How to Calculate Watts: Simple Formulas for Appliances, Solar and Batteries
- How to Calculate Watts From Volts and Amps
- How to Calculate Amps From Watts and Volts
- How to Calculate Watt Hours and Estimate Running Costs
- How Do Watt Calculations Help You Plan Solar, Inverter and Battery Capacity?
- Turning Your Watt Calculations Into a Home Energy Plan That Fits
- Conclusion
- FAQ About How to Calculate Watts
Pick up any kettle, check the sticker underneath, and you’ll find a handful of numbers — watts, volts, amps — that nobody ever explained. Your energy bill adds a fourth, kilowatt-hours, and suddenly it feels like homework. It isn’t. How to calculate watts takes one multiplication, and amps, watt-hours and running costs all fall out of it. That’s why people keep searching how to calculate amps from watts: they want the sum, not a physics lecture. Get your numbers right and you price up an appliance, spot an overloaded lead and size solar panels, an inverter or home energy storage without guessing. We’ll go through the core formula, the watts-to-amps switch, watt-hours and costs, then the planning side.
How to calculate watts is a single sum: volts × amps. Watts tell you how fast something swallows energy; volts are the electrical push; amps is the measure of the flow of energy. For anything with a three-pin plug, the supply to the UK is nominally 230V.
How to Calculate Volts Amps and Watts With One Formula
Write it as watts (W) = volts (V) × amps (A). Flip it round and you get the other two: amps = watts ÷ volts, volts = watts ÷ amps. If all you want is how to calculate for watts, the first version does the job. And a rule for how to calculate watts amps volts together? Know two, get the third. A 10A draw at 230V is 230 × 10 = 2,300W. Done.
How to Calculate Watt Values for Everyday Household Appliances
Grab the amp figure off the label and multiply by 230. A fan heater pulling 8.7A comes out at 230 × 8.7 = 2,001W, so call it 2kW. A dishwasher rated at 7.8A: 230 × 7.8 = 1,794W, near enough 1,800W. A kettle at 13A: 230 × 13 = 2,990W — the 3kW you see on the box. These are just sample ratings and not the final word. Labels are affixed to your own appliances.
Finding Watts, Volts and Amps on an Appliance Label
Flip the appliance over. The rating plate lives on the back, the base or inside the door, and it shows W or kW, V and A. The plug and the manual repeat it. Plenty of labels list only two of the three — usually watts and volts — so run the formula for the missing one. Only amps listed? Multiply by 230. Label reads 1,800W and 230V? Divide, and you get 7.8A. And if the sticker has worn off completely, a plug-in energy monitor reads watts straight off the socket.
Amps are simply the current an appliance pulls, and the sum is the watt formula run backwards: amps = watts ÷ volts.
How to Calculate Amperage From Watts and Voltage
Take a 2,000W heater on 230V. 2,000 ÷ 230 = 8.7A. One step — that’s how to calculate amperage from watts and voltage. It’s also how to calculate ampere from watt and voltage; ampere is just the full name for the unit, so nothing changes.
How to Calculate Watts Into Amps for Common UK Appliances
Back to the appliances. Kettle: 3,000 ÷ 230 = 13A. Dishwasher: 1,800 ÷ 230 = 7.8A. Heater: 2,000 ÷ 230 = 8.7A. That’s how to calculate amps from watts for three machines you probably own. Call it how to calculate amps from voltage and watts, or how to calculate amps with watts and volts — same working either way. Watts on top, volts underneath.
Why Amps Matter for Plugs, Circuits and Extension Leads
Amps decide whether a plug, fuse, extension lead or circuit is overloaded. UK plugs carry either a 3A fuse, for appliances up to 700W, or a 13A fuse for anything above — which is why the kettle, heater and dishwasher all get 13A. Extension leads top out at 13A as well, roughly 3,000W for everything plugged into them; that limit comes from the BS 1363 standard behind UK plugs and sockets. Kettle (13A) plus heater (8.7A) on one lead? That’s 21.7A through a lead built for 13A, and it’s a fire risk, plain and simple. Ten seconds of how to calculate watts and amps saves you finding that out the hard way. Tripping circuits or warm sockets are a different matter. Call a qualified electrician, because how to calculate amperage from watts won’t fix wiring.
Watts describe effort; watt-hours describe the energy used up. Your supplier bills for the second.
How to Calculate Watt Hours From Watts and Time
Multiply watts by hours. A 2,000W heater running for 3 hours: 2,000 × 3 = 6,000Wh. A 100W telly on for 4 hours: 400Wh. Short bursts? Turn minutes into hours — 15 minutes is 0.25.
Converting Watt Hours Into Kilowatt-Hours
Divide by 1,000. The heater’s 6,000Wh is 6kWh, and that’s the unit printed on your statement. One kilowatt-hour is simply a 1,000W appliance running for an hour.
Estimating Running Costs From Your Unit Rate
Multiply kilowatt-hours by your unit rate. To make things easy, use 26p per kWh as an approximation — Ofgem has predicted the price cap for October-December 2026 is 26.32p per kWh for electricity, but the actual rate is determined by your tariff, so use the rate from your latest bill. The standing charge (54.83p a day under the same cap) is billed separately on top. Six kilowatt-hours at 26p is 156p, so £1.56 for a three-hour heater session. Do that every day for a month and you’re at £46.80.
Adding Up a Whole-Day Household Load
List each major appliance with its rated watts and daily hours, multiply, convert. Once you know how to calculate watts for each item, the list takes minutes.
Kettle: 3,000W × 0.25h = 0.75kWh
Dishwasher: 1,800W × 1.5h = 2.7kWh
Washing machine: 2,000W × 1h = 2.0kWh
Oven: 2,400W × 1h = 2.4kWh
Television: 100W × 4h = 0.4kWh
Lighting: 60W × 5h = 0.3kWh
Total: 8.55kWh a day — about £2.22 at 26p. That’s your household load.
Note: These are the Ofgem price cap unit rate and standing charge figures (for October - December 2026) and are for illustrative purposes only. The actual number will depend on the tariff you have, and the price cap is revised each quarter, so please check your recent bills before working out running costs.. |
Watt calculations turn “some solar and a battery” into three real numbers: daily kilowatt-hours, peak watts and overnight kilowatt-hours.
Matching Solar Panel Watts to Your Daily Energy Use
Panel watts × hours of strong sun = watt-hours generated. A 400W panel with four good hours makes 0.4kW × 4 = 1.6kWh. Scale up to a 4kW array — ten 400W panels — and installer figures put annual output near 3,400kWh in average UK conditions, about 9.3kWh a day. June beats that; December falls well short. Compare with the 8.55kWh of load above. When it comes to the numbers, the two are almost equal. In fact they do not, as the panels are at their peak when the sun is at its peak and the household is at their peak when it is tea time.
Sizing Inverter Output Around Peak Demand
Peak demand is whatever runs at the same moment. Kettle (3,000W), oven (2,400W) and washing machine (2,000W) together pull 7,400W. Inverter output appears in watts or kilowatts on the spec sheet, so you compare it straight against that figure. If you don't get it, the grid will fill in the space. Calculate your own worst case overlap; not the average daily overlap.
Choosing Battery Capacity From Overnight Demand
Count what you use once the sun’s gone. Add the oven (2.4kWh), kettle (0.5kWh), telly (0.4kWh) and lights (0.3kWh) and you might have 3.6kWh at an evening's end. Pick a battery that's above that, and leave some head room – an electric car or heat pump adds up the sum quickly.
Do the math, and you will see that four problems keep cropping up: no clue how much battery capacity is sufficient, peak energy needs due to high-consuming appliances, excess solar energy that is wasted, and little room. EcoFlow Battery solutions can solve two of them.
Matching Storage to Your Daily Load When Starting Without Solar Panels
Once you know how to calculate watts for your daily load, EcoFlow STREAM 5000 is the one we recommend for homes with no solar panels. Its 5kWh capacity supports all-night home use, and expansion goes up to 90kWh if your load grows. Up to 3,000W of AC output handles the stove, dryer or kettle behind your peak demand. It manages itself automatically, and the compact body has a built-in handle, handy for a tight garage or attic.
Adding Battery Storage to Existing Solar Once You Know Your Numbers
Comparing generation with usage starts with knowing how to calculate watts on both sides of the meter. EcoFlow STREAM AC 5000 is for homeowners who already have rooftop solar and want storage added later. The unit works with pre-installed rooftop solar systems as well as mainstream third-party meters. Adding the gateway and upgrading up to 90kWh does not require any rewiring at all.
Watts equal volts times amps. Divide watts by volts and you’ve got amps; multiply watts by hours for watt-hours, then divide by 1,000 for the kilowatt-hours on your bill. Those figures show what each appliance costs and what your home uses in a day — and the same numbers size solar panels, inverter output and battery capacity. Once you know how to calculate watts, home energy storage is a step you plan, subject to a professional assessment.
EcoFlow builds home energy storage around exactly this kind of planning, from the STREAM 5000 for homes without solar to the STREAM AC 5000 for existing systems. Work out your numbers, then explore EcoFlow UK and explore the to find the battery that fits your daily load.
What is the difference between watts and volt-amperes (VA)?
Watts are the real power an appliance uses. Volt-amperes (VA) are apparent power — volts × amps with no allowance for power factor. For a kettle or heater the two match. For anything with a motor or electronics, VA comes out higher than watts. Check both ratings when sizing an inverter or UPS; a watts-only figure hides the VA limit.
Can I measure watts with an energy monitor instead of calculating them?
Yes. A plug-in energy monitor shows live watts for whatever’s plugged through it — handy when the label’s gone. A smart meter’s in-home display shows whole-house demand. Use the readings to check your sums and to catch an appliance drawing more than you assumed.
Why does the wattage on a label differ from what an appliance actually uses?
Labels show rated, or maximum, power. In real use, settings, load and thermostat cycling change the draw, and standby adds a small constant trickle.
