September Is National Preparedness Month: Home Safety & Power Backup
FEMA has dedicated September as National Preparedness Month to encourage Americans to begin proactively planning and preparing for disasters rather than taking a reactive response after they occur.
Just a few simple preparation steps can prevent major disruptions, protect your property, and keep your loved ones safe. Building resilience and being ready starts with understanding the risks and best solutions available, then taking action to protect what matters most.
Use the tips below to create a practical emergency kit, plan for power outages, and stay alert in the face of natural disasters.
Why National Preparedness Month Matters for Home Safety and Power Backup
Extreme weather is becoming more regular nationwide, and safety and comfort are paramount concerns. These events pose risks to your health and safety, the structural integrity of your property, and wider utility systems like the power grid.
When extreme weather comes with a warning, there are often shortages of essential items, and panic buying doesn’t always prepare you well. But these disasters frequently come unexpectedly, so being ready is critical.
FEMA’s National Preparedness Month urges you to prepare your home early, ensure everyone in your household knows where to gather safely or how to evacuate if necessary, and gather essential supplies ahead of time so you’re always ready for the worst-case scenario.
Assemble a Practical Emergency Kit for Your Household
  • 72-hour supply of non-perishable food and clean drinking water, at least one gallon per day per person
  • 7-day supply of medications and first aid essentials
  • Battery-powered or hand-cranked radio
  • Flashlight and extra batteries
  • Portable emergency phone charger
  • A cooler or portable refrigerator like the EcoFlow GLACIER Classic Portable Refrigerator Freezer for essential medications and food
  • Vital documents in a waterproof, fireproof container
  • Cash in small bills
  • A portable AC unit like the EcoFlow WAVE 3 for extreme heat
EcoFlow WAVE 3 installed in cabin
Plan for Power Outages with Backup Power Options
Recent storms and heatwaves have exposed vulnerabilities in the power grid, and the average outage duration is increasing for many. Natural disasters and extreme weather often bring power outages, so one of the best ways to prepare is to invest in backup power options you can rely on when the grid goes out.
Backup power allows you to access your most critical power needs without relying on the larger grid. You can run medical devices, preserve the food in your refrigerator, and maintain communication when it matters most.
When considering emergency power supply options, you have many choices: generators, battery systems, and solar solutions are just a few. Traditional gas generators are reliable, but can be noisy, are unsafe to use indoors, and require fuel storage. Battery backup systems offer quiet and safe indoor operation, but may have limited capacity.
Solar generators are a great option because you can recharge them with sunlight, many are expandable, and they have versatile applications, from powering your home to your next camping trip. You could also invest in an integrated home solar system that automatically switches on when the power goes out.
Once you’ve determined which route to take, calculate the run time requirements and wattage for your most essential appliances and devices. Then, look for a solution to meet these needs while leaving some margin for add-ons later.
EcoFlow DELTA Pro 3
Solar Generators for Reliable Home Power
Solar generators are, in many ways, the best of both worlds. They operate silently, making them a good choice for residential neighborhoods and indoor use, even at night. Unlike gas generators, they don’t require fuel storage or ongoing costs. Models like the EcoFlow DLETA Pro 3 Solar Generator (PV400W) are also expandable, so you can add batteries as your power needs grow.
If sunshine isn’t available, it also allows you to recharge with AC or a car adapter, giving you the flexibility you need in emergencies.
And, when your grid power goes out for an extended time, you can trust your solar generator to power your essential appliances for days, not hours.
Need to evacuate? No problem. Solar generators are typically portable, so you can take them to your next destination.
Solar generators are an excellent clean energy solution that allows you to harness your energy independence while aligning with your environmental goals.
Safe Setup, Placement, and Ventilation for Solar Generators
When operating a solar generator, you don’t have to worry about things like ventilation or fumes. While gas generators must be used outdoors and away from windows and vents, solar generators can run indoors without risking your health and safety.
Still, there are some best practices you can follow to optimize its function and prioritize safety.
  • Avoid extreme heat or direct sunlight on the generator battery to preserve longevity
  • Maintain clearance around the ventilation ports and fans
  • Keep units dry and protected from rain or moisture
  • Position your solar panels to the south to capture the most sunlight
  • Only use extension cords that are rated for the appliance loads you power
  • Perform regular maintenance to check on battery health and connections
Harness up to 2600W solar input via dual PV ports for flexible setups and faster charging with high conversion efficiency. Enjoy powerful AC output and 99% MPPT efficiency for optimal energy capture. Manage it all seamlessly through the app—monitor usage, set priorities, and stay powered effortlessly.
Stay Informed with Alerts and Strengthen Preparedness with Drills
Stay informed by signing up for your local emergency alert system and downloading weather apps on your mobile phone. Text or phone call alerts are helpful if you don’t check your email often.
If you want to feel even more prepared, look into Community Emergency Response Training (CERT), available nationwide, and practice your evacuation routes a few times yearly with all family members.
Your evacuation plan should include multiple routes in case of obstruction, at least two meeting places (one near the home, and one outside of the neighborhood), and emergency contacts beyond the local area.
Document any lessons learned from previous extreme weather events and adjust your plans accordingly.
What Are the 5 Ps of Disaster Preparedness?
The five Ps of disaster preparedness are people, prescriptions, papers, personal needs, and priceless Items. Mentally reviewing this list and taking action in this order will help you respond quickly and prioritize what matters when a disaster strikes.
What to Stockpile for 72 Hours?
Essential emergency supplies for the first 72 hours after a disaster include clean water, non-perishable food, a battery-powered or hand-crank radio, medications and first aid supplies, flashlights and extra batteries, and a backup power source for essential devices.
Solar Generators Deliver Power Security, Home Readiness, and Peace of Mind
Planning your preparation will protect your family during unexpected emergencies. Beyond food, water, medications, radios, and flashlights, a reliable backup power source can make a disaster safer and more comfortable when the grid goes out. While many backup options are available, we recommend investing in a solar generator like the EcoFlow DELTA Pro 3 Solar Generator (PV400W) for sustainable, quiet, and safe power that can last through extended outages.
Home Backup
