Problems With Prepaid Electricity Meters: Causes and Fixes
- Key Takeaways
- Prepaid Electricity Meter Not Working? Start With These Checks
- Electricity Token Rejected? Common Causes and Fixes
- Prepaid Electricity Meter Error 30: Meaning and Fixes
- Why Is My Prepaid Meter Not Working Even With Units Left?
- Eskom Prepaid Meter Problems: Who Should You Contact?
- How to Keep Essential Devices Powered While Your Meter Is Fixed
- Support Higher-Power Household Needs During Extended Repairs
- Conclusion
- FAQs
Problems with prepaid electricity meters can leave you without power even after buying credit. In South Africa, your keypad may reject a 20-digit token, display Error 30, or show remaining units while your lights stay off. The cause could be an incorrect meter number, a communication fault, an overload, a local outage, or outdated KRN1 settings. This guide helps you identify common faults, try safe troubleshooting steps, and contact the right electricity supplier. You’ll also find ways to keep essential devices powered while waiting for repairs.
Key Takeaways
Common problems with prepaid electricity meters include rejected tokens, keypad connection errors, overloads, and local outages.
A token showing rEjEct requires a different response from one displaying USED. Check the exact message before buying more electricity.
On applicable Eskom meters, Error 30 indicates a communication problem between the keypad and the main meter.
If safe checks fail, contact Eskom, your municipality, or your authorised meter provider with the error details and meter number.
If your prepaid electricity meter is not working, start with the display message and whether your home still has electricity. The table below helps you identify the likely problem and the first safe action to take.
What You’re Seeing | Possible Cause | First Safe Check |
Token shows rEjEct | Invalid or unauthenticated token | Check the token digits and meter number |
Token shows USED | Token was previously loaded | Check available credit and purchase history |
Error 30, Conn-_FAIL, or E07 | Keypad communication fault | Check the keypad’s power and connection |
Units remain but no electricity | Local outage, overload, or tripped breaker | Check nearby supply and accessible breakers |
Keypad screen is blank | Flat batteries or a power connection power | Check the keypad’s batteries or plug |
You paid but received no token | Purchase processing or delivery issue | Check the vendor’s receipt and transaction status |
These are common Eskom prepaid meter problems. Conlog, Hexing, Itron, and other models may use different codes or troubleshooting procedures. Follow the instructions for your meter and electricity provider.
If you notice damaged cables, exposed wiring, smoke, or a burning smell, stop troubleshooting and contact a qualified professional. Never open, rewire, or interfere with a sealed prepaid meter.
An electricity token rejected by your keypad may be linked to incorrect purchase details, a previously used token, or outdated meter settings. Before buying additional electricity, work through the checks below.
Check the 20-Digit Token and Meter Number
Compare the 20-digit token with the code on your receipt, SMS, or banking app. Enter it carefully, checking that no digits have been omitted or entered in the wrong order.
Next, confirm that the meter number on your purchase receipt matches your actual prepaid meter. Tokens are normally generated for a specific meter, so a purchase linked to another meter number will not load correctly.
If you entered the wrong meter number or paid without receiving a token, contact the original vendor with your transaction reference. Ask the vendor to investigate the purchase before paying for the same electricity again.
What Do “rEjEct” and “USED” Mean?
These two messages require different responses on applicable Eskom prepaid meters.
rEjEct: The token is invalid or has not been authenticated. If the message remains after checking your purchase details, contact your electricity supplier.
USED: The token has already been loaded. Check your remaining credit and purchase history before buying another token.
Keep a record of the exact message and the purchase confirmation. These details will help your supplier determine whether the issue involves the token or the meter.
Could Your Meter Still Need a KRN2 Update?
Some older South African prepaid meters may reject new electricity tokens because they have not been recoded from Key Revision Number 1 (KRN1) to KRN2.
The Standard Transfer Specification (STS) Token Identifier rollover took place on 24 November 2024. Meters that missed the update may no longer accept current electricity tokens.
For applicable Eskom meters, enter this official test code:
1844 6744 0738 4377 2416
Display Result | Meter Status |
1 or 1.2 | Still on KRN1; recoding required |
2 or 2.2 | Updated to KRN2; no further recoding required |
If your meter remains on KRN1, contact Eskom or your municipality for the current procedure. The process described in how to upgrade prepaid meter involves entering two supplier-issued Key Change Tokens in the correct order before loading compatible electricity credit.
Because the original deadline has passed, confirm the current instructions with your provider rather than relying on old update schedules. Eskom also publishes official KRN2 information for affected customers.
On applicable Eskom split prepaid meters, Error 30 indicates that the keypad cannot communicate with the main metering unit. The problem may involve the keypad's power supply, its connection, or electrical interference.
Why Your Keypad Cannot Communicate With the Meter
A Customer Interface Unit (CIU) allows you to enter electricity tokens and check your balance. On some split prepaid systems, it communicates with the main meter through the property’s electrical wiring.
Nearby appliances, socket connection problems, or a disrupted communication link can interrupt this connection. Eskom groups Error 30, Conn-_FAIL, and E07 under keypad communication errors, although the exact display and recovery steps can vary by model.
How to Restore the Keypad Connection Safely
If you see Error 30, follow the steps applicable to your meter:
Check the keypad's power. Replace flat batteries where applicable, or confirm that a plug-in keypad has power.
Try a socket closer to the meter. On supported Eskom systems, a socket near the distribution board may provide a better communication connection.
Reduce nearby interference. Switch off or unplug non-essential appliances where safe, and temporarily turn off fluorescent lights if your supplier recommends it.
Restart the connection. Press the i, blue, or # button according to your meter's instructions.
If the display changes to ConnEct, the keypad is attempting to reconnect. Eskom advises allowing up to 30 minutes for this specific connection-waiting message.
If the problem continues, report it to your electricity supplier rather than repeatedly entering random commands.
Some faults require supplier-issued prepaid electricity meter reset codes. These codes are not universal, so use only instructions approved for your specific meter and error.
If your meter still shows electricity credit but your home has no power, the problem may not involve your token balance. A local outage, tripped breaker, or meter overload could have interrupted the supply.
Check for Local Power Outages and Tripped Breakers
First, check whether neighbouring properties also have electricity. If several homes are affected, the problem may be a network fault, planned maintenance, or a scheduled supply interruption.
Look for official outage updates from Eskom or your municipality before attempting further troubleshooting.
If nearby properties have power, check the accessible circuit breakers on your household distribution board. A breaker may have tripped because of an electrical fault or overload.
Only operate equipment you can access safely. If a breaker trips again after being reset, stop and contact a qualified electrician. Do not open sealed meter equipment or attempt to restore electricity through unauthorised wiring.
Check for Overload and Meter Lockout
A prepaid meter may temporarily disconnect electricity when connected appliances exceed the permitted supply limit.
On applicable Eskom systems:
OUEr_Por: Indicates an overload. Switch off appliances and allow approximately 30 minutes for the meter to reset.
Loct-oUT: Indicates a lockout that may occur when the supply limit has been exceeded. Reduce appliance demand and allow the message to clear according to your supplier’s instructions.
If electricity returns after reducing the load, avoid running several high-power appliances simultaneously.
If the meter repeatedly disconnects despite a reduced load, ask your electricity provider to investigate the supply limit or arrange an electrical inspection.
If the checks above do not restore your electricity, contact the organisation responsible for your supply. Not every prepaid meter in South Africa is managed directly by Eskom, so identifying the correct provider can prevent unnecessary delays.
Contact Eskom, Your Municipality or Your Meter Provider
Your Electricity Arrangement | Who to Contact |
Eskom directly supplies your property | Eskom customer service |
Your municipality supplies electricity | Your municipal electricity department |
You have a privately managed prepaid submeter | Your landlord, property manager, or authorised meter provider |
Payment succeed but the token was not delivered | The bank, retailer, or vending service that processed the purchase |
For direct Eskom customers, the following official channels are available:
Customer Contact Centre: 08600 37566
USSD: *120*37566# to log electricity supply faults, report token issues, and check fault status
Alfred Chatbot: Eskom Alfred for reporting faults and following up on existing cases
Eskom’s USSD service is intended for customers supplied directly by Eskom. If your municipality provides your electricity, use its official customer service channels instead.
If you are unsure who supplies your property, check your electricity purchase receipt, account documentation, or rental agreement.
What Information Should You Prepare Before Reporting a Fault?
Have these details ready when contacting your electricity provider:
Prepaid meter number and property address
Exact error code or display message
Electricity purchase receipt or transaction reference, if relevant
Time the fault started
Safe troubleshooting steps already attempted
Keep the original token available for an authorised support agent, but avoid sharing it publicly. Ask for a fault reference number so you can track the report and follow up if the problem continues. If the meter or wiring appears damaged, report this issue as urgent and avoid further contact with the affected equipment.
A prepaid meter fault may leave your home without electricity when you wait for the supplier or an authorised technician. During that time, refrigeration, lighting, and communication may be your main priorities.
A charged portable power station can supply compatible devices independently of the mains electricity supply. Before choosing one, check how much power your essential appliances use and how long you need them to run.
For example, a 10 W router running for eight hours uses approximately 80 Wh, and two 8 W LED lamps running for the same period use another 128 Wh. Together, they require around 208 Wh before conversion losses. A refrigerator would add its own energy consumption, which varies with its size, temperature settings, and compressor operation.
If your meter fault requires an extended repair, you may need electricity for several household appliances, including equipment with higher startup demands. The EcoFlow DELTA 3 Ultra Plus Portable Power Station provides 3,072 Wh of LFP battery capacity for households planning longer backup periods. It can supply compatible refrigeration, lighting, and other essential appliances through its own outputs when you wait for electricity service to return.
Keep Refrigeration and Communication Running During Meter Faults
If your immediate priority is preserving refrigerated food and keeping your household connected, focus on the refrigerator, Wi-Fi router, phone chargers, and essential lighting. The EcoFlow DELTA 3 Max Portable Power Station offers 2,048 Wh of LFP battery capacity and 2,400 W rated AC output for compatible household equipment. Its stored power can support these priority devices during a temporary interruption, with runtime depending on actual consumption.
Problems with prepaid electricity meters often involve rejected tokens, keypad connection failures, overloads, or local supply interruptions. Start with the display message, follow the relevant safe checks, and contact your electricity provider if the issue continues. If repairs take longer, a suitable backup power supply can help keep essential household devices running until electricity is restored.
Can I Replace My Prepaid Electricity Meter?
You can request a replacement, but you should not remove or install a utility-owned prepaid meter yourself. Contact Eskom or your municipality to report the fault and ask whether a new meter is necessary. For a private submeter, speak to your landlord or authorised meter provider. The replacement must follow the applicable installation requirements. Before work begins, confirm any charges and how your remaining electricity credit will be handled.
Can a Faulty Prepaid Electricity Meter Overcharge Me?
A faulty meter can sometimes record electricity consumption incorrectly, but rapidly disappearing credit does not automatically mean the meter is defective. High electricity usage, tariff changes, or applicable account deductions may explain the difference. Compare your recent purchases and usage patterns before reporting the problem. If you still suspect inaccurate readings, ask your electricity provider about an official meter accuracy test, including any testing fees and possible adjustments.
How Long Does It Take to Replace a Faulty Prepaid Meter?
There is no fixed replacement period across South Africa. The time required depends on the fault, technician availability, replacement stock, and whether additional electrical work is necessary. Some issues can be resolved without replacing the entire meter, while damaged equipment may need a scheduled installation. When reporting the problem, request a fault reference number and an estimated response time. Use that reference when following up if the repair is delayed.
Can I Get a Refund if I Bought Electricity for the Wrong Meter?
A refund is not guaranteed because prepaid electricity tokens are normally generated for a particular meter number. Contact the original bank, retailer, or vending provider as soon as you discover the mistake. Provide your receipt, transaction reference, and the meter number entered during payment. The provider can explain whether cancellation, correction, or another resolution is possible. Avoid purchasing additional credit for the same transaction until you understand the available options.
