The Guide to Seasonal Generator Maintenance: Extending Equipment Lifespan
Your generator needs regular maintenance to work properly when you need it. Without proper care, it might fail during a power outage when you’re counting on it most. This guide walks you through what to do each season to keep your generator in good shape. Regular generator maintenance helps your equipment last longer, run more efficiently, and prevents costly breakdowns that could leave you without backup power.
Spring Maintenance: Getting Ready for Peak Use
Before warmer weather or the main storm season arrives, it’s important to prepare your generator, especially if you expect to use it more often. This tune-up looks after parts that might have been affected by winter storage or not being used.
Visual Check
First, carefully look over the entire generator.
  • Look for Damage or Leaks: Check for any cracks in the body, signs of oil or fuel leaks, rust on metal parts, and any loose wires or bolts. Make sure the exhaust system looks sound.
  • Check for Pests: Small animals or bugs can get into stored generators. Look in air intakes, exhaust ports, and other openings for nests or chewed wires.
Fuel System Care
The condition of your fuel is very important for your generator.
  • Old, Untreated Fuel: If the generator was stored with fuel that didn’t have a stabilizer in it, you must drain all the old fuel from the tank and carburetor. Old gas can break down and create blockages.
  • Stabilized Fuel Check: If you used a fuel stabilizer, check the fuel. It lasts longer but not forever. If it looks or smells bad, replace it. Otherwise, top off the tank with fresh fuel and add stabilizer if the generator might sit for a while.
  • Replace Fuel Filter: Your owner’s manual will say when to replace the fuel filter. If it’s time, or if the fuel seems dirty, put in a new one.
  • Inspect Fuel Lines: Look at all fuel lines for cracks or leaks. Replace any that are damaged.
EcoFlow DELTA 3 Series Solar Generator (PV220W)
1-5kWh expandable power: 10-year battery, 2200W output, 99% appliances, 99% MPPT solar, 25% bifacial conversion, 5-year warranty.
Engine Oil
Good lubrication is vital for the engine.
  • Check Oil Level and Condition: Take out the dipstick, clean it, put it back in fully, then take it out again to check the level. The oil should be in the recommended range. Also, look at the oil’s color. If it’s very dark, gritty, or looks milky, it needs changing.
  • Change Oil and Filter: It’s good practice to change the oil and filter before a season of heavy use or at least once a year. Use the oil type your manual recommends for the current weather.
Air Filter
The engine needs clean air to run well. Inspect the air filter for dirt and debris. Depending on its type (paper or foam), you might be able to clean it as per the manual. If it’s very dirty or damaged, replace it.
Spark Plug(s)
The spark plug ignites the fuel. Remove it and check for wear or buildup. You can clean a lightly dirty plug with a wire brush and check the gap with a feeler gauge, adjusting if needed according to your manual. If the spark plug is very worn, dirty, or due for replacement based on the maintenance schedule, install a new one.
Battery (for Electric Start)
A good battery is essential for electric start models.
  • Clean Terminals: Disconnect the battery cables (negative first). Clean any corrosion off the battery posts and cable ends with a wire brush.
  • Check Fluid Levels (if applicable): If your battery has caps, check the fluid level in each cell and add distilled water if needed. Wear gloves and eye protection.
  • Test Voltage: Use a multimeter to check the battery’s voltage. A good 12-volt battery should be around 12.6 volts or more. If it’s low, charge it. If it doesn’t hold a charge, you’ll likely need a new one.
Test Run
After these checks, make sure everything works correctly.
  • Start the Generator: Start it up following the normal procedure.
  • Run with a Load: Let it run for 15-30 minutes. If possible, connect a light electrical load, like a few lights or a small tool (around 25-50% of its capacity). This helps it warm up properly.
  • Listen and Observe: Pay attention to any strange noises or vibrations. Check that it runs smoothly.
  • Test Outlets/Transfer Switch: For portable units, check that the outlets are working. For standby units, make sure the automatic transfer switch (ATS) is working as it should (you might need a professional for this if you’re unsure).
With your generator tuned up after these spring checks, it’s ready for the season. However, ongoing attention during periods of use is also important.
Summer Checks: During Active Use
If you’re using your generator often, or if it’s on standby during a high-risk season like hurricane season, some quick, regular checks will help keep it reliable.
Regular Checks Before or After Use
For portable generators, do these quick checks before or after you use them. For standby units, once a week or every two weeks is good.
  • Fuel and Oil Levels: Make sure there’s enough fuel for how long you’ll use it, and that the oil level is correct. Running out of fuel can sometimes cause issues, and low oil can severely damage the engine.
  • Look for Leaks or Damage: Quickly check for any new oil or fuel leaks or any physical damage.
  • Clear Airflow: Ensure the air intake and exhaust are not blocked by anything. Good airflow is needed for cooling and safe operation.
Monitor How It Runs
Notice any changes in how your generator operates. If it sounds different, if the power output fluctuates, or if it’s harder to start, these could be early signs of a problem that needs looking into.
Keep It Clean
Wipe down the outside of the generator and keep the engine cooling fins free of debris like leaves or grass. A clean generator often runs cooler and more reliably.
Man connecting a portable power station to solar panels.Man connecting a portable power station to solar panels.
Fall Maintenance: Preparing for Winter or Storage
When you expect to use the generator less, or before storing it for a longer time (like a portable unit over winter), proper preparation is key to avoid problems when you try to use it again. This builds on the attention you gave the fuel system back in the spring.
Thorough Cleaning
Clean off any dirt, grime, oil, or plant matter from the generator. This helps prevent rust and keeps pests away.
Fuel System Preparation for Storage
How you handle fuel before storage is critical.
  • Option 1: Run the Generator Dry: If your generator has a fuel shut-off valve, turn it off and let the engine run until it stops from lack of fuel. This empties the carburetor and fuel lines, preventing old fuel issues.
  • Option 2: Use Fuel Stabilizer: Fill the fuel tank almost full with fresh fuel and add the correct amount of fuel stabilizer. Run the generator for 5-10 minutes so the treated fuel gets through the whole system.
  • Drain Carburetor: Even with stabilizer, it’s a good idea to drain the carburetor bowl if you can. Your manual should show how. This removes fuel most likely to cause gumming.
Engine Oil for Storage
Consider changing oil before long-term storage. Old oil has contaminants that can harm the engine over time. Fresh oil provides better protection.
Air Filter and Spark Plug Review
If you didn’t service the air filter and spark plug in the spring and the generator was used a lot, check them now and clean or replace if needed.
Battery Care During Storage
Batteries can lose their charge if left alone for too long.
  • Portable Units: Disconnect the battery (negative cable first). It’s best to take it out and store it in a cool, dry place (not directly on concrete). A trickle charger or battery tender can help keep it charged.
  • Standby Units: For standby generators, make sure any battery heater (if you have one in a cold area) is working.
How to Store Your Generator
Store the unit in a clean, dry place like a shed or garage. Cover it with a breathable generator cover to protect it from dust and moisture, but allow air to circulate. If possible, don’t store it directly on a concrete floor; placing it on wooden blocks can help prevent moisture damage.
Winter Maintenance: For Standby Units and Stored Portables
Winter brings different challenges, especially for standby generators that need to work in freezing weather, and for portable generators that are stored.
Standby Generators in Winter
These units must be ready for cold conditions.
  • Automatic Exercise: Most standby generators run themselves for a short period each week. Make sure this feature is on and working. It keeps the engine parts oiled, charges the battery (which you prepared in the fall), and helps keep fuel fresh.
  • Battery Heater: If you have a battery heater for cold weather, check that it’s working. Cold temperatures reduce battery power.
  • Keep Clear of Snow and Ice: Regularly check that snow or ice isn’t blocking the air vents or access panels.
  • Correct Oil for Cold: Make sure the engine oil is the right type for very cold temperatures, as listed in your manual.
Home battery system with mobile app display.Home battery system with mobile app display.
Portable Generators in Winter Storage
Even when stored, a little attention is needed.
  • Battery Charge: If you have the battery on a trickle charger, check it occasionally.
  • Storage Location: Make sure the storage area stays dry and protected from bad weather.
Year-Round Good Habits for Long-Term Generator Care
Beyond the main seasonal checks, some ongoing habits will help your generator last a long time and stay reliable. This continuous care complements the specific seasonal tasks, like the spring tune-up or fall storage prep.
Follow the Manufacturer’s Maintenance Schedule
Your finest guide comes from the owner’s manual for your generator. Usually based on time or hours it has ran, it includes a comprehensive calendar with what to do and when. Following this routine is quite crucial.
Keep a Maintenance Log
When you undertake maintenance, it’s good to jot down what you did, any parts you replaced, and the engine hours. This log is great if you sell the generator, helps you remember what has to be done, and comes in handy should issues develop.
Run the Generator Regularly
Running engines is good for them. Usually for standby units, the weekly exercise cycle covers this. Try running portable generators in storage at least every three months—monthly is better if not needed. Let it run for 20-30 minutes with a modest electrical load (25-50% of its power rating). This warms the engine, moves oil, and supports the fuel system.
Software Updates (for Newer Standby Units)
Check whether there are any manufacturer software updates for your more modern standby generator with smart controls. Sometimes these help things run better.
Know When to Get Professional Help
You can do many tasks yourself, but some things are best left to a professional.
  • Standby Generators: These often need a professional service every year or two for things like valve adjustments or checking the transfer switch. This might also be needed for your warranty.
  • Portable Generators: If there are complicated repairs, or you’re not comfortable doing something, call a qualified technician.
Check and Replace Worn Parts
Some parts wear out over time. Regularly look at things like engine belts and hoses for wear or cracks. Replace them as the manual suggests or if they look bad to prevent them from failing unexpectedly.
Common Problems Linked to Poor Generator Maintenance
Many common generator issues are due to not enough, or incorrect, maintenance. Understanding these can help you fix problems faster. These often relate back to skipping steps discussed earlier, such as proper fuel management or battery care.
Generator Won’t Start
This is a common and frustrating problem with several typical causes:
  • Old Fuel: This is a very common reason. Fuel left too long, especially untreated, can go bad and clog the system. Check if fuel smells stale or looks cloudy. Drain old fuel completely and clean the fuel tank before adding fresh gasoline.
  • Dead Battery: The battery might be too low or faulty. Test voltage with a multimeter - it should read around 12.6V for a healthy 12V battery. Try jump-starting with jumper cables or a portable jump starter if the battery is just discharged.
  • Dirty Spark Plug: A spark plug that’s oily, dirty, or worn out won’t create a good spark. Remove and inspect for carbon buildup or electrode wear. Clean with a wire brush and check the gap with a feeler gauge - it should match your manual’s specifications.
  • Clogged Air Filter: If the air filter is too dirty, the engine can’t get enough air. A severely blocked filter can prevent starting entirely. Paper filters should be replaced, while foam filters can often be washed with warm soapy water and re-oiled.
  • No Oil or Low Oil Level: Many generators have a low-oil shutdown feature that prevents starting when oil is insufficient. Always check oil level on a flat surface with the engine off and cooled down for accurate readings.
  • Choke Position: For manual choke models, ensure the choke is in the correct position - typically closed for cold starts, open for warm engines. Move the choke to the open position gradually as the engine warms up to prevent flooding.
Runs Roughly or Stalls
If it starts but doesn’t run smoothly, check these issues:
  • Old Fuel or Dirty Carburetor: Bad fuel can cause poor running and irregular RPMs. Blockages in the carburetor from old fuel will affect fuel flow, causing surging or stalling under load. Use carburetor cleaner spray through the air intake while running to help dissolve minor blockages.
  • Clogged Fuel Filter: A dirty fuel filter restricts fuel flow to the engine, especially noticeable when the generator is under load. Replace the fuel filter annually or whenever you notice performance issues, as it’s an inexpensive preventive measure.
  • Air Filter Problems: A dirty air filter creates a rich fuel mixture, causing rough idling, black smoke, or stalling when throttle is applied. A partially dirty filter may allow starting but restrict airflow under load, so replace it even if it looks only moderately soiled.
  • Incorrect Oil Viscosity: Using the wrong oil type for current temperatures can cause rough operation, especially in extreme weather. Switch to multi-grade oil (like 10W-30) for year-round use, or use manufacturer-recommended seasonal oils.
  • Loose or Corroded Connections: Poor electrical connections can cause inconsistent operation and power fluctuations. Apply dielectric grease to electrical connections after cleaning to prevent future corrosion and ensure reliable contact.
  • Overloading: Running the generator beyond its capacity will cause it to struggle, run roughly, and potentially stall to protect itself. Calculate your total wattage needs and stay within 75-80% of the generator’s rated capacity for optimal performance.
Low or No Power Output
If the engine is running but not producing electricity:
  • Tripped Breaker: Check the generator’s own circuit breakers.
  • Voltage Regulator Issues: The Automatic Voltage Regulator (AVR) controls the voltage. Problems here often need a professional.
  • Other Internal Faults: Some internal electrical problems can also cause this and will usually need professional repair.
Maintain Your Generator, Ensure Your Power
Regular, careful maintenance isn’t just a list of tasks; it’s an investment in your generator’s lifespan and your own peace of mind. By following these steps and always checking your owner’s manual for specific details, you help ensure your generator is ready when you need power most. This consistent effort saves money in the long run and provides security.
Solar Generators
