EcoFlow ImageAsk a Question
Shop Now
EcoFlow DELTA 3 Max Plus (2,048Wh)
Always Ready. More Power.
EcoFlow Image
Power Anything, Anywhere
Industry-leading 3000W AC output 6000W surge output
EcoFlow Image
Industry-First Full-Tab LFP Cells
Exclusive smart BMS with 24/7 protection
EcoFlow Image
Ready in Just 47 Mins [1]
5 charging methods
EcoFlow Image
Extend Power for Your Most Important Devices
Smart Output Priority Tech
EcoFlow Image
Uninterrupted Power
<10ms switchover — fastest-in-class UPS
EcoFlow Image
OASIS 3.0: Our Smartest Energy Management App Yet
EcoFlow Image
Power That Grows With You
2–10kWh scalable capacity
EcoFlow Image
Long-lasting Power for 10 Years [2]
5-year warranty
Free Exclusive Gift
Free Exclusive Gift
Solar Panel Bundle
Extra Battery Bundle
  • EcoFlow ImageEcoFlow Image
    DELTA 3 Max Plus (2048Wh) / 220W Lightweight Portable Solar Panel
    • 3,000W
      AC output
    • 1000W
      PV input
    • 2,048Wh
    £1,573£1,748
    Learn More
    DELTA 3 Max (2048Wh) / 220W Lightweight Portable Solar Panel
    • 2,400W
      AC output
    • 500W
      PV input
    • 2,048Wh
    £1,393£1,548
    Learn More
    DELTA 3 Max Plus (2048Wh) / No Accessory
    • 3,000W
      AC output
    • 1000W
      PV input
    • 2,048Wh
    £1,399
    Learn More
    DELTA 3 Max (2048Wh) / No Accessory
    • 2,400W
      AC output
    • 500W
      PV input
    • 2,048Wh
    £1,199
    Learn More
    DELTA 3 Max Plus (2048Wh) / 400W Lightweight Portable Solar Panel
    • 25%
      conversion rate
    • 3,000W
      AC output
    • IP68
    £1,753£1,948
    Learn More
    DELTA 3 Max (2048Wh) / 400W Lightweight Portable Solar Panel
    • 25%
      conversion rate
    • 2,400W
      AC output
    • IP68
    £1,748
    Learn More
    DELTA 3 Max Plus (2048Wh) / DELTA 3 Max Plus Smart Extra Battery
    • 4kWh
      Expandable Capacity
    • 3,000W
      AC output
    £1,978£2,198
    Learn More
EcoFlow Image
A New Era of Power Performance
25% More Power [3]: 3000W Output, 2kWh Capacity
Next-level energy for next-level peace of mind.
EcoFlow Image
EcoFlow Image
EcoFlow Image
EcoFlow Image
EcoFlow Image
EcoFlow Image
All Your Essentials. All at Once.
DELTA 3 Max Plus (2,048Wh) delivers a powerful 3000W output—enough to run your microwave, kettle, fridge, and blender all at once without a flicker. Lunchtime? Go full throttle. No unplugging, no interruptions—just seamless power. [4]
EcoFlow Image
Pick Your Priority Outputs, Extend What Matters Most
Smart Power Reserve | Set your desired battery threshold (%) to automatically shed non-essential loads during outages
With app-based presets, DELTA 3 Max Plus (2,048Wh) automatically follows your priority settings during outages—shutting off lights while keeping your fridge running. Wake up to fresh food and plenty of power left—just like nothing happened.
EcoFlow Image
Automotive-grade full-tab LFP cells
EcoFlow Image
Automotive-grade Full-Tab LFP Cells: Next-Level Battery Reliability
DELTA 3 Max Plus (2,048Wh) is equipped with automotive-grade full-tab LFP cells. The full-tab design reduces resistance, enhances efficiency and safety, and provides higher capacity with less heat, resulting in a longer battery lifespan.
25% more
efficient power flow (thanks to lower resistance: 1.5 mΩ vs. 2 mΩ) [5]
25% less
self-heating [6]
EcoFlow Image
Unrivaled Balance for Unmatched Battery Longevity
With 27% fewer cells per kWh, [7] our 16-cell design runs cooler, lasts longer, and delivers greater stability. Each cell is rigorously tested for capacity, voltage, and internal resistance—resulting in a highly uniform pack that protects against overcharging, imbalance, and premature wear.
16 cells/1kWh, uniformly matched
Rigorously tested for capacity, voltage, and internal resistance
Built to Last
From battery chemistry to structural design, DELTA 3 Max Plus (2,048Wh) is engineered for extreme durability, environmental resilience, and whisper-quiet performance—delivering power you can count on for over 10 years. [2]
EcoFlow Image
Smart, 24/7 Battery Protection
EcoFlow’s advanced BMS uses a high-performance ARM Cortex chipset and intelligent algorithms to monitor your battery in real time. By tracking SOC, SOH, temperature, and more, it ensures peak performance, extended battery life, and worry-free operation.
EcoFlow Image
EV-Grade CTC Structure
Built with a cell-to-chassis (CTC) structure, DELTA 3 Max Plus (2,048Wh) is drop-resistant (0.25m)—protecting against overnight condensation and off-road bumps during transport. You get stable power even in the most demanding conditions. [8]
EcoFlow Image
Extreme Environment resistance
DELTA 3 Max Plus (2,048Wh) keeps your power flowing through freezing cold, scorching heat, humid environment (95% humidity tolerance), or coastal air (5% salt spray resistance)—for reliable energy anytime, anywhere. [8]
EcoFlow Image
Class B Certification
Class B EMC Certification
Certified to Class B EMC standards, it won’t interfere with TVs, Wi-Fi, or other home electronics.
EcoFlow Image
25 dB Whisper-Quiet Operation under loads [9]
Powered by X-Quiet™ 3.0, EcoFlow’s stepless fan control adjusts airflow smoothly to maintain precise thermal regulation—keeping your home or workspace peacefully quiet, even under heavy loads.
EcoFlow Image
A New Level of Fast
Ultra-versatile 5 charging options, 47-minute fast charge [1]
Remote charging control for added peace of mind.
5 Ways to Charge Up — Ready in Just 47 Mins [1]
EcoFlow Image
EcoFlow Image
EcoFlow Image
EcoFlow Image
AC Charging
Alternator Charging
Generator Charging
Solar + Alternator Dual Charging
Monitor your energy usage, savings, and solar generation—all with one intuitive dashboard. Easily track battery status, solar forecasts, real-time electricity rates, and financial savings.
EcoFlow Image
Output
EcoFlow Image
Solar Generation
EcoFlow Image
Earnings [14]
Cut Costs, Not Comfort
Charge During Low-Cost Periods to Save Big DELTA 3 Max Plus (2,048Wh) intelligently optimizes energy usage to help lower your electricity bills while powering your home sustainably. Set automated tasks to charge during off-peak evening hours and discharge during the day.
EcoFlow Image
AI Mode
Charge During Off-Peak, Use During Peak AI Mode lets you set custom charging and discharging schedules based on your local electricity rates. Charge when energy is cheapest, and discharge during peak hours to cut costs without lifting a finger. [14]
Self-Powered
Reduce Grid Dependency, Lower Electricity Costs Self-Powered mode stores solar energy and powers your home once battery levels exceed a preset reserve. It minimizes grid use while maximizing solar efficiency—ideal for managing fluctuating energy prices and enhancing your energy independence.
EcoFlow Image
Easily Scales Up—From Hours to Days
2–10kWh expandable capacity
EcoFlow Image
EcoFlow ImageEcoFlow ImageEcoFlow ImageEcoFlow Image
Covers essential power needs during a 4–8 hour outage—keeping food fresh, heat running, lights on, and communication devices charged. [15]
Light (10W)
3
6
hrs
Phone (11W)
0
1
time
Wi-Fi Router (10W)
3
6
hrs
50" TV (110W)
0.3
0.5
hrs
Refrigerator (200W)
6
12
hrs
Microwave (1300W)
5
10
mins
Electric Blanket (50W)
3
6
hrs
Hair Dryer (1600W)
7
15
mins
  • Half-Day Power Usage
  • 1-Day Power Usage
  • 2-Day Power Usage
  • 3-Day Power Usage
Comparison
1. 0-80% in 47 minutes was measured in optimal conditions using X-Stream AC charging.
2. Based on proper product usage, DELTA 3 Max Plus (2,048Wh) is estimated to have a lifespan of approximately 10 years, according to internal simulation test data. This information is for reference only; actual user experience may vary.
3. Compared with EcoFlow DELTA 2 Max.
4. The conclusion that multiple appliances can be powered simultaneously is based on internal testing. Actual performance may vary in real-world use.
5. Refers to the internal resistance of EF Full-Tab LFP Cells being 1.5mΩ, which is 25% lower than the 2mΩ internal resistance of the previous EF #C33 Battery Cell.
6. A 25% reduction in single-cell internal resistance. According to the heat generation formula Q = I²Rt, under the same current, a 25% reduction in resistance leads to a proportional 25% decrease in heat generation.
7. Compared with the previous usage of EF #C33 Battery Cell.
8. Unless otherwise noted, all above data comes from EcoFlow labs and is for reference only. The actual data may vary slightly depending on the usage environment, device condition, software version, and other factors.
9. Noise levels measured at 0.5m under 25°C ambient: ≤25dB (600W) for charging/discharging.
10. All charging speed data comes from EcoFlow labs and is for reference only. The actual data may vary slightly depending on the usage environment, device condition, software version, and other factors.
11. Feature requires preset activation via the EcoFlow App.
12. EcoFlow Alternator Charger Plus 1000 will be launched soon and is sold separately.
13. Compared with car cigarette port charging.
14. Certain features in the EcoFlow app will be available soon. Please refer to the EcoFlow app for details on feature availability.
15. Multiple appliances' backup time based on ideal conditions; actual results may vary.
16. Require connecting 1 × DELTA 3 Max Plus (2,048Wh) + 2 × DELTA 3 Max Plus (2,048Wh) Smart Extra Battery with EcoFlow Smart Extra Battery Expansion Adapter. The EcoFlow Extra Battery Expansion Adapter will be released soon.
17. Require connecting 1 × DELTA 3 Max Plus (2,048Wh) + 2 × DELTA Pro 3 Smart Extra Battery with EcoFlow Smart Extra Battery Expansion Adapter. The EcoFlow Extra Battery Expansion Adapter will be released soon.
