Breaking Down the Real Cost of Installing Solar Roof Shingles
Solar shingles cost a lot more than most homeowners expect, and the number changes depending on which source you ask. If you're trying to get a straight answer before you start requesting quotes, that inconsistency alone can be frustrating. This guide breaks down what solar shingles actually cost installed in 2026, what drives that price up or down, and how they stack up against traditional panels.
How Much Do Solar Shingles Cost?
If you only need one number to start with, here it is, though it comes with some real variation depending on the source.
A standard residential solar shingle installation costs roughly $21 to $25 per square foot, putting a typical install around $35,000, according to PowerOutage.us. A separate estimate from EcoWatch puts the range at $25,000 to $60,000 total, or $15 to $35 per square foot, for an average 1,700 sq ft US roof. By comparison, a 5kW standard solar panel setup averages $17,823, meaning solar shingles can cost more than twice as much as panels for similar capacity.
Premium and proprietary systems run much higher. Some homeowners have reported Tesla Solar Roof quotes above $200,000, according to PowerOutage.us, while EcoWatch separately cites Tesla Solar Roof at $70,000+ and budget-oriented SunTegra around $20,000.
One correction worth flagging: the 30 percent federal Residential Clean Energy Credit expired for solar expenditures made after December 31, 2025. Some older articles still claim it runs through 2032, but that's no longer accurate. See EcoFlow's breakdown of the 2026 solar tax credit changes for what actually applies now.
Whatever the up-front cost, solar shingles still generate power that needs somewhere to go, especially during an outage, which is where whole-home battery storage comes in.
Pairing Solar Shingles With a Home Battery: Where EcoFlow Fits In
A solar shingle roof only keeps your lights on during an outage if that generated power has somewhere to go. Pairing it with battery storage is what actually turns daytime generation into backup power you can use at night.
EcoFlow DELTA Pro 3
Ideal for whole-home energy storage alongside solar shingle installations, the EcoFlow DELTA Pro 3 features a 4,096Wh base capacity expandable up to 36kWh. It delivers 4,000W continuous AC output and includes dual PV ports supporting up to 2,600W of high-capacity solar input, allowing households to store clean daytime energy to power essential and high-draw loads overnight.
EcoFlow DELTA 3 Ultra Plus
A compact and portable energy storage solution for targeted backup, the EcoFlow DELTA 3 Ultra Plus packs a 3,072Wh base capacity expandable from 3kWh to 11kWh. It features a 1,600W max solar input and 3,600W rated AC output (7,200W surge) to keep critical household electronics and appliances running without requiring a full-scale whole-home installation.
Product fit aside, it's worth understanding exactly what goes into that per-square-foot shingle figure in the first place.
What's Included in Solar Shingle Installation Cost
The per-square-foot number quoted above isn't just the shingles themselves. Several separate cost categories stack up to make the total installed price.
  • Materials cover the shingles themselves, wiring, an inverter for DC to AC conversion, conduit, and mounting hardware.
  • Labor covers removing the existing shingles, replacing underlayment if needed, installing mounting brackets, mounting the new shingles, wiring them in series, running conduit to the electrical panel, and installing the inverter.
  • Old roof removal adds to the total cost on top of that, since most installers charge separate disposal fees. This is also why timing matters. If your existing roof is already due for replacement, see EcoFlow's guide on roof replacement before going solar for how to sequence the two projects.
  • Permits and fees are typically required before installation begins, and both the rules and the costs vary by city and county.
With the cost breakdown covered, it's worth stepping back to see how shingles actually stack up against traditional panels.
Solar Shingles vs. Traditional Solar Panels
The cost difference above only tells part of the story. Shingles and panels also differ in efficiency, installation method, and which homes they actually make sense for.
Feature
Solar Shingles
Appearance
Seamlessly integrated into roof
Mounted on top of roof, more visible
Installation method
Replaces roofing material itself
Installed over existing roofing
Efficiency
Generally lower (10 to 20%)
Higher (15 to 22%)
Cost
Higher upfront (roofing + solar combined)
Lower upfront for solar alone
Lifespan
25 to 30 years
25 to 30+ years
Ideal use case
New construction or full roof replacement
Homes with a good existing roof
Tesla, GAF Energy (Timberline Solar), CertainTeed (Apollo shingles), Luma Solar, and SunTegra all currently offer solar shingle products. Traditional panels convert more sunlight per dollar spent, while shingles integrate directly into the roof itself. In practice, panels tend to fit retrofits best, while shingles fit new builds, reroofing projects, and HOA-restricted properties where a mounted panel array isn't allowed. For a deeper side-by-side, see EcoFlow's full comparison of solar shingles and solar panels.
Knowing how they compare in general, the next question is what actually moves your specific price up or down.
Solar Shingles vs. Traditional Solar PanelsSolar Shingles vs. Traditional Solar Panels
What Affects Your Solar Shingle Cost
Two homes with similar square footage can still end up with very different solar shingle quotes. Here's what usually explains the gap.
  • Roof size and shape: bigger and more complex roofs, including dormers, valleys, and obstructions, cost more in both materials and labor
  • Brand and manufacturer: premium options like Tesla Solar Roof cost significantly more than budget-oriented brands like SunTegra
  • Shingle type: most solar shingles use thin-film technology at roughly 12 to 14 percent efficiency rather than the roughly 20 percent efficiency of standard monocrystalline panels; monocrystalline solar shingles exist but cost considerably more
  • Location and labor rates: labor costs vary regionally, and local permitting or utility policies can affect total price, a pattern corroborated by EcoWatch's state-by-state cost data showing meaningful state-to-state variation
With the cost factors laid out, the last question is whether solar shingles are actually worth paying that premium.
Are Solar Shingles Worth the Cost?
This isn't really a strict better-or-worse question. It's a trade-off between aesthetics and roof-replacement timing on one side, and straight cost-efficiency on the other.
Solar shingles are worth it primarily for homeowners who prioritize appearance, are already replacing their roof, or face HOA restrictions on mounted panels. A typical solar panel array costs around 20 percent less than solar roof shingles for comparable output, so for homeowners without those specific priorities, panels usually win on pure cost-efficiency.
Solar shingles typically cost $21 to $35 per square foot, roughly double the cost of traditional panels for similar output. The federal tax credit has expired for 2026, which means state and utility incentives matter more now than they used to. Whatever the generation source, pairing it with whole-home battery storage is what actually keeps the power on during an outage.
Take a look at the EcoFlow DELTA Pro 3 and EcoFlow DELTA 3 Ultra Plus product pages to see which fits your roof's output.
How much do solar shingles cost per square foot?
Solar shingles typically cost $21 to $35 per square foot, depending on the source and brand, putting a full installation anywhere from roughly $25,000 to $60,000 for an average US roof.
Are solar shingles more expensive than solar panels?
Yes. Solar shingles generally cost more than twice as much as traditional solar panels for similar output, since the shingles replace the roofing material itself rather than mounting on top of it.
Do solar shingles still qualify for tax credits in 2026?
The 30 percent federal Residential Clean Energy Credit expired for expenditures made after December 31, 2025, so it no longer applies. State and utility-level incentives still vary by location and can help offset the cost.
Can solar shingles be paired with a home battery?
Yes. Pairing solar shingles with whole-home battery storage, like the EcoFlow DELTA Pro 3 or DELTA 3 Ultra Plus, is what allows generated solar power to be stored and used during an outage rather than only while the sun is out.
Home Backup
