How Much Power Does Starlink Use?
Starlink’s satellite internet service has revolutionized connectivity—especially for those in remote or off-grid locations that previously lacked reliable internet access. However, to make the most of this technology, it’s crucial to understand its power requirements, particularly for users relying on generators, battery storage, or solar energy systems.
This guide will break down Starlink’s energy consumption, the key factors that influence it, and the most efficient power solutions available—helping you maintain seamless internet access wherever you are.
How Many Watts Does Starlink Use?
How many watts Starlink uses depends largely on the model you have and how you use it. For example, the standard dish and hardware typically consume about 50–75 watts (W) during active use. Power consumption may spike briefly when the system is booting up, configuring, or reconnecting to satellites.
When sitting idle, the standard system’s energy draw drops to around 20W.
In comparison, the high-performance dish and hardware consume significantly more power, averaging around 110–150W during active use and dropping to about 45W when idle.
Below is a table summarizing the different Starlink hardware systems, their average active and idle power consumption, and an estimate of how much energy (in kWh) they would use if left running continuously for 24 hours.
Starlink Standard Actuated
Starlink Standard & Enterprise
Starlink Mini
High Performance and Flat High Performance
Average consumption when in use
50 – 75W
75 – 100W
20 – 40W
110 – 150W
All-day active usage in Wh (watts x 24 hours)
1200 – 1800Wh
1800 – 2400Wh
480 – 960Wh
2640 – 3600Wh
Idle consumption
20W
20W
15W
45W
All-day idle usage (watts x 24 hours)
480Wh
480Wh
360Wh
1080Wh
What Affects Starlink’s Power Consumption?
Here are the main factors that affect how much energy it consumes.
Network Connections and Activity
The number of devices connected to the router at any given time, along with the amount of data each device uses, can significantly impact electricity consumption. The more devices that are connected, the more energy the dish and router will require to maintain stable connections. Additionally, activities with high data demands—such as downloading large files, playing online games, streaming videos, or making video calls—will cause the system to consume even more power.
Weather
When the weather is cloudy, raining, or snowing, this obstructs theline of sightbetween the dish and the satellite, making Starlink work harder to get a strong enough signal to support your online activities. A clear sky without obstructions will allow it to perform better, leading to lower electricity usage.
Physical Obstructions
Like weather, other physical objects that obstruct the line of sight, including hills, trees, or buildings, will also affect energy consumption. This is because the dish uses more electricity when it needs to re-establish connections with the satellites than it would if it had an unobstructed view.
Yes, you can run Starlink with a generator—and in fact, portable power stations are an excellent solution for powering Wi-Fi routers and serving as reliable UPS battery backups for sensitive electronics and computers. They’re especially useful for running Starlink off-grid, while traveling, or during power outages at home—ensuring you stay connected anytime, anywhere.
Gone are the days of loud, gas-powered generators that emit harmful fumes and pose serious indoor safety risks. Modern solar generators have revolutionized backup power. Since they use no fossil fuels and operate at ultra-low noise levels, they’re safe to use indoors—in your home, tent, or RV—without the worry of carbon monoxide poisoning.
EcoFlow Portable Power Stations come in a range of capacities to meet different needs. Compact models like the EcoFlow RIVER 3 Portable Power Station are ideal for travel and can easily power small devices like Starlink. For greater demands, EcoFlow offers larger, expandable models that function as whole-home backup systems, capable of running anything that requires electricity.
1. How much power does a Starlink use per day?
The power consumption of a standard Starlink dish and router typically ranges from 50–75 watts during active use and about 20 watts when idle. On average, a standard system will use approximately 1–1.5 kWh per day, depending on usage patterns, connected devices, and data activity. High-performance Starlink units can consume up to 2.5–3.6 kWh per day, due to higher wattage requirements (110–150W active, ~45W idle).
2. How much power does Starlink 12V use?
The Starlink 12V system, commonly used in mobile or RV setups with the "Flat High Performance" dish, draws slightly more power. It typically consumes around 110–150 watts while active and around 45 watts when idle. This translates to roughly 2.5–3.6 kWh per day if used continuously. The 12V model is designed for off-grid environments but requires sufficient power support to remain reliable.
3. How much solar power does it take to run Starlink?
To reliably power a Starlink system with solar, you’ll need a solar setup that generates at least 2–4 kWh per day, depending on your dish model and usage. This could typically require a 400W–600W solar panel setup, assuming 4–6 hours of peak sunlight per day. To ensure continuous operation, it’s also recommended to pair the system with a battery backup, such as a portable power station, to store excess power for nighttime or cloudy conditions.
4. How much does it cost to run Starlink?
The daily electricity cost of running Starlink depends on your local energy rates. In the U.S., with an average rate of $0.15 per kWh:
  • A standard system using 1.5 kWh/day would cost around $0.22/day or $6.60/month.
  • A high-performance system using 3.5 kWh/day would cost about $0.52/day or $15.60/month.
This is in addition to Starlink’s monthly service fee, which is typically around $120 USD/month for residential plans (as of 2024).
Off-Grid Power
