electronics are protected from sudden outages.
The EcoFlow DELTA Pro 3 Portable Power Station delivers 230V, 4000W AC output and a 4096Wh capacity, expandable up to 12kWh, providing reliable and flexible power for nearly all household appliances. Equipped with X-Stream fast charging, it reaches 80% in just 50 minutes and supports six independent charging modes with up to 18 combined options. Designed for flexibility, speed, and convenience, its X-Quiet technology keeps noise below 30 dB under a 2000W load, while the plug-and-play design ensures effortless everyday operation.
Knowing which appliances use the most electricity can help households make smarter energy choices. By identifying high-demand devices and adopting practical strategies to reduce consumption, families can lower electricity bills, improve efficiency, and make better decisions about daily energy use. Pairing this awareness with flexible solutions, such as portable power stations, allows homes to stay comfortable while minimising unnecessary electricity waste.
Does leaving a kettle plugged in use electricity?
Leaving a standard electric kettle plugged in but switched off typically uses almost no electricity, as these appliances generally draw power only when the heating element is active. Some modern models with indicator lights, digital displays, or keep-warm modes can draw a minor standby current of about 0.5–2 W. While this cost is often negligible for a single kettle, it can accumulate across multiple devices over time. For most South African households, the primary expense is the high power draw during the boiling process, which is typically 1–3 kW, rather than the idle state. If you prefer to eliminate even that small amount of standby power, simply switch off the wall socket or unplug the cord.
What appliances should I turn off to save energy?
To save electricity, switch off or unplug devices when they’re not in use. High-energy appliances such as geysers, space heaters, air conditioners, and pool pumps should be turned off whenever possible. Standby power from TVs, computers, and chargers can also add up. In South African homes, where energy costs are high, disconnecting unused appliances is one of the simplest ways to lower monthly electricity bills.
What time of day is the cheapest to run appliances?
Running appliances during off-peak hours is usually the most cost-effective strategy. These times generally fall in the late morning to early afternoon and late at night, when overall electricity demand is lower. In South Africa, households on time-of-use tariffs can benefit from scheduling high-demand devices, like washing machines or dishwashers, during these periods to reduce electricity costs while maintaining convenience.
Save Bills
