Starlink Mini Power Consumption: How Much Solar To Run It?
The Starlink Mini is a great option for accessing high-speed internet from remote, rural areas. But remote areas often mean off-grid. The Starlink Mini dish requires continuous electricity to function, leading many to turn to solar energy. With the right size solar panels, you can easily power this dish from any remote location for high-speed internet no matter where you go. Keep reading to learn how much solar power the Starlink Mini requires, what impacts its power consumption, and the best solar generator for this device.
How Much Solar Power Is Needed To Run a Starlink Mini?
The Starlink Mini consumes an average of 20-40W in inactive mode and only 15W in idle mode. When actively using the Starlink Mini, you’ll need a continuous power supply of at least 25W to 40W. For an 8-hour workday, the Starlink Mini needs an energy source with 160Wh to 240Wh battery capacity. The EcoFlow RIVER 3 + 45W is a great option, weighing only 7.8 lbs and offering 245Wh. However, you may need to increase the battery size to maximize the time between recharges.
Which Factors Affect the Starlink Mini’s Power Consumption?
Obstruction and Signal Strength
It’s advised to install the Starlink Mini in a location with a clear, unobstructed view of the sky, ideally with a 360-degree view. Obstructions like trees, buildings, or bad weather can weaken the signal, causing the dish to adjust its positioning and signal amplification to maintain connectivity. The dish may also activate its built-in heater to melt snow and ice, further increasing power consumption.
Network Activity
The Starlink Mini adjusts energy usage based on the amount of data being used. This means high-bandwidth activities like streaming, gaming, or having multiple connected devices require more energy or power consumption, while light browsing or idle periods result in lower power consumption.
Software Updates and Maintenance
It’s a good idea to keep up with software updates and maintenance. However, firmware updates, system diagnostics, and self-calibration cycles increase power draw. During these processes, the dish may adjust settings, restart, or optimize performance, resulting in energy consumption spikes.
Which Solar Generator Do I Need To Power a Starlink Mini?
EcoFlow RIVER 3 Plus + 45W
The EcoFlow RIVER 3 Plus + 45W is a compact and reliable off-grid solar solution—perfect for running your Starlink Mini and Wi-Fi router. Since the Starlink Mini typically consumes 20-40W, let’s assume an average 30W draw. The EcoFlow River 3 Plus could run this dish for about 8 hours without recharging.
The included 45W solar panels help extend runtime significantly by recharging the power station while the sun is shining in off-grid locations. Whether you’re deep in the wilderness, at a remote worksite, or living off-grid, this setup ensures you stay connected for the workday without traditional grids.
The EcoFlow River 3 Plus’s 256Wh storage capacity also supports charging other devices, such as laptops, cameras, and smartphones. This means that in addition to supplying energy to your Starlink Mini, the EcoFlow River 3 Plus can keep essential devices charged and operational throughout the day. With 300W AC output, it’s capable of powering a variety of small household electronics.
EcoFlow RIVER 3 Plus + 45W Specifications
- Storage Capacity: 256Wh
- Expandability EB300 (286Wh), EB600Wh (572Wh)
- AC Output: 600W (1200W Surge)
- Solar Charge Capacity (Maximum): 220W
- Weight: 10.4 lbs (4.7kg)
- Dimensions: 9.2 x 9.1 x 5.8 in (234 x 231 x 146 mm)
- UPS Auto-Switchover Time: >10ms (True UPS for Computers/Hard Drives)
- Operating Noise Level: <30 dB
- Charging Options: Solar/AC/Car/USB-C Charging
- Battery Chemistry: Lithium Iron Phosphate (LFP/LiFePO4)
- Depth of Discharge: 100%
- Warranty: 5 years
- App Monitoring and Control?: Yes
EcoFlow 45W Solar Panel
- Rated Power: 45W
- Efficiency: 25%
- Solar Cell Type: N-Type TOPCon Monocrystalline Silicon
- Weight: 3 lbs (0.45kg)
- Folded Dimensions: 8.7×12.2×1.6 in
- Unfolded Dimensions: 38.6×12.2×0.6 in
- Waterproof/Dustproof Rating: IP68
- Open Circuit Voltage: 25.6V
- Short Circuit Current: 2.06A
- Recommended Portable Power Station: EcoFlow RIVER 3 / EcoFlow RIVER 3 Plus
The Starlink Mini typically uses 20-40 watts of power, depending on network activity and environmental conditions. During periods of high usage, such as video streaming, large data transfers, or video calls, the power consumption spikes. Conversely, during inactive times or idle mode, the power draw is reduced.
Yes, it can run on 12V power, but requires a suitable DC to AC inverter. The current must be converted from direct to alternating, which is what Starlink uses. Alternatively, you can use a 12V power adapter designed specifically for Starlink to connect directly to a 12V source.
Powering your Starlink Mini in remote locations is straightforward with solar energy. You’ll need a 256Wh power supply to keep the device running for up to 8 hours. Be prepared for flexibility when obstructions or high activity increase power consumption. EcoFlow Solar Generators are the perfect solution for reliable, long-lasting off-grid power connected and productive, no matter where you are.
