How to Power Your Glamping Adventure in the Southwest
From dramatic canyon views to Dark Sky certified national parks, glamping in the Southwest should be on any glamper’s bucket list. Glamping combines the beauty of the outdoors with the comfort of modern amenities, but that comfort requires reliable power.
Many Southwest glamping sites are off-grid, so you’ll need to bring your own energy source for lighting, cooling, heating, and running small appliances. Learn how to design a well-planned glamping setup that ensures you can enjoy all the perks of glamping without worrying about dead devices or rotten food.
Why the Southwest Is Perfect for Glamping
The Southwest checks every box if you’re looking for a glamping destination that delivers jaw-dropping scenery, reliable weather, and plenty of unforgettable adventures. It covers Texas, New Mexico, Arizona, Utah, Nevada, and parts of California and Colorado, all of which are known for nature views and national parks.
There are so many reasons to plan a glamping adventure to the Southwest, including:
  • The scenery: See canyons, mountains, deserts, and forests hidden away in the rural areas of the Southwest.
  • (Mostly) predictable weather: The Southwest is mostly dry and sunny, so you don’t have to worry about rain as much as in other glamping destinations. While desert climates can swing from hot during the day to chilly at night, the weather is predictable enough that you can plan ahead and pack accordingly.
  • Outdoor experiences: Adventure is never far away in the Southwest. Hike, ride donkeys in the Grand Canyon, and explore national parks while enjoying the perks of glamping like spa treatments and cozy stays.
  • Dark Sky destinations: The Southwest is dotted with designated Dark Sky Parks, where light pollution is minimal and stargazing is next-level. Check out Big Bend National Park in Texas, or Death Valley and Joshua Tree National Parks in California
What Power Challenges Should You Expect from Glamping Off-Grid?
Unlike primitive camping, glamping is about comfort. Utilities are a big part of staying comfortable at any glamping stay, so expect these challenges when glamping away from civilization:
  • Estimate power needs: Running out of juice is the fastest way to ruin a great glamping getaway. List what you’ll power, how long you’ll use it, and add a buffer. Bring multiple power sources, like the EcoFlow RAPID Magnetic Power Bank (25,000mAh), to charge your phone and larger battery banks for big appliances.
  • Plan for sunlight disruptions: The Southwest is sunny, but overcast days, wildfires, and canyon shade can limit solar power. You’ll need a battery that lasts one or two days without recharging, just in case.
  • Day and night temperature swings: If you’re staying in the desert, expect it to be hot during the day and cold at night. You’ll need to plan for both heat and AC in this environment, both of which require a lot of energy to run continuously.
  • Power usage: Carefully plan how you use your devices, even if you bring a large battery bank on your glamping trip. Run high-draw devices during daylight while panels are producing. Use LED lighting, device battery-saver modes, and charge laptops or phones midday to conserve energy.
How to Build a Flexible, Off-Grid Glamping Power Setup
Glamping gives you the best of the great outdoors, but with the comforts of the great indoors. Still, to enjoy creature comforts off-grid, you need a reliable power system sized to your needs. Follow these steps to get reliable energy no matter where you glamp.
Do An Energy Audit
Start by listing everything you plan to power and separating the must-haves from the nice-to-haves. Remember: you can’t bring your entire house with you, and power needs add up fast.
You’ll need enough power to run must-haves like your smartphone, LED lights, and a fan (especially if you can’t sleep without one). If you need a fridge for medications, the EcoFlow GLACIER Classic Portable Refrigerator Freezer is a travel-friendly addition designed for off-grid setups.
Laptops, speakers, coffee makers, and other nice-to-haves are fun, but they suck up a lot of energy. Decide what you can and can’t live without.
Once you know what you need to charge, calculate how many watt-hours (Wh) each item uses daily. Multiply the device’s wattage by how many hours you’ll use it. Add it up and then double that number for safety and unexpected extras. This helps you figure out how large a power system you need and prevents surprises, like running out of power halfway through the night.
Pick An Appropriate Storage System
Once you know how much energy you need, you can choose the right components to build a glamp-friendly power system:
  • Battery bank: This is your energy reservoir, storing power from solar or wall outlets for later. Look for a portable power station sized to at least twice your daily usage.
  • Solar panels: These capture sunlight to recharge your battery. Go bigger than you think you’ll need—desert sun is powerful, but panels rarely hit their full rated output.
  • Charging options: Pick a system that can recharge from multiple sources: solar, vehicle 12V outlet, or even a wall plug at a café or gas station. That way, you’re not stuck if the weather turns cloudy.
If there’s a chance you may want to add more devices to your glamping kit, consider buying a higher-capacity system. You may not need as much wattage now, but buying up future-proofs your setup.
Think About Backups
Even the best-laid power plans can fail if the weather turns gloomy or you accidentally overuse your system. Always bring a backup energy source, especially if your glamping site doesn’t offer electricity. Your phone is your lifeline, so bring small power banks to charge these up that are separate from your main battery.
Person with EcoFlow TRAIL series portable power station
Do Glamping Sites Have Electricity?
Some do, and some don’t. Most Southwest glamping sites are off-grid and can’t provide electricity to every site. Always check with the glampground to see which utilities they offer. Consider bringing your own off-grid solar and battery setup just in case.
How Much Power Do I Need for a Weekend Glamping Trip?
It depends on which devices you need to charge. Generally, a minimal setup requires 500Wh, a setup with a mini-fridge or laptop would need 1,000Wh, and a luxury setup with AC needs over 1,500Wh. Always calculate your specific power needs: multiply each device’s wattage by the number of hours used per day, then add it up and double the total for safety.
Southwest Glamping Blends Nature, Comfort, and Reliable Power
Glamping in the Southwest lets you enjoy stunning scenery without sacrificing the comforts of home. However, staying off-grid even for a few nights means you need to plan ahead for your power needs. Know which devices you’ll run, bring flexible solar and battery systems, and always pack backups for greater peace of mind.
Spend your time focusing on stargazing and sightseeing, not worrying about your phone battery. A reliable power solution like the EcoFlow TRAIL Series DC Portable Power Station makes it easy to keep your gear charged and your glamping trip stress-free.
