How to Keep Warm in Winter Without Letting the Heating Run Up Your Bill
You turn the heating on, settle down for the evening and still find yourself reaching for another jumper. Meanwhile, the energy meter keeps moving. For many UK households, how to keep warm in winter comes down to more than the thermostat setting. Heat escapes through poorly sealed windows, uninsulated roofs and cold conservatories, while heating an empty room wastes energy. The sensible approach is to deal with these problems in the right order. Start with clothing and simple household changes, then look at insulation, heating controls and electricity tariffs. Home energy storage is another option for households trying to make better use of cheaper electricity, although its value depends on how much energy they use and when they need it.
How to Keep Warm in Winter with Simple Layers and Habits
The easiest changes are often the ones that cost little or nothing. Before buying another heater, consider what you wear, where you spend your time and how you use the rooms in your home.
Layering Clothes to Trap Body Heat
A warm base layer, jumper and cardigan give you more flexibility than one heavy garment. You can remove a layer when moving around and put it back on when sitting still. Thick socks and slippers are useful too, especially in older homes with exposed floorboards or tiled floors.
If you work from home, keep a blanket or extra jumper near your desk. It is a small adjustment, but it can stop you turning up the heating simply because you have been sitting in one place for two hours. For anyone considering how to keep warm in winter in the house, clothing is a sensible starting point because it does not increase household energy consumption.
Warm Food, Hot Drinks and Staying Active
Soup, porridge and a hot drink can make a cold afternoon more comfortable. Regular meals also matter during winter, particularly for older people who might be less aware of how much their body temperature is dropping.
Try not to spend the whole day sitting still. A short walk around the house, a few gentle stretches or getting up between tasks can help you feel warmer. This does not mean exercising hard in a cold room; the idea is to break up long periods of inactivity.
People with medical conditions or limited mobility should follow advice suited to their needs. The NHS winter health guidance includes advice on staying warm, eating regularly and keeping active.
Using the Rooms You Need and Closing Doors
If the spare bedroom is empty all day, it probably does not need to be as warm as the living room. Use programmable heating controls or thermostatic radiator valves to match temperatures to how each space is used. Avoid letting rarely used rooms become persistently cold and damp, however.
Closing internal doors can also stop warm air drifting into colder parts of the house. A person working in a home office, for example, might be more comfortable heating that room appropriately rather than trying to keep every room at the same temperature. This is a practical answer to how to keep room warm in winter without heating more space than necessary.
How to Keep Your House Warm in Winter by Stopping Heat Loss
A heating system has to work harder when warm air escapes through gaps or heat passes quickly through poorly insulated surfaces. Before spending money on a more powerful heater, look at the building itself.
Draught-Proofing Doors, Windows and Letterboxes
On a windy day, check around external doors and window frames for moving air. Letterboxes, gaps around pipework and poorly fitted floorboards can be culprits too. Depending on the gap, a door brush, draught excluder or suitable sealing strip may be all that is needed.
Older timber windows deserve particular attention because seals can deteriorate over time. For fireplaces that are no longer used, a chimney draught excluder that can be easily removed can reduce heat loss, but needs to be appropriate to the fireplace and not block a flue that is still in use.
These jobs are a useful first step when working out how to keep house warm in winter on a limited budget. But do not seal every opening. Kitchens and bathrooms need ventilation, and appliances with open flues require the airflow specified for safe operation. The Energy Saving Trust provides guidance on reducing draughts without creating ventilation problems.
Curtains, Rugs and Thermal Blinds
Windows can feel noticeably colder after sunset, particularly when the glazing is old. Thermal-lined curtains or blinds help reduce heat transfer, while opening them during sunny daylight hours allows useful sunlight to enter. Close them as the room begins to cool in the evening.
Check where your curtains fall. If they cover a radiator, much of the heat can become trapped behind the fabric instead of circulating around the room. Moving furniture away from radiators helps for the same reason.
A rug over bare floorboards will not insulate a whole house, but it can make a room more comfortable underfoot. Reflective radiator panels are another option for radiators attached to uninsulated external walls. They are less useful on internal walls, so fitting them behind every radiator is unnecessary.
Loft and Wall Insulation for Lasting Warmth
While these small changes help, insulation is an even more substantial heat loss reduction. Loft insulation slows heat escaping through the roof. Wall insulation reduces heat transfer through external walls, although the appropriate method depends on the property’s construction. A modern house with cavity walls is NOT a Victorian terrace with solid brick walls. Care will be needed for older buildings as it can be determined that inappropriate insulation can lead to moisture movement and hence damp.
If you are deciding how to keep your house warm in winter for the longer term, check the existing insulation before investing in extra heating equipment. Look for gaps, uneven coverage or insulation that needs upgrading. Where major work is required, get advice suited to the building rather than assuming one solution fits every property.
Note: Financial help may be available to eligible households through government-backed schemes or local programmes. Please refer to the energy grants calculator on GOV.UK to check the current rules as eligibility and support available are different.
Keeping Heat in a Whole Home
Knowing how to keep home warm in winter includes fixing the room that stays cold even though the heating is running. A radiator that is hot at the top but cold at the bottom might have a circulation problem or sludge build-up, while cold patches higher up can indicate trapped air. Draining a radiator might help remove air but if this is a problem you need a heating engineer's attention.
Make sure radiators are not hidden behind large sofas or heavy curtains. Thermostatic radiator valves are used to help control the temperature in individual rooms and a programmable thermostat keeps the heating program in sync with the home's schedule.
These measures work alongside insulation rather than replacing it. If the home still takes a long time to warm up, ask a qualified professional to check the heating system and whether it is suitable for the property’s heat demand. That is often more useful than adding another portable heater.
How to Keep a Conservatory Warm in Winter
A conservatory is often the coldest room in a house for a straightforward reason: much of its structure is glazed, and its roof may be far less insulated than the roof over the rest of the home.
Why Conservatories Lose Heat So Quickly
Glass and polycarbonate roofing generally lose heat more readily than well-insulated walls. Older conservatories can also have worn seals, lightweight frames and gaps around external doors. During the day, sunlight might make the room pleasant; after sunset, the temperature can fall quickly.
This is why how to keep conservatory warm in winter requires a slightly different approach from heating a conventional living room. If heat escapes through the roof and glazing, a bigger heater simply has to replace that lost warmth more frequently.
Simple Ways to Warm a Conservatory
Do the work that can be done without room reconstruction first. Look for gaps around all doors and windows, install appropriate window treatments or curtains, and shut the main door between the house and conservatory when it is cooler outside than the house.
If you use the space every day, upgrading the roof or glazing might be worth investigating. If it is primarily for occasional meals or afternoon sitting, then just a limited heating time and duration might be more convenient. The decision should be made considering the frequency of use of the room and the cost of maintaining a warm environment.
For those researching how to keep a conservatory warm in the winter, the priority is to reduce heat loss before choosing heating equipment. Anyone considering how to keep a conservatory warm in winter should also check that the chosen heater is suitable for the space and used according to its safety instructions. Never use an unvented fuel-burning heater indoors, as it can release harmful combustion products and add moisture to the air.
Cut Heating Costs Without Losing Comfort
Once obvious heat loss is fixed, how to keep the house warm in winter comes down to heating controls and electricity prices. A well-insulated home can still waste energy if the heating runs at the wrong times or is set higher than necessary.
Smart Thermostat and Radiator Valve Settings
A programmable thermostat lets you match heating times to your daily routine. Set the system to warm the home when people need it rather than leaving it running at full settings throughout an empty working day. There is more control given to individual radiator valves for rooms that are not used as often.
On compatible condensing boilers, lowering the central-heating flow temperature can improve efficiency. But don't do it too low or rooms may not reach a comfortable temperature, especially during cold weather. Take boiler manufacturers' guidance or seek the advice of a qualified heating engineer.
Homes with hot-water cylinders need separate care. Stored hot water must be managed at an appropriate temperature to reduce Legionella risk. Avoid turning the hot-water heater down to save money, unless you know what its needs are.
Choosing Efficient Heating
The most suitable heating system depends on the property, available energy sources and how the household uses each room.
  • Heat pumps: These transfer heat rather than generating it directly from electricity. Performance depends on system design, the building’s heat loss and suitable heat emitters.
  • Modern boilers: A maintained condensing boiler with effective controls remains a common option in homes connected to the gas network.
  • Electric heaters: Panel and portable heaters can be useful for short periods in one room. Direct electric heating generally costs more per unit of useful heat than a well-performing heat pump.
Purchase price alone tells only part of the story. Installation, maintenance, energy tariffs and the home’s heat demand all affect running costs. If the whole property is cold, assess insulation and the main heating system before buying several additional heaters.
Off-Peak Tariffs and Time-of-Use Electricity
Some electricity tariffs charge less during designated off-peak periods, often overnight. This may work for homes that can shift some of their activities to lower-cost times, like laundry or electric-vehicle charging.
Heating is more difficult to shift because people generally want warm rooms in the morning and evening. An overnight rate is useful only if you can make practical use of it, either by changing when electricity is consumed or by storing energy for later.
Compare the complete tariff, not just its cheapest rate. Check the daytime unit price, standing charge and precise off-peak window against your usual consumption. Although a good value on the calculator may not save you money on your electricity bill if you use it mostly during the higher cost hours.
How Can You Heat Your Home at Cheaper Rates When You Need It Most?
Home energy storage can help separate the time electricity is purchased from the time it is used. Whether this is financially worthwhile depends on the price difference between charging and discharging periods, battery efficiency, installation costs and the household’s consumption.
Store Cheaper Electricity for the Coldest Evenings
The EcoFlow STREAM 5000 is designed for households without solar panels that are considering battery storage. It can store electricity for later use, potentially helping a household take advantage of an appropriate off-peak tariff instead of buying all its electricity during more expensive periods. Its 5kWh capacity provides a basis for planning, not a guarantee of overnight heating. A home using a heat pump, electric radiators and a kettle will have a different demand profile from one using gas central heating and electricity mainly for lighting and appliances. The amount of usable energy and the timing of charging matter just as much as the headline capacity. For households exploring how to keep warm in winter while managing peak electricity costs, the sensible first step is to examine actual usage and tariff rates. A battery won't prevent heat from flowing through windows and walls and won't necessarily reduce everyone's energy bill in the home.
EcoFlow STREAM 5000
Installed home battery for homes without solar. UK rules require installation, and the setup is designed to be simple 5024Wh capacity, expandable to 90kWh with Expansion Batteries Up to 3000W AC output for high-demand appliances like stoves, dryers or kettles (when solar is generating or an Expansion Battery is paired) 5,000W solar input makes full use of your solar generation Up to 2500W AC charging for fast recharge Smart meter, main unit and solar panels are designed to connect easily, with step-by-step app guidance for setup Compact 45.9kg body with a built-in handle for easier placement during installation Residential-grade protection with pressure-release and fire-resistant materials, designed to reduce thermal runaway risk with high-voltage solar panels Rated for 10,000 cycles Local Mode keeps the system running and communicating even if the network drops
Make More of Your Solar Panels in Winter
The EcoFlow STREAM AC 5000 is intended for households with existing rooftop solar panels that want to add battery storage. It stores suitable surplus solar electricity for use later, including during the evening when solar generation has fallen. Winter brings shorter days and generally lower solar output, so a battery cannot make up for electricity the panels never generate. Its purpose is to shift available energy to a more useful time. Compatibility with the existing solar installation, electrical requirements and the amount of surplus generation should all be checked before purchase. If you are comparing options for how to keep warm in winter while making better use of solar power, review your household’s winter generation and consumption rather than relying on summer figures. Savings depend on how much electricity is stored and used, system costs and the value of electricity that would otherwise be exported.
Installed home battery for homes with existing solar. UK rules require installation, and the setup is designed to be simple Works with existing rooftop PV systems, home battery systems and leading third-party meters 5024Wh capacity, expandable to 90kWh with Expansion Batteries Up to 3000W AC output for heavy household appliances (when solar is generating or an Expansion Battery is paired) AC coupling adds storage alongside your current solar setup, and a Gateway simplifies expanding later Compact 45.1kg body designed to fit into spaces around the home Rated for 10,000 cycles
Note: Rules for plug-in solar in Great Britain are new and still developing. EcoFlow STREAM 5000 and STREAM AC 5000 are home battery storage systems that need professional installation. They are not sold as plug-in solar products, and a battery does not qualify as a compliant plug-in solar microgenerator just because its setup is straightforward. Check current GOV.UK guidance and speak to a qualified installer about the requirements for your home.
The most effective way to make a home more comfortable is to tackle the causes of heat loss before spending more on heating. Draught-proofing, appropriate insulation, well-used curtains and sensible heating controls all have a part to play. Conservatories need particular attention because their glazed construction can make them difficult to keep warm. Tariffs and storage can help some households manage electricity costs, but the numbers need to make sense for the home.
EcoFlow offers home energy storage options for households looking to manage electricity use around their existing setup. Visit the EcoFlow UK to compare the STREAM range and check the specifications before deciding whether battery storage suits your home.
How to Keep Warm in Winter FAQs
How can you keep warm in winter if you cannot afford to heat your home?
Start with layers of clothing, draught excluders and heating only the rooms you use, while keeping the home adequately ventilated. Check whether you qualify for the Warm Home Discount, local council assistance or other energy support.
How do you keep warm in winter if you are elderly or vulnerable?
The NHS advises aiming to keep rooms used regularly at at least 18°C, particularly for older people and those with health conditions. Warm layers, regular meals and a comfortable bedroom also help. Anyone who remains unusually cold or feels unwell should seek appropriate medical advice.
How can you keep warm in bed on winter nights?
Choose comfortable nightwear and bedding suited to the room temperature. A suitable hot-water bottle or electric blanket can provide extra warmth, but never use both together. Follow the manufacturer’s instructions, check electric blankets for damage and keep bedding away from heaters. Take additional care when choosing products for babies, older adults or anyone with reduced sensation.
Home Solutions
