How to Charge a Steam Deck in the UK: Power & Charging Tips
Powering your Steam Deck charger, whether at home or on the road in various parts of the UK and on weekend camping, is necessary for mind-blowing entertainment. Knowing about charger wattage, USB-C compatibility and battery specifications is what every gamer needs to enjoy their gaming sessions to the max.
Using the original 45w charger for the Steam Deck, or portable power banks and stations, will let you keep your gadget active. Finding the right power solution will give you room to play longer while away from a wall outlet.
1. Steam Deck Charger Requirements: Wattage & Compatibility
You should first consider the wattage, compatibility with USB-C, and charging behaviour before picking a charger for your Steam Deck. The right type of charger ensures smooth gaming whether you use the official 45W adapter or portable power sources.
What Is the Official Steam Deck Charger Wattage?
The best charger for the Steam Deck is capable of delivering 45W via a USB-C connection. Both LCD and OLED variants of the Steam Deck can work with 45W-rated USB-C power sources, meaning that the original adapter can be used regularly for gaming as well as charging the battery.
Valve recommends using a 45W power source with both variants. The two variants, however, have different battery ratings:
Steam Deck LCD: 40Wh batteries provide around 2-8 hours of gaming.
Steam Deck OLED: 50Wh batteries provide around 3-12 hours of gaming.
How long the Steam Deck works will depend on the game being played, brightness of the screen, performance settings, and other usage conditions. The 45W rating is the maximum output of the charger and does not mean the Steam Deck uses that much power constantly.
For UK users, the Steam Deck charger can be used for normal home charging from a compatible wall outlet. If needed for travel, make sure that the option you choose meets the required USB-C charging standards.
Steam Deck Charger Specs: Understanding 45W USB-C PD
It utilises USB-C Power Delivery (PD 3.0) to secure an appropriate charging power level with the adapter. This implies that when selecting a replacement charger or a portable source of energy, it is important to consider more than the USB-C plug alone.
The main specifications are:
Charger specification | Details |
Official charger output | 45W |
Charging connection | USB-C |
Power delivery standard | USB Power Delivery 3.0 |
LCD battery capacity | 40Wh |
OLED battery capacity | 50Wh |
Compatible charging source | USB-C PD charger or compatible PD power source |
Having a USB-C connection on the charger is not sufficient. Go for one that supports USB-C PD with enough power output for the Steam Deck.
Note: Valve claims that the Steam Deck uses USB Power Delivery rather than its proprietary Quick Charge or other fast-charging technologies. |
This information is very helpful when selecting a battery bank or a portable power station for outdoor gaming because a suitable USB-C output must match the charging needs of the device.
45W vs 65W Charger for Steam Deck: What's the Difference?
A 45W charger fulfils the power supply requirements of the Steam Deck. Moreover, a 65W USB-C PD charger allows for greater output capacity in the case of compatible devices like tablets and laptops.
Now, does using the best chargers for the Steam Deck that have a large output capacity for wattage lead to faster charging on the Steam Deck? Not necessarily. The Steam Deck's official charger does power negotiation with a compatible USB-C PD adapter, which means that using a 65W charger Steam Deck will not always provide 65W to the device.
Comparison | 45W USB-C PD charger | 65W USB-C PD charger |
Maximum output | 45W | 65W |
Steam Deck compatibility | Yes, with suitable PD support | Yes, with suitable PD support |
Meets official power requirement | Yes | Yes |
Steam Deck charging speed | Supports normal charging | Not necessarily faster |
Charging other devices | Suitable for compatible smaller devices | More headroom for laptops and other devices |
Best suited for | Dedicated Steam Deck charging | Multi-device charging and travel |
Which option should you choose?
45W charger: This is the ideal option if solely the Steam Deck is your concern.
65W charger: The perfect option if you need to also charge a laptop and a phone along with the device.
For people who use the Steam Deck, any compatible 45W charger should be sufficient. Only use a 65W USB-C PD adapter if charging multiple electronics at once is your concern, rather than just faster charging of the Steam Deck.
Charging While Gaming vs Standby: Power Consumption Explained
The power consumption of the Steam Deck varies depending on whether you are playing games on your console or whether you are not using it at all. During gaming sessions, the CPU, GPU and the display, along with other components, consume energy while the power supply charges the device.
When the Steam Deck is on standby, it consumes much less power since most gaming processes are paused. This way, a substantial part of the power supply can be directed to charging the battery.
Factor | Charging While Gaming | Charging in Standby |
Power consumption | Higher due to active gameplay | Lower due to reduced activity |
Battery charging | Shares available power with system usage | More power can go towards battery charging |
Charging speed | Can be slower during demanding games | Generally faster |
Energy usage | Depends on game and performance settings | Usually lower |
Best for | Gaming without interruption | Recharging between gaming sessions |
What are some ways to manage power consumption?
Decrease the brightness of the display to reduce energy wastage.
Use lower graphics settings and frame rates depending on the situation.
Close background apps that you don’t need.
Use sleep mode whenever there is a long break from gaming.
Keep a suitable charger or power bank handy for long hours of gaming.
Knowing your Steam Deck charger watt and charging behaviour helps you to select the right power adapter. But that isn’t the only device: using a high-watt USB-C PD charger, a power bank, etc., are other ways to keep your Steam Deck charged whether at home or during board game night in the UK.
2. Steam Deck Charging Options: Wall Chargers, Power Banks & Portable Power Stations
You don’t have to stick to a wall charger to keep your Steam Deck fully charged. From the official charger and USB-C PD adapters to portable power banks and power stations, there are many options for charging your device at home or on your journeys across the UK.
The best option will vary depending on your requirements in terms of charging speed, battery capacity, and the duration of your away-from-home gaming session. Let’s have a look at the available options and see which one is the most portable, power-efficient, and convenient.
Using the Official Steam Deck Charger and USB-C PD Adapters
The official Steam Deck charger is an excellent option for daily use, as it has the capability of charging devices with up to 45W power through USB-C Power Delivery. However, if you require another charger for work, travel, and outdoor activities, you can consider getting a compatible third-party USB-C PD adapter that will give you wider access to charging options.
When you are picking an alternative product, make sure that it works with USB-C PD and generates enough power. The 45W adapter is normally adequate for working with the Steam Deck, but if you want a stronger device, you can choose a 65W adapter, which allows you to charge other devices as well.
In the case of UK users, it is better to buy a device that has the right UK three-pin plug or a travel adapter that is compatible with the charger. This allows the user to charge their device from home or in the hotel with more convenience.
Can High-Wattage USB-C Chargers Charge a Steam Deck Faster?
Any USB-C charger that supports the proper USB-C PD standard can efficiently charge your Steam Deck, as long as it has a higher wattage than needed. Nonetheless, selecting an adapter that has a power rating of 65W or 100W does not always imply a device charges faster because the Steam Deck takes only the power it requires.
For example, a 65W charger can charge many compatible devices at once, including laptops and smartphones, but the Steam Deck will charge only according to its specifications.
The following points should be kept in mind:
Opt for USB-C PD compatibility and do not use wattage as a guide.
A charger with a power rating of 45W satisfies the power requirement of the Steam Deck.
Higher-wattage adapters enable charging of many devices at once.
How quickly the device will charge depends on the battery level, temperature, etc.
Power Banks vs Portable Power Stations: Capacity and Charging Performance
Power banks and portable power stations are similar in that both keep your Steam Deck powered without the need for main electricity, yet have different purposes. Power banks are compact and perfect for short distances, while portable power stations offer more power storage for prolonged gaming, camping, as well as powering more than one gadget.
Their main differences remain in capacity, efficiency and how many times they can power your device. Here is how they compare:
Comparison | Power Bank | Portable Power Station |
Battery capacity | Generally lower | Generally higher |
Charging output | USB-C PD, depending on model | USB-C PD and, on suitable models, AC outlets |
Portability | Lightweight and easy to carry | Larger and heavier |
Charging multiple devices | Usually limited | Supports multiple devices |
Recharging options | Mains or other supported input | Mains, compatible solar panels or other supported inputs |
Best usage | Commuting, travel and short gaming sessions | Camping, road trips and extended outdoor gaming |
Which option is better for your Steam Deck?
The power bank is a great choice for gamers who want a small backup charging solution while travelling.
The portable power station is a better choice for long gaming sessions, outdoor trips, and using other appliances like laptops, smartphones, and camping gear.
On long trips, a portable power station provides more flexibility because it can be charged with solar panels instead of having to rely on mains supply.
Steam Deck Charging Solutions Compared: Portability, Speed and Usage Scenarios
There is a difference in the convenience levels offered by various charging solutions. The official charger is good for home use, while USB-C PD chargers and power banks are more useful when you are travelling. Meanwhile, portable power stations serve as an alternative for outdoor trips and gaming sessions that require more battery power.
The main features of the charging solutions below are compared.
Charging solution | Power output | Portability | Charging performance | Best usage scenarios |
Official Steam Deck charger | 45W | High | Meets official charging requirements | Home and everyday use |
USB-C PD wall charger | 45W–65W+ | High | Depends on negotiated output | Home, hotels and travel |
USB-C power bank | 45W+ recommended | Very high | Depending on capacity and output | Commuting and short trips |
Portable power station | Varies by model and port | Moderate | Supports longer-term power needs | Camping, road trips and off-grid gaming |
Note: The figures are indicative charging-source ratings, not guaranteed Steam Deck charging speeds. Actual performance will vary by USB-C PD compatibility, cable quality, battery level and device usage. The Steam Deck's official technical specifications are provided by Valve. |
How to Choose Portable Power Based on Output, Capacity and Recharges
When selecting a portable power bank, it’s critical to assess more than just the claimed watt-hour capacity. Pay attention to factors such as USB-C specs, total energy capacity, charging time, and how many times you expect to charge your Steam Deck while you are away.
Key things to consider:
USB-C specs: Make sure to choose a USB-C PD port that can provide the required 45W charge to the Steam Deck. Mind that you need to pay attention to the port specs, not the stated combined wattage output of multiple ports.
Capacity: Look for the rated capacity of the power source in watt-hours (Wh). The Steam Deck’s LCD version has a 40Wh battery, while its OLED version has a battery with 50 Wh capacity. Generally, the bigger the power source, the more recharges it allows you to do.
Charging time: Consider how fast the battery bank or station can recharge from the grid or compatible solar panels.
Recharge count: Calculate your needs according to battery capability and the amount of energy that can be used. A 1,000Wh portable battery, for instance, does not mean that it allows full charging of the LCD device 25 times, since that would only imply dividing 1,000 by 40, and there are charging losses and energy consumption to consider.
Note: Valve states that the Steam Deck will use a 45W USB-C PD3.0 power supply, and confirms they will not be supporting proprietary Quick Charge specifications.
Don't use a single recharge estimate, as the LCD and OLED models have different capacities.
Small chargers and power banks are good in everyday life, but in case of long gaming sessions and expeditions, they might not be enough. This is where portable power generators are helpful, providing larger capacity, various charging options, and solar charging capabilities.
Let's see how EcoFlow power station is the best portable charger for the Steam Deck while camping, travelling, and relaxing off-grid.
3. Best EcoFlow Portable Power Stations for Steam Deck Gaming Outdoors
Take your gaming experience with the Steam Deck outside the house by using EcoFlow portable power stations, which ensure you have enough energy for longer gaming sessions away from sockets. Whether it is travelling, camping, or spending a weekend trip on the road, the correct portable power source allows you to keep all your gadgets charged.
Why Use a Portable Power Station for Extended Steam Deck Gaming?
A portable energy station provides much more charging capability than a regular power bank, which makes it a great option for outdoor Steam Deck gaming for long hours. Depending on the specific model and the number of ports available, you can easily recharge your device using a USB-C port or AC outlet while simultaneously keeping mobile phones and some other gadgets charged as well. Certain EcoFlow energy stations can also be charged by the sun, which ensures that you have one more option for a power source during long trips away from civilisation.
Selection of the right device depends on what needs you have regarding gaming, charging, and how long you are going to stay outdoors.
EcoFlow DELTA Pro 3: Compact Power for Gaming and Everyday Electronics
EcoFlow DELTA 3 Plus: Flexible Charging and Solar Power for Longer Trips
EcoFlow DELTA 3 Max Plus: Higher Capacity for Multiple Devices and Extended Gaming
Comparing EcoFlow Power Stations for Steam Deck Charging
EcoFlow has a range of portable power stations that can be used to ensure that your devices remain charged whether you are camping, driving long distances or enjoying some outdoor gaming. The best option will depend on the capacity you require, the level of portability that you want and whether you plan to charge other devices along with your gaming laptop.
EcoFlow model | Battery capacity | AC output | USB-C charging | Weight | Best for |
DELTA Pro 3 | 4,096Wh | 4,000W | Check the available port specifications. You can use the AC outlet with the Steam Deck charger | Approx. 51.5kg | Extended off-grid stays and powering several devices |
DELTA 3 Plus | 1,024Wh | 1,800W | 2 × 140W USB-C | Approx. 12.5kg | Portable gaming, everyday electronics and solar-powered trips |
DELTA 3 Max Plus | 2,048Wh | 3,000W | 1 × 140W and 2 × 45W USB-C | Approx. 22.1kg | Longer gaming sessions and charging multiple devices |
4. Steam Deck Charging Tips
To maximise the performance of the Steam Deck charger, one must do more than simply choose a suitable charger. Several small changes can make a huge difference in consuming power and receiving more time to play.
How to Extend Steam Deck Battery Life During Long Gaming Sessions
Do you want to have a longer gaming session without worrying about charging your device now and then? Use the following battery-efficient suggestions:
Lower the brightness of the screen: By reducing screen brightness, you will be able to save some unnecessary battery power.
Change performance settings: When high performance is not necessary, you can reduce frame rate, refresh rate, and graphics settings.
Only enable Wi-Fi when needed: Keep wireless connectivity turned off when you play offline games which are not dependent on a stable internet connection.
Stop all background downloads: Stop all updates and downloads of video games so they will consume less energy.
Choose less demanding games: Games which consume less energy require less processing power than high-end games.
Adjust battery-saving settings: Use performance settings provided by Steam Deck to achieve a better battery life.
Charging Your Steam Deck While Travelling, Camping and on Road Trips
It is necessary to have a power supply available when travelling while using Steam Deck as electrical facilities are confined. USB-C PD power bank is best for shorter travels, while a portable power station is good for longer trips.
Make sure that your power bank and Steam Deck are fully charged before you start your trip, and also take the 45W USB-C PD charger with you. When you reach your accommodation or campsite, consider the available charging facilities. For longer days spent in the wild, you may need EcoFlow portable power station with solar charging in case you need to supply power to any of your electronics.
Keeping Your Steam Deck Powered During a UK Power Cut
A blackout doesn't need to ruin your gaming experience. Having a charged portable power bank would give you some backup to run your Steam Deck, while a portable power station would give your console the necessary charge for longer periods.
If you want even more flexibility, opt for a power station with enough USB-C PD output or an AC outlet that will work with your Steam Deck charger. You can also charge some models from EcoFlow using compatible solar panels.
Understanding the proper way to charge your Steam Deck is essential as the gaming experience improves. There are several charging options available, from the official 45W USB-C PD charger to the high-performance power banks and portable power charging stations. The right source of power can keep you gaming longer.
People planning to play games while camping or during long beach trips should consider investing in an EcoFlow portable power supply. Both the DELTA 3 Plus, which offers a strong balance of portability and capacity, and the DELTA 3 Max Plus, which delivers extra power for longer trips and more devices, are available for gamers.
Does the Steam Deck Need a 45W Charger?
The power adapter provided with the Steam Deck is a 45W USB-C power adapter, and it supports USB-C Power Delivery (PD 3.0). You can use a charger with higher wattage, such as a 65W charger, because the Steam Deck needs only sufficient power to operate.
Does the Steam Deck Support USB-C Power Delivery?
Yes, the Steam Deck is capable of working with USB-C Power Delivery 3.0 and can charge with the help of USB-C PD adaptors, power banks, or electric generators. Make sure the output of the charger or USB-C port is ideal for effective charging.
Can I Charge My Steam Deck While Playing?
Yes, you can play games while your Steam Deck is charging. However, running resource-intensive games might draw on some incoming power, which could slow down the battery charging speed. To enhance your charging experience, consider lowering graphics settings or putting the device in sleep mode during charging.
How Many Times Can a Power Bank Charge a Steam Deck?
The number of times a power bank can recharge a Steam Deck varies based on factors like the capacity of the power bank and the model of the Steam Deck, along with energy loss during charging. The LCD version has a 40Wh battery, while the OLED version features a 50Wh battery. A good way to estimate how many charges you can get is by dividing the usable capacity of your power bank by that of your console’s battery capacity, considering any conversion and charging losses. Keep in mind that actual results may differ.
Is a Portable Power Station Better Than a Power Bank?
It depends on your use of the Steam Deck. For daily travels or shorter gaming sessions, one would prefer a power bank being more lightweight and easy to carry. On the other hand, a portable power station is a more powerful and versatile solution. It is suitable for more prolonged trips, camping, and the simultaneous charging of more devices.
