The Must-Have Essentials for a Comfortable Van Life Adventure
There is no match to the freedom that comes with van life. You get to travel at your own pace and wake up in different places, while enjoying different views. Traveling in a camper van also means limited space and the need to pack the essentials to run daily life smoothly.
The right setup and arrangements depend on how you travel, along with how much space you have and the essentials you require. For example, a compact power station like the EcoFlow DELTA 3 Classic can cover the basics for a weekend traveler. At the same time, something like the EcoFlow DELTA 3 Max Plus keeps up with the higher demands of full-time van life.
This guide covers the most practical van life essentials for beginners, from power and sleeping equipment to cooking, storage, and safety gear. Let us jump right into it!
How to Choose the Right Van Life Essentials
The selection of camper van essentials is related to how you plan to use your van. If you are getting away for the weekend, you do not need the same equipment as someone living on the road full-time.
Start with the basics. You can always build your setup further later on. Before buying anything, consider:
  • Available space inside the van because every item needs a place to go when it is not in use.
  • Travel style and lifestyle needs because weekend trips, full-time van living, and remote work require different setups.
  • Power requirements, so you choose the right capacity for the electronics and appliances you plan to use.
  • Essential gear vs optional upgrades because you start with the basics and add extras later as a beginner.
Essential Gear Checklist for Van Life Beginners
Van living essentials packing is different from regular camping packing. Since you will be sleeping, cooking, working, relaxing, storing equipment, and managing everyday tasks inside a much smaller space, you need to pack accordingly.
Focus on the following as an essential gear checklist for van life beginners:
1. Power and Electricity Essentials
Modern van life requires reliable electricity to charge phones, laptops, cameras, lights, portable refrigerators, and other electronics. Your basic power setup should include:
  • Portable power station
  • Solar panels
  • Charging cables and adapters
  • Power strips and compatible accessories
  • Car charging cables
  • Extension cords (where appropriate)
A portable power station is a good place to start for a beginner, since it's simpler and doesn't require installing a complicated permanent electrical system.
EcoFlow's portable power stations provide a convenient way to keep everyday electronics and compatible appliances running while traveling off the grid. Below are two of its best portable power station options for van lifers:
EcoFlow Delta 3 Classic (1024Wh) for Beginner Van Lifers
The EcoFlow DELTA 3 Classic is a great starting point for beginners building their first van life setup. The 1024Wh capacity and 1800W output cover everyday charging needs for phones, laptops, cameras, and lights. Plus, its space-saving design fits into smaller camper vans without taking up valuable storage space.
Multiple output ports let you charge several devices at once without taking turns. Fast charging reaches 80% in around 45 minutes, a convenient top-up before heading out. Four charging methods, including AC, solar, and car charging, give beginners added flexibility on the road. Overall, a lightweight, compact build makes it easy to store and move around a smaller van.
EcoFlow Delta 3 Max Plus (2048Wh) for Extended Van Adventures
For van lifers spending more time off the grid, the EcoFlow DELTA 3 Max Plus offers the higher capacity needed to keep up. The 2048Wh of capacity and 3000W of output can power high-demand equipment such as portable refrigerators, cooking appliances, and work devices. So, it is a better fit for longer trips or full-time van living.
Multiple output ports, including a 140W USB-C port, allow several devices to charge at once, even higher-demand ones. Solar input up to 1000W adds charging flexibility during extended off-grid stretches. Expandable capacity gives full-time van lifers room to scale up power as their setup grows. Plus, a durable build suited for daily use makes it a dependable option for long-term travel.
2. Sleeping and Comfort Essentials
When it comes to sleeping in a van, a comfortable sleeping area is crucial in van life essentials. You won't be able to enjoy even the best travel destination without a good night's sleep. The following items should be a part of your sleeping arrangement:
  • Sleeping platform or properly fitted mattress
  • Sleeping bags or bedding suited to the weather
  • Pillows and Blankets
  • Window covers
  • Privacy curtains
  • Fans or other temperature-control equipment
Window coverings offer privacy and keep light out of the van. Be sure to align your bedding with the weather and time of year you will be travelling. For beginners, prioritize comfort and equipment that is easy to store away during the day. Avoid getting a fancy sleep system until you know what you actually need.
3. Cooking and Food Storage Essentials
You have to plan a little more carefully when you are cooking in a van than you might be at home. With limited counter space, storage, and ventilation, simple equipment works best, including:
  • Portable stove
  • Fuel appropriate for the stove
  • Pots and pans
  • Plates, bowls, cups, and utensils
  • Cutting board and kitchen knife
  • Water and food storage containers
  • Portable refrigerator or cooler
  • Dishwashing supplies
  • Trash bags
Use a multi-purpose cookware set, so you don't have to bring multiple sets. The use of stackable containers and small tools maximizes limited cabinet and drawer space.
A portable refrigerator can be helpful if you cook often, as you can use it to store food and beverages you need to keep cold for extended periods.
If you are only camping occasionally, you can keep your setup more streamlined with just a cooler and basic food storage.
4. Storage and Organization Essentials
The common issue people face while living in vans is space. You will be surprised at how fast an empty-looking van fills with clothes, cooking gear, bedding, and outdoor gear. The best items for van life that will help with storage and organization include:
  • Stackable storage containers
  • Hanging organizers
  • Under-bed storage boxes
  • Collapsible bins
  • Shoe organizers
  • Hooks and storage bags
  • Multi-purpose furniture
  • Space-saving kitchen organizers
Give each essential item a specific spot to keep the van from becoming cluttered. Also, look for multifunctional furniture, like a chair with storage underneath, which saves space by combining two pieces into one.
5. Safety and Emergency Essentials
It's important to include safety gear in the van life essentials list. It comes in useful when you're away from stores and services for a few nights, in winter weather, or in remote areas. Be sure to bring these safety items:
  • First aid kit
  • Fire extinguisher
  • Emergency tools
  • Flashlight or headlamp
  • Extra batteries
  • Weather preparation supplies
  • Emergency food and water
  • Navigation equipment
  • Communication devices
  • Basic vehicle emergency supplies
Keep emergency contact numbers and travel information in a convenient location. Also, check the weather and road conditions before you go to your destination so you can prepare.
The Best Van Life Essentials for Different Lifestyles
Camper van setup with a person relaxing beside a mountain viewCamper van setup with a person relaxing beside a mountain view
There is no single van life essentials list that works for everyone. When you are taking an occasional weekend trip, you will have different requirements than when living in a van full-time or working remotely from the road. Your equipment should match the way you actually use your van.
Weekend Van Campers
Weekend van campers need a lightweight, simple setup since you will be away for only a few days. You don't need to carry large permanent storage systems or high-capacity equipment. Focus on basics such as:
  • Compact sleeping equipment
  • Basic cooking supplies
  • Lightweight storage containers
  • Portable lighting
  • Basic safety equipment
  • A compact power station like the EcoFlow DELTA 3 Classic, which is a practical power source for charging phones, cameras, laptops, lights, and other everyday electronics during short trips.
Full-Time Van Lifers
Full-time van lifers spend much more time using their equipment, so durability and everyday convenience become more important. The setup will be more extensive, including:
  • Larger power capacity
  • More organized storage
  • Comfortable long-term bedding
  • Reliable cooking equipment
  • Portable refrigeration
  • Better temperature control
  • More extensive emergency supplies
When you are living in a van every day, small inconveniences can become major annoyances. You should invest in reliable equipment you can use every day to make life easier.
A higher-capacity solution, such as the EcoFlow DELTA 3 Max Plus, can provide more energy for refrigerators, cooking appliances, work equipment, and multiple electronic devices for longer periods off the grid, and it can be charged with solar panels on the go.
Remote Workers Living in Vans
Working from a van adds another layer to your power requirements. A weekend traveler may only need to charge a phone and camera, but remote workers may need to power laptops, monitors, internet equipment, phones, and other work devices throughout the day. As a remote worker, you should prioritize:
  • Reliable power
  • Multiple charging ports
  • Laptop and monitor charging capability
  • Mobile internet equipment
  • A comfortable workspace
  • Stable lighting
  • Backup communication options
A larger power station can be particularly useful if you need to work for several hours without access to shore power. Ecoflow offers a diverse collection of heavy-duty portable power stations under different specifications. Explore the catalog and pick the right one for your remote van work life.
How to Build Your Van Life Setup Step by Step
It is tempting to buy every accessory you see when you first start preparing for van living essentials. But that can quickly become expensive and leave you with a van full of equipment you rarely use. A better approach is to build your setup gradually.
Person organizing cooking and camping gear beside a camper vanPerson organizing cooking and camping gear beside a camper van
Start With the Essentials
Begin with equipment that supports your basic daily needs. Your first setup should cover sleeping, food, water, power, storage, and safety. There is no need to buy specialized van camping accessories before you know whether you actually need them.
Test Your Setup Through Short Trips
Before committing to a long road trip, spend a weekend using your setup. This practical testing will reveal what is missing and which items are taking up space without adding much value.
Adjust Your Gear Based on Real Usage
Your experience is often more useful than a generic packing list. Pay attention to the equipment you use every day and the items that remain untouched. If you run out of power, consider increasing your capacity. For a cluttered van, rethink your storage system before buying more organizers.
Invest in Reliable Equipment
The cheapest option is not always the most practical for equipment that you depend on every day. Prioritize products that are durable and suited to your travel conditions. This is important for power, sleeping equipment, safety supplies, and other items that directly affect comfort and convenience.
Upgrade Gradually
Your van life setup does not have to be perfect on day one. As your travel style changes, you can add equipment that solves specific problems. This approach also helps you avoid spending money on upgrades that seem useful but do not actually fit your lifestyle.
There is no single universal van life essentials list. What you need depends on your space, your travel style, and how much power you plan to use on the road. A weekend camper chasing scenic overlooks has very different priorities than a full-time remote worker who needs stable electricity for a laptop and monitor every day.
Van life rewards preparation, but it doesn't require perfection from day one. Start simple and build a setup that fits the way you actually live and travel. For reliable power on the road, consider the EcoFlow DELTA 3 Classic for everyday van life needs or the EcoFlow DELTA 3 Max Plus for longer off-grid adventures and higher power demands.
Frequently Asked Questions About Van Life Essentials
What are the most important van life essentials for beginners?
The most important van life essentials include a reliable power source, comfortable sleeping setup, cooking equipment, storage solutions, safety supplies, and communication tools. Beginners should prioritize equipment that supports daily needs before adding optional upgrades.
Do I need a portable power station for van life?
Yes. A portable power station is one of the most useful van-life essentials because many modern travelers rely on electronics such as phones, laptops, cameras, lights, and refrigerators. It provides a convenient power source when traveling without access to traditional electricity.
Can a portable power station replace a van electrical system?
No. A portable power station serves as a secondary power source for a traditional van's electrical system. It is useful for beginners who want a simple setup without installing complex wiring or permanent components.
What should I pack for my first van life trip?
First-time van lifers should bring essential sleeping gear, cooking supplies, storage solutions, safety equipment, navigation tools, and a reliable power source. Testing your setup on shorter trips before full-time travel can help identify missing items.
Outdoors
