The Ultimate Colorado Springs Hiking Places for RV Travelers
Sitting right where the Great Plains slam into the Rockies, Colorado Springs is a high altitude playground that feels like it was designed specifically for the mobile lifestyle. For anyone rolling in with a rig, the area around Manitou Springs offers a rare mix: you get the rugged, lung-busting backcountry of Pikes Peak alongside actual urban amenities that don't require a death-defying mountain pass to reach.
Whether you’re here to stare at 300-foot crimson monoliths or you’re determined to bag a 14er, this region is the ultimate backdrop for a home-on-wheels adventure. We’re going to break down the trails that won't trap your Class A in a tight corner, the gear you need to stay powered up at 6,000 feet, and where to park so you aren't hiking two miles just to get to the trailhead.
Why Colorado Springs is Perfect for RV Hiking Adventures
There’s a reason Colorado license plates are everywhere in the RV world. The infrastructure here actually accommodates big vehicles. Most of the iconic trailheads are a short hop from high-end RV resorts. Many of these modern rigs are now equipped with a high-capacity solar battery system, allowing hikers to recharge their gear using the abundant Colorado sunshine while they hit the trails. You can spend the morning deep in a pine forest and the evening hitting a local brewery by your retractable awning without breaking a sweat over navigation.
A Note for "Flatlanders": If you’re coming from sea level, remember that the city sits at 6,035 feet. Altitude sickness is a real party-killer. Give yourself at least 48 hours to acclimate, drink more water than you think you need, and maybe stick to the easy stuff before you try to conquer the peaks.
Top RV-Friendly Hiking Trails in Colorado Springs
The terrain here ranges from "stroller-friendly" to "legs-are-on-fire." Use this table to match your rig size to your fitness level before you pull out of the campground.
Quick Comparison: Colorado Springs Hiking for RVers
DestinationRV FriendlyDifficultyHighlightParking Tip
Garden of the GodsYesEasyIconic Red Rocks Arrive before 8 AM for oversized spots
Cheyenne MountainYesModerateCity PanoramaTrailhead is right at the campground
Pikes PeakNoExtreme14,115ft SummitLarge rigs: Take the Cog Railway instead
Seven FallsNoModerate7-Tier WaterfallNO RVs allowed; use the shuttle lot
Red Rock CanyonYesEasy-ModLocal GemGravel lots fit vans & small RVs
Garden of the Gods – Iconic Red Rock Formations
You haven't seen Colorado until you’ve walked between these sandstone fins. The Perkins Central Garden Trail is a 1.5-mile loop that’s mostly paved. It’s perfect for a recovery day. Carrying a portable power station in your daypack can ensure your phone and camera stay charged for those hundreds of photos you’re bound to take.
  • The Rig Strategy: The main parking lot has designated oversized sections. If you aren't there by 8:00 AM, you’re going to be circling the lot like a vulture.
Cheyenne Mountain State Park – A Hiker’s Paradise
Located just south of town, this is arguably the most RV-friendly hiking spot in the state. The Dixon Trail is the local pick for sweeping city views. The best part? The park features wide, paved loops and massive campsites, so you can literally walk from your breakfast table to the trail.
Seven Falls – Waterfall and Canyon Hikes
Known as the “Grandest Canyon in the West,” this spot features a series of cascading falls tucked between granite pillars. Understanding how to equip your RV for off-grid living is essential if you plan on staying at nearby dispersed camping sites while visiting the falls.
The Warning: Do not try to drive your rig to the canyon entrance. It’s too narrow. Set your GPS for the Norris Penrose Event Center. It’s the seasonal shuttle hub with plenty of room for Class As and Class Cs to stretch out while you take the bus in.
Red Rock Canyon Open Space – Less Crowded Adventure
If Garden of the Gods feels a bit too "touristy" for you, head just a few minutes west to Red Rock Canyon. It’s built on the same geological shelf, so you get those massive crimson fins, but the trails are a lot more rugged and the crowds are significantly thinner.
  • The Top Trail: Try the Sand Canyon Trail or the Quarry Pass. You’ll see massive geometric cuts in the rock from the 1800s when this area was an active quarry. It’s a bit of a history lesson mixed with a workout.
  • RV Logistics: The parking here is gravel and much more laid-back. While a 45-foot Class A might struggle on a busy Saturday, camper vans and smaller Class C rigs (under 30 feet) usually have no problem finding a spot. It’s also one of the best off-leash dog areas in the city if your four-legged co-pilot needs to blow off some steam.
Pikes Peak – Summit Challenge for Adventurous RVers
You can drive smaller RVs up the Pikes Peak Highway, but if your rig is over 24 feet, don't even try. You’ll be turned away at the gate.
  • The Brake Check: There’s a mandatory temperature check at the 13-mile mark on the way down. If your brakes hit 300°F, the rangers will make you sit in time-out until they cool off. Save your nerves and your brake pads, park the rig and take the Broadmoor Manitou & Pikes Peak Cog Railway instead.
EcoFlow DELTA 3 Plus Portable Power StationEcoFlow DELTA 3 Plus Portable Power Station
Crucial Logistics for Large Rigs
Before you head to the trailhead, keep these "rig-saving" tips in mind. The roads around Colorado Springs are gorgeous, but they can be unforgiving if you’re driving something with a wide turning radius.
  • Manitou Springs Alert: The downtown area is a nightmare for large rigs. If you're tackling the Manitou Incline, skip the stress of narrow streets and park at the Dillon Mobility Hub (134 Manitou Ave) or Hiawatha Gardens. From there, hop on the free Route 33 shuttle, which drops you right at the base of the Incline and the Cog Railway.
  • Pikes Peak Length Limit: This is a hard "no" for big rigs, vehicles over 24 feet in length or with a wheelbase over 19 feet are strictly prohibited from driving the Pikes Peak Highway. If your Class A or large Class C exceeds this, your only way to the summit is by parking at your campground and booking a seat on the Broadmoor Manitou & Pikes Peak Cog Railway.
  • Seven Falls Parking: There is zero parking for RVs (or even cars) at the actual canyon entrance. You must set your GPS for the Norris Penrose Event Center (1045 Lower Gold Camp Rd). This is the designated, complimentary shuttle hub with a massive lot that can easily accommodate motorhomes while you take the bus into the park.
Essential Tips for RV Travelers on Hiking Trips in Colorado Springs
In the Springs, the environment flips a switch fast. Successful RV hiking comes down to being prepared for a 40°F temperature swing in a single afternoon.
Planning Your Itinerary
Don't let a sunny morning fool you. The Pikes Peak region is famous for its afternoon thunderstorms, and being caught on an exposed ridge during a lightning storm is a memory you don't want.
  • The Golden Rule: Aim to be off the summit and back below the treeline by noon.
  • The Reward: Spend your afternoons lounging under your RV awning or grabbing a local brew in Manitou while the rain rolls through. It’s the smarter way to play the high-altitude game.
Safety and Packing Essentials
The trailhead might be a balmy 80°F, but once you climb a few thousand feet, it can easily drop to 40°F with a wind chill that bites.
The Essentials: Always pack layers (no cotton!), a physical map, because cell service dies the second you enter a canyon, and twice the water you think you need. The dry air up here will dehydrate you before you even feel thirsty.
Staying Powered in the Wild
Whether you’re catching a 5:00 AM sunrise at Garden of the Gods or stumbling back to the rig after a grueling day at Cheyenne Mountain, your power situation shouldn't be another thing to worry about. In the Springs, keeping your gear charged is a safety issue, not a luxury.
This is where the EcoFlow DELTA 3 Plus Portable Power Station really earns its keep. It’s got enough "gas in the tank" to handle the heavy hitters like your CPAP machine or that non-negotiable morning coffee, plus it’ll juice up your cameras and laptops multiple times over. Because it plays so well with the Colorado sun, you can set up your solar panels while you're out on the trail and come back to a topped-off battery.
1–5kWh expandable with DELTA 3 Extra Battery, DELTA 2 Extra Battery, DELTA 2 Max Extra Battery, or DELTA Pro 3 Extra Battery via an Alternator Charger XT150 Output Cable. 5 fast recharging methods (AC, Solar, 800W Alternator Charger, Smart Generator 3000 (Dual Fuel), Multicharging)
Another thing, if you’re the type who hates being tethered to a crowded RV park with 200 neighbors, you need a way to charge on the move. The EcoFlow 800W Alternator Charger is the secret weapon here. It pulls power directly from your RV’s engine while you’re navigating the switchbacks toward Pikes Peak. By the time you pull into a remote spot at Red Rock Canyon, you’ve got a fully charged setup ready for your GPS, headlamps, and portable fridge. It’s the easiest way to kill "range anxiety" and stay deep in the mountains where the best views are.
The EcoFlow 800W Alternator Charger is an easy-to-install, 3-in-1 power solution that charges 8× faster than standard outlets—topping up 1kWh in just 1.3 hours. Designed for SUVs, pickups, and RVs, it keeps your battery in mint condition while functioning as a fast charger, maintainer, and jump starter.
Respecting Nature
Colorado takes its "Leave No Trace" rules seriously, especially with the fragile alpine tundra.
  • Stay on the Path: Stepping off the trail kills plants that took decades to grow in this thin soil.
  • Right of Way: Here’s the key: Hikers going uphill always have the right of way. If you’re cruising downhill, step aside and let the person huffing and puffing their way up keep their momentum.
EcoFlow 800W Alternator ChargerEcoFlow 800W Alternator Charger
Best RV Campgrounds Near Colorado Springs Hiking Trails
Choosing your campground in Colorado Springs is all about location. You want to be close enough to the trailheads to beat the 8:00 AM crowds, but secluded enough that you aren't listening to highway traffic all night.
Garden of the Gods RV Resort
Located minutes from the park, this resort offers full hookups, executive pull-throughs for large rigs, two heated pools, and stunning views of Pikes Peak.
Cheyenne Mountain State Park Campground
This is the gold standard for state parks, featuring 51 full-service sites with level, 70-foot paved pads, incredibly clean facilities, and 29 miles of trails right outside your door.
Pikes Peak RV Park
Nestled in nearby Manitou Springs, this creekside park is within walking distance of the Manitou Incline and provides guests with free access to the neighboring indoor pool and hot tub.
Mountaindale Cabins & RV Resort
Located 20 minutes south of the city, this park offers a secluded, wooded feel with natural rock walls between sites and a private 45-acre hiking trail system on the property.
If you’re looking for a "basecamp city" that actually knows how to handle an RV, the answer is a resounding yes. You’ve got the geological wonders of Garden of the Gods and the high-tech comforts of top-tier RV resorts all within a 15-minute radius.
One Last Tip: The Rockies are unpredictable. By picking the right trails for your rig, keeping your gear topped off with a reliable EcoFlow setup, and sticking to that "off the peak by noon" rule, you’re setting yourself up for a legendary trip rather than a stressful one. Respect the alpine tundra, give the uphill hikers the right of way, and enjoy the best views in the Pikes Peak region.
1. What are the easiest RV-accessible hiking trails in Colorado Springs?
The Perkins Central Garden Trail at Garden of the Gods is the easiest and most accessible, featuring wide, paved paths and dedicated RV parking.
2. Are there RV hookups near Colorado Springs hiking trails?
Yes, several premium campgrounds like Garden of the Gods RV Resort and Cheyenne Mountain State Park offer full hookups (water, sewer, and electric) within five to ten minutes of major trailheads.
3. Can I hike with my dog on Colorado Springs trails?
Most trails in the area are dog-friendly as long as your pet is on a leash, though Garden of the Gods also offers a designated off-leash area. If you're bringing a furry friend, remember to check essential tips and gear for camping with dogs to ensure they have everything they need for the high altitude.
4. How crowded do Colorado Springs trails get during peak season?
Trails get very busy on weekends from June through August, so it is highly recommended to arrive at trailheads before 8:00 AM to secure a spot for your RV.
5. What safety tips should RV hikers follow in Colorado Springs?
Always monitor the weather for afternoon lightning, carry at least two liters of water to combat the high altitude, and ensure your RV has a reliable power source like an EcoFlow station to keep your safety electronics charged.
