EcoFlow DELTA Pro Ultra
Since 2021, our smart home energy system EcoFlow DELTA Pro Series has delivered reliable home backup to over 100,000 families.
  • 7-Day Setup, Faster Payback: 75% lower upfront cost vs. traditional solar batteries, from 2.5-year payback¹
  • Expandable Whole-Home Power: Start 6kWh / 7.2kW → scale to 90kWh / 21.6kW
  • Smart Panel Control: 20ms backup + 12 circuits with Smart Home Panel 2
  • High Solar + Generator Ready: Up to 16.8kW solar + portable generator support
  • EV Charging Optimized: Up to 35 miles/hour with smart TOU charging
$0
us-img
us-img
us-img
us-img
Over 12,000 Units installed in U.S. households
EcoFlow DELTA Pro Ultra is a whole-home energy system designed to grow with your family. Integrated with the Smart Home Panel 2, it scales to meet your evolving energy needs — keeping your home powered, intelligent, and secure through every stage of life.
Get the Highlights
Power That Grows With Your Home
Expandable Power, Multi-Source Backup
7.2-21.6kW
6-90kwh
us-img
7-Day Setup.
Storm-Ready
us-img
Powers 99% of Whole-Home Appliances
us-img
Save Up to $3,600/Year
With a Smarter Energy Ecosystem
us-img
Your Smart Home, Under Control
Open Smart Home Ecosystem with 15+ Partner Brands
us-img
  • EcoFlow App
    EF-Image
    Intelligent settings, remote control, and monitor power usage data in the EcoFlow app.
    EF-Image
    7.2kW output per unit, scalable to 21.6kW, supporting heavy loads like 4-ton air conditioners.² Start with 6kWh capacity and expand to 90kWh, adapting to household size or energy demands.
    EcoFlow Smart Home Panel 2
    EF-Image
    20 ms auto-switchover, 12 customizable circuits with single-circuit control by using the EcoFlow Smart Home Panel 2.
    Generators
    EF-Image
    Compatible with EcoFlow or third-party generators to get up to 12kW output for your entire house.
  • EcoFlow App
    EF-Image
    EcoFlow PowerPulse EV Charger (9.6kW)
    EF-Image
    9.6kW delivers 35 miles in an hour charge.³ With DELTA Pro Ultra and Smart Home Panel 2, turn solar into mileage.
    EF-Image
    EF-Image
    Solar Panels
    EF-Image
    Compatible with existing rooftop PV and flexible solar systems. The 5.6kW solar input provides you with up to a day of backup from only an hour of sun.
  • Blackout Preparedness
  • Daily Use
Uninterrupted, Unlimited, and Ultra-Smart Power
The EcoFlow DELTA Pro Ultra and Smart Home Panel 2 are an intelligent whole-house energy system for extended outages. Featuring a 20 ms automatic switchover, it ensures an uninterrupted power supply. With an expandable capacity of up to 90kWh, an output of up to 21.6kW, and five different ways to refuel, the system adapts to diverse power backup needs, ensuring you never sacrifice living convenience.
Grow Your Power, Plug-and-Play
DPU × 1 + SHP2(7200W,30A)
Basic Backup
  • Light (10W)
  • TV (110W)
  • Washing Machine (1000W)
  • Microwave Oven (1000W)
  • Refrigerator (300W)
  • Central Air Conditioning (3 tons, 3.6kW)
DPU × 2 + SHP2(14400W,60A)
Advanced Backup
  • Light (10W)
  • TV (110W)
  • Electric Oven (4kW)
  • Dishwasher (1.3kW)
  • Induction Cooker (3kW)
DPU × 3 + SHP2(21600W,90A)
Hassle-Free Backup
  • Light (10W)
  • TV (110W)
  • Electric Car (6kW)
  • Coffee Maker (1.5kW)
Help me choose with the calculator >
Solar Power Stays Active
Unlike other home battery systems, solar panels can still power your entire home through the DELTA Pro Ultra system even during outages.
Uninterrupted Power with a Generator
When the weather turns stormy, a seamless connection to the EcoFlow Smart Generator 4000 (Dual Fuel) or a 3kW or above portable gas generator ensures your home stays energized without a hitch.⁴
Refuel at EV Charging Stations
Using the EcoFlow EV X-Stream Adapter, get rapid 7200W charging from EV charging stations at home or on the road.
AI-Powered Energy Plans
The DELTA Pro Ultra’s AI analyzes your backup power needs and recommends the best energy-saving plan to stretch your power supply as long as possible.
Single-Circuit Control and Backup Priority Settings
Smart Home Panel 2 offers 12 customizable circuits with single-circuit control and backup power priority settings (e.g., keep the fridge running, limiting non-essentials). The system automatically extends backup time by efficiently managing energy use.
5.6kW-16.8kW solar input
Free energy from various solar sources
A single DELTA Pro Ultra inverter has two PV input ports for a maximum 5.6kW solar input. Connect DELTA Pro Ultra with the Smart Home Panel 2 system for compatibility with existing rooftop PV systems. Connect three inverters for a monumental 16.8kW input, achieving a full day's home energy in as little as 60 minutes.
  • Add Storage to Rooftop Solar and Start Saving
    Looking to add batteries to your solar roof? Connect your Smart Home Panel 2 with the main panel, and the system automatically charges the DELTA Pro Ultra Battery using solar energy. Utilize free energy to support your home's energy needs and maximize the power of your rooftop panels. What's more, with the DELTA Pro Ultra system, there's no wasted energy while staying in the NEM 1.0/2.0 plan.
  • Buy Your Own Solar Panels
    With its flexible plug-and-play design and unrivaled solar input, EcoFlow DELTA Pro Ultra allows you to tailor your solution to fit your energy needs. A single inverter has two PV input ports for a maximum solar input of 5.6kW. Connect three inverters for a monumental 16.8kW. Enjoy $0 electricity bills* on sunny days—let your solar panels do all the work!*
    Wondering which solar panels are the best fit for you?
    Check out our tutorial video >
  • For Roof Solar
  • For DIY Solar
3 Ways to Boost Money Saving
By charging during low-cost periods, topping up with solar energy, and automating tasks, reduce your reliance on expensive grid power.
  • Self-Powered
  • Scheduled Tasks
  • TOU Mode
Reduce grid dependency and lower electricity costs. Self-Powered mode allows you to store solar energy and power your home once battery capacity exceeds the pre-set reserve. Rely on solar to power the entire home, reducing the need for grid electricity. Ideal for managing fluctuating energy prices, this decreases grid dependency, enhancing your energy freedom.
Timed Circuits
Smart Home Panel 2 allows two timed circuits so you can schedule high-power devices (e.g., AC, pool pumps) to run during off-peak hours or to turn off high-power appliances to avoid standby power consumption (will be released in June).
Eco Mode
Eco Mode
Automatically coordinates EV charging with your home's energy flow—utilises surplus solar power and battery during the day, switches to off-peak grid energy at night, and always maintains sufficient backup power reserves for emergencies while keeping daily appliances running.
Surplus Solar Only*
Surplus Solar Only*
Excess solar energy is exclusively used to charge your car. * For vehicle owners with solar systems.
Instant Charging
Instant Charging
Your car begins charging immediately upon plugging into the charger.
EF-Image
AI-Powered Savings
The AI assistant analyzes your electricity habits and suggests smarter, cheaper ways to use energy.
Visualize Every Cent Saved
Every day, see exactly how much you’ve saved—turn those savings into your personal ‘investment fund’.
Share Your Wins
Brag about your savings! Share your cost-cutting achievements with one click and show off your ‘investment returns’.
  • DELTA Pro Ultra Home Battery Solution
    • ​Payback Period
      2.5 Years¹
    • Solar Panel Cost
      $3,999 14*400W Rigid Solar Panel; DIYable, no installation fee needed
    • Installation Cost
      Around $2,000 for Smart Home Panel 2 Installation
    • Total Upfront Cost
      $8,999(DELTA Pro Ultra+Solar Panel Cost) $12,499(DELTA Pro Ultra+Smart Home Panel 2+Installation+Solar Panel Cost)
    • End to end lead time
      Less than 2 weeks
    • Flexibility
      modular and movable design, plug & play for inverter and batteries connection, scaling without installation
  • Traditional Residential Energy Storage System
    • ​Payback Period
      Around 8 Years
    • Solar Panel Cost
      $16,800 5.6kWp × $3, including installation; Roof Solar might cost more due to roof renovation
    • Installation Cost
      Around $8,000
      $35,800 (Including solar panel and installation)
      1-3 months
    • Flexibility
      wall-mounted, battery scaling also requires installation
3 Home Connection Methods
  • EcoFlow Smart Home Panel 2
    Number of EcoFlow DELTA Pro Ultra units that can work with this system:
    1-3
    Capacity:
    6-90kWh
    Voltage/Amps:
    7200W/30A 14400W/60A 21600W/90A
    Solar Input:
    5.6-16.8kW
  • Manual Transfer Switch
    1-2
    Capacity:
    6-60kWh
    Voltage/Amps:
    7200W/30A 12000W/50A
    Solar Input:
    5.6-11.2kW
  • Inlet Box
    1-2
    Capacity:
    6-60kWh
    Voltage/Amps:
    Solar Input:
    5.6-11.2kW
  • Inlet Box
$99 FREE NOW!
Installation Consulting Service For EcoFlow Smart Home Panel 2
With our service, you'll experience a seamless EcoFlow Smart Home Panel 2 installation. We connect you with a fully-trained local electrician and provide tracking from order to fitting. Our team is on hand to answer any technical queries, ensuring a smooth, hassle-free setup that prioritizes your convenience and satisfaction.
  • Step 1: Order Placement
    When placing an order, please provide your full delivery address and contact details.
  • Step 2: Appointment Scheduling
    Our team will contact you via phone or email within two business days to schedule your installation appointment.
  • Step 3: On-Time Visit & Installation
    An EcoFlow engineer will arrive at the scheduled time to complete your installation. They will install and commission your system on site to ensure that it is operational that day, and will also provide instructions on how to use basic features
  • Step 4: Customer Verification & Feedback
Already qualified for the service? Click and check the service details.
EcoFlow Installation
Guaranteed Response Times with Compensation
Once you place an order, an installer will contact you within two business days to schedule your installation.
The standard delayed appointment compensation is USD 200.
On-Time Arrival Guarantee with Missed Appointment Compensation
You will receive compensation if an EcoFlow installer misses your appointment on the appointed day without reason and a new appointment will be booked.
The standard missed appointment compensation is USD 200.
Certified Professional installers with Follow-up Service
All EcoFlow installers are professionally certified. If the 4-step installation process does not meet EcoFlow standards, we'll provide a free follow-up appointment. Ecoflow reserves the right of final interpretation.
Dedicated Customer Service hotline for End-to-End Support
Complete support and tracking for your installation from order placement to final verification.
Third-Party Installation Services
No Response for Extended Periods
No accountability for response times, unreliable service schedule, and no customer guarantees.
No-Show Installers
Lack of accountability leads to frequent appointment no-shows.
No Customer Guarantees
Installers without product knowledge or proper certification often deliver inadequate installations.
Obscure Installation Process
No installation progress updates, difficult to find help quickly when problems arise.
Peace of mind with an advanced design.
  • EcoFlow X-Cooling
    Our proprietary X-Cooling heat dissipation system enhances efficiency even when powering heavy loads around the clock. X-Cooling works to extend EcoFlow DELTA Pro Ultra's lifespan, backed by a 5-year warranty.
    EcoFlow X-Cooling
    11 premium sintered heat pipes
    6 dedicated fans
    Customized aluminum board
    Vertical cooling fins
  • Boost Performance with BMS
    Our state-of-the-art LFP tech and advanced battery management system (BMS) regulates vital data, ensuring the safety, longevity, and high performance of EcoFlow DELTA Pro Ultra.
  • Inverter
  • Battery
EcoFlow DELTA Pro Ultra tackles even the most grueling conditions. The battery automatically starts self-heating if the temperature is lower than 32℉, allowing the battery to run as normal. Whether it's extreme weather or freezing winters, this giant safeguards your power security, just like usual.
  • Operating temperatures:
-4°F to 113°F
    Operating temperatures: -4°F to 113°F
  • 290V high voltage tolerance
  • IP54 dustproof and splashproof
What's in the box?
Inverter box
EcoFlow DELTA Pro Ultra Inverter
EcoFlow Portable Stand
EcoFlow Disassembly and Assembly Tool
EcoFlow Solar to Low-PV Port Charging Cable
EcoFlow AC Charging Cable-C20
Warranty Card
Warranty Card
Quick Start Guide
Quick Start Guide
Battery box
EcoFlow DELTA Pro Ultra Battery
EcoFlow Battery Connection Cable (DELTA Pro Ultra) - 0.66 ft (0.2 m)
Safety Guide
Safety Guide
Accessories
EcoFlow Trolley
EcoFlow Trolley
Learn More
EcoFlow 50 Amp Hub
EcoFlow 50 Amp Hub
Learn More
Learn More
EcoFlow  AC Generator Charging Adapter
Learn More
EcoFlow 4G Dongle PPS (NA)
Learn More
EcoFlow PowerInsight
Learn More
1. Payback Calculation Logic (California Example): Daily solar generation: 5.6kWp system × 6 sun hours/day) × 0.8 = 26.88kWh/day. Electricity rates: Average rate: $0.30/kWh. TOU peak/off-peak price differential: $0.30/kWh. Daily savings: Solar savings: 26.88kWh × 0.30 = $8.064 Battery TOU savings: 6kWh × 0.30 = $1.8 Total daily savings: $8+$1.8 = $9.864 Monthly savings: $9.863/day × 30 days = $295.92/month Annual savings: $9.8/day × 365 days = $3600.36 2. A soft-starter may be needed if the air conditioner's LRA rating is not within 120A 3. Vehicle model and usage dependent 4. The EcoFlow AC Generator Charging Adapter is required to charge DELTA Pro Ultra using a generator 5. We support a comprehensive list of platforms for you to upload utility plans automatically after your consent (released in June)
